[ROM][G800F/M/Y][7.1.2]RESURRECTION REMIX N 5.8.5 Final[UNOFFICIAL][Beta][18.01.2018]
  • 268 Antworten
Nufan
Nufan
Ikone
14.784
Die Resurrection Remix N Rom basiert auf den CM / LOS, Slim, Omni & Original Remix Rom Builds.
Dies schafft eine wunderbare Kombination aus Leistung, Anpassungsmöglicheiten und den neuesten Features.
Wie immer: Flash auf eigene Gefahr! Garantieverlust! Keine Haftung für erzeugte Briefbeschwerer, Datennirwana etc., weder durch Zocker1304, jimmy999x, xda, Android Hilfe oder durch mich!
Disclaimer:
You flash this image at your own responsibility. I am not responsible for any damage that might be caused by flashing this image (bricked device, lost data, ...)
Flashing this kernel image will trigger the KNOX counter, so your warranty will be void.
Applications that use KNOX (e.g. "Private Mode") might not work anymore when returning to the stock ROM, as the device is regarded as compromised. Do not flash this ROM if you need those applications.
The image is only for Exynos3470 based S5 Mini variants SM-G800F/M/Y.
It might be instable, crash your device, drain your battery, or even might damage your smartphone (e.g. if an USB-OTG device drains too much power)
Some users reported that their touch-screen stopped working permanently after some weeks of usage. For some user's (two at the moment including me) NFC stopped working permanently. Probably this issues are not related to this ROM as also many stock user's complain about hardware issues (random reboots, black screens, unresponsive touchscreen) but you have been warned.
Backup your data before flashing and check if the original firmware is present (e.g. at SamMobile)
Features:
Resurrection Remix
Included Main Features
RR Customizations:-
-Enable/Disable Navbar
-Navbar Button Customization smartbar
-Navbar Pulse
-Navbar Fling
-Double Tap To sleep navbar
-Statusbar
-Brightness Slider
-Enable/Disable Show Notification Count
-SuperUser Indicator Switch
-Double Tap To sleep Statusbar
-Carrier Label
-Carrier Label Switch
-Carrier label Color
-Carrier Label Size
-Clock Customizations
-Time & date
-Day & date Toogle
-Center/Right/Left Clock Choice
-Date Format
-Clock Font Styles
-Battery
-Battery Bar customization
-Battery Icon Customization(circle/landscape/Potrait and more)
-Battery % Text
-Network Traffic Indicator
-Network Traffic Arrows Switch
-Incoming/OutGoing Traffic
-Network traffic Color
-Statusbar RR Logo
-RR logo Color
-Position
-Custom Logos
-logo Color
-Position
-Style
-StatusBar Weather
-Weather Color
-Weather Position(left/right)
-Weather Font Style
-Weather Size
-StatusBar Ticker
-Ticker Text color
-Ticker Icon Color
-Animations
-Toast Animations
-ListView Animations
-System Animations
-Power Menu Animations
-Misc Animations
-Gestures
-Gestures Anywhere Feature
-3 Finger Swipe Screenshot Gesture
-App Circle Bar
-Choose apps in AppSidebar
-Trigger Width
-Trigger Hieght
-Trigger Position
-App Sidebar
-Choose apps in App circle
-Trigger Width
-Trigger Hieght
-Trigger Position
-Pie
-Pie Trigger(left ,Right ,Bottom)
-Pie Targets
-Pie Colors
-More Pie Features
-Recents Panel
-Clear All button Switch
-Clear All Tasks Switch
-Clear All Button Location(Top right,Top Left,Top Center,Bottom Left,Bottom Right,Bottom Center)
-Full Screen Recents
-Recents Styles
-OmniSwitch
-Cclock Widget
-CLock And Alarm Customizations
-Weather Panel Customizations
-Calender Events
-LockScreen
-Lockscreen Bottom Shortcuts
-Lockscreen General Shorcuts
-100+ Icons for Shortcuts
-Double Tap to Sleep Lockscreen
-Lockscreen Media Art/Enable Disable
-Quick PIN/Patter Unlock
-LockScreen Wallpaper
-Lockscreen Weather Widget
-Lockscreen Icons Color
-Quick Settings Draggable Tiles
-Customizable Tiles
-Dyanamic Tiles Adjustment
-Number of columns/rows
-Tile Animations
-Notification Drawer
-LongPress Toogles to Enter Settings
-Disable Immersive Mode Messages
-Force Expand Notification
-Quick PullDown
-Smart Pulldown
-Notification Panel Transperency
-Volume Dialog Transperency
-Notification Panel Stroke
-Volume Dialog Stroke
-Buttons
-Backlight Timer
-Backlight Strength
-Advanced Reboot Menu
-Power Menu Customizations
-Power Off
-Reboot(Recovery, Bootloader, Hot Reboot)
-ScreenShot
-Power Menu End Calls Switch
-Restart SystemUI
-Airplane Mode
-ScreenRecord
-On the Go Mode
-Sound Panel
-Home Button(For devices with HW keys Only)
-Home Button answer call
-Long Press Actions
-Double Tap Actions
-Menu Button(For devices with HW keys Only)
-Short Press Actions
-Long Press Actions
-Search Button(If Device Supports)
-Short Press Action
-Long Press Action
-Volume Buttons
-Wake Up Device
-Playback Control
-Ringtone Volume Control
-Keyboard Cursor Control
-Swap Buttons on Landscape mode
-Volume Key Answer
-Miscellaneous
-cLock Shortcut
-Disable Battery Saver Warning Color
-Cammera Shutter Sound Enable/Disable
-SystemUI Tuner
-Enabled By default
-Removed Demo mode and Tweaked SystemUI Tuner As compared To AOSP
-StatusBar Icons Cuzomizations
-Quick Settings Customizations
-Other Features
-Perfomance Profiles
-LCD Density
-Expanded Desktop Mode
-Heads Up Switch and customizations
-Live Display
-Configurable 0,90,180,270 Degree Rotation
-Lock Screen Autorotate Switch
-Native Tap to Wake From Marshmallow
-Double Tap Power Button To enable Camera gesture
-Wake Phone on Charging Plug
-Battery Light Customizations
-Notification Light Customizations
-Font Size
-CM privacy guard
-Performance Tweaks(Kernel Aduitor Inbuilt)
-CM root inbuilt
-A Whole new RR Configurations
-OverAll Smoothness Improvements
-Optimizations to Improve Battery
-Includes All Android Nougat Features
-Includes ALL CM14.1 Features
-AND MUCH MUCH MORE
Installation:
Erst-Installation:
- RR Rom & GApps Download auf SD-Karte
- ins TWRP Recovery booten
- Backup anlegen und einen Full Wipe / Clean Flash ausführen
- Rom flashen
- GApps flashen
-(Kernel flashen)
-(addonsu/SuperSu/Magisk flashen für Root)
- Wipe Cache
- Wipe Dalvik Cache
- Neustart
- Fertig!
Update-Anleitung:
- TWRP Recovery booten
- Backup anlegen und einen Dirty Wipe / Dirty Flash ausführen
- Rom flashen
- GApps flashen
-(Kernel flashen)
- Wipe Cache
- Wipe Dalvik Cache
- Neustart
Downloads:
XDA:DevDB Information
[ROM][G800F/M/Y][7.1.1]RESURRECTION REMIX N 5.8.2][unofficial][kminilte[22.02.17], ROM for the Samsung Galaxy S5 Mini
Contributors
Zocker1304, spookcity138
ROM OS Version: 7.x Nougat
ROM Kernel: Linux 3.4.x
Version Information
Status:
Beta
Created 2017-02-24
Last Updated 2017-02-25
Originalthread XDA
[ROM][G800F/M/Y][7.1.2]RESURRECTION REMIX N 5.8.3][unofficial][kminilte][30.04.17]
Reaktionen: Bo0312, Sunny, Fuhrmann und eine weitere Person
Das Warten hat sich gelohnt, großer Dank anZocker1304, spookcity138 [emoji2]
ROM läuft bei mir bis dato absolut sauber und unauffällig.
Hervorzuheben: Root inbuild, abschaltbare Knopfbeleuchtung[emoji106] , AdAway, OMS (Substratum), unendliche Einstellmöglichkeiten..
Bugs bitte hier oder im Originalthread [emoji14] melden, danke!
Ich halte hier bis auf weiteres aktuell.
Gruß und viel Spaß
----edit:
Bitte keine Lineage-su-Erweiterung bzw. supersu flashen, ROM kommt ungerooted (Builds are coming rootless) mit OS eigenem buildinternem root (root inbuild), addonsu ist also bereits enthalten.
Root aktivieren:
-Einstellungen - über das Telefon - Buildnummer 10(?) mal schnell tippen (Entwickleroptionen freischalten)
-Einstellungen - Entwickleroptionen - root aktivieren (für APPS und/oder ADB)/deaktivieren
App-rootrechte verwalten: -Einstellungen - Datenschutz - Datenschutz - erweitert - root (ganz rechts) oder unter -Entwickleroptionen - Root-Zugriffe verwalten (Anzeigen und Kontrollieren der Root-Regeln)
Achtung: Seit magisk ist root nicht zwingend in RR enthalten.
Download: Magisk, MagiskManager ,uninstall.zip, (je aktuelle Version)
(Magisk nach ROM, Gapps, Kernel installieren, sollte Magisk Manager nicht richtig installiert worden sein, die APK installieren, das kann vorkommen;)).
Legt euch auch die uninstallzip mit auf die SD-Karte !
Probleme Version 5.8.2:
--> temp. kurzzeitige Unterbrechungen WLAN-Verbindungen
--> Kamera funktioniert nicht (versch. Fehlermeldungen), empfehle folgende Vorgehensweise:
-Stockkamera einfrieren mit TitaniumBackup
-reboot
-Stockkamera deinstallieren mit TitaniumBackup
-reboot
-OpenCamera (oder Kamera der Wahl) installieren
-reboot
Deinstallation kann gut gehen, muß aber nicht;)
-->livedisplay funktioniert nicht im Automatikmodus, alternativ kann zB.CF.lumen oder f.lux verwendet bzw.manuell aktiviert werden,
-->Galerieapp hängt sich auf wenn sie über Kameraapp oder Dateibrowser geöffnet wird, deshalb diese über Appübersicht öffnen
Workaround: Galerie einfrieren/deaktivieren, simple gallery installieren.
Update 30.4.2017 :
-Quellen synchronisiert
-Browser funktioniert
Update 28.5.2017:
Update 2.7.2017:
Sollte keine Mobilfunkverbindung zustande kommen, muß der Punkt "Kernel von Spookcity138" in der Installationsanleitung/ Downloads mit beachtet werden! Dieser kann auch im Nachhinein noch installiert werden.
Alternativ: Original Samsung Firmware flashen, da hineinbooten, danach Neuinstallation ROM. Auf keinen Fall die EFS-Partition aus dem Backup wiederherstellen (sonst war die Mühe umsonst;))
Danke für den Thread.
Flash nach wipe (ohne Daten wipe) lief gut.
Startete schnell. Viele Einstellungen des Tesla ROM waren noch da (z. B. 5 soft keys, Statusbar Einstellungen).
Telefon stürzt ab, "true phone" geht.
Erster Eindruck war! gut, bis ich SU aufrief.
Das wollte die binaries aktualisieren (normal, nicht über TWRP), was auch klappte.
Nach dem Neustart hing es beim Boot Logo.
Batterie raus, Neustart half auch nicht.
Flashe gerade neu, diesmal neuste SU direkt mit.
Reaktionen: Nufan
Jetzt läuft es.
Telefon app geht nach wie vor nicht.
Stock Kamera konnte ich nicht testen, weil direkt die unter Tesla installierte FV-5 aktiviert wurde.
Erheblich mehr Einstellmöglichkeiten als bei der Tesla. Weniger freies Ram als dort, weil ich immer Nova launcher nutze, der dort Standard ist. Werde aber wohl hierbei bleiben, auch weil der Sicherheitspatch hier neuer ist.
@Fuhrmann Danke für dein Feedback
ROM läuft bei mir im alltäglichen Einsatz ohne Probleme, habe von slim7 kommend alles außer internen Speicher und SD-Karte platt gemacht.
Kein SU installiert, nur BusyBox und Titanium Backup.
Nova liegt mir nicht, bin Trebuchet/ OmniSwitch gewohnt:)
@Nufan. Ohne internen zu löschen werde ich auch mal probieren. Dann geht das Wechseln noch nen Tick schneller.
AnTuTu gibt übrigens 20447 Punkte.
Werde zum Spaß mal auch die anderen ROMs testen.
AICP steht noch aus. Hab ich bei XDA entdeckt. Läuft auf verborgtem S4 Mini problemlos nach Camera app Wechsel. [ROM][G800F/M/Y][7.1][UNOFFICIAL] AICP 12.1 Nougat
@Fuhrmann Mit Benchmarks habe ich mich noch gar nicht beschäftigt.
AICP laß ich evtl mal auf mein s4 mini Testgerät los, ansonsten sehe ich aktuell keine Gründe zu wechseln.
RR-N 5.8.2. habe ich jetzt auf allen Geräten zu aller Zufriedenheit laufen (einzig das G850F Alpha hängt noch auf RR-M 5.7.4).:thumbup:
@Nufan. Die benchmarks waren auch nur gedacht um die Leistungen der ROMs zu vergleichen. Direkt was drauf geben tu ich auch nicht. Die 20447 waren ein einmaliges Ergebnis. Alle vier ROMs (Tesla, RR, Slim u lineage) lagen zw. 14700 u 15300. Wichtiger sind mir die bugs, Optik u Bedienung.
Reaktionen: Sunny
Nach einem Monat umfänglicher Nutzung kann ich sagen, ROM läuft zuverlässig, ohne Reboots oder andere Auffälligkeiten.
Akkuverbrauch hat sich bei 26h bis 30h eingependelt.
BT-Kopplungen KFZ ohne Probleme.
Gelegentlich verschmerzbare Verbindungsabbrüche im WLAN.
@Fuhrmann :genau so hatte ich dich auch verstanden
Reaktionen: Sunny und Fuhrmann
Hallo S 5 mini Nutzer,
ich habe gestern beim alten S2 meiner Frau RR N installiert und bin wirklich begeistert davon.
Nun bin ich auf der Suche nach der richtigen RR Version für mein S5 mini.
Bei der Nougat Version scheinen ja noch Bugs (Kamera, Kontakte etc) zu bestehen - könnt ihr dies bestätigen? oder läuft dies bei euch ohne nennenswerte Probleme?
Wäre eventuell die RR MM Version die bessere (stabilere) Wahl für das S5 mini?
Freue mich auf eure Infos.
RR MM lief bei mir wesentlich instabiler, hakeliger als die aktuelle Nougatversion.
Kamera kannst du ersetzen #2, welche Kontaktprobleme spricht du an? -WLAN/mob. Daten halten sich in vertretbarem Rahmen.
RR - MM kommt ua mit robitic voice
Probier Nougat;)
Reaktionen: as_73
Danke für deine Meinung und Empfehlung.
Vor lauter Internet-Recherche kann ich gar nicht mehr sagen wo ich das mit den Kontakten gelesen habe. Eventuell vertue ich mich auch mit einer älteren Version. Umso besser wenn es da keine Probleme gibt. Robotic Voice ist also in der RR N Version kein Thema. Kamera App zu ersetzen sollte da das kleinste Problem sein.
Was meinst du genau mit den WLAN Verbindungsabbrüchen? Nur relevant wenn man länger online ist, z.B. im I-net surft?
Dann kann ich das auch vernachlässigen, zu Hause im eigenen WLAN bin ich selten mit dem Handy unterwegs. Einzig updates + Sonos Steuerung sollte laufen.
Ist SuperSU mit an Bord?
WLAN ist manchmal weg, aus-/einschalten über Schnellschalter und es verbindet sich wieder. Tritt eher selten auf, manchmal nach Ruhezustand. In wie weit das sonos Probleme bereitet mag ich nicht beurteilen.
Updates für OS nur durch flashen, keine updates ota ;)
Edit. root im build
Reaktionen: as_73
Welche SuperSU Version hast du genommen. Ich habe die 2.79 auf dem S2 nachträglich installiert Über TWRP aber beim starten der SuperSU app kommt die Meldung das keine su Datei installiert ist.
Hatte TWRP 3.0.2-0, RR, SU 2. 79 u picogapps geflasht.
In einem Rutsch.
SU ist wohl schon drin, aber so war der Aktualisierungsfehler wg binaries weg.
root vorhanden, Verwaltung über Einstellungen - Datenschutz - Datenschutz - erweitert - root (ganz rechts)
ganz rechts kommt in diesem Menü bei mir "Systemstart", "root" finde ich dort nicht.
root sollte da sein - allerdings bin ich jetzt etwas verwirrt ...
laut RR N infos auf xda:
-CM root inbuilt
dann aber weiter unten:
Builds are coming rootless,
auf jeden Fall hatte ich gestern:
SR3-SuperSU-v2.79-SR3-20170114223742
geflasht
wie gesagt springt darauf aber die SuperSU app nicht an
Busybox habe ich bisher noch nicht installiert
Werde ich nachholen
[doublepost=1491851620,1491847306][/doublepost]Also irgendwas scheint nicht geklappt zu haben.
Busybox lässt sich nicht starten, root fehlt oder supersu fehlerhaft.
Buildinternes root:
-Einstellungen - Entwickleroptionen - root aktivieren/deaktivieren
Reaktionen: Sunny
Technoolli
Islaris
Islaris
Technoolli
Technoolli
Technoolli
Nufan
Nufan
Nufan
