Nufan
Ikone
- 14.785
Kernel für Custom-ROM Android 7.x
Originalthread xda:[KERNEL] [G800F/M/Y] Spookcity_Kernel-N (For all 7.x custom ROMS)
Download:
Spookcity_Kernel-N-v6.0
Spookcity_Kernel-N-v6.0-1.5GHZ Version
Installation auf eigene Gefahr, weder Android Hilfe, ich oder Dritte haften für Schäden an Hard-, Software, Daten oder andere! Garantie verfällt durch Installation.
Note
SELinux ist auf moderat gesetzt, kann mit zB Kernel Adiutor-Mod
ab Boot auf moderat geändert werden. Diese App hat einen Schalter für diese Aktion.
Nicht verwechseln mit Kernel Audiutor.
Achtung, unbedingt das [beta] beachten, Backup vor Installation!
Wird in kürze aktualisiert
Download:
Code:
* Your warranty is now void.
* I am not responsible for bricked devices, dead SD cards,
* thermonuclear war, or you getting fired because the alarm app failed. Please
* do some research if you have any concerns about features included in this kernel
* before flashing it! YOU are choosing to make these modifications, DO NOT
* point the finger at me for messing up your device.
* this kernel is only for the S5 mini SM-G8OOF/M/Y (Exynos) Do Not Flash this on any other device!
Note
Features
Added CPU governors
- nightmare
- wheatley
- zzmoove
- dancedance
- darkness
- hyper
- lionheart
- ondemandplus
- bioshock
- pegasusq
- smartmax
- alucard (by alucard24)
- bluactive
- intelliactive (by faux123)
- intellidemand
Added CPU hotplug governors
- alucard hotplug (by alucard24)
- intelliplug hotplug (by faux123)
- thunderplug hotplug (by varun.chitre15)
- MSM Sleeper hotplug
- autoSMP hotplug
Added IO schedulers
- fiops
- sio
- zen
- fifo
- tripndroid
- bfq-v7r8
Added many TCP congestions
- reno
- vegas
- westwood and more
- Added the rest of the TCP congestions
- Westwood is now default TCP
Patches and tweaks applied include:
- Updated ARM topology and added cpu_power driver
- Input: Improve the events-per-packet estimate
- block/partitions: optimize memory allocation in check_partition()
- block: bfq-iosched: tuning for SSD (thanks to anarkia1976)
- cpufreq: Move get_cpu_idle_time() to cpufreq.c (This is important for CPU governors to work better/more efficiently with our kernel version-3.4)
- Fixed all the CPU governors to work properly with the Move get_cpu_idle_time
- cpufreq: Introduce new relation for freq selection (It selects the frequency with the minimum euclidean distance to target. In case of equal distance between 2 frequencies, it will select the greater frequency)
- cpufreq: conservative: Set MIN_LATENCY_MULTIPLIER to 20
- cpufreq-ondemand-Set-MIN_LATENCY_MULTIPLIER-to-20
- cpuidle-Get-typical-recent-sleep-interval
- cpufreq: Persist cpufreq time in state data across hotplug
- implement-LoUIS-API-for-cache-maintenance-operations
- ARM-kernel-update-cpu_disable-to-use-cache-LoUIS-maintenance API
- update-v7_setup-to-the-new-LoUIS-cache-main
- USB-gadget Optimize-tx-path-for-better-performance
- af_unix: speedup /proc/net/unix
- net/socket.c: fix: warning: 'sock/sock1/sock2' may be used uninitialized in this function
- fs/proc/array.c: make safe access to group_leader
- lib/memcopy: use glibc version (the kernel's memcpy and memmove is very inefficient. But the glibc
version is quite fast, in some cases it is 10 times faster than the kernel version)
- lib/string: use glibc version (same as above)
- lib/int_sqrt.c: optimize square root algorithm
- readahead: make context readahead more conservative
- sched-Fix-select_idle_sibling-bouncing-cow-syndrome
- sched-Implement-smarter-wake-affine-logic
- sched-Micro-optimize-the-smart-wake-affine-logic
- sched: Reduce overestimating rq->avg_idle
- power: make sync on suspend optional
- tcp: tweaked for speed
- writeback-fix-occasional-slow-sync
- writeback-fix-writeback-cache-thrashing
- wireless - bcmdhd - reduce scan dwell time to reduce power usage
- bcmdhd reduce wakelocks
- mutex-Queue-mutex-spinners-with-MCS-lock-to-reduce-cc
- mutex-Make-more-scalable-by-doing-less-atomic-operations
- ARM-use-generic-unaligned.h
- Kconfig-enabled-unaligned-capability-for-ARM
- decompressor-Enabled-unaligned-memory-access
- Optimized-ARM-RWSEM-algorithm
- ARM: Fixed negative idle stats for offline cpu
- disabled debugfs[/COLOR]
- mm: remove noisy remainder of the scan_unevictable interface
CONFIG_HZ=100 (reverted commit)
- Plus many more - Check my git repo for full details.
- Based on the latest Samsung kernel sources
- Built an updated Sqlite3 (from version 3.9.2 -> 3.19.3 that will be pushed along with the kernel install (you can verify this by running "sqlite3 --version" in a terminal emulator before the new kernel install and then again after)
- Compiled with self-built (ct-ng) UBERTC 8.0
- Patched Linux to latest 3.4.113
- Used anykernel2
- Unlocked CPU frequencies: 200MHZ and 300MHZ
- GPU overclocked to 600MHZ
- CPU Overclocked to 1.6GHZ
- CPU voltage control ( Max voltage =1500mV. Min voltage =600mV)
- DriveDroid support (add sysfs entry for cdrom to LUNs)
- Implemented zen-tune v4.5
- Added CPU boost driver
- Added PIE net scheduler
- Added support for USB keyboards (You need This app)
- Reduced vm_swappiness from 60 to 20
- Added I/O scheduler switcher by sultanxda (changes the I/O scheduler for a specified request queue to Noop when the screen turns off in order to improve power consumption while the screen is off)
- Added Fsync on/off
- Added dynamic fsync
- Added Dynamic management of dirty page writebacks (allows to have two different intervals for dirty page writebacks and to dynamically manage them when the system has been resumed (it's active) or when has been suspended - Not adjustable via Grarak's Kernel Adiutor app)
- Proc: much faster /proc/vmstat
- Full CIFS support ( Modules will be pushed with kernel install )
- Introduced new flag WQ_POWER_EFFICIENT for power oriented workqueues ( Allows for power saving if selected in Kernel Adiutor ETC. )
- Added /dev/frandom support ( It is yet to be implemented properly yet however )
- Properly enabled faux123's powersuspend v2.5
- Fading LED's
- Enabled graphite
- Enabled AIO
- Readahead set to 512 (from 128 default)
- Reverted "Enabled arch power" (There will be a switch to enable/disable this in the next build)
- Many build flags for optimization
- Added optimization flags for the GPU
- Many more features being worked on and coming soon
Added CPU governors
- nightmare
- wheatley
- zzmoove
- dancedance
- darkness
- hyper
- lionheart
- ondemandplus
- bioshock
- pegasusq
- smartmax
- bluactive
- intellidemand
- autoSMP hotplug
Added IO schedulers
- fiops
- sio
- zen
- fifo
- tripndroid
- bfq-v7r8
- reno
- vegas
- westwood and more
-v4.0 auf einigen Geräten spontane Reboots nach aufwecken
Unbedingt ein Nandroidbackup machen, keine Haftung für verlorene Daten!!!
1.Download "Spookcity_Kernel-N_vx.0"
2.Platziere die zip auf dem Gerätespeicher
3.Reboot ins recovery (Volume-lauter + Home + Power button)
4.installieren auswählen
5.heruntergeladenen Kernel installieren
6.danach zurück in TWRP wipe auswählen -> erweiterter wipe and wipe Dalvik/Art cache sowie cache partition.
Wird dies nicht getan, ist mit Problemen zu rechnen.
Keine Probleme melden, wenn dies nicht getan wurde!
Du bist gewarnt!
7.Reboot
Du bist gewarnt!
7.Reboot
Huge credit and many thanks to:
Hennymcc,Ayke,Psyafter,mirhciulica,ctxZ,DjSteve,Cu rtisMJ,osm0sis,The Sickness,Archidroid,Chet Kener,andip71,faux123,flar2,ZaneZam,AndreiLux,Yank ,Francisco Franco
Big thanks for testing and giving feedback:
Oleggluk,StanleyNL,Mikahlo,Guntzog
and any others as I'm sure I am forgetting people.
HTML:
01-09-2017 - Released Version 6.0
- Added MSM Sleeper hotplug
- Added intellidemand governor
- Added autoSMP hotplug
- Cpufreq: Persist cpufreq time in state data across hotplug
- Reverted "enable arch power"
01-09-2017 - Released Version 5.0
- Removed ROW I/O scheduler
- Enabled AIO
- Reverted a couple of HZ related commits
- Added intelliactive governor
- Added intelliplug hotplug driver
- Added thunderplug hotplug driver
- Fixed voltage control on 1500MHZ version
- Fixed alucard governor
- Fixed ondemandplus governor
- Fixed bluactive governor
- ib/int_sqrt.c: optimize square root algorithm
05-08-2017 - Released Version 4.0
- Added 1.5GHZ version
- Added voltage control
- Full CIFS support
- Introduce new flag WQ_POWER_EFFICIENT for power oriented workqueues
- Added ROW I/O sheduler
- Added BFQ-v7r8 I/O scheduler for 3.4 kernel
- Added Blu_active CPU governor
- block: disabled add_random
- tweaked build flags
- many workqueue related patches
- CONFIG_HZ=300
- disabled debugfs
19-07-2017 - Released Version 3.0
-GPU overclocked to 600MHZ
-Updated Sqlite3 to version 3.19.3 from 06-08-2017
Added CPU governors
-bioshock
-pegasusq
-smartmax
-alucard
-alucard hotplug
-Added the rest of the TCP congestions
-cpufreq: Move get_cpu_idle_time() to cpufreq.c
-Fixed all the CPU governors to work properly with the Move get_cpu_idle_time
-Added /dev/frandom support
-cpufreq: Introduce new relation for freq selection
-lib/memcopy: use glibc version
-lib/string: use glibc version
03-07-2017 - Released Version 2.0
-GPU overclocked to 533MHZ
Added CPU governors
-dancedance
-darkness
-hyper
-lionheart
-ondemandplus
Added IO schedulers
-fifo
-tripndroid
-reno
-vegas
-westwood
-etc.
26-06-2017 - Fix "unsupported device" when flashing in TWRP 3.1.1.0
23-06-2017 - Initial release
[KERNEL] [G800F/M/Y] Spookcity_Kernel-N (For all 7.x custom ROMS), Kernel for the Samsung Galaxy S5 Mini
Contributors
spookcity138
Kernel Special Features:
Version Information
Status: Beta
Created 2017-06-23
Last Updated 2017-06-26
Contributors
spookcity138
Version Information
Status: Beta
Created 2017-06-23
