EgLe
da ich hier noch nichts gelesen habe dies mal als Info ggg
Der Startschuß für Android 6.x auf unserem S3-Mini ist gefallen...
RELEASE for S3 Mini
CyanogenMod 13.0
First dev preview release (20160311) of CM13.0 for S3 Mini is available!
Please, test it and report any bugs!
For flashing Lollipop, we recommend you to install our TWRP recovery (available on Download page)!
Do full backup before installation and wipe data/cache (factory reset) after installation if you don’t updating from older CM12.0 release.
You need to perform a wipe if you’re migrating from software different than CM12.1!
You can get it on our DOWNLOAD page.
Changelog:
We don’t want to apply parts of code from 5.1 and below versions of Android just to boot it – we do it way it supposed to be – and we finally booted it natively and correctly.
I’d be glad, if you shared links to our download page, instead of direct links to download.
Also would be great, if you wouldn’t create the mirrors
Thanks.
If somehow you’ll find a bug, use our bugtracker if you want to report it.
RELEASE for S3 Mini
CyanogenMod 13.0
Changelog:
- First release
Thanks.
