[OS] RootBox (AOKP / CM 10 / Paranoid) + PDroid-Patch
  • 75 Antworten
v3.1
Code:
AOKP Project name: device_samsung_i9300
  •Pierpaolo Pernici - Torch fix: we now use our AOKP torch.
AOKP Project name: android_device_samsung_d2-common
  •Araemo - Re-enable bluetooth dock settings
  •KAsp3rd - d2-common: move composition define from qcom-common
  •KAsp3rd - d2-common: Remove unneeded overlays
AOKP Project name: device_samsung_qcom-common
  •KAsp3rd - qcom-common: actually fix it this time
AOKP Project name: device_samsung_i9100g
  •Andrew Jiang - I9100G: Enable STK functionalities
AOKP Project name: android_device_samsung_galaxys2-common
  •Bajee B. - Revert "Update board config for new audio blobs"
  •Espen Fjellvær Olsen - Update board config for new audio blobs
CyanogenMod Project name: android_hardware_samsung
  •Chirayu Desai - exynos3: omx: moar love for p1
CyanogenMod Project name: android_hardware_qcom_audio
  •Tejas Shikhare - alsa_sound: Add miscellaneous fixes to AudioSessionOut.
  •Krishnankutty Kolathappilly - alsa_sound: Fix EOS - Seek issue.
  •Tejas Shikhare - alsa_sound: fix a merge error which broke LPA functionality
CyanogenMod Project name: android_hardware_qcom_display
  •Steve Kondik - display: Link liboverlay with libqdutils
  •Steve Kondik - display: Unbreak GPU layer detection
  •Neti Ravi Kumar - hwcomposer : Send Video layers below skip layer to GPU
  •Neti Ravi Kumar - liboverlay : Update magnification limit for MDP 400
  •Neti Ravi Kumar - hwcomposer: Modify qcomuiClearRegion to rely on GPU layers only
  •Kevin Bruckert - Older QCOM devices don't support OVERLAY_COMMIT
RootBox Project name: platform_manifest
  •Bajee11 - Another DERP!
  •Bajee11 - Derp
  •Bajee11 - Track RB buildscripts
  •Bajee11 - Track back AOKP MMS
  •Bajee11 - Standarize RootBox builds
  •Bajee11 - Revert "Track own RC"
  •Bajee11 - Track own RC
  •Bajee11 - Track AOKP torch
  •Bajee11 - Revert "Track own ROMControl for PA compatibility"
  •Bajee11 - Track own ROMControl for PA compatibility
 Project name: git-repo
  •Shawn O. Pearce - Revert "Represent git-submodule as nested projects"
  •Shawn O. Pearce - repo selfupdate: Fix _PostRepoUpgrade takes 2 arguments
  •Conley Owens - Add a PGP key for cco3@android.com
  •Conley Owens - Update PGP keys during _PostRepoUpgrade in `sync`
  •Che-Liang Chiou - Fix pylint warnings introduced by the submodule patch
  •Dave Borowitz - sync: Run gc --auto in parallel
  •Olof Johansson - Add regex matching to repo list command
  •Dave Borowitz - project: Support config args in git command callables
  •Dave Borowitz - sync: Keep a moving average of last fetch times
  •Dave Borowitz - sync: Order projects according to last fetch time
  •Sarah Owens - Use modern Python exception syntax
  •Sarah Owens - Change PyDev project version to "python 2.6"
  •David Pursehouse - Add pylint configuration and instructions
  •Che-Liang Chiou - Represent git-submodule as nested projects
RootBox Project name: vendor_rootbox
  •Bajee11 - PA: Restore default SystemUI DPI for HDPI devices
  •Bajee11 - Derp
  •Bajee11 - Colorized builds RB
  •BMc08GT - tools: Colorize squisher and opticharger
  •Bajee11 - Adjust PA config
  •Bajee11 - Bring back GooManger to common.mk
  •Bajee11 - Auto-copy GooManager and PAPrefs
  •Bajee11 - Update Ufone APN
  •Bajee11 - Derp
  •Bajee11 - d2att: Add fastcharge and LTE toggle to RC
  •DAGr8 - fixed ROGERS lte apn
  •Boris Bershadskiy - Torch fix (1/2): add a separate APK to handle the torch
  •Bajee - SystemUI: Workaround clear all button not showing with lock buttton integration
  •Bajee11 - Set all pa.conf files to default DPI/Layout to please whiners.
  •Bajee11 - Include DPI requirements
  •David Gasaway - Remove duplicate openvpn
CyanogenMod Project name: android_vendor_tmobile_providers_ThemeManager
  •Andrew Jiang - ThemeManager: Simplified Chinese Translations
RootBox Project name: frameworks_base
  •Stevespear426 - WeatherPanel: Add toast and sim lock fix.
  •xoomdev - Lockscreen: Port evilisto 4x lockscreen to AOKP - WIP
  •Bajee11 - Resize HDPI weather icons
  •Bajee11 - Restore some center settings
  •Daniel Bateman - Lockscreen: Add clock alignment (1/2) Screenshots: - Left: https://dl.dropbox.com/u/4806199/Screenshot_2012-09-08-20-24-30.png - Center: https://dl.dropbox.com/u/4806199/Screenshot_2012-09-08-20-24-15.png - Right: https://dl.dropbox.com/u/4806199/Screenshot_2012-09-08-20-24-23.png
  •Bajee11 - Derp
  •Stevespear426 - WeatherPanel: Add options to hide weather panel
  •Stevespear426 - Weather panel actions and clock/date derp
  •Bajee11 - RB Settings: Implement Statusbar transparency
  •Bajee11 - Revert "Weather panel actions and clock/date derp"
  •Bajee11 - Revert "WeatherPanel: Add options to hide weather panel"
  •Bajee11 - Revert "DockAudio: Always route audio back to normal on undock."
  •Bajee11 - Revert "Bugfix: Dock events can have state greater than 1"
  •Bajee11 - Revert "Revert "Increase clocksize and center lockscreen""
  •Bajee11 - Revert "RB Settings: Center lockscreen optional (1/2)"
  •Bajee11 - Revert "Fix typo"
  •Bajee11 - Revert "Fix case typo"
  •Bajee11 - Revert "Make keyguard_screen_info public"
  •Bajee11 - Make keyguard_screen_info public
  •Bajee11 - Fix case typo
  •Bajee11 - Fix typo
  •Bajee11 - RB Settings: Center lockscreen optional (1/2)
  •Bajee11 - Revert "Increase clocksize and center lockscreen"
  •StevenHarperUK - Bugfix: Dock events can have state greater than 1
  •Brian Beloshapka - DockAudio: Always route audio back to normal on undock.
  •Bajee11 - Revert "RB Settings: Implement Statusbar transparency"
  •Bajee11 - Revert "SystemUI: Remove duplicate SettingsObserver defined twice"
  •Bajee11 - Revert "Derp!"
  •Bajee11 - Derp!
  •Bajee11 - SystemUI: Remove duplicate SettingsObserver defined twice
  •Bajee11 - Fix policy error
  •zigackly - Expanded desktop capability (2/2)
  •Bajee11 - Add alarm icon toggle in settings provider
  •Bajee11 - Implement alarm icon toggle
  •Bajee11 - Increase clocksize and center lockscreen
  •Bajee11 - Disable lock button until fixed for HDPI devices
  •Bajee - SystemUI: Change statusbar lock icon
  •Bajee11 - SystemUI: Statusbar Screenlock button
RootBox Project name: buildscripts
  •Bajee11 - Remove useless print
  •Bajee11 - Modify readme
  •Bajee11 - Include RootBox buildscripts
  •Bajee Baskararasa - Initial commit
CyanogenMod Project name: android_kernel_samsung_smdk4412
  •Espen Fjellvær Olsen - Fix camera for N80xx
 Project name: android_kernel_samsung_d2
  •Greg Kroah-Hartman - Linux 3.0.50
  •Sjoerd Simons - drm/i915: no lvds quirk for Zotac ZDBOX SD ID12/ID13
  •Ian Abbott - staging: comedi: amplc_pc236: fix invalid register access during detach
  •Yinghai Lu - x86, mm: Undo incorrect revert in arch/x86/mm/init.c
  •Jacob Shin - x86, mm: Find_early_table_space based on ranges that are actually being mapped
  •Andreas Herrmann - cpufreq / powernow-k8: Remove usage of smp_processor_id() in preemptible code
  •Piotr Haber - bcma: fix unregistration of cores
  •Stanislaw Gruszka - mac80211: check if key has TKIP type before updating IV
  •Bo Shen - ARM: at91/i2c: change id to let i2c-gpio work
  •Michael S. Tsirkin - vhost: fix mergeable bufs on BE hosts
  •Sarah Sharp - xhci: Fix potential NULL ptr deref in command cancellation.
  •Johan Hovold - USB: mos7840: remove invalid disconnect handling
  •Johan Hovold - USB: mos7840: remove NULL-urb submission
  •Johan Hovold - USB: mos7840: fix port-device leak in error path
  •Johan Hovold - USB: mos7840: fix urb leak at release
  •Johan Hovold - USB: sierra: fix memory leak in probe error path
  •Johan Hovold - USB: sierra: fix memory leak in attach error path
  •Lennart Sorensen - USB: serial: Fix memory leak in sierra_release()
  •Johan Hovold - USB: opticon: fix memory leak in error path
  •Johan Hovold - USB: opticon: fix DMA from stack
  •Johan Hovold - USB: whiteheat: fix memory leak in error path
  •Octavian Purdila - usb hub: send clear_tt_buffer_complete events when canceling TT clear work
  •Michael Shigorin - usb-storage: add unusual_devs entry for Casio EX-N1 digital camera
  •Anisse Astier - ehci: Add yet-another Lucid nohandoff pci quirk
  •Anisse Astier - ehci: fix Lucid nohandoff pci quirk to be more generic with BIOS versions
  •Geert Uytterhoeven - sysfs: sysfs_pathname/sysfs_add_one: Use strlcat() instead of strcat()
  •Trond Myklebust - SUNRPC: Prevent races in xs_abort_connection()
  •Trond Myklebust - Revert "SUNRPC: Ensure we close the socket on EPIPE errors too..."
  •Trond Myklebust - SUNRPC: Clear the connect flag when socket state is TCP_CLOSE_WAIT
  •Trond Myklebust - SUNRPC: Get rid of the xs_error_report socket callback
  •Will Deacon - ARM: 7559/1: smp: switch away from the idmap before updating init_mm.mm_count
  •Thadeu Lima de Souza Cascardo - genalloc: stop crashing the system when destroying a pool
  •Jan Luebbe - drivers/rtc/rtc-imxdi.c: add missing spin lock initialization
  •Kees Cook - fs/compat_ioctl.c: VIDEO_SET_SPU_PALETTE missing error check
  •Kees Cook - gen_init_cpio: avoid stack overflow when expanding
  •Greg Kroah-Hartman - Linux 3.0.49
  •Elric Fu - xHCI: handle command after aborting the command ring
  •Elric Fu - xHCI: cancel command after command timeout
  •Elric Fu - xHCI: add aborting command ring function
  •Elric Fu - xHCI: add cmd_ring_state
  •David S. Miller - sparc64: Be less verbose during vmemmap population.
  •Jiri Kosina - sparc64: do not clobber personality flags in sys_sparc64_personality()
  •David S. Miller - sparc64: Fix bit twiddling in sparc_pmu_enable_event().
  •David S. Miller - sparc64: Like x86 we should check current->mm during perf backtrace generation.
  •Al Viro - sparc64: fix ptrace interaction with force_successful_syscall_return()
  •Alexey Kuznetsov - tcp: resets are misrouted
  •jeff.liu - RDS: fix rds-ping spinlock recursion
  •Graham Gower - skge: Add DMA mask quirk for Marvell 88E8001 on ASUS P5NSLI motherboard
  •ramesh.nagappa@gmail.com - net: Fix skb_under_panic oops in neigh_resolve_output
  •Jesse Barnes - drm/i915: apply timing generator bug workaround on CPT and PPT
  •Devin Heitmueller - media: au0828: fix case where STREAMOFF being called on stopped stream causes BUG()
  •Andrew Morton - amd64_edac:__amd64_set_scrub_rate(): avoid overindexing scrubrates[]
  •Daisuke Nishimura - cgroup: notify_on_release may not be triggered in some cases
  •Bjørn Mork - USB: option: add more ZTE devices
  •Bjørn Mork - USB: option: blacklist net interface on ZTE devices
  •Nicolas Boullis - usb: acm: fix the computation of the number of data bits
  •Ming Lei - USB: cdc-acm: fix pipe type of write endpoint
  •David Vrabel - xen/x86: don't corrupt %eip when returning from a signal handler
  •Jacob Shin - x86: Exclude E820_RESERVED regions and memory holes above 4 GB from direct mapping.
  •Kees Cook - use clamp_t in UNAME26 fix
  •Kees Cook - kernel/sys.c: fix stack memory content leak via UNAME26
  •Arnd Bergmann - pcmcia: sharpsl: don't discard sharpsl_pcmcia_ops
  •Greg Kroah-Hartman - Revert: lockd: use rpc client's cl_nodename for id encoding
  •Sasha Levin - SUNRPC: Prevent kernel stack corruption on long values of flush
  •Dan Carpenter - oprofile, x86: Fix wrapping bug in op_x86_get_ctrl()
  •Trond Myklebust - NLM: nlm_lookup_file() may return NLMv4-specific error codes
  •Chris Metcalf - arch/tile: avoid generating .eh_frame information in modules
RootBox Project name: android_build
AOKP Project name: packages_apps_Mms
  •Vivek Vasani - Add group mms threading (1/3)
AOKP Project name: packages_apps_ROMControl
  •Stevespear426 - Weather: options to hide Weather Panel
  •Stevespear426 - Weather panel: Redo click options and add longclick
  •Gergely Szell (sethyx) - Updated Hungarian translation by Klasszsrac
  •Gergely Szell (sethyx) - Dear translators...
  •princess - Update Spanish translation
  •tristan202 - Added partial danish translation
  •Dirk Rettschlag - fix aspect ratio for notification wallpaper
  •Petr Reznicek - ROMControl: Updated czech translation
  •Stevespear426 - SBClock: Add nothing for clock and data
  •YULIANGMAX - Updated simplified Chinese translations
  •Stevespear426 - NavRing: Recoded the ROMControl part
  •Gergely Szell (sethyx) - Updated Hungarian translations by Klasszsrac
  •Stevespear426 - Clock: adds Options for custom date and clock apps
  •Petr Reznicek - ROMControl: Updated czech translatin
  •Dirk Rettschlag - Bootservice: add intent to fastcharge notification
  •xoomdev - Fix launch of lockscreen targets/nav bar targets from shortcut
  •Stevespear426 - MATH IS HARD!
  •Stevespear426 - NavBar: Tablet Navbar adujstable width
  •xoomdev - Revert "Add setting to allow lockscreen theming"
  •Stevespear426 - Toogles: Make Toggles hidable (2/2)
  •edoko - ROMControl: Korean translation by arabia1
  •Gary Danko - Add setting to allow haptic feedback on toggle press (1/2) Add a checkbox to ROMControl > Toggles
  •xoomdev - Add setting to allow lockscreen theming
  •xoomdev - Fix lockscreen wallpaper picking for landscape
RootBox Project name: packages_apps_Settings
  •Bajee11 - Add missing bracket
  •Bajee11 - Import proper ressources
  •Bajee11 - Move lockscreen vibration back to security
  •Bajee11 - RB Settings: Cleanup lockscreen options
  •Bajee11 - Add color picker
  •Bajee11 - RB Settings: Implement alt lockscreen
  •Bajee11 - Fix menu FC
  •Bajee11 - Fix biggest mistake of the century.
  •Bajee11 - import ContentResolver
  •Daniel Bateman - Lockscreen: Add clock alignment (2/2) Settings part, check frameworks part for more info and screenshots.
  •Bajee11 - RB Settings: Implement statusbar transparency
  •Bajee11 - Revert "RB Settings: Center lockscreen optional (2/2)"
  •Bajee11 - Revert "RB Settings: add missing variable (Lockscreen)"
  •Bajee11 - Revert "RB Lockscreen: Class Lockscreen OnPreferenceChangeListener"
  •Bajee11 - Revert "Derp"
  •Bajee11 - Derp
  •Bajee11 - RB Lockscreen: Class Lockscreen OnPreferenceChangeListener
  •Bajee11 - RB Settings: add missing variable (Lockscreen)
  •Bajee11 - RB Settings: Center lockscreen optional (2/2)
  •Bajee11 - Revert "RB Settings: Implement statusbar transparency"
  •Bajee11 - Revert "Class Statusbar OnPreferenceChangeListener"
  •Bajee11 - Class Statusbar OnPreferenceChangeListener
  •Bajee11 - About RB: Include button for PieR & move him up
  •Bajee11 - RB Settings: Include XHDPI icon for settings
  •Bajee11 - RB Settings: include icons for settings & add summary for expanded desktop
  •Bajee11 - RB Settings: Only retrieve interface_lockscreen for Lockscreen settings.
  •Bajee11 - Expanded Desktop: change config_show_expandedDesktop value
  •Bajee11 - Revert "Expanded Desktop: Remove xml overlay to enable by default for all devices."
  •Bajee11 - Expanded Desktop: Remove xml overlay to enable by default for all devices.
  •Bajee11 - Alarm toggle: Restart SystemUI & add util
  •Bajee11 - Derp
  •Bajee11 - Allow to hide Expanded Desktop (1/2)
  •Bajee11 - Revert "Add util"
  •Bajee11 - Derp
  •Bajee11 - RB Settings: Fix alarm icon toggle
  •Bajee11 - Add util
  •Bajee11 - RB Settings: Clean up lockscreen options and add Statusbar options
  •Bajee11 - Add new png
  •Bajee11 - Cleanup and add new png for RB settings
  •Bajee11 - RB Settings - Initial commit
  •Bajee11 - Revert "Implement RootBox Settings"
  •Bajee11 - Implement RootBox Settings
  •Petr Reznicek - Settings: Fixed czech translation
  •Gergely Szell (sethyx) - Allow "Vibrate on Touch" behavior for Slide unlock (2/2)
  •Zaphod - Fix Widget Picker color (again!)
  •Zaphod - Revert "Fix Widget Picker text color"
  •Bajee11 - Fix derp
  •Bajee11 - Update About RootBox
AOKP Project name: packages_apps_Contacts
  •JubakubaSlut - Fix Hebrew Numeber4 Image
  •m4570d0n - Fix: Missing color references in layouts
AOKP Project name: packages_apps_Torch
  •Boris Bershadskiy - Torch: allow launching the app from Shortcuts --> Activities
  •Gergely Szell (sethyx) - update key to match with frameworks (TORCH_STATE)
  •Petr Reznicek - Torch: Created czech translation
  •Gergely Szell (sethyx) - Missed this one while replacing
  •Gergely Szell (sethyx) - Change intents, fix formatting; follow Android design guidelines
CyanogenMod Project name: android_external_busybox
  •Paul Beeler - android ndk defconfig: fix default location of modules
  •Ricardo Cerqueira - Revert "dd: support skip and seek values greater than 2G on android"
  •Bajee11 - Derp
PDroid-Patch im Startpost.
v3.2
Code:
  •Oran Avraham - i9300: allow mass storage mode for external sdcard
  •Steve Kondik - d2: Update audio_policy for new A2DP handling
  •Steve Kondik - Revert "Revert "d2: audio: Enable low power audio""
AOKP Project name: android_device_samsung_msm8960-common
  •Steve Kondik - msm8960: Remove deprecated ALSA HAL
  •Andrew Jiang - I9100G: Port translations from I9100 + Add Copyright Headers
  •codeworkx - i9100g: implement sensor calibration, fix some german translations
CyanogenMod Project name: android_hardware_libhardware_legacy
  •Conn O'Griofa - Fix build error caused by ar6000 workaround
  •Conn O'Griofa - libhardware_legacy/wifi: add workaround for ar6000 driver
  •Brian Beloshapka - alsa_sound: Re-add DOCK_USBAUDIO.
  •Deepa Madiregama - audio/msm8660: Fix for Mute not working in VoIP call
  •Krishnankutty Kolathappilly - alsa_sound: A2DP playback changes on jellybean
  •Yamit Mehta - audio/msm8660: Add support for audio effects for LPA clips
  •Deepa Madiregama - audio/msm8660: Fix the issue of voice call when HDMI connected
  •Y Mehta - audio/msm8660: LPA Audio HAL fixes for suspend and eos issue
  •Yamit Mehta - audio/msm8660: Fix to avoid routing in voice call
  •Deepa Madiregama - audio/msm8660: Fix audio routing issue during cam corder
  •Brian Beloshapka - alsa_sound: Enhance support for dock audio.
  •Kevin Bruckert - Legacy QCOM audio does not support ext functions
  •Mike Kasick - Samsung msm8960: Add support for "Voice Earpiece Extra Gain" mode
  •Ramkumar Radhakrishnan - liboverlay: close all the opened pipes after framework reboot.
  •freexperia - display: fix display for msm7x30
  •Bajee11 - Track own Phone, MMS & ROMControl
  •Bajee11 - Track DSPManager package
  •Bajee11 - Add torch compatibility for lockscreen hardware keys.
  •Bajee11 - Add Onandroid script, app and partitions table.
  •Bajee11 - Add hardware keys overlay for all devices.
  •Bajee11 - Add torch toggle hardware keys (2/2)
  •Will DeBerry - Policy: Show lockscreen before secure unlock (Part 1/2)
  •Bajee11 - Fix Circles lockscreen alignment
  •Danny Baumann - Increasing ringtone volume option (1/3)
  •ihtfp69 - TextView: Allow copy/paste in Google Talk
  •Mike Kasick - AudioService: Don't adjust volume when vol-downing to vibrate or silent
  •Bajee11 - Adapt flashlight intent to match AOKP Torch app.
  •Bajee11 - Fix build error
  •jt1134 - LockScreen: allow long-press actions from hardware keys (1/2)
  •Bajee11 - Improve clock alignment (1/2)
  •elelinux - Frameworks: update Swedish translation
  •Danesh M - Fix volume track skip control with 3rd party applications
  •Gergely Szell (sethyx) - TransportControl: Remove unnecessary check, also #blamexoomdev
  •Stevespear426 - NavRing: Long press actions. 1/3
  •Zaphod - SystemUI : Fix NPE on Rotate
  •xoomdev - Lockscreen: Add Circles Lockscreen to AOKP
  •Bajee11 - Revert "Lockscreen: Port evilisto 4x lockscreen to AOKP - WIP"
  •Zaphod - SystemUI:Widgets fix & Class Move
  •Zaphod - Lefty Mode for NavBar (1 of 2)
  •maxwen - Default device volumes not initialised
  •Kyle Teague - SystemUI: Cog Circle Mod Battery
  •Bajee11 - Revert "framework: Add a version of Environment.getExternalStorageState which accepts a path parameter"
  •Bajee11 - Revert "Ability to see through the lockscreen"
  •D4rKn3sSyS - Ability to see through the lockscreen
  •Pawit Pornkitprasan - framework: Add a version of Environment.getExternalStorageState which accepts a path parameter
  •Bajee11 - Revert "frameworks/base: Add support for wired headset detection"
  •Gergely Szell (sethyx) - Lockscreen: Fix NPE (softreboot) if WeatherPanel is null
  •Bajee11 - Revert "WeatherPanel: Add toast and sim lock fix."
  •Bajee11 - Remove mHomePressed variable
  •xkonni - Hardware Key remapping (Part 2 of 2)
  •maxwen - Restore correct volumes when headset is plugged
  •NewbyJE - telephony: neighboring cells are now handled properly
  •mateor - Move voip/java/com/android/server/sip to framework2.jar
  •Sudhir Sharma - frameworks/base: Add support for wired headset detection
  •NewbyJE - core and telephony: Additional HSPAP support
  •Mike Kasick - SettingsProvider: Revert default WiFi sleep policy to "never"
  •JBirdVegas - Suppress String resources build warnings
CyanogenMod Project name: android_bootable_recovery
  •Koushik Dutta - Allow custom RECOVERY_NAME
  •Steve Kondik - Revert "move "install zip from sideload" to installation submenu"
  •Kuogee Hsieh - msm_fb: display: fix iommu leak during base layer swap
  •Kuogee Hsieh - msm_fb: dsiplay: fix frame buffer f_count leak
  •Kuogee Hsieh - msm_fb: display: add fput_light to frame buffer
  •Dhivya Subramanian - Revert "msm_fb: display: add fput_light to frame buffer"
  •Siddhartha Agrawal - msm_fb: display: Enable scaling bit while setting x-flip bit
  •Kuogee Hsieh - msm_fb: display: check pipes queued before enter wait_for_completion
  •Kuogee Hsieh - msm_fb: display: return fail if pipe still staged
  •Kuogee Hsieh - msm_fb: display: add dtv base layer swap
  •Mayank Chopra - msm_fb: display: Make sysfs read request interruptible
  •Huaibin Yang - msm_fb: display: extend mutex protection for mdp pan display
  •Greg Kroah-Hartman - Linux 3.0.51
  •Ben Skeggs - drm/nouveau: silence modesetting spam on pre-gf8 chipsets
  •Jan Kara - mm: fix XFS oops due to dirty pages without buffers on s390
  •Len Brown - x86: Remove the ancient and deprecated disable_hlt() and enable_hlt() facility
  •Herton Ronaldo Krzesinski - floppy: do put_disk on current dr if blk_init_queue fails
  •Bajee11 - Include DSPManager in RB builds
RootBox Project name: packages_apps_Mms
  •Bajee11 - Fix typo
  •gzfighter - Mms: added the option to change the soft keyboard type when composing messages
  •burnsra - Add custom vibrate
  •Bajee11 - Revert "Add custom vibrate"
  •Petr Reznicek - Mms: Updated czech translation
  •Pierpaolo Pernici - ROMControl: Ability to set navbar width/height to 0 (off)
  •tristan202 - Updated danish translation
  •Stevespear426 - NavRing: Long press actions. 2/3
  •Zaphod - ROMControl Widget Fixes
  •Zaphod - Lefty Mode (2/2)
  •xoomdev - Add customizable options for Circles Lockscreen
  •tristan202 - ROMControl: Updated danish translation
  •JBirdVegas - UserInterface: apply build.prop edit to fully remove bootanimation
  •Dirk Rettschlag - Notification: add option to show connected wifi network (2/2)
  •Bajee11 - RB Settings: Add torch toggle hardware keys (1/2)
  •Bajee11 - RB Settings: Show lockscreen before secure unlock (Part 2/2)
  •Bajee11 - Derp!
  •Bajee11 - Fix incorrect android:key
  •Danny Baumann - Increasing ringtone volume option (2/3)
  •Bajee11 - RB Settings: rename strings, clean up & fix HDPI hardware keys icon.
  •Bajee11 - About RB: Add Bluefa1con to contributor list (I9100G)
  •jt1134 - LockScreen: allow long-press actions from hardware keys (2/2)
  •Bajee11 - RB Settings: Update string to reflect lockscreen changes.
  •elelinux - Settings: update Swedish translation
  •Gergely Szell (sethyx) - Set Stock music layout for Lockscreen while enabling Circles style
  •Bajee11 - Revert "RB Settings: Implement alt lockscreen"
  •xoomdev - Add setting to set Circles Lockscreen
  •Bajee11 - Revert "RB Settings: Ability to see through the lockscreen"
  •Bajee11 - RB Settings: Ability to see through the lockscreen
  •Bajee11 - Remove duplicate strings
  •Bajee11 - Correct package name
  •Bajee11 - Settings: Hardware key remapping (2/2)
CyanogenMod Project name: android_packages_apps_DSPManager
  •DelPETER - DSPManager : Added French missing translation
  •Arnav Gupta - DSPManager overrides compiling MusicFX
RootBox Project name: packages_apps_Phone
  •Petr Reznicek - Increasing ringtone volume option (3/3)
  •Juan Rodriguez - Phone: Port CM Advanced Phone Settings
  •Stevespear426 - NavRing: Long press actions. 3/3
hi ich brauche mal Hilfe, ich streife nun schon seit Tagen durch forum und bekomme keine Antworten die mir weiter helfen... :(
Ich weiss ich nutze eine andere rom als hier im thema und ich ich habe ein anderes modell (i9000), das schema müsste trotzallem F sein.
Code:
./auto_patcher helly_bean_allinone_20121109.zip pdroid helly_bean_i9000
Diesen error bekomme ich immer.
In meinem Ordner befinden sich autopatcher entpackt pdroid-patches entpackt und die hellybean rom.
Code:
The Auto-Patcher v2.4.5
### verify tools ###
!! error: Missing "jar (JDK)"
Your set-up is missing a dependency.
We require JDK, patch and cpio.
Each distro is different
but you must ensure you have them all installed and try again.
usage: ./auto_patcher [ROMNAME].zip [MODS] [ROMTYPE] [PATCHDATE]
* [MODS] can be pdroid, pd2.0, v6supercharger, tabletUI, etc...
MODS can be combined by separating them with a comma and NO SPACES!!!
* [ROMTYPE] can be cm, aokp, aosp or pa                      [recommended]
* [PATCHDATE] will select older patch versions, e.g 2012103     [optional]
 try "./auto_patcher ROM.ZIP -h" to see what is available
Was zur helly mach ich falsch ???
Danke im Voraus!!!
Aha. Ich verstehe nicht, warum du dann trotzdem hier im Thread postest. Manche ROMs funzen halt einfach nicht mit PDroid. Dann musst du halt ein anderes ROM nehmen.
In deinem Fall ist die Fehlermeldung doch aber eindeutig.
Das JDK ist nicht installiert.
Du kannst nicht lesen.
v3.4
Code:
  •DvTonder - Framework: Port CM9 features to CM10 This commit includes:  - Profiles
  •Roman Birg - fix IME overlapping fields while typing in certain situations
  •Danny Baumann - Properly handle changes in phone audio focus.
  •Pawit Pornkitprasan - DefaultContainerService: implement additional methods
  •Gergely Szell (sethyx) - Feat: Allow users to disable safe headset volume warning (1/2)
  •Roman Birg - SystemUI: fire off intent to preload along with first task
  •Roman Birg - SystemUI: more consistent nav tinting behavior
  •Robert Burns - Forward port CM Screen Security settings (Part 2 of 2)
  •DvTonder - Framework: Forward port Expanded desktop capability
  •Bajee11 - SystemUI: HSPA+ Support
  •Roman Birg - transparent statusbar
  •Roman Birg - transparent nav bar
  •Bajee11 - Revert "transparent nav bar WIP"
  •Phil Tunstall - Hardware key custom rebinding (1/2)
  •Rowan Decker - Framwork: Add support for variable size pattern lockscreen (Part 1/2)
  •Oleksandr Byelkin - Add ability to answer call with hardware HOME button (1/2)
  •vivek mehta - frameworkbase: Fix the JPEG file indexing
  •Chirayu Desai - telephony: hide needsOldRilFeature
  •dhacker29 - Framework: Fix GSM signal strength
  •vivek mehta - Squashed commit of audio changes from CodeAurora
  •Alex Yakavenka - Add config_speed_up_audio_on_mt_calls option
  •Emerson Pinter - camera: add power mode support
  •jt1134 - Camera: add ISO mode support
  •Roman Birg - Fix reboot dialog causing hot reboot if user long presses power button more than once.
  •qnhoang81 - Fix "Search" as a long press navigation bar target.
  •Pawit Pornkitprasan - Toast: fix force close if called from system service
  •Roman Birg - transparent nav bar WIP
  •Rick C - Added the CM idea / feature to always pull down quicksettings on right side without setting implemenation, which will follow.
  •Shareef Ali - CDMA RIL: add SVDO support (1/2)
  •Stevespear426 - Recents: Fix Recents for MultiUser
  •Gergely Szell (sethyx) - Fix: Handle switching between Wifi & Wifi Tether in QuickSettings
  •Roman Birg - SystemUI: fix bt toggle
  •You Kim - Possible leak in android_emoji_EmojiFactory_newInstance
  •kecinzer - Base: Fixed czech translation
  •Tanguy Pruvot - Option to hide Adb notification icon (framework)
  •Roman Birg - SystemUI: ram bar and recents performance improvements
  •Gergely Szell (sethyx) - LED Notification: Force update on SCREEN_OFF
  •Roman Birg - SystemUI: add statusbar slider preference
  •Roman Birg - SystemUI: don't add tint to app icons or custom images
  •Jean-Christophe PINCE - Memory leak due to bad destroy sequence
  •Roman Birg - SystemUI: refactor fast charge toggle
  •Danesh M - Camera : Powerkey shutter (1/2)
CyanogenMod Project name: android_frameworks_av
  •Adam77Root - stagefright: add support for samsung proprietary omx
  •Andrew Dodd - exynos4:  Part of Netflix fix
  •Ricardo Cerqueira - stagefright: OMXCodec: Re-enable OMX.TI.Video.encoder's quirks
  •vivek mehta - Squashed commit of updates from CodeAurora
  •Steve Kondik - lpaplayer: Shush the verbose logging
  •Emerson Pinter - camera: add ISO3200 and ISO6400
  •David Ng - Fix potential NULL pointer deference in ToneGenerator destructor
  •vivek mehta - libstagefright: Add support to seek to zero
  •Ricardo Cerqueira - WifiDisplay: Add an HDCP toggle
CyanogenMod Project name: android_frameworks_native
  •Ricardo Cerqueira - sensordevice: Dummy ALS: Solve fortified libc warning
  •Ricardo Cerqueira - sensors: Add dummy light sensor
  •Ricardo Cerqueira - ui/sf: Add support for exynos HDMI
CyanogenMod Project name: android_frameworks_opt_telephony
  •Geo Piskas - Fixed FC on calling unregisterReceiver with non registered receiver arg.
  •Danny Baumann - Fix ringing audio focus handling.
  •Alex Yakavenka - Set audio mode after accepting the call
  •Austen Dicken - telephony: CdmaServiceStateTracker: Get cdma sub. when ruim ready.
  •Danny Baumann - Allow registering for supplementary service notifications.
  •Danny Baumann - Add notification type constants.
  •Shareef Ali - SamsungQualcommCDMARIL : fix cdma/lte signal strength implimentation
  •Richard Ross - CdmaLteServiceStateTracker: simultaneous voice and data support on CDMA (e.g: SVDO)
  •Shareef Ali - SamsungQcomCDMARIL: Add support for SIM.
RootBox Project name: device_samsung_i9100g
  •codeworkx - i9100g: set removable flag on external sdcard
  •codeworkx - i9100g: add global cflag for camera iso
  •codeworkx - i9100g: reduze height of keyguard status view
  •codeworkx - i9100g: provide bluetooth conf
  •codeworkx - i9100g: don't hide focus modes
  •bmc08gt - d2-common: Disable wifi background scan and fine tune wifi
  •Steve Kondik - d2: Enable MT call audio speedup
  •Steve Kondik - d2: Update audio policy for new driver
  •Shareef Ali - d2: Add cameradata/SlimISP_GH.bin to support later revisions.
  •Mike Kasick - Audio use case enhacements
  •Steve Kondik - d2: Enable WFD
  •Steve Kondik - d2: Limit MDP composition to 3 layers
  •Shareef Ali - d2: remove nfc firmware,
  •invisiblek - d2-common: build libnetcmdiface
  •BMc08GT - d2-common: Set Fast Charge Path
  •Hrubak - Fixup Mounts
  •Piotr Gasior - i9100:Added Polish Translation
RootBox Project name: device_samsung_galaxys2-common
  •Andrew Dodd - permissions: Remove some nasty 777s
  •codeworkx - galaxys2: don't hide focus modes
  •Mike Kasick - gps: Add loc_eng_set_privacy function to enable/disable GPS privacy lock.
  •Steve Kondik - msm8960: Update msm_mdp header to match kernel
  •Steve Kondik - msm8960: Define module args for AP mode
AOKP Project name: device_samsung_d2att
  •Bajee11 - Add back README which was deleted in the cleanup.
RootBox Project name: device_samsung_smdk4412-common
  •Bajee11 - Remove overlays
  •codeworkx - smdk4412: define WIFI_DRIVER_MODULE_AP_ARG
  •codeworkx - smdk4412: don't hide focus modes
RootBox Project name: device_samsung_i9300
  •Bajee11 - Fix Quick Toggles FC
  •codeworkx - i9300: move uevent conf to common
  •codeworkx - i9300: enable SPKL Boost SPKR Switch on boot
  •codeworkx - i9300: remove include of init.bt.rc
  •codeworkx - i9300: enable samsung stk
  •codeworkx - i9300: audio: remove mutex lock at adev_set_voice_volume
  •codeworkx - i9300: add mountpoints for external sdcard and usb storage
  •codeworkx - i9300: fix group on video nodes
  •codeworkx - i9300: update audio hal for mr1
  •XpLoDWilD - 4.2-ization
  •codeworkx - i9300: use SamsungExynos4RIL class
  •codeworkx - i9300: add bluetooth build config
  •codeworkx - i9300: implement noise suppression for calls
  •Nebojsa Cvetkovic - reorganize device tree, use smdk4412-common tree
RootBox Project name: device_samsung_qcom-common
  •Anurag Singh - power: Use macros instead of string literals.
  •bmc08gt - PowerHAL: Only write to SAMPLING_RATE_ONDEMAND when using Ondemand
  •Steve Kondik - qcom-common: Get rid of the custom recovery graphics
  •bmc08gt - qcom: disable 4 layer MDP Composition temportarily
  •Steve Kondik - qcom-common: Update media_codecs with all QCOM codecs
  •Bajee11 - qcom-common: Use CAF audio variant
  •Mingming Yin - audio: use MAKO audio config files
  •Steve Kondik - qcom-common: Use CAF display variant
  •Steve Kondik - qcom-common: Update property for MDP composition
 Project name: proprietary_vendor_samsung
  •Bajee11 - d2: Delete unused blobs
  •Bajee11 - Update 9300 blobs
  •Bajee11 - Update d2 blobs
  •Bajee11 - d2: Update blobs for d2 devices and follow TheMuppets format.
  •Shareef Ali - d2: on some devices nfc firmware aren't updated because the current is the same as file and never updated
  •Shareef Ali - d2vzw: refix nfc blobs
  •Shareef Ali - d2: update usc blobs
  •Roman Birg - i -> I
  •Bajee11 - Add Trebuchet overlay for grouper.
  •Bajee11 - Build NFC and Tag
  •Bajee11 - Add Home Unlock Setting
  •Bajee11 - Enable hardware keys and led overlay for all devices.
  •Bajee11 - Separate AOKP and CM packages.
  •Bajee11 - Remove Nova Launcher and replace with Trebuchet.
  •Bajee11 - Add grouper support and cleanup tablet configs.
  •Bajee11 - Build CM LockClock
  •Bajee11 - Update Onandroid v2.6.8 and script v6.14
  •Bajee11 - Fix NFC i9100p - Update prebuilt files
  •KhasMek - Dictionary: add low priority to offensive words
  •JBirdVegas - Dict: Include our own word list
  •bmc08gt - squisher: Add zipsize to 'package complete' output
  •KhasMek - Make output of md5sum more uniform.
  •Paul Beeler - Common Tablets bools:  Optimized browser interface for tablets
  •Bajee11 - Remove superuser
  •Bajee11 - Fix NFC for i9100p
  •Bajee11 - Add N7000 support
  •rascarlo - i is now I
  •Bajee11 - Paranoid cleandup
RootBox Project name: android_system_core
  •Prashant Somashekar - audio: fix build break for non QCOM
  •Mingming Yin - audio: add QCOM supported audio devices
  •Steve Kondik - Set ANDROID_PROPERTY_WORKSPACE in exec.
  •Steve Kondik - camera: Add new commands to compatibility block
  •Steve Kondik - camera: Remove histogram commands
AOKP Project name: android_bionic
  •Ricardo Cerqueira - Revert "sha1: Use bswap* to optimize byte order"
  •Pawit Pornkitprasan - linker: restore prelink support
 Project name: Camera
  •codeworkx - camera: add support for various scene modes
  •codeworkx - camera: add support for various focus modes
  •codeworkx - camera: extend supported exposure compensation range
  •jt1134 - Camera: port additional settings from jellybean 4.1
  •Danesh M - Camera : Powerkey shutter (2/2)
  •Igor - DSPManager: removed app title from strings in romanian translation
  •Andrew Jiang - DSPManager: Simplified Chinese Translations
  •Igor - DSPManager: fixed string for romanian translation
  •nebkat - Rename to DSP Manager
  •DvTonder - Settings: Add Utility function
  •DvTonder - Settings: Forward port missing Profiles related changes
  •Ricardo Cerqueira - Bring in Profiles support from mr0
  •Espen Fjellvær Olsen - Add option for switching between UMS and MTP/PTP mode. (2/2)
  •Pawit Pornkitprasan - Settings: use DefaultContainerService for all file operations
  •Pawit Pornkitprasan - Settings: fix storage measurement for device without emulated sdcard
  •nebkat - SoundSettings: Show DSPManager
  •DvTonder - Settings: Fix the SMS Limit setting location
  •Gergely Szell (sethyx) - Feat: Allow users to disable safe headset volume warning (2/2)
  •kecinzer - Settings: Updated czech translation
  •Danesh M - Settings: Forward port CM Screen Security settings (Part 1 of 2)
  •Bajee11 - Add has_led_flash bool
  •DvTonder - Settings: Forward port Expanded desktop capability Originally authored by Jesús David and ported from         ParanoidAndroid ICS branch
  •Bajee11 - Add new pngs for RootBox Settings
  •jt1134 - LockScreen: allow long-press actions from hardware keys (2/2) Allow following actions with button long-presses on lockscreen: - toggle flashlight (if available) -
play/pause/next/previous track selection - toggle silent mode
  •Phil Tunstall - Settings: Forward port Hardware key custom rebinding (2/2)
  •Bajee11 - Fixup strings and whitespace-Chronus
  •lithid - Settings: Add setting in security for sms message rate alerts from CM10
  •Bajee11 - RootBox Settings - CyanogenMod Lockclock
  •Rowan Decker - Settings: Add support for variable size pattern lockscreen (Part 2/2)
  •Oleksandr Byelkin - Adds ability to answer call with hardware HOME button (2/2)
  •codeworkx - Phone: implement noise suppression for phone calls (2/2)
  •kecinzer - Phone: Updated czech translation
CyanogenMod Project name: android_packages_apps_Trebuchet
  •pvolkov - Update Russian Translation-Trebuchet-CM10.1
  •Robert Burns - Remove drop target text in landscape
  •Robert Burns - Fix vertical transition effects
  •Jacob Overgaard Madsen - Resubmitted change Idf6b8399 due to a failed merge
  •Andrew Jiang - Trebuchet: Simplified Chinese Translations
  •djMesias - es_ES: Added icon scale translations
  •Gustavo - PT-BR: Added missing translations
  •nebkat - ShortcutInfo: Save title if itemType shortcut
  •nebkat - Cleanup
  •nebkat - LauncherProvider: Revert changes to check whether app is installed before adding favorite
  •nebkat - Workspace: Fixes
  •nebkat - DeleteDropTarget: Don't accept allapps button
  •nebkat - Workspace: Fix hotseat dropping
  •nebkat - LauncherModel: Fixes
  •nebkat - ShortcutInfo: Save title if custom
  •nebkat - Hotseat: Use single layout
  •nebkat - Hotseat: Fix sw720dp default cell count
  •nebkat - Fix sw600dp icon offsets
  •nebkat - Fix sw720dp icon offsets
  •nebkat - LauncherProvider: Revert some changes
  •Pavel Kirpichyov - Trebuchet: Missing russian strings
  •nebkat - Preferences: Remove useless log
  •nebkat - Launcher: Remove long-press menu
  •nebkat - Preferences: Koush steals yachts
  •nebkat - PreloadReceiver: Use com.cyanogenmod.trebuchet resources
  •nebkat - LauncherProvider: Cleanup
  •nebkat - Launcher: Hide wallpaper when transitioning if rendering manually
  •elektroschmock - German: Update translation
  •nebkat - Launcher: Don't remove pending add info with shortcut pick
  •Marco Brohet - Trebuchet: Dutch translations
  •Tamás Tóth - Added missing hungarian translations
  •Igor - Trebuchet: updated romanian translation
  •nebkat - Hotseat: Icon scale
  •nebkat - Workspace: Fix folder creation
  •nebkat - Workspace: Fix sw720dp scrolling indicator
  •nebkat - Revert "Revert "Launcher: Trebuchet settings visibility""
  •nebkat - EcoGallery: Don't use reflection
  •nebkat - Launcher: Software Menu Button
  •nebkat - Workspace: Hotseat fixes
  •Takuo Kitame - Japanese: update translation for CM10.1
  •nebkat - Fixes
  •nebkat - LauncherActions: Don't use magic intents
  •nebkat - AppsCustomizePagedView: Fixes
  •nebkat - Cleanup
  •Tamás Tóth - Added hungarian translation
  •Gustavo - PT-BR: Added missing translations + fixes
  •djMesias - es_ES: More missing translations
  •nebkat - Revert "Launcher: Trebuchet settings visibility"
  •nebkat - Hotseat: Lanscape layout fixes
  •nebkat - LauncherProvider: Clear dock before DB v13
  •nebkat - Launcher: Trebuchet settings visibility
  •nebkat - Hotseat: Landscape layout fixes
  •nebkat - HiddenAppsActivity: Set PREFERENCES_CHANGED
  •nebkat - Hotseat: Cleanup
  •nebkat - Hotseat: Fix landscape grid
  •nebkat - Hotseat: Number Icons
  •nebkat - Hotseat: Default Page
  •nebkat - Hotseat: Multiple Pages
  •nebkat - Launcher: Long-press Menu
  •nebkat - Launcher actions
  •djMesias - Fixed compiler warnings
  •djMesias - es_ES: Added CM translations
  •Igor - Trebuchet: Updated romanian translation
  •nebkat - Workspace: Shortcut renaming
  •nebkat - Workspace: State transitions fixes
  •nebkat - AppsCustomizePagedView: Filtering
  •nebkat - AppsCustomizeTabHost: Fix apps sorting
  •nebkat - AppsCustomizePagedView: Indicator Position
  •nebkat - Preferences: Hide grid on large
  •nebkat - Preferences: Fix XML whitespace
  •nebkat - Workspace: Run checkWallpaper on UI thread
  •Robert Burns - Fix string/array values
  •Robert Burns - Fix drawer transitions
  •nebkat - Workspace: Wallpaper Size
  •nebkat - Transition Effects: Don't force fade on cube
  •nebkat - Launcher: Fullscreen Mode
  •nebkat - Preferences: Cleanup
  •nebkat - Workspace: Indicator Position
  •Manuel Valentino - Italian translation for Trebuchet (Update)
  •nebkat - Update log tags
  •nebkat - Cylinder Transition Effect
  •nebkat - PreferencesProvider: Prevent FC when invalid transition effects given
  •nebkat - Transition Effects Fixes
  •ak - Fix group message participant list
  •Bajee11 - Mms: add new QuickReply buttons Delete & Mark Read
  •detule - Mms: Take into account image rotation.
  •Gergely Szell (sethyx) - Fix SecurityException when adding a captured photo
  •travp624 - Add themes support to Mms (ala handcent theme ability)
  •JBirdVegas - Mms: add new QuickReply buttons Delete & Mark Read
AOKP Project name: packages_apps_PackageInstaller
  •Roman Birg - fix next button not doing anything when upgrading package
CyanogenMod Project name: Calculator
  •Marco Brohet - Calculator: Dutch translations
  •Michael Bestas - Calculator: Update Greek translations
  •Igor - Calculator: updated romanian translation
  •djMesias - es_ES: Added missing translations
  •Prashant Somashekar - Calculator: fix build break (fr)
  •DelPETER - Calculator : add french missing translation
  •Tamás Tóth - Added hungarian translation (Done)
AOKP Project name: packages_apps_Browser
RootBox Project name: packages_apps_ROMControl
  •Roman Birg - Update default values for nav bar reset
  •Roman Birg - Add statusbar and navigation bar opacity slider
  •Bajee11 - Revert "Add navigation bar opacity slider"
  •Roman Birg - Add navigation bar opacity slider
  •Leandros Linux - added fast toggle preference
  •Leandros Linux - Minor bug fixes in ROMControl where ListPreference don't showed the currently selected item correctly
  •JBirdVegas - UserInterface: refactor IO to use Threads
  •kecinzer - ROMControl: Updated czech translation
  •Roman Birg - comment out unimplemented features
  •Roman Birg - add statusbar slider preference
  •LorD ClockaN - ROMControl: Update Spanish transalations
  •kecinzer - ROMCOntrol: Updated czech translation
AOKP Project name: packages_apps_DeskClock
  •kecinzer - DeskClock: Updated czech translation
  •Marek Walczak - Add option to hide AlarmClock Icon in StatusBar
CyanogenMod Project name: android_packages_apps_LockClock
  •Marco Brohet - LockClock/Chronus: Dutch translations
  •Matteo Panella - LockClock: add Italian translation (1 of 2)
  •djMesias - es_ES: Added spanish translations
  •Andrew Jiang - LockClock: Simplified Chinese Translations
  •DelPETER - Lock Clock : Add French translation
  •Tamás Tóth - Added hungarian translations
  •pvolkov - Update Russian Translation-LockClock-CM10.1
  •igoriok - Chronus: add date format in romanian translation
  •DvTonder - Chronus: Standardize preference categories and layout
  •DvTonder - Chronus: Add support for alternate (Color) weather icons
  •DvTonder - Chronus: Add ability to configure minutes and date/alarm fonts
  •DvTonder - Chronus: Fix weather invert low / high temperatures
  •igoriok - Chronus: updated romanian translation
  •Alan Orth - Chronus: grammar fix for settings
  •DvTonder - Chronus: Updated drawables
  •DvTonder - Chronus: Add ability to hide All day events in the calendar panel
  •DvTonder - Chronus: Optimizations
  •igoriok - Chronus: translated to romanian language
  •Michael Bestas - LockClock: Add Greek translation
  •elektroschmock - LockClock (aka Chronus): Remove build warnings
  •Gustavo - PT-BR: Initial Translation
  •Marco Brohet - LockClock: Dutch translations
  •Geo Piskas - Fixed Force Close when enabling Network Location.
  •dh-harald - LockClock: Hungarian translations
  •DelPETER - LockClock : Initial French translation
  •elektroschmock - LockClock: Initial German translation
  •pvolkov - Added Russian Translation-LockClock-CM10.1
  •DvTonder - Introducing 'Chronus'
  •DvTonder - LockClock: Fix the calendar icon display if no events
  •DvTonder - LockClock: Register a click listener even if there is no weather data
  •Danesh Mondegarian - Stop service if no widgets present and preference updated
  •DvTonder - Update AndroidManifest.xml
  •DvTonder - No need for the summaries, remove
  •DvTonder - Strings cleanup
  •DvTonder - Convert to preference fragments
  •DvTonder - CyanogenMod-ify
  •DvTonder - Start of new fragments based preferences
  •DvTonder - Code cleanup
  •DvTonder - General layout related changes and fixes
  •DvTonder - Add clock font scaling
  •DvTonder - Add clock and calendar click actions
  •DvTonder - Add the ability to force a weather refresh if needed
  •DvTonder - Let the calendar panel show user clicks
  •DvTonder - General cleanup
  •DvTonder - Make the weather panel check if it has enough space to display and hide if not
  •DvTonder - Cleanup
  •DvTonder - Set weather preference defaults
  •Danesh Mondegarian - Widget calendar dynamic visibility
  •DvTonder - Add widget size checking
  •Danesh Mondegarian - Metric preference fixes
  •DvTonder - Add ability to show up to a defined maximum (currently capped at 3) calendar events
  •DvTonder - MInor cleanup and proper settings defaults
  •Danesh Mondegarian - More cleanup
  •DvTonder - Start of changing the preference storage handling
  •Danesh Mondegarian - Change clock font type
  •Danesh Mondegarian - Cleanup and update on change
  •DvTonder - Update ap name string
  •DvTonder - Create README.md
  •DvTonder - Fix showing available calendars
  •DvTonder - Cleanup
  •DvTonder - Add Calendar support and some general cleanup of copyrights
  •DvTonder - Add Alarm display handling
  •DvTonder - Add widget preferences
  •DvTonder - Change widget UI to update every 60 seconds
  •DvTonder - Initial commit
CyanogenMod Project name: recovery
  •Koushik Dutta - Do not attempt to back up .android_secure if it is on /data/media
  •Koushik Dutta - 6.0.2.6
  •Koushik Dutta - nandroid: Fix nonexistent backup format type bug.
  •Koushik Dutta - 6.0.2.5
  •Ben Cheng - Fix a trivial signed vs unsigned comparison for gcc 4.7.
  •Steve Kondik - Don't build when variant is requested.
  •Steve Kondik - audio: Don't build if TARGET_QCOM_AUDIO_VARIANT is set
CyanogenMod Project name: android_hardware_qcom_audio-caf
  •Alexy Joseph - alsa_sound: Issue with seek and write
  •Amal Paul - alsa_sound: Fix for, "Music getting played after onpausetimeout"
  •Vidyakumar Athota - alsa_sound: Fix for MO call delay during LPA playback
  •Vidyakumar Athota - alsa_sound: Fix for device switch crash
  •Mike Kasick - alsa_sound: Add support for "Voice Earpiece Extra Gain" mode
  •Steve Kondik - alsa_sound: Add support for Audience A2220
  •Steve Kondik - alsa_sound: Shush more logspam
  •Steve Kondik - alsa_sound: Disable the qcom.audio init check
  •Vidyakumar Athota - alsa_sound:Resample proxy ouput for other than 48KHz samplerate
  •Steve Kondik - audio: Shush noisy logging
  •Steve Kondik - audio: Fix separated audio input support
  •Steve Kondik - audio: Enable low-latency audio via board flag.
  •Steve Kondik - audio: Only build when TARGET_QCOM_AUDIO_VARIANT=caf
  •Steve Kondik - audio: Dynamic library loading, compilation fixes.
  •Mingming Yin - audio: Fix for TTY mode parameter values in HAL
  •Mingming Yin - audio: Fix for usb headset recording issue
CyanogenMod Project name: android_hardware_qcom_display-caf
  •Steve Kondik - hwcomposer: Disable MDP_BACKEND_COMPOSITION for video
  •Naseer Ahmed - hwc: Retry vsync on EBUSY
  •Amara Venkata Mastan Manoj Kumar - hwc: Handle ext display device conn/disconn requests
  •Naseer Ahmed - hwc: Support swap interval zero
  •Mathew Karimpanal - libcopybit: Correct AOSP license marking.
  •Steve Kondik - overlay: Bring back debug.mdpcomp.maxlayer
  •Steve Kondik - Update include paths
  •Steve Kondik - Only build CAF display variant when requested.
  •Naseer Ahmed - hwc: Fix issue with Layercache
  •Naseer Ahmed - gralloc: Mark framebuffer as ION memory
  •Naseer Ahmed - hwc: User Layercache for external display
  •Mathew Karimpanal - display: Standardize log-tags for qcom display logs.
  •Sushil Chauhan - display: Add target specific flag to support Venus color format
  •Ken Zhang - overlay: Do not unset overlay for MSMFB_NEW_REQUEST
  •Ken Zhang - hwc: Remove buffer_fence definition as it is not used
  •Naseer Ahmed - external: memset commit struct
CyanogenMod Project name: android_hardware_qcom_media
  •Steve Kondik - media: Compensate for alternate display variant
  •Srinu Gorle - mm-core: Adds support for encryption type request.
  •vivek mehta - DivxDrmDecrypt: Export the headerinclude file
  •vivek mehta - mm-core: Add QC specific MetaData and MediaDefs
  •Eric (Quic - mm-core: remove duplicate color format enum
CyanogenMod Project name: libhardware_legacy
  •Mingming Yin - audio: Add support for QCOM audio devices, formats, and channels
  •Ricardo Cerqueira - audio_policy: Fix volumes for ICS blob compat
  •codeworkx - wifi: fix samsung wifi logic
  •Steve Kondik - wifi: Add support for AP module args
  •Steve Kondik - Revert "Change-Id: Ie2dcf87494c71d6da9493eddad8fe0a59ac5f0f9"
  •Mingming Yin - audio: add support for VOIP
  •Andrew Dodd - gralloc: Add missing GRALLOC_USAGE_HW_FIMC1 logic
  •Koushik Dutta - mkvendor.sh: fixes for Android 4.2.
  •Koushik Dutta - makerecoveries.sh: Fix up some error reporting. Have errors return a non-zero return value for scriptage.
  •Koushik Dutta - echo args
  •Koushik Dutta - fix rc file for charge mode
  •Koushik Dutta - Add initial support for charge mode. also support recovery/root in the device tree to easily copy props into recovery images.
  •Koushik Dutta - zte prefix. really need to fix this code.
  •Koushik Dutta - override ro.build.date.utc for recovery builds. fixup makerecoveries.sh script for touch recoveries.
  •Bajee11 - Do not build Launcher2
  •Ying Wang - Split to multiple bash commands.
  •David Ferguson - build: work around missing readlink -f on Mac
  •Chirayu Desai - envsetup: set OUT_DIR to an absolute path always
  •Steve Kondik - build: Add board platforms to qcom_utils
  •Koushik Dutta - SignApk: setLevel(9) should be called on APKs and not OTAs.
  •Koushik Dutta - SignApk: perform the whole file signature in a single streaming pass.
  •xoomdev - Re-add AOKP LatinIME
CyanogenMod Project name: android_kernel_samsung_d2
  •Padmanabhan Komanduru - msm_fb: Use an exclusive semaphore for Vsync IOCTL
  •Henrik Rydberg - Input: Send events one packet at a time
  •Steve Kondik - Revert "USB: Prevent system suspend when HSIC device is active"
  •Steve Kondik - d2: Increase size of ION AUDIO carveout to 5MB
  •Girish Mahadevan - msm: event_timer: Fix potential race condition
  •Colin Cross - hardlockup: detect hard lockups without NMIs using secondary cpus
  •Steve Kondik - video: msm: Initialize screeninfo in pan_display
  •Pavankumar Kondeti - USB: Prevent system suspend when HSIC device is active
  •Pavankumar Kondeti - USB: Allow skipping device resume during system resume
  •Oliver Neukum - USB: code cleanup in suspend/resume path (3rd try)
  •Shareef Ali - d2: update to uscc lk5 kernel sources
  •Arianna Avanzini - block: introduce the BFQ-v5r1 I/O sched for 3.0
  •Arianna Avanzini - block: cgroups, kconfig, build bits for BFQ-v5r1-3.0
  •Arianna Avanzini - block: prepare I/O context code for BFQ-v5r1 for 3.0
  •Shareef Ali - d2: add d2cri support to kernel
  •Steve Kondik - d2: Disable the pmem_audio devices
  •Vidyakumar Athota - ASoc-msm: Modify ASM drivers to invoke ION APIs
  •Steve Kondik - Revert "msm_fb: display: remove background invert alpha option for alpha drop pipe"
  •Steve Kondik - Revert "msm_fb: display: add per stage alpha drop detection"
  •Steve Kondik - video: msm: Add missing perf update in pipe commit
  •Shubhraprakash Das - msm: kgsl: Remove extra interrupts when setting MMU state
  •Jordan Crouse - msm: kgsl: Make the GPU device aware of the next pending event
  •Carter Cooper - msm: kgsl: Remove last_expired_ctxt_id
  •Carter Cooper - msm: kgsl: Disable clock gating earlier during snapshot
  •Harsh Vardhan Dwivedi - msm: kgsl: Remove incorrect check for current context
  •Ken Zhang - msm: display: sync point error handling
  •Todd Poynor - cpufreq: interactive: adjust load for changes in speed
  •Arik Nemtsov - nl80211: Add probe response offload attribute
  •Mingming Yin - ASoC: msm: Fix for a seekbar issue during audio playback.
  •Jay Wang - ASoC: msm: qdsp6: Fixed the volume command timeout issue
  •Jay Wang - ASoC: msm: qdsp6: Fixed the issue unmap command is sent incorrectly
  •Srinu Gorle - msm: vidc: Avoid memset of list elements in the buffer entry.
  •Steve Kondik - Revert "msm_fb: Clear real pipe attributes in the pipe free"
  •Mayank Goyal - msm: rotator: Add pseudo-planar 422 H1V2 dst format for MDP4
  •Steve Kondik - video: msm: Enable pixel repeat in X direction
  •Huaibin Yang - msm_fb: display: fix frame rate wrong calculation
  •Jay Chokshi - msm: Ensure krait pll clamp is always set for CPU0
  •Russell King - ARM: decompressor: avoid speculative prefetch from non-RAM areas
  •Stepan Moskovchenko - msm: platsmp: Update Krait reset sequence
  •Jay Chokshi - msm: Ensure droop detectors do not affect krait PLLs
  •Carl Vanderlip - msmfb: Add Enable/Disable flag definition
  •Padmanabhan Komanduru - msm_fb: Add histogram support for MPQ 8064
  •Carl Vanderlip - video: msm: Finish histogram collection framework for MDP blocks
  •Carl Vanderlip - video: msm: Remove an ifndef from mdp_isr
  •Shruthi Krishna - Update the display board file to reflect the correct MDP revision.
  •Ken Zhang - video: msm: Add logical display id for post processing
  •Carl Vanderlip - video: msm: Handle MDP_REV_43 MDP identity
  •Srinu Gorle - msm: Add switch node mechanism for wfd
  •Srinu Gorle - video: msm: wfd: Send signal HDMI observer to mirror on  FB2.
  •Deva Ramasubramanian - video: msm: wfd: Don't signal HDMIDaemon to mirror on FB1
  •Shruthi Krishna - msm_fb: display: add wfd clk ctrl in pipe_commit
  •Stephen Boyd - msm: Remove idle stats and cpuidle hooks
  •Anji Jonnala - msm: cpuidle: Update C state time stats in the cpu idle device.
  •Stephen Boyd - msm: cpuidle: Don't disable irqs again
  •Narayanan Gopalakrishnan - msm: cpufreq: increase priority of thread that increases frequencies
  •Praveen Chidambaram - msm: cpufreq: Add API to allow limiting of min and max cpu frequencies
  •Huaibin Yang - msm_fb: display:  add mdp bandwidth runtime calculation
  •Steve Kondik - video: msm: More cleanups
  •Huaibin Yang - msm_fb: display: add iommu mapping for mdp cursor buffer address
  •Steve Kondik - d2: Update defconfigs
  •Ken Zhang - msm: display: Clear performance request data in turning on
  •Steve Kondik - msm: display: Remove dead code
  •Steve Kondik - HACK: Don't return ENOTSUPP for register_beacons call
  •Steve Kondik - bcmdhd: Fix mismerge
  •Dmitry Shmidt - net: wireless: bcmdhd: Update wireless stack pm mode
  •Dmitry Shmidt - net: wireless: bcmdhd: Fix host reodering and CRC error handling
  •Dmitry Shmidt - net: wireless: bcmdhd: Fix compilation without SUPPORT_PM2_ONLY
  •Dmitry Shmidt - net: wireless: bcmdhd: Turn ON SUPPORT_PM2_ONLY
  •Dmitry Shmidt - net: wireless: bcmdhd: Reduce keep-alive period to 28 sec
  •Dmitry Shmidt - HACK: net: wireless: bcmdhd: Skip freeing skb in case of FW hang
  •Dmitry Shmidt - net: wireless: bcmdhd: Add sync for wlfc data access
  •Dmitry Shmidt - net: wireless: bcmdhd: Skip turning chip off if not responding
  •Greg Goldman - net: wireless: bcmdhd: Propagate FW failure to upper layer
  •Dmitry Shmidt - net: wireless: bcmdhd: Increase scan unassoc active time to 80 ms
  •Dmitry Shmidt - net: wireless: bcmdhd: cfg80211 fixes
  •Dmitry Shmidt - net: wireless: bcmdhd: Protect dhd_wlfc_cleanup() call
  •Dmitry Shmidt - net: wireless: bcmdhd: Update to version 1.28.13-1
  •Dmitry Shmidt - net: wireless: bcmdhd: Adjust roaming treshold to -65 dB
  •Dmitry Shmidt - net: wireless: bcmdhd: Fix wldev_ioctl set parameter
  •Dmitry Shmidt - net: wireless: bcmdhd: Update wifi stack ps state if was changed
  •Dmitry Shmidt - net: wireless: bcmdhd: Adjust PS mode if we are in 'suspend'
  •Dmitry Shmidt - net: wireless: bcmdhd: Add print when power-save mode is OFF
  •Dmitry Shmidt - net: wireless: bcmdhd: Update to Version 1.28.12-1
  •Steve Kondik - bcmdhd: Underp DOS line endings
  •Steve Kondik - Relocate bcmdhd drivers.
  •Shareef Ali - d2: rename d2usc to d2-r530
  •Ajay Dudani - msm: rq_stats: Support to know cpu utilization in userspace
  •Stephen Boyd - msm: rq_stats: Fix lockdep warnings with key's not in .data
  •Todd Poynor - cpufreq: interactive: pin timers to associated CPU
  •Mayank Chopra - msm: rotator: Add pseudo-planar 422 H1V2 dst format for MDP4
  •Mayank Chopra - msm_fb: display: Program source address registers correctly
  •Mayank Chopra - msm_fb: display: Add pseudo-planar 422 H1V2 support in the MDP4
  •Steve Kondik - video: msm: Remove dead code
  •Ajay Singh Parmar - msm_fb: hdmi: black out pipes on unset
  •Steve Kondik - bcmdhd_samsung: Fix non-modular build
  •Naseer Ahmed - msm_fb: display: blt always enabled for 720p,1080p, secure buf
  •Steve Kondik - video: msm: Remove BLT mode check for new requests
  •Steve Kondik - d2: Update and regenerate D2 defconfigs
  •Steve Kondik - docs: Remove stray file
  •Steve Kondik - Quiet down some noisy logs
  •Dmitry Shmidt - net: wireless: bcmdhd: Skip scan params allocation in timeout
  •H Hartley Sweeten - lib/sha1.c: quiet sparse noise about symbol not declared
  •Linus Torvalds - arm: remove "optimized" SHA1 routines
  •Mandeep Singh Baines - lib/sha1: use the git implementation of SHA-1
  •Anji Jonnala - cpufreq: ondemand: Fix kernel warning in cpufreq_governor_dbs
  •Narayanan Gopalakrishnan - ondemand: Add support to consider other cpu load when scaling frequencies
  •Stephen Boyd - cpufreq: Avoid using smp_processor_id() in preemptible context
  •Shubhraprakash Das - lib: genalloc: Change chunk allocation to vmalloc
  •Huaibin Yang - msm_fb: display: change the location of wakeup timer call
  •Ken Zhang - msm_fb: display: wake up system around vsync
  •Jeevan Shriram - msm_fb: display: Add support for vsync driven composition on 7x30
  •Siddhartha Agrawal - msm_fb: display: Removing extra disable irq in cmds_rx API's
  •Kuogee Hsieh - msm_fb: display: Do not use ION_IOMMU_UNMAP_DELAYED
  •Kalyan Thota - msm_fb: commit mixer stage for WFD during unset
  •Mayank Chopra - msm_fb: display: Add alpha enable check in blend
  •Mayank Chopra - msm_fb: display: Fix blend configuration for command mode panels
  •Ajay Singh Parmar - msm_fb: display: Proper pipes solidfill
  •Huaibin Yang - msm_fb: display: skip one vsync event after enabling mdp and vsync clk
  •Ajay Singh Parmar - msm_fb: display: Correct dtv pipe black out
  •Prasad Sodagudi - video: msm: Do not use disable_irq in the spin_lock_irqsave context
  •Carl Vanderlip - video: msm: Remove adjustment to MDP revision
  •Carl Vanderlip - video: msm: Send ETIMEDOUT on update-notify timeout
  •Kinjal Bhavsar - msm_fb: display: Add timeout for waiting on update
  •Kalyan Thota - msm_fb: configure LM1 and LM2 CSC coefficients with RGB2YUV for WFD
  •Kalyan Thota - msm_fb: Retain CSC values across suspend/resume sequence
  •Carl Vanderlip - video: msm: Enable mdp clock for histogram and histLUT
  •Carl Vanderlip - video: msm: Ensure idle state before enabling histogram
  •Carl Vanderlip - video: msm: Defer histogram reset to workqueue
  •Carl Vanderlip - video: msm: Dynamically toggle histogram interrupt
  •Carl Vanderlip - video: msm: Move histogram disable to before panel off
  •Naseer Ahmed - msm: display: non-blocking for overlay update
  •Kuogee Hsieh - msm_fb: display: delete dsi clock control from cmdlist_commit
  •Girish Mahadevan - msm: pm: Adjust for events with hard wakeups
  •Girish Mahadevan - msm: event_timer: Support to add event timers.
  •Vikram Mulukutla - iopoll: Introduce the readl_iopoll_timeout_noirq macro
  •Matt Wagantall - iopoll: Tweak min sleep time used with usleep_range()
  •Matt Wagantall - iopoll: Introduce memory-mapped IO polling macros
  •Steve Kondik - video: msm: Fix mismerge
  •Kuogee Hsieh - msm_fb: display: add wait4videodone for video mode
  •Kuogee Hsieh - msm_fb: display: force mdp clock off at suspend
  •Kuogee Hsieh - msm_fb: display: fix dsi_busy_wait race condition
  •Kuogee Hsieh - msm_fb: display: add video mode dcs cmdlist support
  •Kuogee Hsieh - msm_fb: display: add sysfs and clock control to smart panel
  •Pradeep Jilagam - msm_fb: display: Fix blend configuration for MDP4.1
  •Steve Kondik - Merge Samsung changes from T999 source drop.
  •Huaibin Yang - msm_fb: display: add config of wb_mux_sel during update
  •Huaibin Yang - msm_fb: display: empty pending queue during suspend for wfd
  •Kalyan Thota - msm_fb: Wifi display changes for commit ioctl
  •Kuogee Hsieh - msm_fb: display: empty pending queue during suspend
  •Kuogee Hsieh - msm_fb: display: wfd with vsync driven frame push
  •Ajay Dudani - msm_fb: Add option to enable/disable mixer commit
  •Naseer Ahmed - msm_fb: display: fix dsi controller hang up during blt enable/disable
  •Naseer Ahmed - msm_fb: display: Fix flickering when BLT is enabled/disabled
  •Naseer Ahmed - msm_fb: display: add options to switch blt mode for dsi video
  •Steve Kondik - video: msm: Remove BLT_MODE_CHANGE_ISSUE
  •Iliyan Malchev - msm_fsb: handle pipe-allocation errors
  •Kuogee Hsieh - msm_fb: display: add stage commit before kickoff to WFD
  •Ken Zhang - msm_fb: display: mdp4 version assigned at board file
  •Naseer Ahmed - msm_fb: display: add per stage alpha drop detection
  •Naseer Ahmed - msm_fb: display: remove background invert alpha option for alpha drop pipe
  •Naseer Ahmed - msm_fb: display: Consolidate commit ioctls
  •Devin Kim - msm: display: check get_unused_fd_flags return val
  •Ken Zhang - msm: display: Increase timeout value for fence waiting
  •Steve Kondik - d2: Import FMEM changes to board files
  •Steve Kondik - fmem: Use alignment property from platform data
  •Larry Bassel - FMEM: allocate non-fixed FMEM from memory pool
  •Larry Bassel - fmem: add missing zcache_put after zcache_get
  •Larry Bassel - fmem: hotplug notifier should do nothing if fmem is inactive
  •Larry Bassel - fmem: interact properly with DMM
  •Shareef Ali - d2: improve modem stability across all devices.
  •nebkat - n7100: CONFIG_USE_FIMC_CMA
  •Andrei F - exynos-mem: Add fimc1 to mmap whitelist check
  •Andrei F - exynos-mem: Fix major security hole
CyanogenMod Project name: android_kernel_samsung_smdk4210
  •R. Andrew Ohana - i815: enable USB3503 driver
  •R. Andrew Ohana - add USB3503 driver for the p8lte board
  •Bajee11 - Update buildscript
  •Bajee11 - Disable i9100p Nightlies and include i9300.
  •Bajee11 - Making things easier.
  •Bajee11 - Remove andro for releases and make some minor changes.
  •Bajee11 - Update package name for each device.
  •Shawn Pearce - Support resolving relative fetch URLs on persistent-https://
RootBox Project name: platform_manifest
  •Bajee11 - Track own Phone package
  •Bajee11 - Track AOKP DownloadProvider
  •Bajee11 - Update branch in README
  •Bajee11 - Add smdk4412-common and grouper repos
  •Bajee11 - Track CM omap4
  •Bajee11 - Derp
  •Roman Birg - track own frameworks_rs; fix lwp
  •Bajee11 - Track some CM repos.
  •Bajee11 - Track CM Trebuchet Launcher
  •Bajee11 - Track CM LockClock
  •Bajee11 - Tracking changes
  •Bajee11 - Include N7000
  •Bajee11 - Derp
Aktuell kein PDroid-Patch, da der aktuelle Auto-Patcher noch nicht zu 4.2.x kompatibel ist.
Custom Rom: RootBox 3.2
Hab das handy eben neu aufgespielt, also die Custom Rom neu drauf gemacht. Jetzt verbindet das FAQ Handy nicht mehr mit dem PC. Keinen Zugriff auf die Speicherkarte, nix. Kies bringt auch nix.
Ich schmeiß das Teil gleich an die Wand, hab gleich ne lange Zugfahrt vor mir und brauch Musik! Bitte helft mir...
Dass Kies nur mit einem OS von Samsung funktioniert ist weder neu noch verwunderlich. Also kannst Du Dir diesbezügliche Versuche ersparen.
Was hast Du denn nun alles getan um Dein S2-G wie mit dem großen Computer zu verbinden? Welchen Kernel verwendest Du?
Thread abzugeben, wer möchte?
gerne doch :)
Sehr schön. Bekommst du das hin, den OP aktuell zu halten und neue Versionen auf Patcher-Kompatibilität zu testen? Und ggfs. auch von mir erstellte Builds zu testen (besteht noch Interesse an aktuellen Nightlies mit OpenPDroid?) und die im OP einzupflegen? Dann geb ich email Bescheid, damit er den Thread an dich abgibt. Ich hab nämlich mein S2G zur Zeit verliehen und kann daher selber nix mehr testen. :)
okay, soviel aufwand betreibe ich dann doch nicht, mit dem geteste undco, dazu hab ich atm durch das extrem viele arbeiten keine zeit. :/
v3.8
Code:
  •olivergeith - Fix Quiet Hours icons
  •Daniel - Sleep Tile
  •olivergeith - Change QuietHours Icons
  •drcmda - PIE: narrow down inner arcs for even gaps
  •drcmda - PIE: option for Pie to maintain its position, disregarding orientation changes (useful for gaming)
  •drcmda - hardware rendering for statusbarmanager and pie
  •kecinzer - FW: Updated czech translation
  •rdgate - Updated Japanese translations
  •minuteZERO - PowerMenu: Security Feature (Toggle) to Hide Reboot (reboot recovery) 2/2
  •Peter Gregus - Profile Tile: fix reboot when activating Profile Tile We need to create GlobalActions dialog and its handlers prior to opening Profile select dialog. Otherwise NPE caused by uninitialized handlers occurs causing soft-reboot.
  •Michele Primavera - Allows notification behiavour selection
  •D4rKn3sSyS - Lockscreen see through (1/2)
  •Bajee11 - Fix some stuff in Profile Tile
  •sbrissen - Workaround until gps can be fixed, force gps to stay in standalone mode when ro.agps.allow=false
  •jt1134 - SystemUI: highlight quick settings and notification clear buttons
  •StevenHarperUK - Bugfix : Quick pulldown sometimes flips when it should not
  •drcmda - Policy: fix keyguard statusbar showing while in ext desktop, fixes it in apps like currents as well
  •drcmda - PIE: animation revamped (back to the first draft), style changes
  •Peter Gregus - Low battery warning policy (1/2) Option to choose how low battery warning will be indicated - Popup dialog and sound - Popup dialog only - Sound only - Off
  •Stevespear426 - AwesomeAction: Performance update
  •olivergeith - Sound Toggle: Improve logic with new icons.
  •Jubakuba - SwaggerTile: Added Swagger - SundaysFTW
  •Dirk Rettschlag - Quicksettings: fix updating 2G,LTE and WifiTether tiles
  •Matanya Elchanani - QuickSettings: fix GPS graphic state logic
  •Bajee11 - QuietHours: Y U NO REFRESH!
  •Bajee11 - RootBox Toggle (1/3)
  •Bajee11 - Derp Profile Tile
  •Bajee11 - Option to disable fullscreen keyboard
  •Sven Dawitz - Changed profile selection to single-tap action
  •Bajee11 - Profiles Toggle: Long press toggle for Profiles Settings
  •Zaphod - Fix Searchlight showing under NavBar at Lockscreen
  •DvTonder - Framework: Forward port the ability to enable/disable keyguard with Profiles
  •Robert Burns - Fix lock screen timeouts
  •Bajee11 - Fix Sound/NavBar Holo toggle - Update WiFi/Signal icons
  •Jubakuba - Framework: QuickRecord Tile (2/3)
  •Zaphod - Fix NavButton AlphaGlow when pressed
  •kecinzer - Fix longpress action for tehter toggles
  •Dirk Rettschlag - Lockscreen: allow widgets to use more space on tablets (1/2)
  •kecinzer - Fix Transparency Value not sticked with autohide
  •Dirk Rettschlag - Lockscreen: remove mAppWidgetContainerHidden instead of hiding it
  •drcmda - PIE: style
  •drcmda - PIE: better looking snappoints, reorientation bug
  •Dirk Rettschlag - SystemUI: unregister ContentObserver
  •Pawit Pornkitprasan - policy: always use hardware acceleration for keyguard
  •Stevespear426 - Lockscreen Targets: Icon Revamp
  •Danesh Mondegarian - LockscreenTargets : Dismiss on target select
  •Jorge Ruesga - Keyguard: Reduce font size of clock in status keyguard (sw720dp) (portrait)
  •Espen Fjellvær Olsen - Fix Quiet Hours not muting notification sounds
  •Dirk Rettschlag - fix framworks/base after 4.2.2 merge
  •vivek mehta - libstagefright: Check for duration > 0 to avoid DivideByZero crash
  •Amal Paul - audioflinger: Fix to set correct volume in Tunnel playback
  •Shalaj Jain - libstagefright: Add support for frame-by-frame mode
  •ApurupaPattapu - ACodec: Support for dynamic port reconfig
  •Ajit Khare - libmediaplayerservice: Add new player for DASH
  •Mingming Yin - audio: apply volume on DirectOutput streams
  •Haynes Mathew George - libstagefright: Adjustment for TunnelPlayer buffer size
  •Giulio Cervera - fmradio: use caf naming
  •Giulio Cervera - QualcommSharedRIL: allow skipping pin/puk count
AOKP Project name: device_lge_mako
  •Jonathan Steadman - mako: enable krait optimizations
  •Ricardo Cerqueira - Add mako's audio package
  •Ricardo Cerqueira - Remove OLD_ION flag
  •Iliyan Malchev - mako: enable pre-rotation
  •Gergely Szell (sethyx) - Fix mako build - changes for 4.2.2
  •Ricardo Cerqueira - Remove test/debug props taken out of 4.2.2
  •R. Andrew Ohana - add widevine to proprietary-blobs
CyanogenMod Project name: android_device_samsung_omap4-common
  •Andrew Jiang - omap4-common: Consolidate CPU configs & opt-in to bionic optimizations
  •codeworkx - initial commit
RootBox Project name: device_samsung_tuna
  •Gergely Szell - tuna: Inline kernel building - from AOSP
  •codeworkx - i9100g: camera: fix copy & paste fail
  •codeworkx - i9100g: use omap4-common repo, samsung jb update
  •codeworkx - i9100g: update smc service
  •codeworkx - i9100g: add cpboot-daemon service, update extract script
RootBox Project name: device_samsung_d2-common
  •Araemo - Re-Add USB Dock audio output devices to policy
  •meviox - Settings: Fix a typo in the German translation
  •pvolkov - Update Russian Translation-Galaxy S II Settings-CM10.1
  •codeworkx - i9100: keyfiles and extract cleanup
  •Espen Fjellvær Olsen - Update focus behaviour to match Samsungs
  •Espen Fjellvær Olsen - galaxys2: camera: code cleanup, higher min buffer count
  •angelsl - galaxys2-common: Use open source libsecion.
  •Espen Fjellvær Olsen - Add another success header
  •codeworkx - galaxys2: camera hal updates from paulk
  •codeworkx - galaxys2: update for new kernel, cleanup, replicant camera hal
  •codeworkx - galaxys2: remove legacy egl hack
  •Andrew Dodd - Disable fimgapi
  •codeworkx - galaxys2: camera have iso
RootBox Project name: device_samsung_t0ltecdma
  •sbrissen - T0ltecdma: fix speaker not working after being on bt
  •Bajee11 - Fix headset mic volume
  •sbrissen - t0ltecdma: Fix switching incall devices
  •sbrissen - t0ltecdma: fix incall bt audio quality
  •sbrissen - t0ltecdma: adjust capture period size and count
RootBox Project name: device_samsung_msm8960-common
  •Steve Kondik - msm8960: Update headers to match kernel
RootBox Project name: device_samsung_n7100
  •kristof.petho - Fix audio recording on N7100
  •kristof.petho - N7100: Fix incall BT audio and cleanup
  •codeworkx - smdk4412: camera: fix copy & paste fail
  •codeworkx - smdk4412: use opensource libsecion
  •codeworkx - smdk4412: remove legacy egl hack
  •codeworkx - i9300: add support for SlimISP_ZH camera fw
  •codeworkx - i9300: fix speaker not working after bt, headset mic
RootBox Project name: device_asus_grouper
  •Stevespear426 - Grouper: Let N7's use neon MEMCPY
  •Gergely Szell - Move kernel definitions into Common (for tilapia)
  •Gergely Szell - grouper: Inline kernel building - from AOSP
AOKP Project name: vendor_lge
  •Ricardo Cerqueira - mako: Updated to 4.2.2 binaries
RootBox Project name: vendor_samsung
  •codeworkx - smdk4412: cleanup
  •codeworkx - galaxys2: use opensource libsecion
  •codeworkx - galaxys2: update mali to r3p1-01rel1
  •codeworkx - smdk4412: update mali to r3p1-01rel1
  •codeworkx - smdk4412: use mr0 hostapd
  •codeworkx - galaxys2: use mr0 hostapd
  •codeworkx - i9100g: use mr0 hostapd
  •Bajee11 - Update quincyatt blobs
  •Bajee11 - Cleanup: Remove unsupported devices blobs
  •Bajee11 - Update N7000 blobs (JB)
  •Bajee11 - Update i9100 blobs (JB)
  •Gergely Szell (sethyx) - tuna: Update to 4.2.2 props - maguro/toro/toroplus
  •Shareef Ali - d2: adreno blobs update from 4.2.2
  •Bajee11 - Add Adrenoblobs 4.2
  •codeworkx - smdk4412: dont use prebuilt hostapd, keyfiles cleanup
  •codeworkx - i9100g: update blobs from LSD, add omap4 common blobs
  •codeworkx - i9100g: update ril from LSD
RootBox Project name: vendor_rootbox
  •dhacker29 - Update SuperSU and su to latest version
  •Bajee11 - Enable Sleep Tile for all devices
  •Bajee11 - Remove redundant  apns-conf.xml copy
  •Bajee11 - Build RootBox Wallpapers
  •Bajee11 - Add RootBox Toggle for all devices
  •Jubakuba - Vendor: QuickRecord Tile (1/3)
  •Dirk Rettschlag - Lockscreen: allow widgets to use more space on tablets (2/2)
  •Bajee11 - Add Maguro Support (1/2)
  •Gergely Szell (sethyx) - Update mako fingerprint
  •Bajee11 - Show some love to Nexus 7 - Add a few RC Toggles
RootBox Project name: vendor_asus
  •Gergely Szell (sethyx) - grouper/tilapia: Update to 4.2.2 props
CyanogenMod Project name: android_vendor_tmobile_providers_ThemeManager
  •Marco Brohet - ThemeManager: Indonesian translations
AOKP Project name: themes-platform-vendor-tmobile-apps-ThemeChooser
  •YULIANGMAX - Updated simplified Chinese translations
  •Bajee11 - Revert "FM Radio: Add support for FM Radio in Android"
CyanogenMod Project name: bionic
  •Steve Kondik - libc: Fix invalid macro
  •Dirk Rettschlag - libc: Add optimized strcmp
  •Ricardo Cerqueira - msm: vidc: Add the support for MPEG-2 extension and user data
  •Kito Cheng - Bionic/libm: Fix the mismatch ENTRY/END in e_pow.S
  •Steve Kondik - libc: Remove Scorpion memmove() routine
  •Steve Kondik - libc: Add ARMV7 optimized memchr()
  •Steve Kondik - libc: Add optimized memcpy for Cortex-A15
  •Steve Kondik - libc: Enable the fast memmove for NEON targets
  •Steve Kondik - Revert "Add optimized version of memcpy for Cortex A9"
  •Steve Kondik - libm: Check for NEON support when choosing fast pow()
  •Steve Kondik - libc: Add ARCH_ARM flags to enable new optimizations
  •Steve Kondik - libm: Enable fast NEON pow() for supported targets
  •Henrik Smiding - Add optimized version of memcpy for Cortex A9
  •Elliott Hughes - Add a memmove(3) benchmark.
  •Elliott Hughes - Simple google3-compatible benchmarking.
  •Nick Kralevich - FORTIFY_SOURCE: optimize
  •Nick Kralevich - fix strerror_r test
  •Nick Kralevich - Add stack canaries / strcpy tests.
  •Elliott Hughes - glibc 2.15 treats errno as signed in strerror(3).
  •Anna Tikhonova - Tests for string routines.
  •Henrik Smiding - Add optimized version of memcmp for Cortex A9
  •Steve Kondik - Revert "memcmp: prefetch optimizing for ARM Cortex-A8/A9"
  •Henrik Smiding - Add optimized version of memset for Cortex A9
  •Nick Kralevich - FORTIFY_SOURCE: remove memcpy overlap checks
RootBox Project name: RootBox_wallpapers
  •Bajee11 - Switch to RootBox Wallpapers
AOKP Project name: packages_apps_Nfc
  •Jonathan Steadman - fix nfc after 4.2.2 merge
RootBox Project name: packages_apps_Camera
  •jt1134 - HDR: only show slide animation after final shot
  •Ricardo Cerqueira - Util: Disable software HDR if the camera HAL actually supports it
  •XpLoDWilD - camera: SoftHDR: Use parallel processing
  •XpLoDWilD - Camera: SoftwareHDR: Reduce mem usage and let exposure time get tuned
  •XpLoDWilD - [1/2] Camera: add software HDR rendering
  •maxwen - fix for correct handling of video snapshot feature
RootBox Project name: packages_apps_Settings
  •Bajee11 - Pie: Stick Orientation
  •Kroz - RB Settings: Icons for Lockscreen Seethrough & Notification Behaviour
  •Bajee11 - Allows notification behiavour selection
  •Bajee11 - RB Settings: Lockscreen See Through
  •Bajee11 - RB Settings: Do not show some options for Nexus devices.
  •Peter Gregus - Low battery warning policy (2/2)
  •Bajee11 - Fix lockscreen delay stuck at 5 seconds for Pattern/Pin/Password Lock
  •Bajee11 - RootBox Toggle (2/3)
  •Kroz - RB Settings: Change icons for Volume Cursor/Fullscreen Keyboard/CRT
  •Bajee11 - Move volume control cursor to RB Settings
  •Bajee11 - RB Settings: Option to disable fullscreen keyboard
  •Bajee11 - Add Profiles in Manifest
  •Bajee11 - RB Settings: Fix lockscreen delay stuck at 5 seconds.
  •Bajee11 - Move profiles under Personal header
  •Bajee11 - Fix Pattern Lock FC
  •Bajee11 - RB Settings: LCD Density Changer
  •Bajee11 - Fix Phone Settings FC
  •Dirk Rettschlag - Custom vibration per contact
  •jared waters - Mms: adds the option to hide sprints vm text messages, but still allows sprints vvm to receive messages.
  •Jonathan Steadman - fix mms after 4.2.2 merge
RootBox Project name: packages_apps_Gallery2
  •XpLoDWilD - [2/2] Camera: add software HDR rendering
AOKP Project name: packages_apps_Contacts
  •Danny Baumann - Fix call grouping.
  •Dirk Rettschlag - fix contacts after 4.2.2 merge
CyanogenMod Project name: android_packages_apps_Calculator
  •Veeti Paananen - Move the window background to the activity theme
  •Francesco - Calculator: Update italian translation
  •Will - Calculator bugfixes
  •Will - Calculator: New Features Part 3
  •Marco Brohet - Calculator: Indonesian translations
AOKP Project name: packages_apps_PerformanceControl
  •YULIANGMAX - Added simplified Chinese translations
  •Bajee11 - Sleep Tile
  •Dirk Rettschlag - UserInterface: updated logic for initial Allow 180 Rotation check state
  •minuteZERO - PowerMenu: Security Feature (Toggle) to Hide Reboot (reboot recovery) 1/2
  •Dirk Rettschlag - UserInterface: remove vibrate on expand if device has no vibration
  •Bajee11 - RootBox Toggle (3/3)
  •JBirdVegas - Fix AndroidHttpClient leaking connection
  •Jubakuba - ROMControl: QuickRecord Tile (3/3)
RootBox Project name: packages_apps_DeskClock
  •Artem Chep - Added flip and shake to snooze
  •Danny Baumann - Fix layout issues with increasing volume option.
  •Danny Baumann - Fix a number of issues introduced with the increasing volume setting
  •Austen Dicken - DeskClock: Add increasing volume option for alarm clocks
  •Pawit Pornkitprasan - Clock: fix layout for 320dp devices
  •DelPETER - LockClock : add french translation
  •Danny Baumann - Extend maximum look ahead range.
  •elektroschmock - Fix typo.
  •Gustavo - PT-BR: Update translations
  •Nicolai Ehemann - removed hardcoded reference to stock cm calendar app; ask for calendar app instead
  •Matt Mower - UI text corrections
  •Matt Mower - Fix use of TARGET_USE_CUSTOM_LUN_FILE_PATH
CyanogenMod Project name: hardware_qcom_audio-caf
  •Emerson Pinter - alsa_sound: use "Voice Speaker" instead of "Speaker" when in calls
  •Haynes Mathew George - alsa-sound: Adjustment for tunnel mode buffer size
  •Haynes Mathew George - AudioSessionOut: Fix to handle a single write() with an empty buffer
  •Giulio Cervera - fmradio: enable STE radio
  •Saurabh Shah - overlay: Add support for pipe dumps.
  •Saurabh Shah - overlay: Fix rotator output buffer size.
  •Ramkumar Radhakrishnan - display: Do not align down input rotator src height
  •Naseer Ahmed - display: Close 0 fds
  •Sushil Chauhan - libhwcomposer: Only 4 pipes can be used per display for MDP Comp.
  •Steve Kondik - Revert "Revert "libhwcomposer: Don't count video layers marked for SKIP""
  •Steve Kondik - display: Don't enable pixel repeat for YUV buffers
  •Steve Kondik - display: Disable use of copybit temporarily
  •Steve Kondik - Revert "libhwcomposer: Don't count video layers marked for SKIP"
  •Steve Kondik - gralloc: Remove usage of METADATA_SET ioctl
  •Steve Kondik - display: Disable unsupported copybit features
  •Josh Ancill - Fix ION_IOC_MAP error on old ion api during drm video playback
  •Steve Kondik - gralloc: Add TARGET_USES_QCOM_BSP flag for non-AOSP features
  •Naseer Ahmed - hwc: Log if vsync read takes more than 2 expected vsyncs
  •Sushil Chauhan - liboverlay: Fix stride alignment issue for s/w decoded video.
  •Raj kamal - liboverlay: Set mdp src format as rotator output format.
  •Sushil Chauhan - overlay: mdssRot: Do not reset non-rotation flags.
  •Sushil Chauhan - overlay: mdssRot: Fix the logic for setting Rotator info flags.
  •Saurabh Shah - overlay: mdssRot: Fix stale rotation flag values.
  •Sushil Chauhan - liboverlay: Mdss Rotator secure buffer needs to be aligned to 1M.
  •Sushil Chauhan - mdssRotator:For Venus, rotator buffer size depends on rotated w/h
  •Naseer Ahmed - display: Reconcile display HALs
  •Ramkumar Radhakrishnan - libgralloc: Add support for custom buffer size.
  •Sushil Chauhan - display: Add support for Venus color format for newer platforms
  •Ramkumar Radhakrishnan - display: Add display metadata in buffer handle
  •Ramkumar Radhakrishnan - Update buffer dimensions with new dimension
  •Jeykumar Sankaran - Revert "gralloc: Support for old and new ION API"
  •Steve Kondik - display: Add support for MDP 4.1
  •Steve Kondik - gralloc: Fix redefinition of metadata struct
  •Jeykumar Sankaran - hwc: Don't use MDP for buffers of width less than 5
  •Duy Truong - Update copyright to The Linux Foundation
  •Jeykumar Sankaran - libhwcomposer: Don't count video layers marked for SKIP
  •Saurabh Shah - overlay: Remove unnecessary lock.
  •Naseer Ahmed - gralloc: Do not set ION_SECURE for non-contiguous heaps
  •Arun Kumar K.R - libexternal: change the order of ioctl call for HDMI
  •Saurabh Shah - hwc: Call MSMFB_DISPLAY_COMMIT even if FB handle is null.
  •Arun Kumar K.R - display: Add support for overscan compensation for ext display
  •Jeykumar Sankaran - hwc: Pass transform value while cropping dst rect
  •Amara Venkata Mastan Manoj Kumar - hwc: Do not set Secure flags for UI layers
  •Jeykumar Sankaran - libhwcomposer: Allow 2 YUV layer frames to use MDP composition
  •Ken Zhang - external: use metadata ioctl to set vic
  •Sushil Chauhan - hwcomposer: In Mdss,secure content policy applies to layer buffer
  •Sushil Chauhan - display: Use GRALLOC_USAGE_PROTECTED to indicate secure content
  •Sushil Chauhan - liboverlay: Enable secure content flag in Mdss Rotator.
  •Naseer Ahmed - gralloc: Remove update rect
  •Arun Kumar K.R - libexternal: set hw.hdmiON system property
  •Ken Zhang - display: use metadata ioctl to get panel frame rate
  •Praveen Chavan - libgralloc: force 1M alignment for secure buffers
CyanogenMod Project name: android_hardware_qcom_gps
  •Giulio Cervera - qcom/gps: add TARGET_PROVIDES_GPS_LOC_API
  •Ethan Chen - mm-video: venc: always align buffer before ion_map_iommu
  •Arne Coucheron - Add back check for msm7x30 that got lost in merge
  •Steve Kondik - vdec: Add ifdefs to featurize extended user metadata
  •Steve Kondik - Add ifdefs for target-specific and optional features
  •Steve Kondik - Remove dependency on kernel headers
CyanogenMod Project name: android_hardware_libhardware_legacy
  •Giulio Cervera - fmradio: cleanup QCOM_FM_ENABLED/STE_FM defs and ifdef
CyanogenMod Project name: android_hardware_samsung
  •angelsl - exynos4: Add open source libsecion.
  •Steve Kondik - exynos3: power: Tuning and cleanups
  •codeworkx - exynos4: update media headers
RootBox Project name: android_build
  •Bajee11 - Remove gapps version
 Project name: mako
  •Steve Glendinning - usbnet: ratelimit kevent may have been dropped warnings
  •Ming Lei - usbnet: decrease suspend count if returning -EBUSY for runtime suspend
  •Hemant Kumar - net: usb: Define waitqueue head as static global variable
  •Hemant Kumar - net: usb: Handle interface suspend properly
  •motley - net: usb: Abort suspend if get_encap response is not sent
  •Hemant Kumar - net: usb: Prevent suspend if response available notification received
  •Jack Pham - usb: misc: Avoid excessive logging during disconnect
  •Ido Shayevitz - usb: hsic: suspend hsic until really activated by the gadget driver
  •Hemant Kumar - usb: ks_bridge: Fix memory leaks in the driver
  •faux123 - defconfig: updated for "enhanced" stock
  •faux123 - gamma control: fix typo derp :(
  •faux123 - gamma control: add checksum to validate data integrity
  •faux123 - gamma control: fix wip code derps :p
  •faux123 - gamma control: WIP expose gamma parameters to sysfs interface
  •Steve Kondik - Revert wait4vsync changes until panel init sequence is fixed.
  •Steve Kondik - video: msm: Remove timeout from wait4vsync
  •Huaibin Yang - msm_fb: display: get mipi frame rate from panel file
  •Kuogee Hsieh - msm_fb: display: wait4vsync before set suspend flag
  •Kuogee Hsieh - msm_fb: display: wait4vsync after timing generator is turned off
  •Kuogee Hsieh - msm_fb: display: replace msleep with wait4vsync
  •Huaibin Yang - msm_fb: display: check bus scale handler for registration
  •Rajeev Kulkarni - msm: msm_bus: Add support for 64-bit bandwidth requests
  •Kuogee Hsieh - msm_fb: display: clean pipes from commit queue at suspend
  •Steve Kondik - Revert "msm_fb: display: blt always enabled for 720p,1080p, secure buf"
  •Steve Kondik - msm: rotator: Support Fast YUV for 8960, 8064 and 8x30 targets.
  •Huaibin Yang - msm: rotator: clear rotator bus scale handler
  •Steve Kondik - video: msm: Cleanup a bad merge
CyanogenMod Project name: android_kernel_samsung_smdk4412
  •codeworkx - s5c73m3: only use camera fw from system if newer than on data
  •codeworkx - s5c73m3: print s_ctrl and g_ctrl values
  •codeworkx - s3cfb: disable spam
  •codeworkx - mali: update to r3p1-01rel1
CyanogenMod Project name: android_kernel_samsung_t1
  •codeworkx - cpufreq: interactive: bring inline with omapzoom
  •codeworkx - modem_if: stop the spam
  •codeworkx - apply JB update from opensource.samsung.com
  •Andrea Arcangeli - ondemand: cpuidle detection
  •Andrew Dodd - cpufreq_conservative: Reduce minimum polling interval
  •Andrew Dodd - config: Update n7000 defconfig
  •Andrew Dodd - u1-gpio: Add GPIO definitions for SGH-I777
  •Andrew Dodd - mach-u1: Unmap HOME key GPIO on SGH-I777
  •Andrew Dodd - cpufreq_conservative: Change default tuning settings
  •Andrew Dodd - cpufreq_conservative: Bump default frequency step up to 10 from 5
RootBox Project name: buildscripts
  •Bajee11 - Build Maguro for Official Releases
  •Bajee11 - Cleanup Buildscript and build Nexus devices first.
  •Bajee11 - RootBox Splash
  •Bajee11 - Track RootBox Wallpapers
  •ajrty33 - Update README
  •Bajee11 - Track own DeskClock
  •Bajee11 - Track CM qcom wlan & audio-caf
  •Bajee11 - Track CM bionic and change libnfc-nci revision.
  •Bajee11 - Add Maguro Support (2/2)
  •Bajee11 - Add remote
  •Bajee11 - Track own grouper device tree
  •Bajee11 - Track own vendor asus
  •Bajee11 - Tracking changes 4.2.2
  •Bajee11 - Track android-4.2.2_r1
  •Bajee11 - Fix repo name
CyanogenMod Project name: android_external_busybox
  •Tanguy Pruvot - update config (fstrim addition)
Der Patcher funktioniert leider immer noch nicht. Ich versuche gerade, die 3.8 aus den Sourcen inkl. OpenPDroid zu kompilieren. Da ich mein S2G gerade nicht zur Hand habe, würde ich mich freuen, wenn jemand das ganze für mich testet, wenn es fertig ist, damit ich das im Thread verlinken kann :)
v3.9.1
Code:
RootBox Project name: frameworks_base
  •blk_jack - InputMethodService: Auto Keyboard Rotation (1/2)
  •Amit Kumar - FIX Null Pointer Exception on dialog cancel
  •Sungmin Choi - update preloaded-classes
  •D4rKn3sSyS - Uppercase
  •D4rKn3sSyS - Please don't hardcode strings!
  •Bajee11 - Replace 4G icons with LTE.
  •Kroz - Improve AOSP Download/Upload animation
  •Danesh M - LockscreenPattern : Toggle dots/error pattern visibility (1/2)
  •Elliott Hughes - Use getRelativeDayString in getRelativeTimeSpanString.
  •kufikugel - [Framework] Fix possible NPE on tablets
  •Stevespear426 - Navring: Fix landscape for phones and 4+ targets
  •Posselwhite - Performance increase in thumbnail handling
  •Steve Kondik - Vectorize bitmap operations on A15 too
  •Lucas Crowthers - core/jni/android/graphics: Cache copy of pre-scaled Bitmaps
  •Lucas Crowthers - frameworks/base: vectorize Bitmap operations
  •Stevespear426 - Navring: fix NPE if app uninstalled and in Navring
  •Bajee11 - RootBox SquareMod Battery (1/2)
  •olivergeith - RootBox Circle Mod (1/2)
  •Bajee11 - Alternative RootBox Battery Icons (2/2)
  •Gergely Szell (sethyx) - NFC toggle fix
  •Bajee11 - MMS Breath (2/3)
  •olivergeith - Update Sleep Toggle icon
  •jungheang.lee - Fixed the problem ime invisible status despite being the icon that appears in the statusbar.
  •olivergeith - Update Charging Animation
  •Sar Castillo - Smooth Spinners: Makes the loading "spinner" animation smoother in non-holo apps
  •Bajee11 - Increase statusbar notifications alpha to 90%
  •drcmda - PIE: slightly smaller as default
  •olivergeith - Update QS drawables for a uniform look.
  •Bajee11 - Some Pie Toggle fix
  •Roman Birg - SystemUI: set correct initial NFC toggle state
  •Roman Birg - SystemUI: avoid NPE when no toggles are set
  •Stevespear426 - FW: Navring Rework.
  •Bajee11 - Pie Toggle (2/2)
  •drcmda - PIE: one finger swipe-up for notifications
  •drcmda - PIE: /// is ready for prime time
  •drcmda - PIE: header with time and date (+///) for both panels
  •aaronpoweruser - PIE: clear all button
  •Tylar Overturf - frameworks: Smooth background gradient
  •Dirk Rettschlag - Toggles: fix silent off label
  •JBirdVegas - derp can't have webaddress here
  •Thiago Vinícius Freire de Araújo Ribeiro - SystemUI: Avoid "phantom" status bar collapsing
  •blk_jack - Notification shortcuts spacing and tablet transition fix
  •JBirdVegas - Include android.permission.ACCESS_SUPERUSER permission in the base API
  •olivergeith - SystemUI: Update WiFi & Signal icons
  •Stevespear426 - Spen Options 1/2: Enable Spen options
  •Stevespear426 - AwesomeAction: Make more awesomeer
  •Bajee11 - Pie: Fix dependency on Last App target for proper alignment.
  •Bajee11 - Fix Menu not showing up in PIE
  •Gergely Szell (sethyx) - Final BT toggle fix!
  •Roman Birg - Toggle bug fixes
  •Laszlo David - Swap volume buttons when the screen is rotated by 90 or 180 degrees (1/2)
  •Nathan Grebowiec - Have DashClock hide lockscreen clock
  •Lars Greiss - Frameworks: Add PNG'S for Notfication and Lockscreen shortcuts
  •blk_jack - Framework: Notification Shortcuts (1/2)
  •kufikugel - [Frameworksbase] Port Add Wifi name to notification drawer (1/2)
  •Muhammed Nazim - Enable Copy/Paste in Google Talk
  •Danny Baumann - Add method to PowerManager that allows querying the lowest possible brightness.
  •Bajee11 - Add missing toggles string
  •Roman Birg - SystemUI: transparency mgr bug fixes
  •Mathias Jeppsson - Framework: AOSP Fix - starting window memory leak
  •Dirk Rettschlag - Keyguard: fix nasty file handle leak
  •Roman Birg - Toggles: cleanup class and quiet down logging
  •Roman Birg - Toggle rewrite (1/2)
  •drcmda - PIE: support for expandable notifications
  •Muhammed Nazim - Make Camera shutter follow device sound setting
  •Muhammed Nazim - Oh Google... this is AOSP
  •drcmda - PIE: compressed layout, stubs, new defaults
  •drcmda - PIE: improved touchhandling, no emptyangle, better animations
CyanogenMod Project name: android_frameworks_av
  •Ravishankar Sarawadi - audio: Subsystem Restart changes
  •Steve Kondik - libstagefright: Stop the logspam from LPAPlayer
  •YuanQY - libstagefright: Fix incorrectness nPortIndex value for QueryCodec                 The query index is wrong, it will make a death loop in my ME722 when get resource thumbnail for MPEG4 video.
  •Haynes Mathew George - libstagefright: Squashed commit of LPA/tunnel updates from CAF
CyanogenMod Project name: android_frameworks_native
  •Ramkumar Radhakrishnan - libgui: Add support to update buffer geometry.
  •Ramkumar Radhakrishnan - Add support for custom buffer sizes.
  •Steve Kondik - Revert "SurfaceFlinger: Change to support framebuffer flip for 2D blitters"
  •Naomi Luis - Reset the FrameNumber for dropped frame in async mode
CyanogenMod Project name: android_frameworks_opt_telephony
  •Dan Pasanen - PhoneProxy: fix key.length > 31 characters
  •Dan Pasanen - PhoneProxy: Add a prop to enable always creating of CDMALTEPhone
  •Dan Pasanen - Revert "PhoneProxy: On v6 or greater RIL, when LTE_ON_CDMA is TRUE,"
  •Roman Birg - mako: update fast charge path
AOKP Project name: device_samsung_tuna
  •akellar - Update GPS.conf
RootBox Project name: device_samsung_i9100g
  •codeworkx - i9100g: mms overlay cleanup
  •codeworkx - i9100g: add ext4 as second filesystem for sdcard for recovery
  •detule - d2: audio: Fix routing for BT voicedial feature
  •codeworkx - i9100: add ext4 as second filesystem for sdcard for recovery
  •Bajee11 - Add Torch overlay
  •codeworkx - t0lte: add ext4 as second filesystem for sdcard for recovery
  •Stevespear426 - t0lte: Fix reboot dialog to reflect download mode.
  •Jonathan Steadman - t0lte: enable s-pen gestures
RootBox Project name: device_samsung_galaxys2-common
  •athurh - mount preload partition at the end
  •codeworkx - galaxys2: add mms overlay
  •iKillCypher - fixed i9100 low headphones sound issue
  •sakindia123 - BoardConfig: Add Cortex-A9 & Neon optimization
  •athurh - galaxys2: camera: enable useProfileVideoSize
  •Stevespear426 - t0ltecdma: Fix reboot dialog to reflect download mode.
  •sbrissen - t0ltecdma: use mms_config from smdk4412-common
  •cordell - msm8960: temp disable KERNEL_HAS_GETTIMEOFDAY_HELPER;
RootBox Project name: device_samsung_smdk4412-common
  •codeworkx - smdk4412: add flags for cortex-a9 and neon optimizations
  •codeworkx - smdk4412: overlay: add UAProf URL
  •codeworkx - smdk4412: mms: higher max message and image sizes
RootBox Project name: device_samsung_i9300
  •codeworkx - i9300: add ext4 as second filesystem for sdcard for recovery
RootBox Project name: device_samsung_qcom-common
  •Steve Kondik - qcom-common: Build libdashplayer
  •Roman Birg - mako: update blobs
  •Tom Marshall - p930/su640/vs920: initial bringup
  •Bajee11 - Add Tuna blobs
  •Bajee11 - Update Toro blobs
  •Bajee11 - Add Adaptive Multi-Rate Wide Band tweak
  •Bajee11 - Embed Superuser into System Settings
  •Bajee11 - Update Xposed Settings
  •Bajee11 - Update Xposed installer 2.1.3
  •Bajee11 - Switch to open source SuperUser
  •Bajee11 - Add Official Toro support
  •Bajee11 - Add t0lte and clean up vendor
  •Bajee11 - Refactor RC Options for all devices.
  •Bajee11 - Remove CDMA Tools for l900
  •Bajee11 - Add CDMA tools to common apps. (Part 2 of 3)
  •Bajee11 - Note2-common: Add RC config
  •Bajee11 - Remove RC Overlays for most devices.
  •dhacker29 - Init: Allow building of init that is compatible with second init boot
  •Andrew Sutherland - unpackbootimg: remove host LOCAL_MODULE_TAG
  •codeworkx - init: create mountpoint for fuse
  •Thomas Wendt - Fix audio recording for ICS audio blobs
  •Ricardo Cerqueira - audio: Fix input enums for pre-4.2 audio blobs
AOKP Project name: system_vold
  •codeworkx - vold: add support for ext4 media
  •codeworkx - vold: use blkid to detect filesystem type
CyanogenMod Project name: netd
  •Vishal Mahaveer - netd: Enabling softAP/Hotspot for TI solution
  •Ricardo Cerqueira - Revert "system/netd TI mac80211: Hostapd updates from omapzoom JB"
  •Richard Hansen - bionic/libc: fix getsid() syscall number for mips
  •Richard Hansen - bionic/libm: fix x86 support regression
  •Martin Johnson - Fix camera extra settings menu
  •Nagaprasad N - camera: add much more scene & focus modes
  •jt1134 - BurstMode: only show slide animation after final shot
  •isimobile - Camera: Allow setting "profile-video-size" before recording starts
  •Steve Kondik - camera: Restart the preview if record size changes
CyanogenMod Project name: android_packages_apps_DSPManager
  •isimobile - Add Afrikaans translation
  •Kroz - Add icons for new feature
  •blk_jack - Settings: Auto Keyboard Rotation (2/2)
  •Bajee11 - Switch png to XHDPI
  •fuzz - LockscreenPattern: Fix toggle dots/error pattern visibility
  •Bajee11 - About RB: Complete makeover
  •Danesh M - LockscreenPattern : Toggle dots/error pattern visibility (2/2)
  •Bajee11 - Add kilometers4 as device maintainer. (Grouper)
  •Bajee11 - About RB: Add Device Maintainers and Graphics Team
  •Or Harambam - Settings: RTL layout fixes
  •Ryan Baxter - Fix the message when Bluetooth is turning off while on the tethering menu.
  •Kroz - RB Settings: Breathing SMS Icons
  •Bajee11 - MMS Breath (3/3)
  •Koushik Dutta - Switch to open source superuser
  •Paul Henschel - PIE: slightly smaller as default Change-Id: I307749f1e894e8e31a7b0b8bc39a0da11c20090f
  •Bajee11 - Pie Toggle (1/2)
  •Bajee11 - Revert "Fix lockscreen delay stuck at 5 seconds for Pattern/Pin/Password Lock"
  •Kroz - Update RB Settings & Update Center Icons
  •qnhoang81 - Settings part: Add Sprint Tools (CDMATools) into settings. (Part 1 of 3)   -devices can set this in overlay. (Not for all CDMA devices)
  •Kroz - RB Settings: Update with new icons
  •Bajee11 - RB Settings: Swap Volume Buttons for Rotation
  •blk_jack - Settings: Notification Shortcuts (2/2)
  •Bajee11 - RB Settings: Show connected WiFi network in notification drawer.
  •Bajee11 - Pie Updates
RootBox Project name: packages_apps_Phone
RootBox Project name: packages_apps_Mms
  •Bajee11 - MMS Breath (1/3)
  •Gergely Szell (sethyx) - Fix shifted CallLog duration display
  •jackmu95 - Calculator: Update German translation
  •djMesias - es_ES: Update spanish translations
  •jackmu95 - Calculator: Some cleanup
  •pvolkov - Update Russian Translation-Calculator-CM10.1
  •Bajee11 - Fix Lockscreen FC
  •demon1987 - Update strings.xml
  •Zaphod - RC :  Hide items when not viable
  •Bajee11 - RootBox SquareMod Battery (2/2)
  •Bajee11 - RootBox CircleMod (2/2)
  •Bajee11 - Alternative RootBox Battery icons (1/2)
  •Dirk Rettschlag - Add check for sw600DP screens
  •Gergely Szell (sethyx) - RC: Fix toggle setup dialog width & move toggle option up in RC
  •Stevespear426 - RC: Navring rework.
  •Bajee11 - Fix Toggles summary
  •Gergely Szell (sethyx) - RC: Fix Headers
  •Stevespear426 - Navbar and navring: remove screenshot option
  •Stevespear426 - Spen Options 2/2: Enable Spen options
  •JBirdVegas - New CMDProcessor
  •KhasMek - Vibrations: add more stock custom vibrations.
  •Jonathan Steadman - RC: point toggles preference to correct string
  •kecinzer - RC: Updated czech translation
  •Jonathan Steadman - RC: Add a little clarity to new toggle implementation
  •JBirdVegas - support Koush's Superuser
  •Roman Birg - RC: Toggle rewrite (2/2)
  •Bajee11 - Revert "QuickSettings: add holo dark/light theme chooser (2/2) - WIP"
  •bmc08gt - DeskClock: Add option to toggle unlock on dismissal of alarm
  •Tamás Tóth - Added translation for weather_show_when_minimized
  •DvTonder - cLock: Add ability to change font and monochrome icon colors
  •Vavooon - Add LockClock uk translation
  •Nicolai Ehemann - cLock: Updates to how dates are displayed in calendar entries
  •DvTonder - cLock: Add HDPI summary weather support for minimized widget
  •Francesco - LockClock: Update italian translation
  •DelPETER - LockClock : add French translation
  •Mikael Lindemann Jepsen - cLock: Danish translations
  •Marco Brohet - cLock: Dutch translations
  •Michael Bestas - cLock: Update Greek translations
  •DvTonder - cLock: Make the Color icons default --!TRANSLATORS PLEASE NOTE!--
  •DvTonder - cLock: Remove redundant code and cleanup, bump version
  •Andrew Jiang - cLock: Simplified Chinese Translations
  •DvTonder - cLock: Make the showing of weather when minimized a user option
  •Tamás Tóth - Added hungarian translation for 'Done' button
  •DvTonder - cLock: Add a 'Done' button to configurator
  •DvTonder - cLock: Add support for a small widget layout with weather
  •DvTonder - cLock: Launch configuration when adding the widget
  •DvTonder - cLock: Add mdpi support
  •Cédric Cabessa - FIX: do not display event too far in the future
  •Tamás Tóth - Added hungarian translation for lookahead_2-4wks
CyanogenMod Project name: android_bootable_recovery
  •Koushik Dutta - 6.0.2.9
  •Nathan Grebowiec - Blocked cached Google Music files from nandroid
  •Elliott Hughes - Pass the correct pointer to munmap on failure.
  •Doug Zongker - add optional overscan compensation to recovery graphics
  •jt1134 - adb: handle adbd auth in recovery mode
  •Ravishankar Sarawadi - alsa_sound: Subsystem Restart Changes
  •Kalyani polepeddy - 7x30 : Port heap mask change to ion
  •Deepa Madiregama - audio/msm7630: Fix the issue of voice call when HDMI connected
  •Vineela Tummalapalli - audio/msm7630: Add usb audio hal profile.
  •Vicky Sehrawat - alsa_sound: Fix to prevent additioal doRouting call
  •Preetam Singh Ranawat - hardware/qcom/audio: fix memory leak in alsa_ucm.c file
  •Haynes Mathew George - alsa-sound: Use errno to check for error code of ioctl()
  •Haynes Mathew George - alsa-sound: Avoid use of extra bytes to signal seek processed
  •Vidyakumar Athota - alsa_sound: Fix usb headset record noise
  •Haynes Mathew George - alsa-sound: AudioSessionOut optimization
  •Vidyakumar Athota - alsa_sound: Fix for Audio routing to HDMI when BT connected
  •Krishnankutty Kolathappilly - alsa_sound: Set tunnel/lpa bit for playback over usb headset
  •Mingming Yin - audio: fix to play Skype calltone on earpiece instead of speaker
  •Vidyakumar Athota -  Fix for MT call ringtone on USB headset
  •Karthik Reddy Katta - alsa_sound: Fix for no audio when switching between BT headsets
  •Vineela Tummalapalli - msm7630 : Send proper channleMask for getInputProfile()
  •Subhash Chandra Bose Naripeddy - alsa_sound: Initialize the mPfdProxy in constructor
  •Giulio Cervera - alsa-sound: fix typo
  •Mingming Yin - audio: invoke CSD client APIs only for Fusion3 platform
  •Naseer Ahmed - hwc: Check for correct screen state before enabling vsync
  •Sushil Chauhan - overlay: Reset allocation on all pipes, if commit fails.
  •Naseer Ahmed - gralloc: Fix incorrect flag usage on old ion API
  •Saurabh Shah - hwc: Process only MAX_NUM_LAYERS
  •Ramkumar Radhakrishnan - hwc: handle blank/unblank for virtual display explicitly.
  •Jeykumar Sankaran - display: Add hook for triggering screen update
  •Naseer Ahmed - gralloc: Allow IOMMU memory to be uncached
  •Steve Kondik - hwc: Enable use of copybit
  •Naseer Ahmed - hwc: Use intermediate buffers for copybit
  •Jeykumar Sankaran - libhwcomposer: MDP composition for Higher Resolution panels
  •Saurabh Shah - hwc: Close acquireFenceFds always.
  •Arun Kumar K.R - libexternal: prefix the property name with hw
  •Amara Venkata Mastan Manoj Kumar - hwc: Allow HWC to support Virtual Display
  •Saurabh Shah - hwc: Get notified on media player death.
  •Saurabh Shah - libqservice: Add a client interface.
  •Naseer Ahmed - qdutils: Default to GPU composition
  •Steve Kondik - FIX: "display: Reset metadata pointer to NULL during unmap."
  •Naomi Luis - libgralloc: Get the stride information from libadreno_utils.so
  •Naomi Luis - libgralloc: Add Perform function to get the stride.
  •Sushil Chauhan - libgralloc: Calculate aligned width & height using common header
  •Sushil Chauhan - libgralloc: Import header for Venus buffer size calculation
  •Arun Kumar K.R - libcopybit: update the target config_mask for transformation
  •Ricardo Cerqueira - Revert "display: Reset metadata pointer to NULL during unmap."
  •Ramkumar Radhakrishnan - display: Reset metadata pointer to NULL during unmap.
  •Steve Kondik - hwc: Only perform the yuv+composition workaround on MDP < 4.2
  •Neti Ravi Kumar - liboverlay : Update magnification limit for MDP 400
  •Steve Kondik - media: Better compatibility with new KGSL
  •Steve Kondik - mm-video: Support for QCOM_BSP define
  •jerpelea - wifi: add suport for WIFI_EXT_MODULE
  •Steve Kondik - Revert "hwcomposer: Add HWC_BLIT compositiontype value"
  •Steve Kondik - libhardware: Remove unused sourceTransform field
  •Ravishankar Sarawadi - audio: Subsystem Restart Changes
  •codeworkx - exynos4210: lights: add missing brightness check
  •Conn O'Griofa - releasetools: Add support for BML partition type
  •Ying Wang - Squash commits from CM for making lunch faster
  •Tom Marshall - Remove unused RunConfig.
 Project name: mako
  •faux123 - Sound Control: Sound control for WCD93xx codec
  •faux123 - ASoC: add missing updates from CAF
  •faux123 - defconfig: fix sip issues
  •Gopichand Nakkala - wlan: Fix for ARP offload issue
  •faux123 - defconfig: update to latest configurations
  •faux123 - speaker amp control: allowed all configurable registers to be adjusted
  •faux123 - cpufreq_limit: remove unused vars
  •faux123 - msm_cpufreq_limit: add GPL V2 licensing to access to GPL symbols
  •faux123 - msm_cpu_freq_limit: fixed coding copy and paste error :p
  •faux123 - msm_cpu_freq_limit: initial coding for controlling MSM quadcore cpus
  •faux123 - speaker amp control: initial release for speaker amp control
  •Kuogee Hsieh - msm_fb: display: calculate mdp clock including borderfill pipe
  •Siddhartha Agrawal - msm_fb: display: Configure solidfill color to black
  •Steve Kondik - Revert "netfilter: xt_qtaguid: remove AID_* dependency for access control"
  •Aravind Venkateswaran - msm_fb: dtv: Serve device off in a separate thread
  •JP Abgrall - netfilter: xt_qtaguid: Allow tracking loopback
  •JP Abgrall - netfilter: xt_qtaguid: extend iface stat to report protocols
  •JP Abgrall - netfilter: xt_qtaguid: remove AID_* dependency for access control
  •Pontus Fuchs - netfilter: qtaguid: Don't BUG_ON if create_if_tag_stat fails
  •JP Abgrall - netfilter: xt_qtaguid: fix error exit that would keep a spinlock.
  •Brian Beloshapka - d2: fix wpa/wpa2 tethering
  •Padmanabhan Komanduru - msm_fb: Update backlight level on resume after first pan display
  •Jeff Brown - video: msm: use linear brightness ramp
  •Murali Nalajala - msm: rq_stats: remove io_is_busy from load computation
  •codeworkx - melfas touch: report touch events to cypress for backlight timeout
  •codeworkx - display: updates for t0 devices
  •codeworkx - i777, i9100, n7000: enable uhid
  •codeworkx - uhid: backport from 3.4
  •codeworkx - i777, i9100, n7000: enable last_kmsg
  •Andrew Dodd - i777: config: Change from ALP to RP audio
  •Bajee11 - Add i605 and l900 to Nightlies & Official
  •Bajee11 - Add toro to build list
  •Bajee11 - Add t0lte to build list
 Project name: git-repo
  •Shawn Pearce - upload: support --re and --cc options over HTTP
  •Mitchel Humpherys - Add --no-tags option to prevent fetching of tags
  •htchoi1995 - Use 4.2.2_r1
  •Bajee11 - Track own t0lte
  •Bajee11 - Track own superuser
  •Bajee11 - Track AOKP e2fsprogs
  •Bajee11 - Fix typo
  •Bajee11 - Track AOKP grouper
  •Bajee11 - Track toro device tree
  •Bajee11 - Track t0lte device tree
  •Bajee11 - Fix typo
 Project name: external_koush_Superuser
  •Bajee11 - RootBox Support and Dark Theme
  •Koushik Dutta - slovak
  •kecinzer - Czech translation
  •Koushik Dutta - style renames in Widgets
  •Koushik Dutta - remove values-fr files that are unnecessary
  •jchleb - Update strings.xml
  •Koushik Dutta - allow hooking for the native fragment for CM. CM requested feature to change the stylings.
  •jchleb - Create styles.xml
  •jchleb - Update dimens.xml
  •jchleb - Create attrs.xml
  •Pavel Volkov - Russian fixes
  •udK - Update values-it/strings.xml
  •ed10vi - Update spanish translation
  •Danny Baumann - Fix switch not updating the DB when toggled by sliding instead of clicking it.
  •yadro - Updated Russian localization
  •oGre - Theme + PIN disabled translation
  •Mack Zhang - Update values-zh-rSG/strings.xml
  •Mack Zhang - Update values-zh-rCN/strings.xml
  •Koushik Dutta - formatting
  •Alvin - Update strings.xml
  •Koushik Dutta - make the process of removing pin protection more apparent.
  •Koushik Dutta - fix the pin protect screen to be a proper dialog on tablets.
  •Koushik Dutta - be verbose about the dark/light activity themes
  •Koushik Dutta - whatsnew
  •Koushik Dutta - apparently some phones crash if a notification is made without a contentIntent
  •sparkym3 - Update system install to set safer access rights.
  •Koushik Dutta - missing files
  •udK - small fixes and optimizations
  •Koushik Dutta - 1012
  •Koushik Dutta - remove logging
  •Koushik Dutta - Add dark theme option. Fix bug where the version string was sent as an int, instead of the version code.
  •Koushik Dutta - add missing /system/bin/su symlink
  •Whitexp - added pt translation
  •Koushik Dutta - send the binary version in the protocol, so a notification can be shown if it is out of date
  •Koushik Dutta - Update README.md
  •Koushik Dutta - update whatsnew
  •Koushik Dutta - purge logs over 2 weeks.
  •Koushik Dutta - db refactorings
  •Koushik Dutta - fix up some db churn by reusing a single db connection
  •Koushik Dutta - Move the logs and settings into a separate database, to prevent database locks by su binary. The policy database, for the most part, should just be read only.
  •Ben - Should use getWritableDatabase() instead of getReadableDatabase() because we run db.delete();
  •Koushik Dutta - fix uninitalized variable usage
  •Yuval Aboulafia - Hebrew update
  •oGre - Two new rows Swedish translation
  •Simone Picciani - Update strings.xml
  •Koushik Dutta - dont handle config changes, so the entire layout is rebuilt.
  •Pavel Volkov - Update Russian Translation
  •Koushik Dutta - fix margins
  •OSAKANA TARO - add japanese language
  •Mack Zhang - Update strings.xml
  •Koushik Dutta - always allow root/shell, no matter if superuser is not installed
  •Koushik Dutta - "nice" the logging by waiting a bit before adding it to the db. some wacko apps send a ton of concurrent su requests and hit a db lock
  •Koushik Dutta - add whats new notice. 1008
  •Koushik Dutta - switch from opening the market to explain why superuser is broken
  •Koushik Dutta - Fix froyo pin crash
  •Zanza00 - Updated and tweaked italian translation
  •Igor Sorocean - Update romanian translation
  •ed10vi - Use existing translations in Cyanogenmod/Superuser
  •htchoi1995 - Update korean translation
  •coolzjy - Update strings.xml
  •Koushik Dutta - refresh on resume
  •Koushik Dutta - only show the market app if the requestor is the same as the market app. This fixes the embedded scenario.
  •Kristoffer Andersen - Updated Danish.
  •Koushik Dutta - allow customization of the requestor prefix
  •oGre - Swedish translation for superuser access block
  •Koushik Dutta - escaping fixes
  •Koushik Dutta - 1007
  •Koushik Dutta - Add settings toggles for superuser global policies: apps only, adb only, apps + adb, or disabled. su: fix binary so Superuser always gets access, even if root is disabled. Obviously need this to reenabled root. Check superuser binary version.
  •yadro - Updated Russian translation
  •Mack Zhang - Simplified Chinese translation
  •oGre - Removed extra backslash
  •Pavel Volkov - Update russian translation
  •Pavel Volkov - Update some russian typos
  •Koushik Dutta - stopgap to fix rotation crash
  •Tan Tran - Remove redundant file
  •Tan Tran - remove draft
  •Tan Tran - Add Vietnamese translation
  •Koushik Dutta - 1006
  •Koushik Dutta - check superuser on boot. but do it nicely... with a notification. and back off if notification is deleted.
  •Koushik Dutta - fix up menu about and other icons for pre ics. try a new launcher icon. add superuser version to about section.
  •Koushik Dutta - add version info to about page
  •ed10vi - Spanish: Use the same word for the same thing
  •Kristoffer Andersen - Added missing translations in Danish
  •AlvinHKH - Add Traditional Chinese translation
  •Zanza00 - Updated italian translation
  •Pavel Volkov - Russian-Removed extra backslash
  •Koushik Dutta - opening the github url requires Intent.ACTION_VIEW
  •Koushik Dutta - 1005
  •Koushik Dutta - fix ndk to go to assets?
  •oGre - Extra backslash removed
  •Koushik Dutta - 1003
  •Koushik Dutta - most devices dont support rm -f
  •oGre - Preceed apostrophes with backslash.
  •Koushik Dutta - Italian fixes
  •Koushik Dutta - missing resources
  •Koushik Dutta - resource name changes
  •Zanza00 - Added Italian Translation
  •ed10vi - Update Spanish translation
  •oGre - Fixed typo (installation)
  •oGre - Updated Swedish translation (installation)
  •Koushik Dutta - check file exists
  •Koushik Dutta - remove cruft
  •Koushik Dutta - In app installation done. Release on Play soon.
  •oGre - Updated Swedish translation whitespace
  •yadro - Update Russian localization
  •Koushik Dutta - open the superuser link on the market if the app is missing.
  •Koushik Dutta - Add About Page linking to my twitter, apps, and Superuser github in the standalone APK version of Superuser. Embedded users (like CM, PA, etc) wont see this.
  •Koushik Dutta - use full path on symlink
  •Koushik Dutta - fix recovery zip su location to be aosp standard. /system/bin/su symlinks to xbin/su
  •Koushik Dutta - Set noHistory on MainActivity to prevent a running instance of Superuser from regaining focus after a request is finished.
  •ed10vi - update spanish translation
  •yadro - Fixed Russian localization
  •Kristoffer Andersen - Fixed a typo.
  •Koushik Dutta - pin related fixes
  •Koushik Dutta - Dont crash if log could not be added. This happens during su -c reboot, when /data is unmounted, etc.
  •Koushik Dutta - use android:excludeFromRecents instead of noHistory
  •Koushik Dutta - Fixup theme usage for light/dark
  •Koushik Dutta - fix bug where logs were not shown on startup
  •Koushik Dutta - fixes
  •Mustaavalkosta - add Finnish translation Partly a bit clumsy but will do for now.
  •Yuval Aboulafia - Update Hebrew translation
  •Igor Sorocean - Updated romanian translation
  •Koushik Dutta - remove watermark from anything but koush builds
  •Koushik Dutta - fragment stack fixes
  •Koushik Dutta - LICENSE
  •Koushik Dutta - refactor into single db
  •Samuel Rivera - Update strings.xml
  •Koushik Dutta - fix up pin stuff that i had commented out
  •Koushik Dutta - Fix build
  •Koushik Dutta - LOCAL_PATH fixes
  •Kristoffer Andersen - Moar fixes!
  •Koushik Dutta - ant now builds zip
  •Kristoffer Andersen - Fixed typos
  •Koushik Dutta - add module tag
  •oGre - First draft
  •oGre - Partial Swedish translation
  •Koushik Dutta - add local_manfest.xml for AOSP embedding
  •Koushik Dutta - native fragment stuff working
  •Kristoffer Andersen - Danish translation. First translation
  •Koushik Dutta - remove noisy logging
  •Koushik Dutta - fixups for embedding. proper back stack support
  •Koushik Dutta - fragment instance fixes
  •ed10vi - First translation
  •Koushik Dutta - embedded fixes, need to move fragments out of inner classes.
  •Koushik Dutta - license
  •Koushik Dutta - Fix german crash and mistranslation of english
  •Koushik Dutta - crash fix
  •Koushik Dutta - merge with german changes
  •Koushik Dutta - fragment revamp to support both native and support fragments (blerg)
  •Danny Baumann - Split automatic response summary.
  •Danny Baumann - Improve German translation.
  •Koushik Dutta - change app_name to superuser as that is more resource friendly for embedding into Settings
  •Koushik Dutta - Fixup third party embedding su
  •Koushik Dutta - C code fixups. Modify REQUESTOR if embedded in ROM.
  •Koushik Dutta - if a ROM is building superuser (vs embedding it into Settings), put the package into a com.thirdparty.superuser This is so that it doesnt try to get updates from google play, which will be signed with a different key.
  •Koushik Dutta - move su to optional executables so it is suid
  •Koushik Dutta - Fix up request theme/
  •Koushik Dutta - Crash Fix on tablets
  •Koushik Dutta - holo dark done
  •Koushik Dutta - aosp fixes
  •sparkym3 - AndroidManifest to use the "signature" protection
  •Ben - 2013_0226 make sure to call close on the DataInputStream line 233
  •oGre - added possibility to change ndk-executable
  •Koushik Dutta - fix russian string formatting. lint fixes
  •Koushik Dutta - fix widgets ref
  •Koushik Dutta - Fix bug where "Remember" does not work when pin protected.
AOKP Project name: external_koush_Widgets
  •Koushik Dutta - style fixes for pre ics
  •Koushik Dutta - allow base theme override
  •Koushik Dutta - move the setAdapter to after the create, so addHeaderView can be used
  •Koushik Dutta - fragment should get replaced on create. config changes cause weird behavior. i did not think fragments stuck around between config changes. surprise!
  •Koushik Dutta - onResume
  •Koushik Dutta - fixups for large devices
  •Koushik Dutta - fix bad style on pre ics
  •Koushik Dutta - theme cleanups
  •Koushik Dutta - remove comment
  •Koushik Dutta - fragment stack working
  •Koushik Dutta - backstack fixes
  •Koushik Dutta - convenience functions and fixes
  •Koushik Dutta - config fixes
  •Koushik Dutta - remove gen
  •Koushik Dutta - cleanups and consolidations
  •Koushik Dutta - Android stylization and resources
AOKP Project name: external_skia
  •Lucas Crowthers - Skia: Introduce caching of unscaled Bitmaps.
  •Richard Hansen - skia: SkPaint::SkPaint(): don't cast away const
  •Richard Hansen - memcpy_76(): fix behavior on non-ARM architectures
  •Steve Kondik - FIX: memcpy_76(): add support for non-ARM architectures
AOKP Project name: external_bluetooth_bluedroid
  •blackout4 - Update btif_media_task.c
 Project name: wpa_supplicant_8
  •Steve Kondik - Revert "enable CONFIG_PCSC"
  •Tanguy Pruvot - Busybox 1.21.0 squashed commit for jellybean
  •Evan McClain - Build with -fno-strict-aliasing
Ich habe es jetzt endlich mal geschafft, einen aktuellen Build mit OpenPDroid zu kompilieren. Würde mich freuen, wenn das jemand testen könnte, damit ich das im OP verlinken kann :)
https://dl.dropbox.com/u/20496861/RootBox-JB-i9100g-Nightly-20130313.zip
MD5: 65295da16e97f76e786f26d2cac81c8b
OP aktualisiert, selbst kompilierte Nighty eingefügt, Patches entfernt.
Hallo, hab mir Rootbox 3.2 mit Pdroid wieder auf mein S2G gemacht, jetzt ist mir grade aufgefallen das die Kamera App weg ist! Hat jemand ´ne Ahnung wie ich die wieder auf den Home kriege oder wohin die verschwunden ist? (Mp3 Player ist ebenfalls weg, lässt sich aber im Market wieder laden)
Probier es mal mit der 20130313 Nightly, die ich verlinkt habe. Dort funzt die Kamera.
Reaktionen: healTHCare#1
Werds morgen probieren. :smile: PDroid funktioniert damit aber nicht oder?
PDroid ist Vergangenheit, aktuell ist OpenPDroid. Und die Patches sind natürlich drin.
Die normale PDroid App funktioniert nicht mehr, du kannst stattdessen den PDroid Manager verwenden.
Habs grade gesehen, bin nicht mehr auf dem neuesten Stand ^^
Werd mich jetzt einlesen. Thx 4ndr0!
ive
Cloud
Cloud
ive
ive
  • Papillon0305
iCeCoPe
I
