[OS] Resurrection Remix (AOKP / CM 10-basierend, AROMA + OTA)
  • 11 Antworten
Martini3001
Gast
Hallo zusammen
Ich möchte Euch heute eine ROM vorstellen, die sich auf meinem S3 als wahrer Glücksgriff erwiesen hat.
AOKP JB Resurrection Remix
Ich betreue den Thread so gut es geht.
Installation:
WICHTIG:
Das S2G muss bereits auf einer ICS-basierenden ROM laufen.
1.- Wipe data / factory reset
2.- Resurrection Remix installieren
3.- In AROMA "Custom Installation" auswählen
4.- Wähle aus was mit dem Flashen der ROM zusätzlich mitinstalliert werden soll
5.- Wenn der AROMA installer den Flashvorgang beendet hat "Reboot Now" ABWÄHLEN
6.- In der CWM Recovery Advanced auswählen
7.- Wipe Dalvik Cache
8.- Fix Permissions
9.- Wipe Cache Partition
10.- Neustarten
http://forum.xda-developers.com/showthread.php?t=1822409 schrieb:
About Resurrection Remix ROM
Changelog
Installation
Downloads and useful links
Donations
Contact
Videos
Since version 1.2 of Resurrection Remix the ROM has been based on AOKP, CM9/10 and original Remix ROM builds, this creates
an awesome combination of performance, customization, power and the most new features, brought directly to your Device
Many things that in previous versions were tweaked with mods, are now included by default in the ROM so, please enjoy!
As of August 5th 2012, Resurrection Remix is now also released for Samsung Galaxy SIII (GT-I9300) devices
Special thanks to the AOKP team, the CM9/10 team, and of course to all the supporters​
Included Mods:changelog by Jubakuba
-Toggles
-Center Clock/No clock/Right Clock
-AM/PM display
-AOKP clocks and Digital Clock
-New Wallpapers
-Volume rocker moves cursor when keyboard is open (optional)
-Nova/Stock launcher included
-%1 battery mod and CircleMod battery
-Brightness adjustable via statusbar if auto brightness is disabled. It even shows your current brightness percentage as you slide!
-There's also a "Emergency Broadcast Settings" that allows you to check/uncheck for notifications of "Amber Alerts" and other such Local Emergencies. I personally haven't seen this yet in the other Jelly Builds.
-Change NavBar targets and long-press actions
-Battery Bar
-Change NavBar height
-Volume Panel (Volume Rocker allows you to change ALL volume levels in one Menu)
-Notification Counter
-Disable Boot Animation
-AOKP Statistics
-Device Options (Color Tweaks)
-Led Options (Color and Pulse Rate)
-NFC Polling Mode (NFC with Screen Off or Locked)
-Theme Engine
-Quiet Hours
-T9 Dialer
-Notification Shade Wallpaper Changer (And Transparency)
-Lockscreen Wallpaper Changer
-Wait To Lock Screen
-Volume Wake
-Quick Pin Unlock
-Phone Face-Down Ringer Setting (Silent/Vibrate)
-Headphones Plugged in Ringer Setting (Silent/Vibrate)
-Bluetooth Connection Ringer Setting (Silent/Vibrate)
-Lockscreen Weather
-Performance/Color Settings
-Brightness Control Slider
-Added Device (Color) Settings To Maguro
-Flip Phone To Silence Incoming Call
-NavBar Open/Close Notification Shade Option
-A Plethora of BugFixes and Updated Translations​
Code:
[B][SIZE=3][FONT=Century Gothic][COLOR=DimGray]v3.0.9[/COLOR][/FONT][/SIZE][/B]
[LIST]
[*]Custom NavBar Ring on tablets
[*]Force dual panel view on any device
[*]Flip or shake your device to snooze/dismiss the alarm (check alarm settings)
[*]Take screenshot from NavBar
[*]Enabled USB mass storage emulation
[*]Updated from latest cm source
[*]Brand new HD weather icons
[*]improved scrolling
[*]updated default youtube app
[*]Update Me Push Notification
[/LIST]
[B][SIZE=3][FONT=Century Gothic][COLOR=DimGray]v3.8[/COLOR][/FONT][/SIZE][/B]
LATEST AOKP SOURCES AND RR CHANGELOG
[LIST]
[LIST]
[*]updated cm10 kernel (AOKP)
[*]Better Ram performance(tweaked)
[*]updated latest cm sources
[*]improved hw comp /memory leaks
[*]hacked and fixed bluetooth (can recieve apk files)
[*]SMS QuickReply Default & inverted
[*]Stopwatch & Countdown in the Clock app (CM)
[*]Expert Calculator functions (Graph, Matrices, etc.) (CM)
[*]IME Switcher & Vib/Ring toggle as NavRing target
[*]fixed add custom ringtone
[*]fixed inverted gtalk issues
[*]added bottom and blue default notification planel with middle clock (aroma)
[*]Custom Ring targets
[*]Allow up to 7 Nav buttons on some devices
[*]IME Toggler
[*]Hide ADB icon
[*]Allow disabling of volume adjust sound
[*]Hide signal bars
[*]WeatherPanel
[*]WiFi & Cell signal text
[*]Allow rotation on any device
[*]Added back Info-Lines (Weather, Calendar)
[*]Menu unlock
[*]Alternative music layout
[*]updated latest cm10 camera features issues fixed
[*]Display full date & time mms
[*]Kill all button in Recents panel
[*]Backlight settings
[*]Tablet UI on any device
[*]DPI switcher
[*]Custom Vibrations for Phone Calls
[*]ADB over network
[*]National Data Roaming option
[*]Volume music controls
[*]LED Brightness control
[*]Charging LED
[*]Boot animation preview
[*]Allow full theming of Contacts & Mms
[*]Allow to set color of Digital Clock Widget
[*]Power menu options (airplane, screenshot, navbar toggle)
[*]Ability to answer calls with hardware Home button
[/LIST]
[/LIST]
[B][SIZE=3][FONT=Century Gothic][COLOR=DimGray]v3.0.6 [/COLOR][/FONT][/SIZE][/B]
[LIST]
[*]-Updated Horse Power Kernel 3.0
[*]-Updated inverted pack -added inverted google+
[*]-Updated gapps to latest version
[*]-Updated superSU
[*]-Framework improved totally renewed added holo icons
[*]-Aroma installer improved
[*]-Weather from cm10
[*]-Fixed bluetooth A2DP Connection
[*]-HSPA+ Support ( credit to bajee11)
[*]-Safe Headset Volume (Prevent Full Volume When You First Plug Your Phones In)
[*]-Allow "Touch To Focus" option to have a user-defined time out in Camera
[*]-GPS Source (Change Antenna To External Bluetooth Antenna)
[*]-User Defined Lockscreen Text Color
[*]-Change Clock Color In Status Bar
[*]-Disable pattern visibility on lockscreen
[*]-Set time before secure lock is activated
[*]-Exit to Home on End Call
[*]-ADB over WIFI (Settings>Developer Options)
[*]-Lockscreen Calendar
[*]-Lockscreen Text Weather
[*]-Status Bar Weather
[*]-Launch Custom App with Click of Weather
[*]-Option to unlock device with menu button (Devices with soft/hard key menu buttons)
[*]-Option to disable IME switcher
[*]-Option to disable volume change sound
[*]-Install bootanimation.zip via Rom Control
[*]-Enable 180 degree rotation
[*]-Option to add a "Kill all" button to recents menu
[*]-Option to unlink ringer and notification volume
[*]-Return of down arrow if keyboard is open
[/LIST]
[B][SIZE=3][FONT=Century Gothic][COLOR=DimGray]v3.0.5[/COLOR][/FONT][/SIZE][/B]
[LIST]
[*]Renewed aroma installer
[*]updated system apks
[*]Custom Carrier Text
[*]updated RR wallpapers
[*]Led Settings Customizable For Individual Applications
[*]Safe Headset Volume (Prevent Full Volume When You First Plug Your Phones In)
[*]Allow "Touch To Focus" option to have a user-defined time out in Camera
[*]GPS Source (Change Antenna To External Bluetooth Antenna)
[*]User Defined Lockscreen Text Color
[*]Change Clock Color In Status Bar
[*]updated camera firmware
[*]wake clock fixed
[*]updated gapps
[*]updated update me
[*]fixed navigation buttons on /off
[/LIST]
[B][SIZE=3][FONT=Century Gothic][COLOR=DimGray]v3.0.4[/COLOR][/FONT][/SIZE][/B]
[LIST]
[*]Latest merged changelog [B][U][URL="http://gerrit.sudoservers.com/#/q/status:merged,n,z"]AOKP[/URL][/U][/B] & [U][B][URL="http://changelog.bbqdroid.org/#i9100/cm10/next"]CM10[/URL][/B][/U]
[*]updated rom control
[*]updated (phone ,browser,keyboard,camera,email,calendar.mms)
[*]many of system files up to date
[*]system ui improved
[*]more free ram
[*]better deep sleep
[*]updated inverted apps
[*]fixed inverted contact apk
[*]updated jb launcher
[/LIST]
[B][SIZE=3][FONT=Century Gothic][COLOR=DimGray]v3.0.3[/COLOR][/FONT][/SIZE][/B]
[LIST]
[*]updated from latest cm10 and aokp sources
[*] Kernel Choice Added in Aroma (CM10,Horse Power & Twrp )
[*]fixed deep sleep issue (improved)
[*]added new aokp features
[*]updated phone app
[*]improved sounds,
[*]better battery life (improved)
[*]faster gps ,faster wifi, (improved)
[*]framework issues fixed
[*]and more improvements
[/LIST]
[B][SIZE=3][FONT=Century Gothic][COLOR=DimGray]v2.6.1[/COLOR][/FONT][/SIZE][/B]
[LIST]
[*]GPS ,M.DATA and WİFİ improved
[*]fixed swipe speak to text
[*]fixed notification toogles and date
[*]updated build prop
[*]updated lib files
[*]updated R-wallpepers
[*]added apex launcher JB HD theme (aroma)
[*]deep sleep & battery life improved
[*]and many fixes included in update ,,
[*]cm9 volume drop patch not including because causes other unexpected issues
[*]based on latest M6 aokp source --[U][URL="http://pastebin.com/NDavjqgP"]see changelog[/URL][/U]--
[*]scrolling  improved
[*]added updated samsung apps &TW task manager  (aroma)
[*]ics notes added
[*]ics contacts widget added
[*]added sony experia launcher (aroma)
[*]160 dpi phone removed (aroma)
[*]updated browser
[/LIST]
[*]enjoy...
Installation Files
KNOWN İSSUES
- FMradio
- Bluetooth media share
-Missıng some Rom Control features (updating by releases)​
Useful Links
General FAQ
Version FAQ and Mirrors Index
Feedback / Reviews
XDA Rules
Resurrection Remix ROM Thread of MODS [Backgrounds, Toggles and more]
If you appreciate my work you can buy me a beer :)
Donate To me
Donate To Westcrip
USD
EUR
CHF
Install Resurrection Remix v3.0.3 Jelly Bean ROM Galaxy S3 (AOKP, CM10)
Install Resurrection Remix v3.0.3 Jelly Bean ROM Galaxy S3 (AOKP, CM10) - YouTube
Resurrection Remix ICS ROM 2.6 for Galaxy S2 i9100!
WATCH ZEDOMAX REVİEW
Resurrection ICS ROM Review (thanks to hypnobabes)
You are a Noob on XDA-Developers [If you really are one, please see this video ;)]
You are a Noob on XDA-Developers - YouTube
Big thanks to:
XDA developers
CM9 team
Kang (AOKP) team
WESTCRIP [Rom Maker]
zedomax [For videos]
GaboWinter [For support]
cyberboob [For signatures, images and toggles]
BigDenn [For Bootanimations]
Pier [For Support ]
Bajee11 [For support & Base Rom]
Bluefa1con [For support]
AND OF COURSE TO ALL THE SUPPORTERS, DONATORS AND USERS
Special thanks to the Beta Test team of Resurrection Remix
Maurm (Support & Testing)
Incarnation95
Rskyline
Kingspp
elias17
Infinite96
vincent47me
Beste Grüße
Martini
Reaktionen: Diomoron
gut kopiert :p
wenn du mal bei den youtube-videos noch die links änderst und vielleicht noch ein paar bilderchen + eine "kleine" deutsche übersetzung anstatt der englischen rein haust wäre das sogar perfekt :D nicht, dass ich das nicht lese oder verstehe. geht mir eher um andere.
gut wäre auch, wenn du vielleicht so 2,3 sätze schreiben könntest wo die unterschiede zu der stock-rom ist oder was dir so aufgefallen ist. das wäre dann echt perfekt.
Reaktionen: arkit, Wazula und 4MAZ1NG
@Martini3001: Entsprechend unseren Forenrichtlinien sind auch OS- & Kernel-Versionen in deutsch hier vorzustellen. Andernfalls müsste der Thread gelöscht werden. Ich bitte Dich daher, das nachzuholen!
Änderungen folgen morgen...
... ich habe es hinbekommen mein S2"G" -.- auf JB Remix zu flashen -> sofern es noch gewünscht ist, werde ich nun nicht mehr meiner schlechten Laune über das Gerät hier im Forum freien Lauf lassen, sondern versuchen die Nutzer mit sinnvollen Beiträgen zu "bereichern"...
Fazit 2.0 -> es war ein riesen Akt das S2G zu flashen, aber nun glaube ich den "Fehler" erkannt zu haben ;)
(Leider auf eigene Faust und nicht durch Ratschläge, welche ich normalerweise hier im Forum vermutet hätte..)
-- ich teste und werde berichten, vielleicht kann ich ja dem ein oder anderen etwas Arbeit ersparen :)
Der ursprüngliche Beitrag von 05:13 Uhr wurde um 05:58 Uhr ergänzt:
NACHTRAG:
Bitte vorerst nicht versuchen die ROM zu flashen eine genaue Anleitung folgt in den nächsten Tagen...
Eine Anleitung von jemanden der sich selber nicht mal richtig aus kennt*hust*
BTW: oben steht SIII und nicht SII :rolleyes:
SII - CM9 - Tapatalk
Aufpassen, dass Ihr auch wirklich die OS-Version fürs SGS2 (ohne G) erwischt!
Auch wenn die cool gestylte, aber letztendlich unübersichtliche Präsentation so schön aus dem XDA-Thread kopiert wurde, ist sie doch zu übersetzen!
Wo genau lag denn dein "Fehler"?
Der Fehler lag in der Auswahl der ROM...
Mit GT-I9100G_XXLPY_XXLPV_DBTLP habe ich es problemlos hinbekommen.
Die Verlinkung zu Resurrection Remix beinhaltet den Download für das G. Somit lässt sich die ROM ohne weiteres auf dem Gerät installieren, sofern es vorher über eine ICS-ROM betrieben wurde.
Letzteres ist entscheidend dafür, dass RR sich auf das S2G flashen lässt.
Dass der ICS-Bootloader für ICS- und JB-ROMs benötigt wird, ist ja allgemein bekannt und steht auch in ALLEN Kurzinstallationsanleitungen zu den ROMs ;)
OT:
Ich verstehe deine Aufregung (die ja mittlerweile glücklicherweise wieder abgeklungen ist) nicht wirklich :) Alle Infos die du benötigt hast sind im Forum vorhanden und dass du nachts zwischen 4 und 8 Uhr keine Antwort kriegst ist denke ich auch verständlich, die meisten Leute schlafen zu dieser Zeit :)
Aber nichts für Ungut und herzlich willkommen im G-Bereich ;)
Ja, da hast du wohl Recht, mein Fehler. Bin es vom S3 eben anders gewohnt, da geht der "Sprung" auf JB ohne den Step mit ICS... :p
Welche Recovery könnt ihr mir empfehlen? Ich habe den Eindruck, da läuft auf meinem Gerät noch etwas schief :)
Der ursprüngliche Beitrag von 17:15 Uhr wurde um 17:19 Uhr ergänzt:
Update:
Startbeitrag angepasst.
Klar, auf dem S3 war ja auch von Anfang an ICS drauf ;)
Ich nehm mal an du meinst die CWM Recovery? Was läuft an der Recovery denn nicht rund? Jeder Kernel bringt hier ja im Prinzip seine eigene mit, also ist es vielmehr die Wahl des Kernels.
Für Custom Roms (ICS+JB) ist hierbei die Auswahl derzeit sehr begrenzt. Neben den ROM-eigenen Kerneln (meist der CM9/10-Kernel) gibt es glaube ich nur noch den Horsepower.
Horsepower habe ich eine Weile benutzt, als der Entwickler dann eine Weile im Urlaub waren war er nichtmehr mit den neusten Versionen kompatibel. Die letzte Variante läuft für mich noch nicht 100%ig flüssig, aber er arbeitet dran und bald wird der auch wieder richtig stabil laufen. Vorteile: CPU von 150-1350 (bald vielleicht sogar noch mehr), Undervolting, mehr Governor, mehr Dateisysteme unterstützt...
Ich benutze derzeit CM10 mit dem CM10-Stock-Kernel und bin zufrieden :)
ive
Cloud
Cloud
debaki
Booma69
Booma69
After_Midnight
