ive
Dauer-User
- 528
Das zweite Weckersymbol gab es auch vorher schon. Sobald die Weckzeit näher rückt kommen das Symbol Links und die Benachrichtigung dazu.
Alex64 schrieb:
Die Updatefunktion verrät es dir:DAD214 schrieb:und langsam könnte ja mal ein Changelog kommen damit man überhaupt mal weis wo man dran ist
Since Tue Jan 14 11:54:01 UTC 2014
bootable/recovery
*1404ae2 correctly mount tmpfs as /tmp in recovery
*a874b5f Merge "minui: do not use flexible array initialization" into cm-11.0
*809de0b install: Fix possible overflow condition in the updater "scanner"
*a0f0fc0 install: Support downgrade scenarios
*1153ae5 Add a copy of the updater binary to the recovery resources
*b633db3 Fix potential chmod failures
*d7faa36 do not error on missing sd-ext when wiping dalvik cache
*53b6f08 do not use static type
*7a78235 Merge "Remove "Go Back" option from verify root and recovery options" into cm-11.0
*e216a26 Remove "Go Back" option from verify root and recovery options
*824447d minui: do not use flexible array initialization
*3db302b Merge "Clean up c formatting - 1" into cm-11.0
frameworks/base
*0459911 Merge "base: added national roaming info for Tuenti Movil in Spain" into cm-11.0
frameworks/opt/telephony
*39d4b1d Merge "SamsungQualcommRil: bring back operatorCheck. (1/2)" into cm-11.0
hardware/qcom/display-caf
*e249700 hwc: Add binder interface to get the visibleRegion
*1e38126 hwc: Calculate viewframe from layers display frame information.
*d38617b qdutils: Add display config to qdutils
*5d0ff23 display: Clean up binder interface
*ef73796 libhwcomposer: Log and dump app layers of screen frames
*4beb320 display: Properly handle NO_IOMMU case
hardware/qcom/media-caf
*79f361f mm-video: vdec: display: Change in screenRefresh interface
hardware/qcom/power
*b4b9303 power: Option for disabling input boost
packages/apps/Gallery2
*49db1d7 Gallery2: avoid the crash of gallery during trimming video
*75e016e Gallery2:Show title in movie activity's action bar
packages/apps/Settings
*7c4d834 Bluetooth: HID: Use proper values of connection status
*3b3fd28 Bluetooth: GAP: Avoid adding device to cached device list
vendor/cm
*9d1a861 cm: Set perms on a few additional paths
*04423d7 Merge "cm: add selective based spn (2/2)" into cm-11.0
DAD214 schrieb:
