Radagast
Ehrenmitglied
- 23.366
Das glaube ich, das dauert laaaaange .....
Da gibts auch gleich was Neues bei XDA:
Xeore-Rom <--- XDA-Link
Base 4.2.2 - SlimBean
Die wichtigsten Infos:
Viel Spaß
System Details:
Installation:
1.Make a nandroid!
2.Wipe data+Factory Reset
3.Wipe cache
4.Install zip from sdcard
5.Choose the XeoreRom.zip
6.Immediately after rom installation you have to flash the "GAPPS" or the Home-Button will not work.
7. Reboot (first reboot takes longer)
After flashing you will see , that the icons are very small.
You can fix that: Go to Settings , then go to "Interface" , then to "General" , then to "LCD density" , then "1."Change LCD Density to stock value" and took 240. After that you have to reboot.
Known issues:
If you found one , say it
- Android 4.2.2
- Aroma Filemanager
- Stable Version
- Latest Semaphore Kernel
- Newest Android Jelly Bean 4.2.2
- Added new tones (Alarm
ure Nature ,Xeore WakeUp ) (Ringtones Old but Gold,Xeore Beat,Xeore Tone)
- New Bootanimation
- Fast Booting
- Browser with Icognito-Function
- Smooth Handling
- No lags
- Smoother Navigation Bar added
- Slim Bean OTA
- Butilt in Superuser
- Better wlan-signal
- Faster Webbrowsing
Installation:
1.Make a nandroid!
3.Wipe cache
Known issues:
Viel Spaß
