Diskussionsplattform & Newsletter - JB & ICS Roms - Zubehör Übergreifend
  • 673 Antworten
Welches der ICS Roms nutzt Ihr
  • CynogenMod 9 (TeamHackSung Build)
    Stimmen: 120 36,8%
  • Onecosmic (Paul Forde Build)
    Stimmen: 119 36,5%
  • [S.U.R.F.A.C.E. (auf CM 9 Build Basis)
    Stimmen: 3 0,9%
  • MyICS ( auf Onecosmic Build Basis)
    Stimmen: 9 2,8%
  • Codename Android
    Stimmen: 11 3,4%
  • Slim ICS
    Stimmen: 17 5,2%
  • ICS-BLUES
    Stimmen: 1 0,3%
  • AOKP-Android Open Kang Project
    Stimmen: 46 14,1%
  • Umfrageteilnehmer
    326
[ROM][ICS][4.0.3] TsunamICS 1.5 [AOKP_milestone-4][UNOFFICIAL]
Rom entirely based on te excellent AOKP for Nexus S. Official forum HERE!
Thanks to the forum androidiani.com for teaching me so many things.
For all other screenshors click HERE!!!
  • Based on AOKP_milestone-4
  • Kernel Semaphore 0.9.5b
  • ZSJPG
  • Converted Amoled BLUE Theme + other customization by me
  • Blazing Fast
  • Build.prop tweaked
  • Fixed Camera, customized with Amoled BLUE Theme
  • Circular Battery from Tsunami 7
  • App Youtube,Contacts, MMS, Dialer, Google Search amd Keyboard with inverted colours
  • File Host hacked.
  • Sound system from MIUIV4.
  • Nova Launcher
  • Added more Wallpapers and Launcher Icons.
  • Deleted launcher Trebuchet.
  • Deleted Unicornporn.apk
  • Fonts Windows Mobile
  • GApps 4.0.4
  • Fixed widget Sync
  • Added Tw Framework + Samsung Apps
  • Added Task Manager Samsung
  • Added DigitalClock SGS2.
  • Added Widget Weather SGS2 glass mod by me
All other bugs are the same of the original AOKP
  • Google Play
  • Chrome Beta
  • OI File Manager
  • SpiritFM (Don't work for now. Please downgrade to an old version)
  • FoxFi
  • App Memo Samsung.
  • Google Music + Music AOSP
  • Perka's File Stash
  • NSTools
Neuauflage 1.5: DOWNLOAD!
1.5:Mediafire[10/03/2012]
  • Roman and the whole TEAM KANG
  • decalex
  • bernie66
  • ferfecir
  • PaWill
  • stratosk
  • PERKA
  • addicted2088
  • PAWITP
  • TEAM HACKSUNG
  • ONECOSMIC AND TEAM ICSSGS
  • RTPFESSOA
  • etoy
  • psyntyst
  • raffaele88
  • sonnysekhon
[ROM][ICS][3/10] Gummy for Galaxy S Nightlies by sixstringsg / xda
This is entirely untested, as I do not have a Galaxy S. SteveSpear46 and I are the maintainers for Gummy on the Galaxy S series of phones, but between the two of us we only have the Fascinate and Captivate. This works just fine on the Captivate, so should work just fine here. Here's what I need from you: flash it, then flash GAPPS, then see if it boots. If it does, awesome, check 3G connectivity. If that works, post here. If it doesn't, install the kernel here. If after flashing that, you don't get 3G, then you can post here. Other than those two things, I do not need anything else right now. I will make it clear when I am ready for other bug reports. I was having issues with 3G for a bit on the Captivate, so I need to know if those carry over to here.
The Gummy Resurrection is here!!!
We are recommending that everyone wipe data with this install.. while you may not have issues without wiping data we will still ask you to do so if you wany our assitance with issues
Team Gummy:
  • Kejar31 - Primary Developer and Project lead
  • Syaoran12 - Developer
  • Atesc - Developer
  • Sixstringsg - Developer
  • Stevespear426 - Developer
  • TKGlitch - Kernel Dev
  • PoiTEE - Forum support guru
  • Daank - Wallpapers and artwork
Info:
Notes:
  • We are no longer supporting our own Gapps.. instead we ask that you use the Gapps found at Goo-Inside.me
  • YOU MUST UNCHECK ANY OVERCLOCK UNDERVOLT BOOT UP OPTIONS YOU HAVE SET BEFORE INSTALLING
Features:
  • AOSP build based on 4.0.3 complied by me
  • Glitch Kernel- Credit TK and Glitch Team
  • Performance Settings - Credit CM / Jrummy16 / Kejar31 / Stevespear426
  • GUI manageable init.d scripts tweaks - Credit Jrummy16 / Kejar31
  • Customisable SystemU tweaks - credit Xoomdev / Syaoran12 / Kejar31
  • Battery % always available in the lockscreen (now with the option to turn on and off) - Credit Syaoran12
  • Faster rotation initiation - Credit XoomDev / Kejar31
  • T9 Dialer - Credit CM
  • Quad Lockscreen with open customizable seats
  • Customizable battery icons options ( Hide, miui, stock, fat battery with %, side bar with % and circle)
  • Softkeys can be turned on and off(only for G-Nex)
  • LED settings - credit Romanbb
  • ApexLauncher - credit Android Does
  • Pulldown Widgets - credit Syaoran12 / LTE toggle credit - CM (notice it may take a min two for your phone to make the transisiton)
  • OI FileManager (compiled with the ICS SDK)
  • Softkey Mod and settings - Credit XoomDev / Icons - WJD Designs
  • FaceBook contact sync - Credit Roman
  • AOSP Wifi tether enabled
  • Busybox
  • Su and Superuser apk - Credit ChainsDD
  • Android Term - Credit jackpal
  • Stk
  • Livewallpapers compiled and included
  • Custom Gummy live wallpaper
  • AppWidgetPicker - credit boombuler
  • All png's are optimized during build via CM script and PNG Crunch
  • Compcache support
Whats not working:
  • MMS
ChangeLog ROM:
  • <0.7.6
  1. Removed from the changelog to save space
  • 0.8.1
  1. ApexLauncher .7 - credit Android Does
  2. Full list of new features can be found here
Credit / Thanks:
  • Birdman and co for releasing his Rootz Boat which I used as a guide to get this up and going without his initial hard work there is no way I would have had this up an running in two days
  • ChainsDD for su and superuser
  • Xoomdev for all his assistance and answering my stupid questions :p
  • RomanBB for all his help and assistance
  • CyanogenMod for all they do and the way they mak everything available to all of us
  • Goo-Inside.me for hosting our builds.
  • Android Does, for letting us use thier launcher in our ROM
  • Bytemark hosting, for the buildbot/nightly hosting.
Install:
  • Download the latest THS ROM
  • Download Gapps
  • adb reboot recovery
  • wipe data in CWM
  • install ROM if on ICS already, If not Flash THS Build 2, Reboot Recovery Wipe and Flash ROM
  • install gapps
  • reboot
Files
Download Nightlies Here
Add-ons:
  • AriesPart (Minus TVouthack For now.)
Updates / Fixes:
  • None ATM
Donate:
Speacial Thanks to Teamhacksung for everything they've done. JT1134 and Sbrissen!!!
Habe die letzten Tage mit etwas mit der LCD Density rumgespielt und würde gern 210 statt 240 benutzen. Hab es mit der AOKP Control App umgestellt, aber kurze Zeit später sind alle Apps aus dem Market nicht mehr kompatibel. Habe den Wert wieder zurückgesetzt, Market Daten gelöscht und dann ging es wieder. Sobald ich wieder auf 210 stelle, will der Market nicht mehr =(
Weiß jemand einen Rat?
@quasimodo was benutzt du für ne rom
Gesendet von meinem GT-I9000 mit Tapatalk
Ja mal hier mal da, aber jetzt Stock aokp. Warte aber auf das rc5 Update von Team icssgs. Immerhin die meist genutzte Rom
Ich teste seit heute morgen die
WeUI-Miui
Läuft bisher ganz gut ... Ein kleines bisschen träge, aber wollte mal wieder Miui haben.
Berichte die Tage mal genauer
Grüße ... :D
Sent from my GT-I9000 using Android-Hilfe.de App
Oh man, mit 40 beginnt wohl langsam die Demenz ... Na klar kommt das dann in den Miui-Thread :banghead:
SORRY :rolleyes:
Liest sich ganz interessant - aber die Frage, ob's für unsere Region (Europa/Germany) taugt, wurde leider noch nicht beantwortet.
Glaub ich hau's mal drauf und schau was passiert...
by pwneman / xda schreibt ja, man soll Ihm einen Feedback geben!
Hier natürlich auch gewünscht. Danke schon im Vor raus!
Bin bei XDA nur lesendes Mitglied, deshalb schreibe ich gleich mal kurz.
Soviel schon mal vorab: Mit KF1 scheint der Empfang (lt. Balkenanzeige) schlechter zu sein als bei JVU.
Probiere jetzt mal das KB3--- (Wenn USB Debugging geht - da hab ich manchmal echt Probleme und muß das Galaxy neu starten)
... in Prozess :)
ED'IT: KB3 scheint etwas empfindlicher zu sein - 1-2 Balken mehr bei gleicher Position wie vorhin. Interessant, dass standardmäßig 3g aktiv ist, und sobald Daten fließen (Internet o.ä. springt es um auf HSDPA). Warum das so ist, kann ich nicht sagen, wird aber sicherlich seinen Grund haben und bestimmt wird mich hier gleich jemand erleuchten und aufklären.
Ich lass das jetzt mal so und schau heut Nacht mal, wie sich die Akku-Situation verhält. Habe hier ziemlich unterschiedliche Empfangssituationen und hoffe, durch dieses automaische Umschalten könnte sich das positiv auf den Akkuverbrauch auswirken.
ACH - fast vergessen: Es kommt mir unglaublich schnell vor - vielleicht kann das alles nochmal jemand bestätigen oder widerlegen - je nach dem.
Zapper
Ich habe mit dem KB3 kein Signal beim KF1 genau umgekehrt besseres Signal wie mit JVU - Netz O²
Ich habe mit dem KB3 kein Signal - Netz O²
Edit: Hebe KB3 es noch mal geflasht und siehe Da, 4 Volle Balken
Das hatte Ich mit keinem Modem zuvor - bei Mir Zuhause
So, wie versprochen gehts kurz weiter:
Akkuverbrauch über Nacht: ein Traum! In 8 Stunden 6% (das ist bei meiner Empfangslage bisher unerreicht im automatischen Modus)
Leider bekomme ich hier in der Firma, wo die Netzabdeckung ziemlich schlecht ist, KEIN 2G! Mir scheint, dass das Modem gar kein 2G kann - ist das möglich? habe also keinen Empfang :-(
Das wäre für mich das K.O. Kriterium - fände ich sehr schade, weil Internet und Datenübertragung (gefühlt) so schnell wie nie mit diesem Modem sind...
Kann vielleicht mal jemand prüfen, ob 2G wirklich nicht mit KB3-Modem geht, oder ob das Problem mal wieder VOR dem Bildschirm sitzt.
DANKE
DANKE
schaut so aus, bei mir geht 2G mit dem KB3, dauert aber eine Weile bis er es "findet" ;)
ich merke ehrlich gesagt keinen großen Unterschied zum ZSJPG, welches ich sonst immer oben hab...
im Speedtest hab ich gleich viel wie sonst auch immer, Empfang hab ich hier sowieso immer die volle Leistung, muß mal später zu Hause probieren (am Land) ...
Beim KF1 bricht bei mir übrigens der Upload zusammen, statt 2,5Mb/s nur mehr 0,4Mb/s
Hi tobiasth,
2G ist vom Empfang schlecht (bei mir). Mit JVU keine Probleme 2G zu haben, mit KF1 und KB3 nur sporadischer empfang und andauernd "nur Notrufe". Die Notrufnummern werden ja mit erhöhter Leistung gefahren - man müßte das irgendwie umstellen können, dann wäre es für mich ideal. Aber da kenn ich mich absolut nicht aus.
Zapper01
