Diskussionsplattform & Newsletter - JB & ICS Roms - Zubehör Übergreifend
  • 673 Antworten
Welches der ICS Roms nutzt Ihr
  • CynogenMod 9 (TeamHackSung Build)
    Stimmen: 120 36,8%
  • Onecosmic (Paul Forde Build)
    Stimmen: 119 36,5%
  • [S.U.R.F.A.C.E. (auf CM 9 Build Basis)
    Stimmen: 3 0,9%
  • MyICS ( auf Onecosmic Build Basis)
    Stimmen: 9 2,8%
  • Codename Android
    Stimmen: 11 3,4%
  • Slim ICS
    Stimmen: 17 5,2%
  • ICS-BLUES
    Stimmen: 1 0,3%
  • AOKP-Android Open Kang Project
    Stimmen: 46 14,1%
  • Umfrageteilnehmer
    326
Dark Night V 3 Online - steht in Post 2 zum Download bereit!
Change log 08/03/2012:
1. AOKP Rom Control.
2. External SD card fix.
3. Import from simcard.
4. Signal bar fixed.
5. Necessary apps are installed in data partition.
6. Galaxy s settings.
7. T9 Dailer.
8. New wallpaper added to launcher.
9. Build.prop and INIT.D script Updated.
10. Chrome browser fix.
11. More accurate GPS.
Integrierter Kernel: Devil_1.1.6b_BFS_BLN_CMC
Viel Spaß beim Flashen!
Reaktionen: psyfreak
[ICS] Android Open Kang Project
Change Log
  • Weather panel updates (sethyx, Zaph, tgwaste, and many more!)
    • new more compact layout that fits at the top of your screen
    • ability to hide it in your statusbar
    • added lockscreen weather to tablets
  • Added statusbar transparency (rob43)
  • Added alternate notification drawer layout (toggles/date on bottom instead of top)
  • Added day of the week before clock style option (rob43)
  • Signal text reading improvements (Zaph)
  • Added option to show lockscreen before secure unlock
  • Simplified nav bar hide/show code => should be working on all devices properly
  • Added PhaseBeam alongside UnicornPorn
  • Fixed all weird tablet FCs (was caused by that messy nav bar code
  • p4: 3G should now be working on the 3G 10.1" tab samsung tab
  • stingray: Data should be working now! Thanks travp for helping me debug this
  • added fascinatemtd
  • added a500
  • vzwtab renamed to galaxytab7c, also now using MTD instead of BML. No m4 for it yet.
aokp_galaxysmtd_milestone-4 Online & steht zum Download bereit!
Hat jemand von Euch eine Idee, warum ich bei keiner ICS-Rom HSDPA kriege?
Weder per Toggle noch per Einstellungen ...
Natürlich alles sauber geflasht und erneut geflasht usw ... APN stimmt auch
Merkwürdig ist, dass ich bei Doc's Master kurzzeitig HSDPA hatte, danach nie wieder bei Slim-ICS, CNA und Dark Knight ... :(
Gesendet von meinem GT-I9000 mit der Android-Hilfe.de App
ich würde noch mal 2.3.6 flashen und dann ohne dalvik cache zu löschen wieder auf ics dann muss es gehen. Hatte noch nie probleme damit.es lief mit jeder zur zeit aktuellen rom bei mir
Reaktionen: Radagast
Hallo zusammen!
Kann mir jemand sagen, was an einer ROM für das Auslesen/Festlegen/Anzeigen des Mobilfunkproviders zuständig ist?
Mein Provider ist KD Mobile, mir wird aber O2 angzeigt. KD Mobile nutzt das O2-Netz, insofern ist das auch richtig. Unter GB wurde mir aber auch richtigerweise KD Mobile als Provider angezeigt. Auf dem SGN unter ICS (Stock) wird KD Mobile auch korrekt angezeigt. Das SIM-Toolkit für ICS habe ich auf dem SGS nachinstalliert, es funktioniert auch, bringt aber nichts hinsichtlich der Anzeige des Providers, immer noch O2.
Deshalb meine Frage: Gibts ne Möglichkeit, das auf KD Mobile ohne großen Aufwand umzustellen?
Irgendwie kommt mir das so vor das alle ICS version mehr oder weniger auf AOKP basieren oder täusche ich mich da so stark?
Ausser die Slim und 4.0.4 von ELITE
Hier könnt Ihr Eure Bugs die im Dark Night Release auftreten eintragen
Dark Knight ROM BUGs zur Hilfe
btclpat reicht es an den Entwickler weiter. Besten Dank an dieser Stelle!
Wäre sicher Klasse wenn sich User bereit erklären, dies auch für die andern ICS Roms einzurichten.
Freue Mich auf die Unterstützung!
Hi allerseits,
bin auf Milestone4 und bekomme das FM-Radio nicht zum Laufen. Irgenwo habe ich gelesen, dass eine Einstellung geändert werden muß, finde es aber nicht wieder und krieg es nicht geregelt. Weder über Kopfhörer, noch über Lautsprecher - "Schweigen im Walde".
Was muß denn da nun eingestellt werden?
Danke schon mal
Zapper
Leider keine ahnung was man da einstellen muss. Als alternative lad dir spirit fm im market.
FM Spirit hab ich ja - wird das nicht sogar mit der Rom geliefert?
[ROM][ICS][4.0.3] TsunamICS 1.5 [AOKP_milestone-4][UNOFFICIAL]
Rom entirely based on te excellent AOKP for Nexus S. Official forum HERE!
Thanks to the forum androidiani.com for teaching me so many things.
For all other screenshors click HERE!!!
  • Based on AOKP_milestone-4
  • Kernel Semaphore 0.9.1
  • ZSJPG
  • Converted Amoled BLUE Theme + other customization by me
  • Blazing Fast
  • Build.prop tweaked
  • Fixed Camera, customized with Amoled BLUE Theme
  • Circular Battery from Tsunami 7
  • App Youtube,Contacts, MMS, Dialer, Google Search amd Keyboard with inverted colours
  • File Host hacked.
  • Sound system from MIUIV4.
  • Nova Launcher
  • Added more Wallpapers and Launcher Icons.
  • Deleted launcher Trebuchet.
  • Deleted Unicornporn.apk
  • Fonts Windows Mobile
  • GApps 4.0.4
  • Fixed widget Sync
  • Added Tw Framework + Samsung Apps
  • Added Task Manager Samsung
  • Added DigitalClock SGS2.
  • Added Widget Weather SGS2 glass mod by
  • Fixed app SoundRecorder
All other bugs are the same of the original AOKP
  • Google Play
  • Chrome Beta
  • OI File Manager
  • SpiritFM (Don't work for now. Please downgrade to an old version)
  • FoxFi
  • App Memo Samsung.
  • Google Music + Music AOSP
  • Perka's File Stash
  • NSTools
1.5:Mediafire[10/03/2012]
  • Roman and the whole TEAM KANG
  • decalex
  • bernie66
  • ferfecir
  • PaWill
  • stratosk
  • PERKA
  • addicted2088
  • PAWITP
  • TEAM HACKSUNG
  • ONECOSMIC AND TEAM ICSSGS
  • RTPFESSOA
  • etoy
  • psyntyst
  • raffaele88
  • sonnysekhon
Also bei mir hat sich das automatisch aktualisiert auf 3.4.7 (Team ICSSGS RC4.2)
kann mir einer sagen wie man navigon zum laufen bekommt, wenn die maps auf der externen sd liegen?
SaschaKH
SaschaKH
kingoftf
Islaris
Islaris
Q
yosenami
Y
