Q
quasimodo
Gast
Platzhalter
quasimodo schrieb:@ Hallo Criz89,
Ja, die Gibt es!
Wenn man alles Sauber flasht, gibt es mehre Alternativen.
Da währen vorneweg
- HellyBean (Devilkernel)
- CM10 Base
Am sichersten bist Du aber mit der letzten CM9 Stable.
Wenn du für einen Greenhorn flashst, kannste da nicht verkehrt machen. Gelle!
@ An Alle!
Neu gelistet: [ROM][CodeNameAndroid] - JB 3.3.0
tacx schrieb:Hi Everyone,
I'm Chris known also as Tacx and this i my first ROM build from sources, so this is just the beginning. I'm still in the learning phase of Android Mechanics. So let's begin:
This is a Android 4.1.1 ROM. This ROM it's based on CM10 sources with some small source modifications. Very simple and clean system.
ROM Information
- Android 4.1.1 based on CyanogenMod Source 29/09/2012
- Semaphore Kernel 2.2.0
- Pre-rooted
- WiFi Tethering
- HD 720p Video recording
- Full USB transfer speed
- Google Apps
- Face Unlock
- Semaphore Script Manager
- Build.prop tweaks
- Apollo Music Player
- Purple Status Bar (I can remove this if you don't like it xD)
- Solid Explorer as file manager
- Stock Nexus Jelly Bean Bootanimation
- RextonJB Updater (My app for OTA ROM Updates Download from the section below)
- Weekly Updates (I try to bring every Weekend a new update, if not it will be every 2 weeks)
Installation:
I am not responsible for bricked devices, dead SD cards and so on xD !!!
- DOWNLOAD ZIP
- COPY TO YOUR INTERNAL SD
- WIPE DATA/FACTORY RESET.
- WIPE CACHE PARTITION.
- FLASH AND THEN REBOOT
Downloads
RextonJB v1.0 - Click Here (Dropbox for the moment)
RextonJB Updater - You can find it on the market BUT it's not working properly yet. (I'm trying to fix it as soon as possible)
Special Thanks and Credits
- CyanogenMod for their awesomeness
- jfupdater and cyanogen for the base files of the RextonJB Updater
- Chainfire for CWM Manager
- XDA for this great Community
AceofSpades90 schrieb:Changelog:
-New System CM10/Hellybean partition (1.5 GB for data)
-Fixed reboots when you install apps
-No Facelock(Cappy don't use it, sorry)
-CM messaging app (More messaging limit?)
-CM wallpapers (no reason? lol)
-CM clock (has timer and stuff)
-CM calculator (more features)
-Added Exchange2
-Tweaked Hack from X-Bean 2.0
-Latest Devil kernel 1.6.1 VC (VSYN)
-Added back TV out
-Several Init.d tweaks
-Build.prop tweaks
-LANIGHT stock bootanimation
-Compiled with latest Google AOSP sources
-KC1 modem is added back (?)
-GPS hack is added as promised
-Tweaked appearance (If you're using 4.2, it'll feel like home)
-All the features from v6.0NDD and more
-Several other tweaks
-Took out the landscape mode from launcher, it was causing issues
Download: LINK IS UPLOADING IN 30 MINS![]()
