Datenbank, Kurzvorstellung & Erfahrungsberichte aller bekannten ICS- & JB-Roms
  • 133 Antworten
Es gibt wieder ne neue Rom:
Eine im Xperia S-Style ...
Screenshots ganz unten ...
Erster Eindruck: göGar nicht übel ... ;)
XDA-Link: http://forum.xda-developers.com/showthread.php?t=1738492
ALESSIO94x schrieb:
Do you like the Xperia S Style? Try this wonderful ROM and you will be able to enjoy all the amazing features powered by Sony!
Here is the full features:
-Sony Walkman Music Player
-Full Xperia S Launcher
-Live wallpaper "Cosmic Flow" by Sony
-Full Xperia themed UI
-Xperia Notes
-All Xperia Widgets (including clocks, ON/OFF Tools, Photo Widget and Weather Widget)
-Xperia S Keyboard
-Original Xperia S Fonts
-Xperia S Sounds (including ringtones, alarms and notifications)
-Xperia S bootanimation
-Kernel Devil3_0.79 with Devil Kernel Config inside
-Based on AOKP b40
For enable Xperia S gallery, just install this APK after the first boot ;)
LATEST VERSION
DOWNLOAD 1.0
OLD DOWNLOADS
OFFICIAL PROJECT WEBSITE
Xperia S Wallpapers
GAPPS
Thanks to:
DaXmax - Xperia S Apps
ra3al - Xperia S Launcher
jasonevil - Xperia S Theme
sdk16420 - Xperia S Keyboard
T.a.p.a.2.t.a.l.k.e.d
Reaktionen: beicuxhaven
Darky hat seine v11 veröffentlicht, ist eine ICS-Rom:
Darkyrom v11 black Edition
Link: http://darkyrom.com/index.php?threads/darkyrom-v11-0-black-edition-android-4-0-4-ics.7941/
Dear Community,
The newest downloadable and stable ROM for the Samsung Galaxy S is: DarkyROM v11.0 Black Edition A fully stable Android 4.0.4 Ice Cream Sandwich ROM which works excellent out of the box.
Rememberthatthis ROMis only for the SamsungGalaxy S (codenamed GT-I9000). Itis not meant for the American variant (I897).
The features.
Based on Android 4.0.4 AOSP Extras from CM9, AOKP and Slim Clean stock Android 4 Ice Cream Sandwich theme Fast & responsive user interface Long lasting battery life [tested] Fast & reliable GPS BLN support [backlight notifications] Voodoo Sound [formuch better sound] T9 Dialer Extended statusbar toggles Smooth Android 4 Ice Cream Sandwich Launcher Google Apps Fully rooted Galaxy S III ringtones, SMS and alarm sounds Easy & fast install engine
The look & feel. Look here.
The changelog. Can be found here.
The installation guide. Click here for a tutorial.
The download. DarkyROM v11.0 Black Edition @sourceforge.net
Mirror download - by Totallydubbed
Credits. Click me.
Happy flashing!
- DarkyROM.
[ROM] RCMP | 20120704 | Salad bar | Jellybean themed | Full of essential nutrients!
Am 1.7. ist ein weiteres auf CM9 basierende Rom an den Start gegangen
Jellybean themed
FEATURES
- CyanogenMod 9 base
- Bottom statusbar
- Brightness toast panel
- Gradient background fix
- Settings: GPS toggle & status info
- All-In-One Salad Bar (combined navigation & statusbar)
* swipe up to expand
* customizable power widget
* same button layout as stock navigation bar
* key button popup effect
- Jellybean framework drawables
- Few of my other patches
Der ursprüngliche Beitrag von 20:44 Uhr wurde um 21:57 Uhr ergänzt:
Habe alle Listen aktualisiert - sollte noch was fehlen bitte Bescheid geben. Danke!
@ Hallo Carsten, Nachfolgendes in Post 1 übernehmen, altes zuvor in Post zuvor Löschen (Links haben sich geändert ) Danke!
Offizielle
- und modifizierte Rom Ports
AOKP
1 und 17
CM9
1 und 9
ICSSGS
1 und 2
CNA
1 und 1
Elite & Dark Night
2 und 4
weitere AOSP Projekte
MIUI V4 ICS Builds & MIUI Ableger Qiss Me
10
Reaktionen: Radagast
Geändert,
Danke, Qasim !!!!
hatte bisher immer offizielle FW's (auch wenn für ein anderes Land) geflasht. Welches ICS Rom hat die wenigsten Fehlfunktionen ? Ich möchte halt am besten keine Nachteile (höherer Akkuverbrauch, GPS, WLAN, fehlende Funktionen etc.) gegenüber z.B. JW1 2.3.6 haben.
Danke
Alter, wieso so ein Thread? Alle sind bugfrei
Gesendet von meinem GT-I9000 mit Tapatalk
Da werden Dir nur wenige Leute eine ausführliche Antwort geben können. Denn die wenigsten werden alle ROMs und alle Versionen getestet haben. Jeder wird unterschiedliche Schwerpunkte haben, die für den jeweilgen User ein ausschlaggebendes Kriterium darstellen. Allgemein kann man schon sagen, dass es mittlerweile nicht wenige alltagstaugliche ICS-ROMs gibt. Am besten wäre es, wenn Du in die jeweiligen Threads hier und im XDA-Forum reinschnupperst, dann solltest Du recht schnell ein Gefühl dafür bekommen, welche ROM etwas taugt und welche nicht. Da wirst Du kaum drumherum kommen.
Ich selbst bin seit ein paar Wochen auf TsunamICS und sehr begeistert. Die ROM ist schnell, relativ bugfrei, sieht gut aus und ist gut ausgestattet. Damit solltest Dueigentlich keinen Fehler machen.
Aber wie gesagt, Du wirst nicht umhin kommen, Dir selbst nen Eindruck in den jeweiligen Threads zu verschaffen, da jeder User andere Schwerpunkte setzt. Für den einen ist genau die Funktion wichtig und das Kriterium, während für andere genau dieses Kriterium unwesentlich ist.
Ich hoffe, ich konnte Dir ein wenig weiterhelfen.
Ich mag eher Stockversionen. Brauche also nicht irgendwelche schnick schnacks. Komme von der JW1 2.3.6. Mir sind alle Grundfunktionen wichtiger als irgendwelche optischen Änderungen etc.
Alle sind Bugfrei ? Wenn es so wäre gäbe es doch finale Versionen oder ?
Ich würde auch nicht behaupten, dass alle CRs bugfrei sind. Ich selbst habe seit gestern meine erste CR (AOKP) drauf. Nach etlichen Stunden lesen und Videos schauen habe ich mich dazu entschieden. Habe nur einen nervigen Bug im Alltagsgebrauch entdecken koennen (W-Lan Tethering geht nicht). Gerade jetzt nach einem Tabletkauf. Andere haben mir aber bestaetigt, dass es funktioniert.
Auf jeden Fall wuerde ich es wieder tun, denn mein SGS läuft fluessiger als ab Werk. Ueberlege aber vllt wegen dem Bug eine andere zu flashen.
Ist wirklich für mich schwer zu entscheiden. Wenn Cyanogenmod 9 final wäre würde ich mich trauen, da es sehr bekannt ist.
Anders formuliert. Gibts eine ICS Version, welche genausogut läuft wie Stock-ICS auf Nexus S ? Alle Funktionen A-Z ohne Ausnahmen und Bugs ?
Probier´s doch einfach aus. Wenn Du nicht zufrieden bist, gehst Du schlicht wieder auf Deine AusgangsROM zurück. Fertig. Das ist doch alles kein Hexenwerk.
Nein. Das eine oder andere wirst du immer finden.
Also entweder damit leben oder dir andere Wege suchen um dir das ROM dann anzupassen
Ich persönlich bin eigentlich auch eher Stock affin. Einfach deshalb weil diese ROMs in der Regel am besten funktionieren, bzw. alle features am besten nutzen.
Nun ist es aber so dass die Custom-ROMs mittlerweile doch vieles bieten was man sich bei Stock ROMs wünscht und gleichzeitig auch noch so gut wie alle features des Geräts nutzen.
Was bei allen Custom ROMs (ich beziehe mich jetzt mal nur auf ICS, alles andere ist für mich uninteressant) nicht zu gehen scheint, ist der TV-Out, bzw. er geht zwar, aber Videos ruckeln.
Bisher getestet habe ich Onecosmic/ICSSGS/Nyx, AOKP und remICS. Mein favourite ist letzteres, weil eben die Jungs versuchen so Stock wie möglich zu sein, oder anders ausgedrückt, so auszusehen wie ein Update von Samsung selbst. Daher verwandelt remICS auch unser SGS ein Stück weit in ein SGS3 ;-)
Hier meine Reviews dazu:
https://www.android-hilfe.de/forum/...n-ics-jb-roms.212919-page-3.html#post-3430955
https://www.android-hilfe.de/forum/...n-ics-jb-roms.212919-page-3.html#post-3494264
Letztlich kann ich aber auch nur allen anderen zustimmen: Nur Deine eigene Erfahrung kann Dir das für Doch optimalste ROM zeigen.
"Danny Crane. Name an der Tür."
Genauso bin ich auch. Stehe auf Stock.
Ist remICS die einzige Version, welches nah am Stock ist ?
Wenn ich bis auf TV-Out, was ich nie nutze, keinerlei Nachteile gegenüber JW1 haben werde (System-Performance, Spiele-Performance etc.) wäre es interessant.
Meikel_61 schrieb:
Und nun bitte nicht wieder, das jeder seinen Favoriten empfiehlt, das bringt keinen mehr weiter. Wie jedesmal, wenn wieder hier die gleiche Frage gestellt wird.
Aber das ist doch genau der Punkt.
Wenn man das "beste" ROM sucht hat man nur 2 Möglichkeiten. Entweder man liest den eigens hierfür eingerichteten Thread
https://www.android-hilfe.de/forum/...ichte-aller-bekannten-ics-jb-roms.212919.html
oder man testet selbst.
Macht man keines von beiden, muss man sich eben auf die natürlich subjektiven Aussagen der User verlassen.
"Ein klassischer Schmosby."
Genau das ist es doch, man muss einfach mal selber etwas tun, nämlich mal lesen. Und nicht immer wieder die gleichen Fragen neu stellen.
Gesendet von meinem GT-I9000 mit der Android-Hilfe.de App
Ist remICS die einzige Version, welches nach am Stock ist ?
@obdan_van_darg
Die Antwort auf die Frage von mirac wäre für mich auch interessant. Was kannst du dazu sagen ? Danke.
SaschaKH
SaschaKH
kingoftf
Islaris
Islaris
scorp182
sgs9000A
sgs9000A
