Datenbank JB & ICS (AOSP) * Mods-Apps-Widgets-Launcher-Fixes * Für Entwickler
  • 106 Antworten
[APP] [NO ROOT]%100 ICS Blue SGS2 Digital Clock Widget for ALL ROMS and ANY LAUNCHER. by xda
Modded by me. Working on all ICS, GB phones and launchers. It's %100 matched with ICS Blue. And fixed for all languages.
Just Click to install. You don't need root or anything.
Click thanks if you like it.
Reaktionen: raXoN
New Google Play Store v3.5.19 by lnando84 / xda
A new version of the Android Play Store (formerly Android Market) is now available!! As far as I can tell, there isn't anything visibly different from v3.5.16 so it looks like the new updates are all "under the hood" one's. If you're like me and can't wait for it to auto update, get it here!! Install the apk as you would any other..
Reaktionen: Radagast
Wo finde ich denn den recovery fix, zum flashen mit odin??hab ihn in etlichen beiträgen schon gesehen, finds aber nicht mehr
Tausend dank im voraus:):beer:
mmmmmmh... Ice Cream :p
Tausend dank :):beer::):D
Mein Mirror für Dich
FixRecovery.tar.md5 (7.1 MB)
Multiupload.nl - upload your files to multiple file hosting sites!
Wird auch gleich mal in (Post1) der Diskussionsplattform ICS Kernel Übergreifend / für - CM9 - Onecosmic - MIUI V4 platziert.
Unter Kompatibel mit allen ICS Roms gelistet
SuperSU v0.89
Changelog 07.05.2012 - v0.89
- Fixed stay-on-top issue
- Fixed possible exploit
- Improved security
[DEV] Reloaded ICS 1.9b4-050712 | CyanogenMod 9 UI Enhancements | All phones by rob43 / xda
For all phones running CyanogenMod 9
FEATURES
Transparency
Status Bar Layout
Date Format
Brightness Control
Horizontal Recent Panel
Clock Location
Power Widget Enhancements
Tabbed Layout
Bottom Statusbar
Volume control
Statusbar Theming
INSTALLATION
Reloaded ICS replaces the default user interfaces and adds many options for you to choose from.
Install CWM zip in recovery, clear dalvik cache, and reboot.
After reboot, click on the settings button in your expanded statusbar, or find the Reloaded ICS icon in your app drawer.
For a video installation/review guide, check here:
REQUIREMENTS
Any Deodexed CM9 ROM
Reloaded ICS is not compatible with tablets.
DOWNLOADS
All files are attached below this post.
Version 1.9b4
MD5: 143a126819feaf7b8b91dc166afac422
Older Versions
Version 1.9b3 - MD5: dcbbd4e828786934568137cac213da26
Version 1.9b2 - MD5: 8b3d691584ba53d3f585ede12b53cd1b
Version 1.7 - MD5: 8d47337480b6ced2fdf59ddbd200d05e
Version 1.51 - MD5: 4406321665a93996cad960a51980836e
Version 1.5 - MD5: e78b6ba1c3bb8fc75dceac6aecfea753
Version 1.4 - MD5: a2a5deefe6ffd2fd8b5a058c15f346a9
BUG REPORTING
If you experience a FC with Reloaded, and want it fixed for your device, please use logcat to help locate the problem.
More information is available on this thread: http://forum.xda-developers.com/show....php?t=1378491
Using pastebin or a pasting service is recommended.
TESTED ON
http://forum.xda-developers.com/show...&postcount=233
This should work on all phones with CM9. This list is just some of the devices that have been tested.
DONATOR HALL OF FAME
Alexey B
Perka
drfr
mudferret
Aloïs
Rsloan
knirirr
NeoWiz73
inversechi
maxiclo
CHANGELOG
May 7, 2012 - Version 1.9b4
Statusbar icon alignment bug fix
Reloaded Settings bug fixes
New color settings for wifi/data indicator & data type
Updated power widget icons to new CM ones
Full Circle battery set added
Stock signal/wifi icons with transparency
(thanks to lilxflip for the stock transparency icons)
Lots of other bugfixes
Known issues:
Small display bugs while changing settings - toggle themes on/off to fix
CM9 Torch toggle requires you to have torch app installed (net.cactii.flash2)
(not really an issue but listed here to avoid erroneous posts)
USB string bugs in certain kangs
April 10, 2012 - Version 1.9b3
All text color bugs fixed when no themes are applied
Initial battery icon implementation, 6 different types, more to come
Alternate notification style, inspired from fake Jellybean screenshots
Wifi/bluetooth switches no longer jump, acts like Settings toggles
Other bugfixes
April 2, 2012 - Version 1.9b2
Restarting UI no longer necessary for changes
Theming
New app to allow better organization
Navigation bar customization (CM9 navbar editing patched in)
New wifi/3g/battery icons to allow for theming
Too many to list!
March 20, 2012 - Version 1.7
Audio widget - volume slider in statusbar
Widget ordering, select how you want audio/backlight/power widget displayed
Hide auto-brightness button option
Date positioning options as requested
Large battery text style
Updated Reloaded Settings
THANKS
CyanogenMod Team
All my donators for testing and sending me logs!
thebobp, Munfered, Recess, RATBORG (testing)
AOKP Team (Brightness Slider, Recents Panel)
htzs, Alois (icons)
djdarkknight96 (power widget icons, 1.51)
Android Team
update-reloaded-1.4-cm9-031112.zip - [Click for QR Code] (987.2 KB, 4408 views)
update-reloaded-1.5-cm9-031512.zip - [Click for QR Code] (1,002.0 KB, 1209 views)
update-reloaded-1.51-cm9-031712.zip - [Click for QR Code] (999.3 KB, 1382 views)
update-reloaded-1.7-cm9-032012.zip - [Click for QR Code] (1,006.1 KB, 6117 views)
update-reloaded-1.9b2.cm9-040112.zip - [Click for QR Code] (1.03 MB, 5421 views)
update-reloaded-1.9b3-cm9-041012.zip - [Click for QR Code] (1.39 MB, 12455 views)
update-reloaded-1.9b4-cm9-050712.zip - [Click for QR Code] (1.75 MB, 4947 views)​
[CWM] [Script] CM9 Slimmer 1.0 | Delete Bloatware, Free up memory and RAM by burakgon / xda
That's very very basic script that deletes some bloatwares from CM9.
I just bored from deleting these apps after flashing every nightly and made this flashable script.
You can flash it after flashing every nightly.
This script will delete this apps:
  1. CMWallpapers
  2. Email
  3. Exchange
  4. Galaxy4
  5. HoloSpiralWallpaper
  6. HTMLViewer
  7. LiveWallpapers
  8. MagicSmokeWallpapers
  9. PhaseBeam
  10. PicoTts
  11. RomManager
  12. LiveWallpapersPicker
  13. NoiseField
  14. VisualizationWallpapers
  15. DSPManager
  16. Stk
  17. VoiceDialer
  18. Term
  19. VpnDialogs
  20. VoiceDialer
  21. GoogleBackupTransport
  22. GoogleFeedback
  23. GooglePartnerSetup
  24. GoogleTTS
  25. GenieWidget
  26. FaceLock
Download and more info
APPS [ICS] S Voice (S3), ICS Blue SGS2 Digital Clock Widget & Dandelion Galaxy S3 Live Wallpaper
Mein Screenshot
(1)
[APP] [ICS] S Voice (S3) by sbnaul / xda
Found this while browsing... Its an app from S3... Just extract and install like a normal apk from the download link given below...
Download Link :
S Voice
I just played a bit with it...
Original thread where i got it from :
S Voice
Tested on Slim ICS as i am using it...
(2)
[APP] [NO ROOT]%100 ICS Blue SGS2 Digital Clock Widget for ALL ROMS and ANY LAUNCHER by burakgon / xda
This widget only for personel use. I just modded this widget for Doc's Master ICS ROM. That's not allowed to add it your ROM.
(3)
Dandelion Galaxy S3 Live Wallpaper !!!! by
whereiamro / xda
Dandelion Galaxy S3 Live Wallpaper !!!! I found it on internet ...
Im not the author..
I just shared !!
Download :Zippyshare.com - i9300lwp.apk
[APP][MOD][4.0+] MIUI v4 Superuser & Permissions for non-MIUI Roms
I liked the simple superuser and permissions management of MIUI v4, so thought I'd port it to work on any ICS rom. Attached is a flashable zip. Screenshots explain it all really, it covers root permissions management as well as a few other permissions in a stylish and simple way. Note that this zip will replace Superuser/SuperSU so always take a backup first. I'm not responsible if something goes wrong and you haven't.
Any questions which I realise the answer should be in the OP, will be when I have time. Also if I messed something up in the zip I'll fix tonight, but it should be OK.
Please note that it defaults to not allowing any root permissions, but when an app tries to access them it will give you a dialog explaining as much, with a link to go to settings and turn on root permissions, so this shouldn't be an issue.
Questions you shouldn't ask:
Does this work on gingerbread/froyo etc.
Answer: NO, its ICS only.
Does this work on MIUI v4?
Answer: Probably, but if your on v4, you already have it so don't waste both of our time trying.
Anything not specifically related to this apk.
To Do: Fix the horrible English :p
(Never mind the horrible theming of title/status bar etc which I did whilst bored, its actually running on Evervolv 0.8.1 on HTC Desire)
Samsung started blocking S-Voice service for non S3 phones...Because S3 not released for public yet but everyone started using theri servşce with old phones
I readed a new hacked S-voice apk for solution of this problem...Don't tested yet...
For new hacked S-Voice: www.mediafire.com/download.php?4t459mb5xhsg7tv
Also maybe this post can help also:
http://forum.xda-developers.com/show...&postcount=238
P.S: Editing build.prop to GT-I9300 may break some apps...
TWICS-CM9-Nightly-Addon
Samsung-Addon-Pack: CM9 (i9000) im SGS3-Look
Bored with Stock-CM9? But you go crazy when you don't get your nightlies day by day? You like the SGS3 style and miss some features of the stock ROMs?
Then I have this for you!
The TWICS-CM9-Nightly-Addon-Pack adds a bunch of stock-apps that where ported by xda-members, some SGS3 feeling with (system) sounds and icons directly ripped from leaked frameworkres.apk/systemui.apk/systemapps of the SGS3 ROM and many more features.
You can flash it over every CM9-nightly...day by day
Instructions:
1. Install your CM9-nightly like you do it always (wipe cache/dalvik, flash nightly, flash gapps, flash the kernel of your choice...I persnonally recommend mnics, then boot the phone)
2. Reboot to recovery and flash the slimfast zip (this will remove some system apps, because it needs space...eg: trebuchet, some livewallpapers) Thanks to burakgon!
3. Install the TWICS-CM9-Nightly-Addon and reboot.
Content:
- Modified TouchWiz 4 with SGS3 icons
- themed a bit
- SGS3 ringtones, system-sounds, alarmsounds (beautiful), notification sounds
- Samsung Apps:
Appstore,
Memo
Accuweather-widget,
Digital-clockwidget,
Memowidget,
Taskmanager,
Angry-GPS,
Calculator,
SGS3-Livewallpaper
EXTRA-Apps (uninstallable)
- CM9-Nightly-App (shows the changelog of cm9-nightlies with donwloadlink)
- File-Explorer
- App Backup and Restore
- Swype
- Voodoo-Sound
- Mrmad-App (Read our blog, and get notifications whenever we release an update of TWICS-ROM or the Addon-Pack)
- and more
Download-Links und Anleitung in Deutsch finden sich auf mrmad.net.
Mein Mirror: http://www.multiupload.nl/LN7U2SW6VUhttp://www.multiupload.nl/LN7U2SW6VU
VIDEO: http://www.youtube.com/watch?feature...&v=9EMwTtBYsE0 (some icons changed to orgiginal SGS3-Icons)
Credits:
pawitp
teamhacksungs
Samsung
supercurio
robinrg86
pfsolutions
apposite Designs
TeslaCoil Software
SAND STUDIO
DemiDoef
zeitgeist181
dhiru1602
burakgon
Jarmezrocks
__________________
TWICS!
Ich kriege das Nightly AddOn Pack nicht herunter geladen. Mediafile öffnet ne leere Seite.
4 Browser versucht :confused:
Gesendet von meinem GT-I9000 mit Tapatalk
Guten Morgen,
Komisch, bei Mir geht es, 76,9 MB werden runter geladen.
Mein Multiupload ist in der Mache, habe ein wenig Geduld!
Edit: Online
Mein Mirror:
Reaktionen: susdiehl und Radagast
Das AddOn hat bei mir einen Fullwipe gemacht ... das nur zur Kts, falls wer unterwegs flashen will (wie ich :love:) und keine Lust auf neu einrichten hat ...
Eine Frage: Wie viel RAM verbraucht TWICS CM9 Theme und lohnt es sich?
