Q
quasimodo
Gast
P.S; It will work on all Custom[ICS]ROMs.
http://forum.xda-developers.com/showpost.php?p=24733685&postcount=1366
Quelle xdahttp://forum.xda-developers.com/showthread.php?t=1328461&page=137
How To Fix External SD!!
Requirments;
Directory Bind [Download];DirectoryBind_0.2.0k.apk - 4shared.com - online file sharing and storage - download - Dashu
Rooted Phone
How To Fix It;
Download & Install Directory Bind
Open It
Press The Menu Button
Click Add New Entry
On the Source Path type /emmc/
On the Mount(target) path type /sdcard/ecternal_sd/
Then Hit! Add!
Then you will see the entry there will be a disk sign in grey color just press it once and it'll be green
Then Exit the app goto file manager
/sdcard/external_sd/
And your files will be there
Hope This Helped You
barome bestädigt
Yes it's work. Originally, external SD is emmc. This app rename this folder.
Requirments;
Rooted Phone
How To Fix It;
Open It
Click Add New Entry
Then Hit! Add!
barome bestädigt
addingLeft="@dimen/status_bar_recents_item_padding" - android
rientation="horizontal" - android:clipToPadding="false" - android:clipChildren="false"> + android:layout_centerVertical="true"> + + <ImageView + android:gravity="center" + android:layout_width="match_parent" + android:layout_height="match_parent" + android:layout_marginTop="0.0dip" + android:src="@drawable/status_bar_recents_background" + /> + + <com.android.systemui.recent.RecentsHorizontalScrollView + android:id="@+id/recents_container" + android:layout_gravity="bottom|left|center" + android:scrollbars="none" + android:fadingEdge="none" + android:fadingEdgeLength="0.0dip" + android:clipChildren="false" + android:clipToPadding="false" + android:layout_width="match_parent" + android:layout_height="wrap_content" + android:layout_marginRight="0.0dip" + android:stackFromBottom="true" + android:divider="@null"> <LinearLayout android:id="@+id/recents_linear_layout" - android:layout_width="wrap_content" - android:layout_height="match_parent" + android:layout_width="match_parent" + android:layout_height="wrap_content" android
