Q
quasimodo
Gast
- Themenstarter
- #241
MIUI ROM 2.10.12 Changelog
MarkHUK
MIUIAndroid Site Owner & Server Admin
Translator of MIUI ROM into English since September 2010 & various other mods / hacks
Donate if you want to: http://bit.ly/9hWYa6
MarkHUK, Today at 6:53 AM
[System]
[Phone]
[Contacts]
[Messaging]
[Lock screen, status bar and notification bar]
[Desktop]
[Music]
[FM Radio]
[Calendar]
[Anti-disturb / DND]
[Notes]
[Alarm Clock]
- Optimise current themes in the program selector icon
- Optimise global search when using the current theme icons
- Fix issues with insensitive touch screen, also optimise click operation accuracy
- Fix some devices IMEI numbers can used to erase phone data (USSD Exploit)
[Phone]
- Add T9 search can switch between "alphabet" and "phonetic" search modes
- When hanging up call, fix in some cases will lead to FC errors
- Fix CDMA operator display name does not change with the system language is modified
- Fix in some cases, the missed call reminder ringtone will not stop alerting
- Fix in some cases, call log list avatars do not refresh
- Fix call answering interface and call interface shows overlapping in some cases
- Fix in some cases, the caller interface leads to FC errors
[Contacts]
- Fix when restoring contacts backup, avatars display with problems
[Messaging]
- New, If you have not opened through the network SMS to open the SMS list prompts (10-09)
- Optimise SMS expression types
- Optimise searching SMS messages or bulk SMS will be merged into one result list
- Fix issue with Phrases content not being hidden when English language is selected. Tab sliding right will lead to FC error
- Fix when sending network SMS, send and receive status displays error issues
- Fix when MMS is received, before message has been read, the notification will be repeatedly prompted
- Fix received time for MMS in notification bar shows incorrect details
- Fix HTC phones cannot send MMS message
- Fix network SMS messages cannot be sent to foreign numbers
- Fix problem with SIM card SMS contact names length
- Set the maximum number of prompts for the first time SMS is used
- Optimisation of phone misuse system default
[Desktop]
- Fix adding a Widget to new screen, the display of the widget is not centered correctly
- Fix in some cases, the dynamic effect of the free desktop widget does not show correctly
- Fix Photo frame widget pictures cannot be replaced / edited
- Optimise Taiwanese version, alter the camera anti-flicker (banding) frequency from 50Hz to 60Hz
- Optimise video camera frequency limits
- Optimise focusing quality of videos by tapping on screen area to be focused on
- Fix burst mode cannot be muted
[Music]
- Optimise lyrics adjustment state inside the user interface
- Optimise smart removal of lyrics at the end of line with extra blank line
- Bug fix for 4x1 Desktop Widget album cover display
[FM Radio]
- Fix headphones no longer prompt to be inserted on some devices
- Fix recorded radio is not displayed in the list of recordings
- Fix when Caller ID is unknown / empty, call recording will lead to FC errors
- Fix recording 'title' display shows incorrect information
[Calendar]
- Contact birthday reminders, fix porting to 4.1 android system
- Fix, turning off anti-disturb function and issues relating to unknown caller
- Fix, some types of number prefix are missing after being added to the Blacklist
[Notes]
- Fix in certain circumstances, the notes text displays some overlapping problems
- Fix in some cases, selecting grid notes layout will lead to FC errors
[Alarm Clock]
- Fix timer ringtones select, interface dislocation issues
- Fix when setting two or more world clocks, on New Year's Day will lead to FC errors
MarkHUK
