Olli von G
Dauer-User
- 431
Hier bitte noch nicht Posten hier kommt alles wichtige rein zur cm10
Gesendet von meinem GT-I9003 mit der Android-Hilfe.de App
Für Anfänger: Falls Ihr erst auf KPU flashen müsst bevor Ihr CM10 drauf ziehn könnt, hier steht alles...If you are on ROMs like CM 7/CM 9/MIUI skip to step 6.
1. Download the Rom and put it in the root of your micro SD card.
2. To flash ROMS you need Clockworkmod Recovery or CWM on your phone.
3. Flash XXKPU. Please note that XXKPU can be flashed only after flashing XXKPE, so read it carefully.
5. Download CF ROOT for XXKPU and then install it by putting the phone to download mode, selecting the tar file as PDA and flash it. CF ROOT comes with CWM.
6. Go to CWM recovery by pressing Vol Up+ Home+ Power button.
7. Use vol buttons to navigate and power button/Home to select.
8. Select Wipe data/factory reset.
9. Go back and select "install zip from sd card" and choose the ROM file you just downloaded.
10. Wait for it to install and then go to advanced and select Reboot recovery.
11. After recovery is rebooted, go to mounts and storage and format dbdata.
12. Reboot the phone!
In order to get Google applications, you need to download Google apps for jelly bean and install the zip from CWM recovery.
You have successfully install jellybean on your galaxy sl i9003 with Cyanogenmod 10(CM10)
Credits to dhiru
Olli von G schrieb:Das sollte eigentlich jeder wissen
Olli von G schrieb:Die bekannten bugs wie die Videoaufnahme wifi/thetering sind weiter dabei
-WIFI: Click the menu button, click advanced and untick avoid poor connections. (Done.)
-Bluetooth: If you (badly) need bluetooth and it doesn't turn on, click it like you are turning it on and reboot the phone,
it will re-open with bluetooth activated.
-Gallery issues: Needs to get fixed by dhiru.
-GAPPS/DRAIN Reflash using EXACT steps below.
-CM9 issues will need to get fixed by dhiru.
