frankie78
Dauer-User
- 884
Dhiru hat CM10.2 veröffentlicht!!!
[ALPHA][ROM][4.3] CyanogenMod 10.2 for Samsung Galaxy SL - Alpha 1
Alpha 3 - 10042013
Fixed random reboots
Bluetooth pairing and AVRCP fixed during sleep.
Cleaned up proprietary files.
Few kernel changes.
Alpha 2 - 09242013
Numerous changes and fixes.
Please refer to the Github commit history.
Initial Release based on 3.0.8 Kernel.
Alpha 1 - 09042013
gapps-jb-20130813-signed.zip für Android 4.3
CM10.2-GalaxySL-JSS15Q-Alpha3.zip
SwapSD APK - NEW CM10.2 A1 !
Known Issues
CyanogenMod 10.1, Kernel 3.0.8 Entwickelt von Dhiru
Downloadseite
Google Apps für CM10 gapps-jb-20130812-signed.zip
XDA Threat
Aktuellste Version!!
Alpha 9 - 21082013
Improve Performance considerably.
Fixed Compass.
Improvements to Display Subsystem (DSS)
Switched to Ondemand Governor with Optimizations
Fix SD Card detection failures.
Fix LED Notification light for few applications.
Other Misc Kernel Changes.
Changes from Upstream Cyanogen.
Alpha 8 - 31072013
Fix issues with backlight turning on and off for few users
Fix bootimage fade away.
Fix USB Mass Storage.
Upstream changes.
Standard Flashanleitungen oder https://www.android-hilfe.de/forum/root-hacking-modding-fuer-samsung-galaxy-s-scl.501/anleitung-installation-eines-community-os.304303.html --> Installationsanleitung für CM10 Alpha4.
Nur die Rom und Gapps flashen
Stock ROM
1. Flash CWM Compatible Kernel (CF ROOT)
2. Reboot to Recovery.
3. Wipe Data / Factory Reset.
4. Select the ROM zip from your SD Card and flash.
5. The device will reboot and finish flashing.
6. Reboot to Recovery Again.
7. Flash Google Apps.
8. Reboot
Any other AOSP ROM (CM7/MIUI/CM9)
1. Reboot to Recovery.
8. Reboot
Upgrading from previous versions of CM10
2. Select the ROM zip from your SD Card and flash.
3. Flash Google Apps.
4. Reboot
Hier mal die Links zu den Roms auf CM10 A8 basis.
Like S4 v2.0.2 Samsung Feeling (05/08/13
CarbonRom1.7 (01/08/13/)
JellyBeer - v4.33 [BeerGang][Hybrid] (01/08/13)
remICS-JB [V6][02/08/13] ~STABLE~
Fusion V8.3 [SELinux][@ppSideBar][HALO] (01/08/13)
Xperia Style FINAL - with Ac!d audio engine [Stable|Fast] (01/08/13)
**crDroid AOSP** [Build 14] (01/08/13)
Halltet euch bitte an die Anleitung, bei den Roms kann ich leider kaum hilfe bieten.
TopDroid All-In-One MOD's ►TURBO CHARGE◄[03.08.2013][V1.3.1] Der sinnvollste Mod bisher für Alpha8!!!!
SD Swap kann man über das Terminal selbst einstellen.
So wieder deaktivieren!!
Interessante Anleitung von Dhiru, wie man den EFS-Ordner(IMEI-NR) sichert und wiederherstellt.
Backup your EFS IMMEDIATELY. [Backup and Restore Guides]
Official MEGA CM10/CM10.1 Theme Chooser Thread [989 THEMES] [UPDATED 8/9/13]
Alpha 3 - 10042013
Few kernel changes.
Alpha 2 - 09242013
Alpha 1 - 09042013
Known Issues
- Few random crashes (?)
- Video recording preview is slow.
- Doesn't have wings
- Doesn't have 4 processor cores
Downloadseite
XDA Threat
Alpha 9 - 21082013
Fixed Compass.
Alpha 8 - 31072013
Upstream changes.
Stock ROM
8. Reboot
8. Reboot
4. Reboot
Code:
su
setprop persist.sys.vold.switchexternal 1
Code:
su
setprop persist.sys.vold.switchexternal 0
