XeLLaR
Dauer-User
- 620
Moin.
Seit geraumer zeit bringt der Developer "Doomsday94" immer mal wieder CM10 Versionen für das Galaxy S Plus GT-I9001, Jetzt hat er seinen eigenen Thread.
Ich werde denhier so aktuell halten wie es geht.
CyanogenMod is based on the Android Open Source Project with extra contributions from many people within the Android community. It can be used without any need to have any Google application installed. Linked below is a package that has come from another Android project that restore the Google parts. CyanogenMod does still include various hardware-specific code, which is also slowly being open-sourced anyway.
All the source code for CyanogenMod is available in the CyanogenMod Github repo. And if you would like to contribute to CyanogenMod, please visit out Gerrit Code Review.
Latest alpha: https://docs.google.com/file/d/0B-NPErilnJ2VMUx6RllUVmE1Z0k/edit?pli=1
Google Apps: Goo.im Downloads - Downloading gapps-jb-20120719-signed.zip
- First time flashing CM10 to your Galaxy S Plus (or coming from another ROM)?
Root your device and install ClockworkMod Recovery.
Reboot into Recovery using 2-button-combo
Do a Nandroid backup!
WIPE (wipe data/factory reset + wipe cache partition)
Install the ROM from internal sdcard using ClockworkMod Recovery
Optionally install the Google Addon
- Upgrading from CM7/CM9?
Do a Nandroid Backup!
- Upgrading from another CM10 Build?
Note: Nandroids of CM7, CM9 and CM10 are incompatible due to partition layout changes. Please be on the correct version before restoring Nandroids.
What Works:
Audio
Video (sometimes youtube crashes)
Receiving and making calls
Proximity sensor
Wifi
Bluetooth
USB mass storage
HW accelerated gui
HW accelerated video
60% project butter
Not Working:
headset audio
camera
full butter experience
many other things
GUYS DON'T FORGET ITS AN ALPHA,BUGS WILL BE THERE. ALSO,THIS THREAD WILL NOT BE UPDATED VERY OFTEN,YOU GUYS KNOW THE REASON. (EXAMS) . THIS THREAD WAS CREATED BECAUSE THE PREVIOUS ONE WAS A TOTAL MESS. PEOPLE WERE NOT ABLE TO FIND DOWNLOAD LINKS.
Credits:
IVENDOR
ARCO68
CRYBERT
DASTIN1015"
Code:
"CyanogenMod is a free, community built, aftermarket firmware distribution of Android 4.1 (Jelly Bean), which is designed to increase performance and reliability over stock Android for your device.
Code:
#include <std_disclaimer.h>
* Your warranty is now void.
* I am not responsible for bricked devices, dead SD cards,
* thermonuclear war, or you getting fired because the alarm app failed. Please
* do some research if you have any concerns about features included in this ROM
* before flashing it! YOU are choosing to make these modifications, and if
* you point the finger at me for messing up your device, I will laugh at you.
What Works:
Audio
Proximity sensor
Wifi
Bluetooth
USB mass storage
HW accelerated gui
60% project butter
Not Working:
headset audio
camera
many other things
Credits:
IVENDOR
ARCO68
CRYBERT
DASTIN1015"
