[ROM][JB] - ChaMel - [CM10]
  • 6 Antworten
halver
halver
[JB 4.1.2] ChaMel V4 [CM10 by ivendor]
ximg.php
Ich habe mal eine Jelly Bean-Version ähnlich meinem Chamel V3 (ICS) erstellt.
Es ist ein modifiziertes CM10 auf der Basis von Ivendor Beta2.
Mit dem CastagnaIT Kernel, geändertem standard Design und erweitert um nützliche Apps,Wallpaper und Themen.
ChaMel V4 (13.03.2013).
Features:
- stabil
- stand CM10 Beta 2 by Ivendor
- CastagnaIT OC/UV Kernel v10.5, bis 1.8GHz
Kernel version 3.0.66
Compiled with Linaro 4.7.3 2013.01 optimized from Christopher
Linaro O3 optimizations
Snapdragon optimizations
Overclock until 1804 Mhz (selectable - default 1401 Mhz)
Governors: Lulzactive(v.2) (default), Ondemand, OndemandX, Interactive, InteractiveX, Powersave, Performance, SmartAssV2, MinMax, Lagfree, Savagedzen, Smoothass, Lionheart, BrazilianWax, Scary, Lazy, Intellidemand, Fantasy
I/O scheduler: ROW (default), SIO, V(r), BFQ, CFQ, Deadline, Noop
CK1 Con Kolivas performance improvements
Init.d support
USB-OTG Host ready (mice, keyboard, for mass storage device only FAT system work)
FAT and NTFS filesystem support
CIFS support
TUN support
BLN CyanogenMod
BLNv9 - Led backlight notification (see*)
Increased boot speed
Increased audio loudness
Improved Low Memory Killer values
USB Forced Fast Charge support (see**) (info)
HQ Photo - without compression (default enabled)
Speed up SD card read-write
Default readahead based on the size of the connected disk
VDD level sysfs interface
Dynamic sync control
Dynamic writeback and I/O-less dirty throttling
Writeback optimized for slight best smooth performace
Battery Life eXtender (BLX) (see***)
Stochastic Fair Blue (SFB) network scheduler
Cleancache
Brightness of display tweaked, you can set brightness levels even lower
Lowered display voltage
Lowered wi-fi voltage
Lowered touchscreen voltage
Wi-fi seen lowered signals
Zram swap ready (default disabled)
Google snappy compression for zram
SLUB memory allocator
UI speed up tweaks
Memory/vm tweaks
...and much more!!
- JellyBean-Nexus Bootanimation
- inverted Apps: Email, Kalender, MiuiMusik Player - verringert den Akkuverbrauch
- neue Wetter-Grafiken für die Bildschirmsperre
- modifizierte Settings mit S3 Icons
- Teile von S3 Design
- Maps integriert
- 3 Designs
- Font Installer (über 200 Fonts)
- CPU-Last
- 3 Player: Musik(Stock), Apollo, Miui Musik
- Apollo Player mit Black Design
- zusätzliche LWP
- Stock Taskmanager
- Automodus
- nicht funktionierende Apps entfernt
- paar andere, hilfreiche Apps: CPU Spy, AppMonster (Backup)
Installation:
Falls noch Stock-Recovery auf dem Handy, zuerst hier lesen
https://www.android-hilfe.de/forum/...lus.770/anleitung-root-flash-roms.287675.html - Punkt 3,
und CWM oder TWRP flashen.
Download Zip:
ChaMel V4
Gapps:
gapps JB 4.1.2
Downloaden und auf die SD kopieren.
1. TWRP oder CWM benutzen
2. Format system, wipe data, wipe cache und dalvik cache
3. Install ChaMel.Zip
4. Install Gaaps.Zip
5. Wipe cache und dalvik cache.
Damit das erweiterte PowerOFF-Menü (Neustart, Recovery, Download) richtig funktioniert (ist ein CM-Bug) unter Einstellungen->Töne->Töne bei Berührung das Häckchen wegmachen.
Hier noch FM-Radio (SpiritFM):
Spirit-FM
Nach der Installation in den Einstellungen -> Audio -> Method = "qdsp5v2 Altern" auswählen. Für den Empfang müssen die Kopfhörer eingesteckt sein (dienen als Antenne).
Screens:
V4:
ximg.php
ximg.php
ximg.php
ximg.php
ximg.php
ximg.php
EXTRAS
BLN - Led backlight notification -> BLN Control
Erweiterte Kernel-Einstellungen -> CastagnaIT - AriesPart (CWM flashable zip)
gruss
Reaktionen: pjozsef54, flasher78 und Th3 Witch3r
Um die CpuLast-Anzeige zu deaktivieren, UsageTimelines starten und mit "Zeitreihe anzeigen" auschalten.
Font Installer - zuerst unter Backup/Restore ein Backup anlegen, damit mann immer zu Standard Font zurück kann.
Hey,
eine Frage... hast du eig die Rom erstellt? :)
halver schrieb:
....Es ist ein modifiziertes CM10 auf der Basis von Ivendor Beta2....
modifiziert :) , wie eine Stock-Rom.
Reaktionen: Th3 Witch3r
wie ist der Akkuverbrauch bei dieser Rom?
Edit
Hab sie heute morgen mal geflasht und finde sie ganz gut,der verbrauch liegt bei 6-7% denke aber mal da kann man noch was mit anderen Kernel rauskitzeln.
ich hab da ein paar Fragen zu dem ROM:
- Wird es eine Version5 geben?
- Wenn ich auf den Kernel 12.4 update, dann geht das WLAN nicht mehr zu aktivieren.
Kann man das Beheben?
Genug mit den Fragen.
halver schrieb:
Erweiterte Kernel-Einstellungen -> CastagnaIT - AriesPart v1.0 (CWM flashable zip)
[/QUOT]
Der Link scheint tot zu sein.
MGF
Klepto
PS: Sorry fürs Leichen hochziehen:o
ich habe kein Galaxy S Plus mehr, daher keine neue Version.
Die neueren Kernel kenne ich nicht, würde wieder die beigefügte Version flashen, damit lief alles.
mfg
Link geht wieder.
  • Lohenstein
se1111
O
senator1008
Philipp.hy
  • Philipp.hy
Philipp.hy
Philipp.hy
