[ROM][JB 4.2.2 JDQ39E][LINARO 4.8] Unofficial JellyBeer Release 1 --- Kernel 3.4
  • 14 Antworten
flasher78
flasher78
Dauer-User
309
Inoffizelle JellyBeer Version
Features
+ Basiert auf CM-10.1
+ PA's hybrid engine for a full user experience
+ Per App Layout
+ 3 verschiedene UI-Modi @ jede DPI (Telefon, phablet und Tablet)
+ Verschiedene benutzerdefinierte DPI
+ Add apps to different DPI groups
+ AOKP Navbar
+ Änderung der Navigationsleiste in der Höhe
+ Uhren Mods
+ Notification Background
+ Circle Battery Tweaks
+ Wake up when device is plugged or no
+ CRT Off Animations
+ Mitteilung Hintergrund
+ This is always a work in progress
Was funktioniert
Audio
RIL
GPS
Kompass
Näherungssensor
Wifi
USB-Massenspeicher
HW beschleunigt gui
HW-beschleunigte Video
Kamera
BLN
USB / Wifi Tethering
Vsync - für die vollständige Projekt Butter Erfahrung
Bluetooth
Link Download Release 1 : Release 1
Mediafire Mirror Release 1
Link Gapps 2013/06/28 : Zippyshare.com - gapps-jb-20130628-signed.zip
Ältere Versionen
Mediafire Mirror von der Beta 6.2.1
Mediafire Mirror Beta 6.3 -20.5.2013-
Mediafire Mirror Beta 6.3-22.05.2013
Mediafire Mirror Beta 10
Screens
Changelogs
Code:
[B]Release 1[/B]
Compiled With GCC Linaro 4.8.2 by   @Christopher83
Added NEON Optimizations
Update Romanian language AriesParts thanks Laurentyu1995
Update Kernel 3.4.50 With Fix lower volume in call (Thanks to CastagnaIT and Skywalker)
Update GAPPS
Sync CM and BEER repo
[B]Beta 10[/B]
Fix Wallpapers FC
Same changes from My cm-10.1 Beta 10
[B]Beta 7[/B]
Fix Inverted Picture make with front camera (Thanks CastagnaIT)
Update kernel 3.4.48 "Without CM BLN for now in test fase by Ariesve-devcon-team"
Sync CM repo
[B]Beta 6.3 - 2013/05/22[/B]
New Kernel with Battery drain fixed by Christopher
DIsable by default NAVBAR
[B]Beta 6.3[/B]
Update CameraHAL
Update liblights with BLN support
Update vibrator setting with softer vibrations
Update BoardConfig
Softer keyboard vibration
Sync BEER and CM repo
[B]Beta 6.2.1[/B]
Compiled with linaro 4.6.4 by Christopher
Same changes from CM-10.1 beta 6.2.1
Update Kernel with linaro 4.7.4 by Christopher
Sync BEER repo
FAQ
Die Navigation Bar ist standardmäßig aktiviert, sie können die Höhe in den Navigationsleisten Einstellungen deaktivieren
CREDITS
BeerBong
CM team
AOKP team
PA team
Ivendor
Arco
Blackmambazzz
Reaktionen: Th3 Witch3r
uff, dem david muß ja langweilig sein, so wie der grad verschiedene ModROMs rausschießt^^
Ja der ist richtig fleißig :D
krislibaeer schrieb:
kommt aber noch nicht an mich ran :blink::tongue::lol:
Sei willkommen im German Forum :D Schade, dass Du erst jetzt den Weg hierher gefunden hast - aber besser spät als nie ;)
He Flasher78,
ich sehe, dass Du das Eröffnungspost "teilweise" übersetzt hast :thumbsup: Danke für Deine Bemühungen
THX for all :D
Rhonin
ja der Rest kommt noch wenn ich Zeit finde :D
Nochmal Update der 6.3 nur diesmal vom 22.5.2013
Startpost aktualisiert !!!
Mediafire Mirror folgt gleich
Hat schon jemand getestet bzw. was ist JellyBeer jetzt genau? Neue android version?
Ja ist ganz gut mehr fehlen aber einige Einstellungen da es keine reine cm ist, da ist noch aokp mit drin.
Die UI Mode Einstellung unterHypridSetting gefallen mir voll gut .
Leider werden Tablet und Phablet - Mode Fehelerhaft dargestellt.
Oder muss man da noch was umtellen an den dpi(?)Einstellung,oder so ?
Sonst sehr schöne Arbeit . Mit dem K Kernel echt super alles.
Außer mein W-Lan Hotspot läuft nicht mehr . Liegt aber am Kernel vermute ich mal.
Beste Grüße
bei mir dauert das Booten 3-4 Minuten und wenn es dann gebootet hat bekomm ich ne Fehlermeldung und es geht nichts mehr trotz full wipe
Ja und welche Fehlermeldung?
Würde es mal mit wipe Cache wipe dalvik und fix permission probieren ansonsten nochmal drüber flashen
Beste Grüße
ja liegt am kernel hab einen passenden beitrag bei xda gepostet
aber hier nochmal
arco hat ein flag in der boardconfig gelöscht weil das für den kernel 3.4 nicht mehr benötigt wird und das betrifft den wifi hotspot sodass mit 3.0 kernel der wifi hotspot nicht mehr funktioniert
hast du einen custom kernel geflasht ??? wenn ja ich hoffe mal nicht die 4.1.2 variante weil es sich schwer danach anhört du bekommst dann immer eine meldung
com.android.phone has stopped oder so in der art
Bei mir lag es auch am Kernel einfach den stock der ROM drauf gelassen und dann gings
Update auf Beta 10
Beta 10
Fix Wallpapers FC
Mac79
flasher78
flasher78
flasher78
sgspluss
mueh-chr
