[ROM][ION][4.4.4][KTU84Q] CyanogenMod 11.0 by ADC-Team - Release 17 [EOL]
  • 1.538 Antworten
Akku geht schnell lehr :(
Beta 3 ist online http://d-h.st/mDz
ROM:
Synched with CM sources
init: Fix storage mount points permissions (credits to Christopher83)
cameraHAL: fixed focus workaround for panorama (credits to CastagnaIT)
Various changes for bluetooth (credits to arco68)
Remove obsolete features for webkit (credits to arco68)
Fix switchable configuration (credits to arco68)
Revert "BoardConfig: add TARGET_RUNNING_WITHOUT_SYNC_FRAMEWORK := true new feature on 4.4" (credits to CastagnaIT)
AriesParts: Removed vibration preference (credits to CastagnaIT)
Change zRAM configuration, now zRAM is enabled by default (credits to arco68)
Read only 1 page cluster at a time (credits to arco68)
BoardConfig.mk: Enable BOARD_SCREENRECORD_LANDSCAPE_ONLY (credits to educk)
Disable render dirty regions (credits to arco68)
BoardConfig: Enable Qualcomm VoIP over MVS (credits to arco68 and Christopher83)
telephony: Keep InCallUI in memory to fix slow showing of current caller (credits to Pawit Pornkitprasan)
audio-caf: LPA support (credits to CAF Team, arco68 and Steve Kondik)
config: audio_policy: Add AUDIO_DEVICE_IN_COMMUNICATION to global configuration (credits to Christopher83)
BoardConfig: Enable LPA (credits to arco68)
prop: Temporary disable LPA, it caused various output routing issues (credits to Christopher83)
20140118 KERNEL: (DL from Dev-Host Mirror 1) - (DL from Dev-Host Mirror 2)
MD5SUM: e9855a5b2f4d1940db313c324efe6e82
ATTENTION: This kernel is included in the rom... this download is in case of custom kernel installed and want to come back to stock!
Kernel 3.4.77
ARM: dts: msm: Add new 'sharedmem' devices (credits to Pratibhasagar V)
Asoc:msm:Added Buffer overflow check (credits to Mohammad Johny Shaik)
cfg80211: intersect the regulatory rules for a new country (credits to Mihir Shete)
csdio: Remove the driver (credits to Hamad Kadmany)
msm: kgsl: Protect against a potential overflow in kgsl_sg_alloc (credits to Jordan Crouse)
msm: kgsl: avoid zero length scatterlist allocation (credits to Prakash Kamliya)
msm_serial_hs: Programming Auto RFR Ctrl bit (credits to Dilip Kota)
radio: iris: Avoid inconsistent free (credits to Ayaz Ahmad)
radio: tavarua: Added NULL checks for input arguments. (credits to Satish Kodishala)
radio: iris: Prevent probable overflow (credits to Ayaz Ahmad)
radio: iris: Use kernel API to copy data from user space (credits to Ayaz Ahmad)
radio: iris: Avoid memory leak and NULL pointer dereferencing (credits to Ayaz Ahmad)
radio: iris: Prevent loss of data (credits to Ayaz Ahmad)
spi_qsd: Remove check for unaligned length during input_irq. (credits to Sana Venkat Raju)
uio: msm_sharedmem: Add new device driver for sharedmemory access (credits to Pratibhasagar V)
Update defconfigs to build TUN/TAP and ZRAM as a built-in modules (credits to Christopher83)
Update defconfigs to build NFS, LockD, SunRPC as built-in modules (credits to arco68)
msm: pm2: Setup memory for save/restore cpu registers early (credits to Christopher83)
workqueue: Added null check and warning (credits to Srinivasarao P)
cfg80211: discard regulatory hints from country IEs with undefined wiphy (credits to Mihir Shete)
msm: msm_fb: Update panel info in case of resolution change (credits to raghavendra ambadas)
Revert "mm: make is_vmalloc_addr work properly." (credits to Shruthi Krishna)
mm: make is_vmalloc_addr lockless (credits to Laura Abbott)
android: lowmemorykiller: add lmk parameters tunning code. (credits to seungho1.park)
android/lowmemorykiller: Account for total_swapcache_pages (credits to Liam Mark)
defconfig: Disable CONFIG_ENABLE_VMALLOC_SAVING (credits to arco68)
defconfig: Disable KGSL shadow writes (credits to arco68)
ARM: kconfig: select HAVE_EFFICIENT_UNALIGNED_ACCESS for CPUv6+ && MMU (credits to Will Deacon)
Revert "staging: zram: Add auto loading of module if user opens /dev/zram." (credits to Greg Kroah-Hartman)
Staging: zram: Fix access of NULL pointer (credits to Rashika Kheria)
Staging: zram: Fix memory leak by refcount mismatch (credits to Rashika Kheria)
usb: msm72k_otg: Update OTG status management (credits to Christopher83)
usb: msm72k_otg: Allow USB bus overdraw for Legacy OTG (credits to Christopher83)
Update defconfigs (credits to Christopher83)
msm: Qdsp5v2: audio: Migrate to ION. (credits to Kalyani Polepeddy)
audio: msm: qdsp5v2: Switch hostPCM driver to ION (credits to Kalyani Polepeddy)
Initial commit for ION compilation errors (credits to Kalyani Polepeddy)
msm: audio : Enable LPA (credits to Kalyani polepeddy)
audio : Copyright correction. (credits to Kalyani polepeddy)
msm: audio VOIP fixes. (credits to Kalyani polepeddy)
msm: Remove all references to pmem from audio files (credits to Laura Abbott)
qdsp5: memset stack buffer allocation (credits to Asish Bhattacharya)
exFAT: Update to v1.2.5 (credits to arco68)
defconfig: Disable NTFS and build exFAT as built-in (credits to arco68)
Revert lowmem and vmalloc patches (credits to arco68)
Reaktionen: Lars124 und rl2664
Sehr nett. Läuft auf den ersten Blick prima.
Hmmm - das ist natürlich nicht wirklich gut, aber ein paar mehr Infos wären hilfreich, damit man den Verbrauch wirklich einschätzen kann. Z.B.: ein Screenshot von BBS wie angefügt...
Cheers
Rhonin
hab beta 2 clean geflasht danach 10.1 :) teste mit der...komischerweise gehts bei 10% Akku aus
Mir fällt grade auf da die Gallerie-App bearbeitete Bilder zwar speichert, aber dabei das original überschreibt. Bei allen anderen Geräten bleibt das Original erhalten. Kann das jemand bestätigen? Liegt das an den Gapps oder an der Rom?
Noch was, K^Kernel geflashed und jetzt werden die CPU Einstellungen beim Neustart nicht gespeichert obwohl "Beim booten einstellen" angehakt ist...
Könnte es sein, dass Dein Akku einen Hau hat ?
Ich stimme Dir zu, ich habe auch den Eindruck, dass der Verbrauch der KK leicht höher ist als bei der 4.2.2. Allerdings ist es mit der neuen Version besser geworden - ist aber nur ein Gefühl, da ich viele Versionen getestet habe, konnte ich noch keinen vergleichbaren Alltagsverbrauch bestimmen....
Rhonin
kann man denn Akku memory wipen oder so
ich weiß, dass man früher die BatteryStats wipen konnte - hatte aber gerade noch einmal nachgeforscht und herausgefunden, dass es für Dich keine Lösung bringt - Es werden nur Gebrauchsstatistiken gelöscht, die nichts mit dem aktuellen "Füllstand" des Akkus zu tun haben. Einmal bis 100% aufladen, dann abziehen - damit hast Du die Battery Stats auch gewiped ;)
Sry - habe da leider keine bessere Antwort für Dich
Rhonin
hat vlt. wer nen dropbox link zur beta 3? dev host will bei mir absolut nicht zuende laden :(
danke. weiss auch nicht warum dev host bei mir immer abbricht.
Also bei mir funktioniert dev host ganz normal womit lädst du die rom den runter??
Der ursprüngliche Beitrag von 10:29 Uhr wurde um 10:33 Uhr ergänzt:
Kann ich gleichmal über die Stockrom drüber flashen
denk es liegt an meinem inet seit kurzem egal ob mit handy oder pc hört der mitten drin immer auf zu laden und ja geht halt nicht weiter. is aber echt nur dev host was probleme bereitet sonst gehen alle hoster normal.
damit es nit ganz off topic is:
update läuft bisher gut mit k^kernel. vorallem das beim cLock widget jetzt beim druck auf das wetter symbol ne wochenvorschau dabei ist gefällt mir.
Reaktionen: derred
Gibts ne Möglichkeit das Lockscreen Widget zu verändern? Das cLock.Widget kann man zwar einstellen aber die Änderungen beziehen sich nur auf ein Widget auf dem Homescreen. Auf dem Lockscreen wird kein Wetter angeziegt, oder überseh ich eine Einstellung?
unter erweiterte einstellungen auf low ram gehen und low ram ausschalten. danach startet sich das telefon neu und du kannst cLock auf den lockscreen setzen. muss man nach jedem neu flashen wieder ausschalten weil die low ram einstellungen nach jedem flashen wieder auf default (also ein) stehen
Reaktionen: rl2664
Ok, danke. Die nächste Frage ist dann wofür ist LowRam? Sicherlich für Geräte wie unseres mit wenig Ram. Hat das Auswirnkungen auf die Performance?
ja ist dafür gedacht aber finde nicht das es auswirkungen auf die performance hat. merkst du warscheinlich wenn du apps nutzt die viel ram brauchen. aber ich hab keine probleme. hab noch ksm aktiv dann passt das bei meiner nutzung. musst du am besten mal selbst testen. kannst es ja wieder einschalten
Das einzige "Problem" das ich grad habe ist die transparente Statusleiste. aber das ist ne Geschmacksache und da gewöhn ich mich sicher dran.
Wenn du Low Ram aktivierst, ist die Status Bar nicht mehr transparent. ;)
