[ROM][ICS] UltraGen 1.8 [Galaxy S3 UI | Smooth | Battery | Performance]
  • 93 Antworten
O
OPC_300
Dauer-User
129
Orginaltheard: http://forum.xda-developers.com/showthread.php?p=32178564
ROM Details:
Zitat:
Galaxy S3 UI, Sounds, Apps
busybox
Zipalign beim Booten
Datenbankdefragmentierung
EXT4 Tweaks (Erhöhung I / O)
SD Speed ​​Tweaks
RAM optimiertes Management
Heap-Größe optimiert
LMK Tweaks
JB Adreno Libs
Statusleiste JB
Battery Tweaks
Erhöhen Touch Sensibilität
Erhöhen Fotoqualität
Scroll Geschwindigkeit Tweaks
Net Speed ​​Tweaks
GPS Fast Fix
3G Tweaks
Beats Audio
... und mehr!
Apps:
Google Apps
ES Datei Explorer
Walkman
Karten
Flash Player
Youtube HD via Wifi
Aus früheren Versionen von UltraGen:
Wipe Cache
Wipe Dalvik Cache
Flash UltraGen
Reboot
Von Custom Rom Gingerbread:
Flash CWM Recovery
Wipe Data
Wipe Dalvik Cache in Advence
Flash UltraGen
Reboot
Von Gingerbread Stock ROM:
Install ClockWorkMod Recovery with Odin
Go in recovery (VOL+ and Power)
Wipe data/factory reset
Advanced -> Wipe dalvik cache
Mounts and Storage -> Format /sdcard*
*WARNING! Formatting the SD Card will erase ALL CONTENTS! THEN SAVE THE NECESSARY (images, videos, music and more ..) ON THE MICRO SD.
Install zip from sd card-> choose zip from sd card (Or choose zip from external sdcard) -> UltraGen-> yes
Wipe data/factory reset ->
Wipe cache partition ->
Advanced-> wipe dalvik cache->
Advanced-> fix permissions
Reboot system now
From previous versions of UltraGen: * Wipe Cache
* Wipe Dalvik Cache
* Flash UltraGen
* Reboot
From custom ROM Gingerbread: * Flash CWM Recovery
* Wipe Data
* Wipe Dalvik Cache in Advence
* Flash UltraGen
* Reboot
1.8:
- Update base CyanogenMod 9 (RC5 by arco) -> Changelog
- Update 3.0.65 kernel stock
- ROM completely reworked
- Update apps
- Improve Multi-tasking
- Increase general performance
- Minor bugs fixes
UltraGen 1.8: https://hotfile.com/dl/195838412/7464d9a/UltraGen_1.8.zip.html
Add-ons>Disinstalled Apps: https://hotfile.com/dl/172231068/a04f561/AppsCyanogenMod9.zip.html
Credits
CastagnaIT for the kernel
Galaxy S3 Stock ROM for the theme
Android Revolution HD for the dividers
Hier mal ein Paar Bilder:
Screenshots
Reaktionen: Druckschrift, Cyanlux und Keemo
Einer hat sich erbarmt den Thread zu erstellen um die Danke abzusahnen :D
Downloadlinks würden nicht schaden ;)
Reaktionen: Hussi_414
schaue mal unter den Text "Bassiert auf CM9 RC 3.1 von ivendor ." da ist der Downloadlink:)
Gut versteckt :D
Rom funktioniert soweit recht gut. mini bug, wie das bei mir zB der "sanfte" erste wecker nicht geht, erst der zweite normale.
sonst mit kernel 6.4 alles bestens was wlan und akku angeht.
Kann ich das einfach über CM9 by Ivendor mit Dalvik Cache und Cache Wipe rüberziehen?
Ja kannste .
OPC_300 schrieb:
Ja kannste .
Sicher? Beim manuellen Galaxy S3 UI Flash musste man ja das ganze System neu aufspielen mit wipe data.
Wenn du froher schon eine CM9 Version drauf hattest brauchst du kein factory reset machen weil diese Rom auf die RC 3.1 von ivendor basiert .
Gute ROM, hat ein bisschen Samsung Feel und das find ich gut ;)
Funktioniert bln bei euch?
S+ with tapatalk...
S+ with tapatalk...
Benutze BLN control damit geht es . Habe mir die BLN control Pro gekauft aber müsste mit der kostenlosen Version auch gehen .
BLN control sagt mir: Fehler Diese Liblights unterstützt kein BLN
Ok dann wird es wohl noch nicht gehen.
ich komm nicht mehr an meine interne SD, der PC erkennt sie nicht und ich find sie auch mim root Explorer nichtmehr.. waruum? :p
Update 1.4 nun draußen... Mit bln Feature, da castagnait 6.6 vorhanden ist... Die Rom bockt sich!
S+ with tapatalk...
Hab die Rom gestern mit CWM 5 geflasht. Bis jetzt läufts sie sehr stabil. Sieht optisch wirklich Top aus und hängt auch eher selten bei aufwändigen Apps. Allerdings kann ich egal mit welchem dateimanager nicht auf meine Externe SD Karte zugreifen. Wenn ich Bilder knipse und sie auf die Externe SD Karte speichern lasse dann kann ich sie über die Galerie ansehen. Gibt es da ne lösung?
Edit: Hmm jetzt hab ich noch den Whitescreen Bug bei Facebook :/
S+ mit Tapatalk
Der whitescreen bug ist bei jeder cm9 Version vorhanden...
EDIT : mit root explorer kannst du auf deine externe zugreifen, mit anderen hab ichs nicht versucht
S+ with tapatalk...
Reaktionen: sfk_jonas
Mit dem Solid Explorer gehts auch problemlos.
LG
Weiß einer warum es FaceUnlock nicht mehr gibt?
juni
  • Lohenstein
se1111
Rhonin
Rhonin
