XeLLaR
Dauer-User
- 621
Broodplank1337 hat mal wieder was für uns
Orginal Thread@XDA-Developers: [ROM][ICS][IMM76L]AOSP 4.0.4 Stock Alpha (Build 1) *HOT* - xda-developers
AOSP 4.0.4 IMM76L by broodplank1337
Info:
I'm very happy to release the first alpha build of AOSP IMM76L for Samsung Galaxy S Plus (GT-i9001). Most of you probably know that i've been busy with compiling AOSP for a long time now, and I finally succeeded to compile it by using a very wrong and lame way (tut will come later). Anyways the build is running very stable so far and the performance is very neat. Currently some CM9 sources are copied to the AOSP build to make it working correctly, all the apps (except Phone.apk) are compiled from original AOSP source, I use the framework files from CM9 (Ivendor) but downgraded to get the AOSP wanted result.
I've included a stock kernel based on Arco's i9001 kernel, I've replaced interactive with smartassV2 and added SIO, these 2 are the default choices for the kernel/rom. The kernel is compiled with Linaro toolchain for best performance.
Finally we got ourselfs an AOSP Stock ROM to modify ! Please give me as much feedback as possible, so I can improve the ROM!
What's working:
Audio
Receiving and making calls
GPS
Compass
Proximity sensor
Wifi
Bluetooth
USB mass storage
HW accelerated gui
HW accelerated video
Camera
Wifi and USB tethering
What's not working:
FM Radio
CHANGELOGS:
New Release! Alpha 02
- Fixed FC's at APNList/AccessPoints
- Removed Dialpad preferences / additional vibrate options for Phone.apk (CM9)
- Original Extended Power Menu / Statusbar now
- Removed ThemeManager/ThemeChooser/Development apks
- Added more sounds
- Much higher performance thanks to linaro "stock" kernel (with some castagnait tweaks)
- Updated libs/egl
- Removed all deprecated and useless files
- Added init.d support (make the folder and give permissions of atleast RWX-RX-RX)
- Probably more, but I forgot it, will add it when I remember
And for the record, I have no clue if incall volume is fixed, couldn't really test it today. Also same thing for random reboots, I haven't experienced one since the new version, so I hope that's for all of you!
Download:
Note: I am not responsible for any damage caused to your device.. >>> insert violation warranty bollocks here <<<
Version Alpha 02 (19-11-2012)
Mirror #1 Mediafire.com
Version Alpha 01 (03-11-2012)
Mirror #2 Sourceforge.com
Mirror #3 Zippyshare
Mirror #4 broodplank.net
Also download gapps
Goo.im Downloads - Downloading gapps-ics-20120429-signed.zip
Install
Make sure you use CWM5 or CWM6. (important!)
(Newer CWM 6.0.1.2 version available here)
- Wipe data and cache. (if coming from samsung rom, if you're using CM9 you may only wipe cache)
- Flash AOSP_IMM76L_AriesVE-Alpha01-broodplank-signed.zip.
- Flash update-Gapps-ICS-20712.zip. You must flash gapps after every upgrade to AOSP 4.0.4 since /system is formatted, wiping your previous add-ons.
- Reboot phone.
Credits
CyanogenMod Team
AOSP Team
arco
ivendor
Info:
What's working:
Audio
GPS
Compass
Proximity sensor
Wifi
Bluetooth
USB mass storage
HW accelerated gui
Camera
What's not working:
FM Radio
CHANGELOGS:
- Added more sounds
- Updated libs/egl
Download:
Also download gapps
Install
- Reboot phone.
Credits
CyanogenMod Team
AOSP Team
arco
ivendor
