[ROM][I9001] Ice Cream Sandwich [PRE-ALPHA][WIP]
  • 43 Antworten
Meecrob
Almost 3 Weeks ago there's release by someone called "AR" to be name contact one of our site
moderator and submit a non-working build to us where all were going wrong in the term of progress!
This time i took sometime to look over the build and the complain where many occur bootloops/stuck
Might even occur to return to previous rom? Well i am not pretty sure due to the problem occur as
i don't own a GT9001 (SGS Plus) incase any build of mine are not bootable then will need to have adblogcat(Dont ask me How) or other dev to teach me (Learning is a part of daily life)
I do ported from other device due to the fact i am not with my desktop and left with my [1.6Ghz N455 Atom with 2gb Ram <Compiling with this takes ages]
Faq (Read Properly and stop questioning)
  1. We shall not responsible any brickage/data lost/exploding or etc happening physical or software based on your phone
  2. I don't know whether it works nor bootable so if it does then is great!If isn't bootable or working then is not anyone fault thus if you need to let the whole world to know (Comment below)
  3. This a [PORT] so is not compiled on source so no source code or whatever(Want to learn compiling do search on WWW.XDA-DEVELOPER.COM
  4. Posting on other site are permitted but we doesn't endorsed any build downloaded or uses apart from our site.
  5. Isn't our responsible to port for SGS+ in any term but we do it as favour of learning thus any complain or report on this build just left a comment about it
  6. We do repeat no bullshiting & trolling such as thread like this ([dev][rom][i9001]ics nightly build[pre-alpha][26/2/2012] - xda-developers
  7. Asking Release and ETA are RUDE
Credit :
-Skywalker (CM7 Kernel & CM7 Build Awesomeness)
-CM Team
-Nexx (Based Port)
Installation:
  • Rom downloaden
  • Zip-Datei nach clockwordmod/backup entpacken
  • FeaMod Recovery (bzw. CWM) starten
  • Gerät komplett wipen (factory reset + mount & storage -> format /system + advanced > erase dalvik cache)
  • Backup and Restore > Restore
  • Reboot
Download:
BUILD 1 [26/02/2012] (Link deaktiviert, da hohe Brickgefahr -> Nutzt den Thread erstmal, um über diese Rom bzw. die Builds zu diskutieren)
BUILD 2 [13/03/2012]
Infos zum ersten Build:
Erstes Ice Cream Sandwich Rom für das Samsung Galaxy S Plus! DroidXDA's Entwickler, der eigentlich an dem ICS-Port fürs SGS+ arbeiten sollte, konnte nicht genug Zeit dafür aufbringen, deshalb hat die Portiererung ein andere Entwickler übernommen, der nichtmal ein SGS+ besitzt, sondern nur ein Samsung Galaxy W, welches jedoch dem SGS+ sehr ähnelt. Es handelt sich hierbei um eine ungetestete Pre-Alpha!
Ich habe selbst nichts mit dieser ROM zu tun und die Installation erfolgt auf eigene Gefahr.
FAQ:
  • DroidXDA möchte mit dem Release nicht direkt in Verbindung gebracht werden (nicht vom Haus-eigenen Entwickler)
  • Es handelt sich um ein ungetestetes Pre-Alpha Release
  • Brickgefahr -> Benutzung auf eigene Gefahr!
  • Bugs & Feedback als Comment hier posten
  • Das Release ist nicht für den Otto-Normal-User gedacht (eher für Entwickler)
  • Wenn ihr das Projekt unterstützen wollt, klickt auf Werbung bei DroidXDA!
  • Es handelt sich um ein Work-In-Progress (WIP) Build und es kann sein, dass es nicht funktionsfähig ist
Installation:
  • Rom downloaden
  • Zip-Datei auf SD-Karte kopieren
  • "install zip from sd-card" wählen, Zip-Datei auswählen und bestätigen
Originaltext:
Previously Project Have Been delay due to our dev couldn't able spare much time in the progress then step in a new guy who willing to work as he has more suitable device to port.With much effort we manage to get a up to date pre-alpha build from him (Remember To Read FAQ and Instruction properly)
"He doesn't own an SGS+ but he does own an SGW which he now porting ICS to it as well"
: FAQ :
  • This Build/Releaseis in no way related to or endorsed byDroidXDA
  • This is a very pre-alpha which is untested build released
  • It may break your device and use it at your own risk
  • Any Bugs/Result Do Report in the comment below
  • Preferable user with adb and debugging experience to work on it
  • Don't report bug to any our DroidXDA Pages neither XDA(PM)
  • To Help The Project Do Clicks Our Advert/Ads to support thanks!
  • This is Work-In-Progress(WIP) BUILD and it might not even worked
  • Avoid this post if you not willing to brick you device
____________________________________________________________________
Working
/Not Working/Broken:
  • Unknown (Untested)
Installation - Backup Where it's required to prevent data lost
• Download the ROM
• Copy Zip to Memory Card
• Start CWM
• Make a Full Wipe (factory reset, mount & storage > format /system , advanced > Erase Dalvik cache)
• Start the install
• Enjoy!
Credits:
CM Team and Other
Quelle: [DEV][ROM][I9001]ICS NIGHTLY BUILD[PRE-ALPHA][26/2/2012] - DroidXDA
Reaktionen: LotosHans, fr33kiLL und hjkl1234
Habe mir mal das Updater-Script angeschaut.
Da sind echt ein paar komische Dinge dabei.
Zunächst wird ein backuptool ausgeführt. Was dieses genau im einzelnen macht, weiß ich allerdings nicht.
Code:
#!/sbin/sh
# Backup and restore proprietary Android system files
C=/tmp/backupdir
S=/system
V=9
PROCEED=1;
check_prereq() {
   if ( ! grep -q "^ro.cm.version=$V.*" /system/build.prop );
   then
      echo "Not backing up files from incompatible version.";
      PROCEED=0;
   fi
check_installscript() {
   if [ -f "/tmp/.installscript" ] && [ $PROCEED -ne 0 ];
   then
      # We have an install script, and ROM versions match!
      # We now need to check and see if we have force_backup
      # in either /etc or /tmp/backupdir
      if [ -f "$S/etc/force_backuptool" ] || [ -f "$C/force_backuptool" ];
      then
         echo "force_backuptool file found, Forcing backuptool."
      else
         echo "/tmp/.installscript found. Skipping backuptool."
         PROCEED=0;
      fi
   fi
get_files() {
    cat <<EOF
vendor/pittpatt/models/recognition/face.face.y0-y0-22-b-N/full_model.bin
vendor/pittpatt/models/detection/multi_pose_face_landmark_detectors.3/left_eye-y0-yi45-p0-pi45-rn7-ri20.2d_n2/full_model.bin
vendor/pittpatt/models/detection/multi_pose_face_landmark_detectors.3/nose_base-y0-yi45-p0-pi45-r0-ri20.2d_n2/full_model.bin
vendor/pittpatt/models/detection/multi_pose_face_landmark_detectors.3/right_eye-y0-yi45-p0-pi45-rp7-ri20.2d_n2/full_model.bin
vendor/pittpatt/models/detection/multi_pose_face_landmark_detectors.3/nose_base-y0-yi45-p0-pi45-rp7-ri20.2d_n2/full_model.bin
vendor/pittpatt/models/detection/multi_pose_face_landmark_detectors.3/left_eye-y0-yi45-p0-pi45-rp7-ri20.2d_n2/full_model.bin
vendor/pittpatt/models/detection/multi_pose_face_landmark_detectors.3/right_eye-y0-yi45-p0-pi45-rn7-ri20.2d_n2/full_model.bin
vendor/pittpatt/models/detection/multi_pose_face_landmark_detectors.3/nose_base-y0-yi45-p0-pi45-rn7-ri20.2d_n2/full_model.bin
vendor/pittpatt/models/detection/multi_pose_face_landmark_detectors.3/right_eye-y0-yi45-p0-pi45-r0-ri20.2d_n2/full_model.bin
vendor/pittpatt/models/detection/multi_pose_face_landmark_detectors.3/left_eye-y0-yi45-p0-pi45-r0-ri20.2d_n2/full_model.bin
vendor/pittpatt/models/detection/yaw_roll_face_detectors.3/head-y0-yi45-p0-pi45-rn30-ri30.5/full_model.bin
vendor/pittpatt/models/detection/yaw_roll_face_detectors.3/head-y0-yi45-p0-pi45-rp30-ri30.5/full_model.bin
vendor/pittpatt/models/detection/yaw_roll_face_detectors.3/head-y0-yi45-p0-pi45-r0-ri30.4a/full_model.bin
framework/com.android.nfc_extras.jar
framework/com.google.widevine.software.drm.jar
framework/com.google.android.maps.jar
framework/com.google.android.media.effects.jar
lib/libfacelock_jni.so
lib/libfilterpack_facedetect.so
lib/libflint_engine_jni_api.so
lib/libfrsdk.so
lib/libgcomm_jni.so
lib/libpicowrapper.so
lib/libspeexresampler.so
lib/libspeexwrapper.so
lib/libvideochat_jni.so
lib/libvideochat_stabilize.so
lib/libvoicesearch.so
etc/permissions/com.google.android.nfc_extras.xml
etc/permissions/com.google.android.media.effects.xml
etc/permissions/com.google.android.maps.xml
etc/permissions/com.google.widevine.software.drm.xml
etc/permissions/features.xml
app/MediaUploader.apk
app/GoogleFeedback.apk
app/GoogleTTS.apk
app/MarketUpdater.apk
app/GoogleServicesFramework.apk
app/YouTube.apk
app/GenieWidget.apk
app/GooglePackageVerifierUpdater.apk
app/SetupWizard.apk app/Provision.apk
app/GoogleEarth.apk
app/ChromeBookmarksSyncAdapter.apk
app/GoogleQuickSearchBox.apk
app/GoogleLoginService.apk
app/Talk.apk
app/Maps.apk
app/GooglePackageVerifier.apk
app/GoogleBackupTransport.apk
app/GalleryGoogle.apk app/Gallery.apk
app/FaceLock.apk
app/Vending.apk
app/GoogleContactsSyncAdapter.apk
app/GoogleCalendarSyncAdapter.apk
app/Gmail.apk
app/OneTimeInitializer.apk
app/NetworkLocation.apk
app/GooglePartnerSetup.apk
app/Phonesky.apk
etc/hosts
etc/custom_backup_list.txt
EOF
get_custom_files() {
   local L
   if [ -f "$C/custom_backup_list.txt" ];
   then
      [ ! -f $C/fixed_custom_backup_list.txt ] && tr -d '\r' < $C/custom_backup_list.txt \
      L=`cat $C/fixed_custom_backup_list.txt`
      cat <<EOF
$L
EOF
   fi
backup_file() {
   if [ -e "$1" ];
   then
      if [ -n "$2" ];
      then
         echo "$2  $1" | md5sum -c -
         if [ $? -ne 0 ];
         then
            echo "MD5Sum check for $1 failed!";
            exit $?;
         fi
      fi
      local F=`basename $1`
      local D=`dirname $1`
      # dont backup any apps that have odex files, they are useless
      if ( echo $F | grep -q "\.apk$" ) && [ -e `echo $1 | sed -e 's/\.apk$/\.odex/'` ];
      then
         echo "Skipping odexed apk $1";
      else
         mkdir -p $C/bak/$D
         cp -p $1 $C/bak/$D/$F
      fi
   fi
restore_file() {
   local FILE=`basename $1`
   local DIR=`dirname $1`
   if [ -e "$C/bak/$DIR/$FILE" ];
   then
      if [ ! -d "$DIR" ];
      then
         mkdir -p $DIR;
      fi
      cp -p $C/bak/$DIR/$FILE $1;
      if [ -n "$2" ];
      then
         rm $2;
      fi
   fi
# don't (u)mount system if already done
UMOUNT=0
case "$1" in
   backup)
      if [ ! -f "$S/build.prop" ]; then
         mount $S
         UMOUNT=1
      fi
      check_prereq;
      check_installscript;
      if [ $PROCEED -ne 0 ];
      then
         rm -rf $C
         mkdir -p $C
         for file_list in get_files get_custom_files; do
           $file_list | while read FILE REPLACEMENT; do
              backup_file $S/$FILE
           done
         done
      fi
      if [ $UMOUNT -ne 0 ]; then
         umount $S
      fi
   restore)
         mount $S
         UMOUNT=1
      fi
      check_prereq;
      then
              R=""
              [ -n "$REPLACEMENT" ] && R="$S/$REPLACEMENT"
              restore_file $S/$FILE $R
           done
         done
         rm -rf $C
      fi
         umount $S
      fi
      sync
      echo "Usage: $0 {backup|restore}"
      exit 1
esac
exit 0
Dann wird die System-Partition mit YAFFS2 formatiert. Obwohl ich nicht glaube, dass das so für unser System funktioniert.
Code:
format("yaffs2", "MTD", "system", "0");
Dann gibt es viel symlinking. Aber es gibt einfach keinen Eintrag, in dem das boot.img geflasht wird.
Also ich werde es nicht testen. Vielleicht kann es jedoch helfen die Einträge für format/mount durch diese zu ersetzen und den boot.img-Eintrag hinzuzufügen. Dadurch dürfte zumindest das Risiko eines Hardbricks vermindert werden. Aber so kenn ich mich da dann doch nicht aus. Ist noch mal was anderes als RomCooking :D
Code:
format("ext4", "EMMC", "/dev/block/mmcblk0p15");
mount("ext4", "EMMC", "/dev/block/mmcblk0p15","/system");
package_extract_file("boot.img","/dev/block/mmcblk0p8");
Dies ist das ganze Updater-Script:
Code:
package_extract_file("system/bin/backuptool.sh", "/tmp/backuptool.sh");
set_perm(0, 0, 0777, "/tmp/backuptool.sh");
run_program("/tmp/backuptool.sh", "backup");
show_progress(0.500000, 0);
mount("yaffs2", "MTD", "system", "/system");
package_extract_dir("system", "/system");
symlink("Roboto-Bold.ttf", "/system/fonts/DroidSans-Bold.ttf");
symlink("Roboto-Regular.ttf", "/system/fonts/DroidSans.ttf");
symlink("busybox", "/system/xbin/[", "/system/xbin/[[",
        "/system/xbin/arp", "/system/xbin/ash", "/system/xbin/awk",
        "/system/xbin/base64", "/system/xbin/basename", "/system/xbin/bbconfig",
        "/system/xbin/blockdev", "/system/xbin/brctl", "/system/xbin/bunzip2",
        "/system/xbin/bzcat", "/system/xbin/bzip2", "/system/xbin/cal",
        "/system/xbin/cat", "/system/xbin/catv", "/system/xbin/chattr",
        "/system/xbin/chgrp", "/system/xbin/chmod", "/system/xbin/chown",
        "/system/xbin/chroot", "/system/xbin/clear", "/system/xbin/cmp",
        "/system/xbin/comm", "/system/xbin/cp", "/system/xbin/cpio",
        "/system/xbin/crond", "/system/xbin/crontab", "/system/xbin/cut",
        "/system/xbin/date", "/system/xbin/dc", "/system/xbin/dd",
        "/system/xbin/depmod", "/system/xbin/devmem", "/system/xbin/df",
        "/system/xbin/diff", "/system/xbin/dirname", "/system/xbin/dmesg",
        "/system/xbin/dnsd", "/system/xbin/dos2unix", "/system/xbin/du",
        "/system/xbin/echo", "/system/xbin/ed", "/system/xbin/egrep",
        "/system/xbin/env", "/system/xbin/expand", "/system/xbin/expr",
        "/system/xbin/false", "/system/xbin/fdisk", "/system/xbin/fgrep",
        "/system/xbin/find", "/system/xbin/flash_lock",
        "/system/xbin/flash_unlock", "/system/xbin/flashcp",
        "/system/xbin/flock", "/system/xbin/fold", "/system/xbin/free",
        "/system/xbin/freeramdisk", "/system/xbin/fsync", "/system/xbin/ftpget",
        "/system/xbin/ftpput", "/system/xbin/fuser", "/system/xbin/getopt",
        "/system/xbin/grep", "/system/xbin/groups", "/system/xbin/gunzip",
        "/system/xbin/gzip", "/system/xbin/halt", "/system/xbin/head",
        "/system/xbin/hexdump", "/system/xbin/id", "/system/xbin/ifconfig",
        "/system/xbin/insmod", "/system/xbin/install", "/system/xbin/iostat",
        "/system/xbin/ip", "/system/xbin/kill", "/system/xbin/killall",
        "/system/xbin/killall5", "/system/xbin/length", "/system/xbin/less",
        "/system/xbin/ln", "/system/xbin/losetup", "/system/xbin/ls",
        "/system/xbin/lsattr", "/system/xbin/lsmod", "/system/xbin/lsusb",
        "/system/xbin/lzcat", "/system/xbin/lzma", "/system/xbin/lzop",
        "/system/xbin/lzopcat", "/system/xbin/man", "/system/xbin/md5sum",
        "/system/xbin/mesg", "/system/xbin/mkdir", "/system/xbin/mke2fs",
        "/system/xbin/mkfifo", "/system/xbin/mkfs.ext2",
        "/system/xbin/mkfs.vfat", "/system/xbin/mknod", "/system/xbin/mkswap",
        "/system/xbin/mktemp", "/system/xbin/modinfo", "/system/xbin/modprobe",
        "/system/xbin/more", "/system/xbin/mount", "/system/xbin/mountpoint",
        "/system/xbin/mpstat", "/system/xbin/mv", "/system/xbin/nanddump",
        "/system/xbin/nandwrite", "/system/xbin/netstat", "/system/xbin/nice",
        "/system/xbin/nohup", "/system/xbin/nslookup", "/system/xbin/ntpd",
        "/system/xbin/od", "/system/xbin/patch", "/system/xbin/pgrep",
        "/system/xbin/pidof", "/system/xbin/ping", "/system/xbin/pkill",
        "/system/xbin/pmap", "/system/xbin/poweroff", "/system/xbin/printenv",
        "/system/xbin/printf", "/system/xbin/ps", "/system/xbin/pstree",
        "/system/xbin/pwd", "/system/xbin/pwdx", "/system/xbin/rdev",
        "/system/xbin/readlink", "/system/xbin/realpath", "/system/xbin/renice",
        "/system/xbin/reset", "/system/xbin/resize", "/system/xbin/rev",
        "/system/xbin/rm", "/system/xbin/rmdir", "/system/xbin/rmmod",
        "/system/xbin/route", "/system/xbin/run-parts", "/system/xbin/rx",
        "/system/xbin/sed", "/system/xbin/seq", "/system/xbin/setconsole",
        "/system/xbin/setserial", "/system/xbin/setsid", "/system/xbin/sh",
        "/system/xbin/sha1sum", "/system/xbin/sha256sum",
        "/system/xbin/sha512sum", "/system/xbin/sleep", "/system/xbin/sort",
        "/system/xbin/split", "/system/xbin/stat", "/system/xbin/strings",
        "/system/xbin/stty", "/system/xbin/sum", "/system/xbin/swapoff",
        "/system/xbin/swapon", "/system/xbin/sync", "/system/xbin/sysctl",
        "/system/xbin/tac", "/system/xbin/tail", "/system/xbin/tar",
        "/system/xbin/tee", "/system/xbin/telnet", "/system/xbin/telnetd",
        "/system/xbin/test", "/system/xbin/tftp", "/system/xbin/tftpd",
        "/system/xbin/time", "/system/xbin/timeout", "/system/xbin/top",
        "/system/xbin/touch", "/system/xbin/tr", "/system/xbin/traceroute",
        "/system/xbin/true", "/system/xbin/ttysize", "/system/xbin/tune2fs",
        "/system/xbin/umount", "/system/xbin/uname", "/system/xbin/uncompress",
        "/system/xbin/unexpand", "/system/xbin/uniq", "/system/xbin/unix2dos",
        "/system/xbin/unlzma", "/system/xbin/unlzop", "/system/xbin/unxz",
        "/system/xbin/unzip", "/system/xbin/uptime", "/system/xbin/usleep",
        "/system/xbin/uudecode", "/system/xbin/uuencode", "/system/xbin/vi",
        "/system/xbin/watch", "/system/xbin/wc", "/system/xbin/wget",
        "/system/xbin/which", "/system/xbin/whoami", "/system/xbin/xargs",
        "/system/xbin/xz", "/system/xbin/xzcat", "/system/xbin/yes",
        "/system/xbin/zcat");
symlink("mksh", "/system/bin/sh");
symlink("toolbox", "/system/bin/cat", "/system/bin/chmod",
        "/system/bin/chown", "/system/bin/cmp", "/system/bin/date",
        "/system/bin/dd", "/system/bin/df", "/system/bin/dmesg",
        "/system/bin/getevent", "/system/bin/getprop", "/system/bin/hd",
        "/system/bin/id", "/system/bin/ifconfig", "/system/bin/iftop",
        "/system/bin/insmod", "/system/bin/ioctl", "/system/bin/ionice",
        "/system/bin/kill", "/system/bin/ln", "/system/bin/log",
        "/system/bin/ls", "/system/bin/lsmod", "/system/bin/lsof",
        "/system/bin/mkdir", "/system/bin/mount", "/system/bin/mv",
        "/system/bin/nandread", "/system/bin/netstat",
        "/system/bin/newfs_msdos", "/system/bin/notify", "/system/bin/printenv",
        "/system/bin/ps", "/system/bin/r", "/system/bin/reboot",
        "/system/bin/renice", "/system/bin/rm", "/system/bin/rmdir",
        "/system/bin/rmmod", "/system/bin/route", "/system/bin/schedtop",
        "/system/bin/sendevent", "/system/bin/setconsole",
        "/system/bin/setprop", "/system/bin/sleep", "/system/bin/smd",
        "/system/bin/start", "/system/bin/stop", "/system/bin/sync",
        "/system/bin/top", "/system/bin/touch", "/system/bin/umount",
        "/system/bin/uptime", "/system/bin/vmstat", "/system/bin/watchprops",
        "/system/bin/wipe");
retouch_binaries("/system/lib/libgsdi_exp.so", "fdd8815f4765155da6553c1479c84037b44c257d", "/system/lib/libext2_blkid.so", "47fc1ae134679623359bd74ff49bb22ec1ce2d0a", "/system/lib/libjni_mosaic.so", "cec47df0ae28ca48b2bb4247d3b4c9aa5cf46a3d", "/system/lib/libmiscta.so", "0b99f6e3320deb0cbc3f357d11efe811bd9e84d8", "/system/lib/libauth.so", "17c4fcad1880a2c4853165c0f6189cabd3d63fda", "/system/lib/libpowermanager.so", "327eeaed62537e5303c0d48fecc7ff24aed9f1c2", "/system/lib/libinput.so", "ca20960ce320d87ba2339c319e03b84237f6f17e", "/system/lib/libcameraextensionservice.so", "df9c4da5ab66d15afbad26f3d34854ddf4619876", "/system/lib/libgsl.so", "58dea6ea824370eaf4e6af9e0d6b1392f05447bb", "/system/lib/libwmsts.so", "d449957591aaa33e233dc34cee5b93fdb2928eb2", "/system/lib/libwebrtc_audio_preprocessing.so", "43b49b1a547b3acc5dee09dfbb46a0e3191498c6", "/system/lib/liboem_rapi.so", "737510db6b6dc177a67e316f803953eb99f4567e", "/system/lib/libdsutils.so", "252c153264e8422e75e05e42dcffd281669c6c06", "/system/lib/libcm.so", "35ea3eb0f0fea96b3013fcf9609edbabce9a15ae", "/system/lib/libsystem_server.so", "1d5bb969d377827e78679a8b48dc8dcf4c5ed712", "/system/lib/libext2_com_err.so", "16377a5fe10193524bd080577ea14c0623aee1b2", "/system/lib/libETC1.so", "24d2c1201ae05ff0068049c53e7dd656e8f580e9", "/system/lib/librs_jni.so", "5779de5f4de72e989cd87f9bc3aba0adc0fa2983", "/system/lib/libmmgsdilib.so", "fc6a8bf90f21069651d675d9d6bb3c5532ccd063", "/system/lib/libface.so", "4867e41e48bd90c98a5418fe3f3fff29212b5f62", "/system/lib/libhardware_legacy.so", "0edfd02c919713dfad374b84d1883df0bd1e705e", "/system/lib/libharfbuzz.so", "52d07b8f04c74c289e38ee76c384e871a378a510", "/system/lib/libttscompat.so", "81fcad80ee71e40e279f3cedd40d2fa22a693223", "/system/lib/libnfc_ndef.so", "fa67345e7a6c8a7613adad0f2a39644021631882", "/system/lib/libgabi++.so", "73091b19fabc3fd9b79edd28e22ce3455ca2b33a", "/system/lib/libcrypto.so", "572c7220c6057490a238b607b3629449d93f1795", "/system/lib/libvideoeditorplayer.so", "345b40c4b20b94d26a458f57f36ccfbf7f28a4db", "/system/lib/libvorbisidec.so", "9f0cb4a96e570f1818cdd6e6ba297a89af6c44ba", "/system/lib/libicui18n.so", "275cb6f59c2170893d85c845c8d7a0ad130f43f6", "/system/lib/libdrmframework.so", "6b6624164461e2162f6ad53921c6cae649905ee3", "/system/lib/libOpenMAXAL.so", "a8e34cdf380104de82256bef487585ed7b27ef3e", "/system/lib/libsoundpool.so", "0d263eac71274329bc3175ac534c0d4290227726", "/system/lib/libFFTEm.so", "6d6741fd9ad78c4b11285e6f4669e6d941284aef", "/system/lib/libril.so", "6c675b6de7ed27db4f93598e87626cde36bf98fa", "/system/lib/libOmxCore.so", "a103b648849302fdd739daa31f7108d79bd958c4", "/system/lib/libstdc++.so", "d5e0a3b3ba351ff582402d4e4c21fabadf4095b4", "/system/lib/libGLESv2_dbg.so", "88a91d13d4e8b0393d84258dc9d1eb5a816d3ba5", "/system/lib/libext2_profile.so", "ce574f1b8ce9293b2b48b0bfc8440ee4a8b91bed", "/system/lib/libthread_db.so", "d2dfc250b4fd235ffdba98f901e0592a5e455f0f", "/system/lib/libz.so", "dfaa21a21101d9aac39fb6496a66021f751d5970", "/system/lib/libgui.so", "a08d270c628f68af0f33d080dfa619852051d49c", "/system/lib/hw/audio_policy.msm7x30.so", "c4b861861d65b5edba4fc077a07926cd04cead0c", "/system/lib/hw/hwcomposer.msm7x30.so", "82794ce5e1ae581b40878b90c055e8ba17654602", "/system/lib/hw/gps.semc.so", "6880b435d385ca734e4462d6862fdd0850f35751", "/system/lib/hw/camera.goldfish.so", "8efa5d001740f2c64b4712f3ee0ce8d4595b6476", "/system/lib/hw/gralloc.default.so", "de95c6045e4340e7b9484968eca2399889c3eb75", "/system/lib/hw/copybit.msm7x30.so", "abd4af66433b1621afa6eefcf272e51e367b7e73", "/system/lib/hw/audio.primary.default.so", "2b00c298a6a405b2fe8576abc5f7c944ab7295d1", "/system/lib/hw/camera.semc.so", "e7aea5543aa53b0c3e585c330e1ebe24719e906e", "/system/lib/hw/lights.goldfish.so", "58723e65bd4376575894ea17d362070c86664d68", "/system/lib/hw/sensors.default.so", "cfc9e509da335fd23e2973334a4fe097d379caf3", "/system/lib/hw/audio.primary.msm7x30.so", "7853c66f24ec001f4ed527c37bcbc6d39d652cbc", "/system/lib/hw/gralloc.msm7x30.so", "d84941d6992ea95642b87a9ca5c6db087f9246df", "/system/lib/hw/gps.goldfish.so", "fd18fd08c45793af52507d72cbc6d9924f8bc78e", "/system/lib/hw/sensors.goldfish.so", "362a2a7d7d78ea43c1e320319cfb37de6f6bbbe1", "/system/lib/hw/lights.semc.so", "621e1415ac92cf3f59d5f4e8f03fe183d3c3bcba", "/system/lib/hw/audio_policy.default.so", "292820c220ed72bc2e47838d15b1c21bee415e95", "/system/lib/libpagemap.so", "f187e57837fa697f0c875e3d3c3d456ec714bf2c", "/system/lib/libcald_imageutil.so", "b487b7879f79545c6110b7799298b0b97d6b1eee", "/system/lib/libGLESv1_CM.so", "905e9039b0d622df6c097d01d6879b6015a98b40", "/system/lib/libiprouteutil.so", "21a474397fb24c1c290ba09d0e72d22fce5f8b09", "/system/lib/libdiag.so", "80d33c0fb749d7342e8c0065092a2879d74a0605", "/system/lib/libwms.so", "bed70ae3a26bda8094e641c77c0e5b7856e6cccc", "/system/lib/libskia.so", "03dd71d92fb42df9830c378b6e2d2c9bb9df5d90", "/system/lib/libemoji.so", "c98b5ede771259beaedaf45f662884ba46573590", "/system/lib/libwebcore.so", "fc77d7a9cc2fdc6d995bddb65f3709ac38cb7fa0", "/system/lib/libbinder.so", "57e3d594ec32fc032fe7c5ad71dbb408b3e279c6", "/system/lib/libwnndict.so", "78a5084c240de375ef5464d3599d2f5bdccace2a", "/system/lib/libmediaplayerservice.so", "b19a8eb64505e1b1aab7241ff0ccbe33c7e8b0cb", "/system/lib/libqdp.so", "94060e279c501f6121bc3da2acb3fe01dc052b1e", "/system/lib/libext2fs.so", "a2bb21db2d42a24f539ce94870eefaa81088625d", "/system/lib/libutils.so", "b8be5dfe84461e3435e7bba42f569f81de356b4f", "/system/lib/libc.so", "4aabc586cd015f412671762dbecf40a3135859d5", "/system/lib/libext2_e2p.so", "cb0da7e541d1e3f710614a6d55d9571753e9c4a6", "/system/lib/libctest.so", "4f5400a79a26d87f4e430ae541dc69eb7f98cb8c", "/system/lib/libdll.so", "45a8bf996b441ca375d9e6cd3f50f29f69ea26d8", "/system/lib/libOpenVG.so", "a4409b1f0335a699d57d8458b544f28237c53dbf", "/system/lib/libspeexresampler.so", "55065f7531b48dc09d1a28ece65dc02139887e08", "/system/lib/libandroid.so", "932121d6a263cac3029911e8f34678e28c60e98f", "/system/lib/libusbhost.so", "654aefc3f7f47610c798bc9b08d8c0730b6e055e", "/system/lib/libaudioflinger.so", "5916e9a2315600127dfb6713d71ed96ac98be29d", "/system/lib/libEGL.so", "092c367132fda5462c72c69d673a1d78b88998e0", "/system/lib/libGLESv2.so", "8912f0cb6455bcf33e252a3cc5765c722012e476", "/system/lib/libfilterpack_imageproc.so", "942b6b46b6a45967fc6ebc1ec02bf1da92797a96", "/system/lib/libRS.so", "9724169a91ae67e3840afa81cf6460af8c0298b8", "/system/lib/libcameraextensionclient.so", "15222a2d94fe049bd10a5e73f219865adab6cf90", "/system/lib/libbcinfo.so", "da11f6ecc147adced472a6d62882fb7e9d3f5bfa", "/system/lib/libmemalloc.so", "2319b776b9c4f2e0f1e7a16e0e71c840404d5772", "/system/lib/libttspico.so", "5de02bb0c3f10f05a9e184b1286d6c059be642c0", "/system/lib/libreference-ril.so", "0aa9b62ec365cae7b570134dade5ddddac2a9ba9", "/system/lib/libgemini.so", "6696f1a2f9a7f41476f196eeccdaf2d575094abc", "/system/lib/libnv.so", "c259c4e4b9b231128f4d948c92aa3d63d13ac53a", "/system/lib/libdrm1_jni.so", "c03e286d9329945c08383de8593bf8a1dd1bdd43", "/system/lib/libpixelflinger.so", "a711f84bd92a6d2c9330cf4c53ff50af5cbcf3e7", "/system/lib/libpng.so", "ca4e5833e966aa737ffb44e241c745494782277f", "/system/lib/libsqlite_jni.so", "0f03a6a4fa1071df2f193939a5e01ebd154e4263", "/system/lib/libdsi_netctrl.so", "791be9795bd07f7f21ecf7b4c048130a82ef7428", "/system/lib/libdrm1.so", "f915a8b9a59441ebf81f9026d905233ae3f0f3d4", "/system/lib/libbluedroid.so", "05655d3786fd9961f0564b339fe9d9b59cb16477", "/system/lib/libbcc.so.sha1", "1a2287864186c22e910129cc93937cac3539ea8d", "/system/lib/liboncrpc.so", "be6115637c96d314282889702022c5ba353f42a4", "/system/lib/libmedia.so", "3857b1d0702437fcac1633382ffb3650631f7c58", "/system/lib/libstagefright_omx.so", "ae7c768c128aed1e0606b8803daf51c72f67cedf", "/system/lib/libWnnJpnDic.so", "0389d68204c94da21d2084336903c28fde6c64ef", "/system/lib/libdvm.so", "72df39b9d07743b89f99f7d28a293f92914f188a", "/system/lib/libglib.so", "734412eae2cb2e09c5b35ed9f88ca65bf8a558f8", "/system/lib/libstlport.so", "270ebd887979be9cd5fd5ae3b8e4ad7a0a8487d6", "/system/lib/libdiskconfig.so", "d840de38069a31620c13cbfd9a1c04f0cd6fcebf", "/system/lib/libstagefright_soft_mpeg4dec.so", "8d2a70fa845b6714f4d744f07f3638f3093ea079", "/system/lib/libsc-a2xx.so", "0bb99fad64873d3188457d23a75882ffb01d75ba", "/system/lib/libmtp.so", "6a59ca8afdac8bbc5d650d519edc5fcf7e42c4d2", "/system/lib/libext2_uuid.so", "2a157e84e766b81a198e39571e46713cff3356fb", "/system/lib/libdss.so", "a30000b4b0ad861aeb61e13aef57f3f35a905d51", "/system/lib/librpc.so", "f9efa08a49a5a119a0f1990d2e22b38bc5b04301", "/system/lib/libcameralight.so", "3047a9e352912699ebf9ccb8d3b5e229922c9d71", "/system/lib/libdsm.so", "8a0103bdf15fa39b60624c94a4bb41c6af6fd03a", "/system/lib/liboverlay.so", "0efba0ac6aa41afbebf5fd1d991fd4de361d2a2c", "/system/lib/libOpenSLES.so", "2af38557b58ed166ba7154284c736fbd7858ce4d", "/system/lib/libril-qc-1.so", "8e0cdbb49156a9fb6e9285504b26202d38f5d55b", "/system/lib/libSR_AudioIn.so", "c061bb30fc974b7c0134cad995aa2cad8d802637", "/system/lib/libchromium_net.so", "00e0fe9f5239f5f799cb51569d8d5ba3d2576756", "/system/lib/libstagefright.so", "fa0e10e7ca10176aa983450a649b3119d0bb8cf2", "/system/lib/libmmipl.so", "1c464d7cac14508d510d9c88996fae99c4882920", "/system/lib/libcald_debugger.so", "2ae77358fdb7ac4ba83e994518da587779fdef6e", "/system/lib/libjni_pinyinime.so", "a314caadf16561915eb3972c5ec3298750f4c412", "/system/lib/librtp_jni.so", "8d86a0986ba3ba4741b3ecaed01004d5e0c08281", "/system/lib/libncurses.so", "4a02fbccf1ca68f158bad5b703d87127ab29f9c3", "/system/lib/libc_malloc_debug_leak.so", "ecf6878cefaf7bac500b5855deb5ba689dd43e22", "/system/lib/libcutils.so", "8354849d778f29440873adee4ab1ac7553623df1", "/system/lib/libcamera_clientsemc.so", "2762e6269e7c8dd96434d7a3f629a3e4d3416b0d", "/system/lib/libdefcontainer_jni.so", "6900b622330b890b05807ab4cebcca9ba264513c", "/system/lib/libqmi.so", "00887091f2e37ae8df7d7f2ff5ef6a2bf9f58f16", "/system/lib/libm.so", "146ef7ea611b2d66ccd972c3aacab4b19b8fb1cb", "/system/lib/libext4_utils.so", "67ca2ebb1105a6bec094efd7bd0389fcec62c010", "/system/lib/libsonivox.so", "17dbd3ca7eb209f2d1765fedd2ce9a4145685200", "/system/lib/liboemcamera.so", "b8f2432272443146935fdd369377249d0bc84e3c", "/system/lib/libpower.so", "4e62a2bec2c1451ad30dc3eed859a55d7a8685eb", "/system/lib/libnativehelper.so", "81348300f8290cc8f77d64feec7a9a0988d36bab", "/system/lib/libgstk_exp.so", "e4496eb51425388a12ae481d8cd532ec43995e22", "/system/lib/libaudioeffect_jni.so", "026dfe508683b1b5d0a304a1032a34adc3597c15", "/system/lib/libpbmlib.so", "753c121ff5f12c2ede502507ea5ee7df54aa0ea0", "/system/lib/libdrmframework_jni.so", "ef4126886149779968016afecfa3eff961dabaa1", "/system/lib/libcald_hal.so", "cb8b3f82be1c7ad00c4af0a11a88bdb16731c8c7", "/system/lib/libcald_pal.so", "cca696339823fa22d25d25bb835420a4df2ffd11", "/system/lib/libwilhelm.so", "8e5cf049164c8f963c3e296a0373c079ba0aa63a", "/system/lib/libstagefright_foundation.so", "b7d35c39e5ac409ac3c4df47e6aec3c6481e6469", "/system/lib/libmedia_jni.so", "b5ab60eb52d44528dc32704d0b6b6b9fd99e8b80", "/system/lib/libaudioalsa.so", "4435b96bbdbfd9f560fc3c4b4db8c2ef8ed694ca", "/system/lib/libnetmgr.so", "5670d041965d90d33f7bb700c896bdc69ea85251", "/system/lib/libexpat.so", "497257c20f055595a15142a744ffcc8a08c46a6a", "/system/lib/libC2D2.so", "3c4cc15e9f1a33a5d757673a0f03f5203d955dd7", "/system/lib/libjni_latinime.so", "c144f2ea512817104dcdb5672a4d2dd155f32ab1", "/system/lib/libexif.so", "d0ce3529f87bd53d584aa5c9bd70aa57487634e1", "/system/lib/liblog.so", "58db0a39f510cb88ed259b0da303881e1a134ed2", "/system/lib/libdbus.so", "1df92ac95992fea14c4345e3ce1838ebef553c21", "/system/lib/libcamera_client.so", "4b39ca8b80f56076d755fe0a06b0c9f8d949ae60", "/system/lib/libicuuc.so", "c3632a5c847af32b07a23c2d9dbfd3867aca3882", "/system/lib/libnetlink.so", "a008c101e79049ee6c04be806c5ee84d9cc22ca7", "/system/lib/libjackpal-androidterm3.so", "ecaeb903c230d76e6becedc058fc61b518e9d60b", "/system/lib/libssl.so", "cea2beafda64a1f90f9a445bc4413c8156c98c1f", "/system/lib/libjpeg.so", "748305c91e7eaccadc6531c67300db9701883ce7", "/system/lib/libeffects.so", "91536fe56cc6ace77e3e030696c7d77352727750", "/system/lib/libstagefright_enc_common.so", "19366f6429aa3451620c78c1fc916819bf1e9569", "/system/lib/soundfx/libvisualizer.so", "9f259bd06607f4dabe8aec35ebff3df9b43c2c0a", "/system/lib/soundfx/libbundlewrapper.so", "fa261236c43fdb4ec6711b578bad55472ec96da0", "/system/lib/soundfx/libcyanogen-dsp.so", "0fcb0147f97e241e5bbccad6f878422e66490552", "/system/lib/soundfx/libaudiopreprocessing.so", "343b096e21c694a70ad2c2baca51a51077ccaa53", "/system/lib/soundfx/libreverbwrapper.so", "ff96fff27505c0b13b073bb6f23fa61f86ecf406", "/system/lib/libstagefright_yuv.so", "200bc648233944dc489f806f8b30efa909d7d2c3", "/system/lib/libdl.so", "c6e8850a721d297730574aaa8b256abab1f43203", "/system/lib/libQcomUI.so", "74cd8066ce5f7a22abeb59c4c7debca918581656", "/system/lib/libstagefright_avc_common.so", "3d5946873021b17daa8208658cb584f229f7ea68", "/system/lib/drm/libfwdlockengine.so", "56ed38b918dcc8f44b2ab6d8f6ce207c6cddd235", "/system/lib/libnetutils.so", "4501a094d253b1578d6925c3eb631c2a59d4752e", "/system/lib/libgenlock.so", "d3bd1385228c4f662e533540e9aab7f895665790", "/system/lib/libsurfaceflinger.so", "742a628bcb6d528cc45f21256bd0c1d1e7b44546", "/system/lib/libjnigraphics.so", "c365f208cce339e933d4388c7af3495e89ca3aa0", "/system/lib/libbcc.so", "70fa43caa49f9dec512cae834577b8044dae5276", "/system/lib/libwpa_client.so", "ea081b91cc1255ab5479cb725cdc3164386f59e7", "/system/lib/libsurfaceflinger_client.so", "12ba180d276b44d96e23f91c3d328f6ffdeed0eb", "/system/lib/libWnnEngDic.so", "3a02e0e39d9663f71ae10e3c0fed01048e64fd7e", "/system/lib/libhardware.so", "e9c66e4389a52b72547819a03ef105dc516a6c69", "/system/lib/libandroid_servers.so", "b21f39bd7e756a13c04c44371669434860f695d4", "/system/lib/libstagefright_soft_h264dec.so", "9cc7043e72b00cdddbf17537486177529bce2cbe", "/system/lib/libstagefright_amrnb_common.so", "933d810b78795fe26ba4e9ea4450e1059051ead7", "/system/lib/libbluetoothd.so", "872c73b8126162a8eed15ce8b424384d37e49e9e", "/system/lib/libstagefright_soft_mp3dec.so", "39aba1bda7d1151cfe8afcb5c1e1ad458f53e75a", "/system/lib/bluez-plugin/network.so", "64567f4ec64c490d34276937bb769e6804178a8b", "/system/lib/bluez-plugin/audio.so", "0afd91c4b707d480f9d39c8c62837721417253ee", "/system/lib/bluez-plugin/bluetooth-health.so", "789982e03b2569bff1b70c9165a7b6ba43d6cd72", "/system/lib/bluez-plugin/input.so", "3e08ebf69b139232b8394ba839f97cc1de6b2f67", "/system/lib/libcameraextensionjni.so", "f200bae32348f989299863736431ad8a95028bd7", "/system/lib/libsysutils.so", "a5e14dffa7fbcf9ad03992ad13ef62ab015e8a33", "/system/lib/libstagefright_soft_amrdec.so", "6ee9b4575da75ea04a6741eaa4063a6ef0b25d37", "/system/lib/libstagefright_soft_vpxdec.so", "44a52ce0242e19c30e5c0f9b7ff7ed691c0c682b", "/system/lib/libbtio.so", "7456a7c898aee869c61f7f451ab2acf76877f697", "/system/lib/libvariablespeed.so", "6f652702ce0c845173cf6fb1dacdb189ead6b078", "/system/lib/libqueue.so", "9936fd9da90bbdc88b005956bf3f001865dea89b", "/system/lib/libcald_server.so", "56f212a5195621aa246da37e844112247aae2e3d", "/system/lib/libstagefright_soft_g711dec.so", "d50f57b50370ef9fb97f57cdca4a93b27d6b020b", "/system/lib/libsqlite.so", "de2b1ad2d05462e1f82f9d12bf0ad158c8f11280", "/system/lib/libclcore.bc", "a1e2610fdc0c2ef151248092fa32be807d1b983d", "/system/lib/libcameraservice.so", "5d3d35cc638734f4641387ff4ac09ef4c2c2ccb5", "/system/lib/libsrec_jni.so", "8f8fea7aed3ce5454d21598d73e2d07616027003", "/system/lib/libc_malloc_debug_qemu.so", "a211f77580a7d5268b21ca2f8a8e54b8d881edf1", "/system/lib/egl/libGLESv1_CM_adreno200.so", "fe89043638d4c72bfb5fe16b4e0a54f0350d7c08", "/system/lib/egl/libEGL_adreno200.so", "626a3ba5b6e79d8bca3d8e2c9c1d76e44ee04f69", "/system/lib/egl/libGLESv2_adreno200.so", "f258fb7b73db91bbcec8a1a2d619aa9e6dc9d197", "/system/lib/egl/libGLES_android.so", "b42196bc78221ec337cb22fdb51f626c12c737ba", "/system/lib/egl/egl.cfg", "812655c141446e225230be00e36f7e9d6eb89106", "/system/lib/egl/eglsubAndroid.so", "2e8deced255024a28eb296a265a3e311120871d4", "/system/lib/egl/libq3dtools_adreno200.so", "db90e0bf74905c0455e0687b0b5bd330039ba6aa", "/system/lib/libcald_client.so", "ce4c11b16f350c0548f30d38e0390036ff3a1fd5", "/system/lib/libvideoeditor_jni.so", "886cb6f139ecb658cac0d66caee48f4ad90b8ced", "/system/lib/libstagefright_soft_aacdec.so", "2c9fa4c755f88a99c36d3350ce548e1e81fdc7a2", "/system/lib/libfilterfw.so", "948dc7106a02b44064bdc8d0324ae8c8bb747702", "/system/lib/libuim.so", "e25299a3deff5d95aeda325fe259326056d06727", "/system/lib/libbluetooth.so", "5bd2b8f2bc21f1955c9cffd697672b3187ed398f", "/system/lib/libstagefright_soft_vorbisdec.so", "f70273cef293291d94e88bd2ce12ed8c2b14a0cc", "/system/lib/libandroid_runtime.so", "7af02f5963fbce549eae71e32fc569ecf3a2ecd0", "/system/lib/libmmjpeg.so", "62f0141361e3b01721894797322903f2c7191f38", "/system/lib/libui.so", "27596240c1f17ef7131486d1123440692745994b", "/system/lib/libsensorservice.so", "d476c0f79a47abf0b5e7471bfb3ee7fe96290ca0", "/system/lib/libidl.so", "0b71b4b909eb9c378a01bfa262d09f222221885b");
set_perm_recursive(0, 0, 0755, 0644, "/system");
set_perm_recursive(0, 2000, 0755, 0755, "/system/bin");
set_perm(0, 3003, 02750, "/system/bin/netcfg");
set_perm(0, 3004, 02755, "/system/bin/ping");
set_perm(0, 2000, 06750, "/system/bin/run-as");
set_perm_recursive(1002, 1002, 0755, 0440, "/system/etc/bluetooth");
set_perm(0, 0, 0755, "/system/etc/bluetooth");
set_perm(1000, 1000, 0640, "/system/etc/bluetooth/auto_pairing.conf");
set_perm(3002, 3002, 0444, "/system/etc/bluetooth/blacklist.conf");
set_perm(1002, 1002, 0440, "/system/etc/dbus.conf");
set_perm(1014, 2000, 0550, "/system/etc/dhcpcd/dhcpcd-run-hooks");
set_perm_recursive(0, 2000, 0755, 0755, "/system/etc/init.d");
set_perm(0, 0, 0755, "/system/etc/init.d");
set_perm(0, 2000, 0550, "/system/etc/init.goldfish.sh");
set_perm_recursive(0, 0, 0755, 0555, "/system/etc/ppp");
set_perm_recursive(0, 2000, 0755, 0644, "/system/vendor");
set_perm(0, 0, 0644, "/system/vendor/etc/audio_effects.conf");
set_perm_recursive(0, 2000, 0755, 0755, "/system/xbin");
set_perm(0, 0, 06755, "/system/xbin/librank");
set_perm(0, 0, 06755, "/system/xbin/procmem");
set_perm(0, 0, 06755, "/system/xbin/procrank");
set_perm(0, 0, 06755, "/system/xbin/su");
show_progress(0.200000, 0);
show_progress(0.200000, 10);
run_program("/tmp/backuptool.sh", "restore");
show_progress(0.100000, 0);
unmount("/system");
OMG. ich riskiers sicher nicht will ja mein handy noch möglichst lange haben :D
Sehr nice! So wer ist mutig genug?
Ein normalo von uns wird es sicher nicht auszuprobieren :) wobei ich echt gespannt bin, ob des was wird!
Gesendet von meinen Galaxy S Plus
also habs probiert...full wipe gemacht...reboot...mein altes system startet...also satz mit x :biggrin:
Also ich habe mich jetzt mal noch ein wenig genauer damit beschäftigt.
Die upadte-binary im package ist nicht in der lage eine partition in ext4 zu formatieren. Ich habe das somit händisch über CWM geregelt. Das mounten von /system habe ich auch von Hand gemacht. Ich habe also die Befehle für mount und format aus dem updater-script herausgenommen.
Desweiteren habe ich die ganzen strings für backuptool.sh entfernt. Weiß nicht genau was die bewirken, aber scheinen ein Backup des alten Systemy anzulegen. Kann mich auch irren.
Zusätzlich habe ich noch den string für das boot.img eingefügt (siehe zweiter post)
Das Package wurde auch erfolgreich geflasht und ich kann über adb auch die Dateien auf meiner system-partition liegen sehen.
Nun kommt jedoch das eigentliche Problem. Das mitgelieferte boot.img schafft es nicht über das SamsungLogo hinaus.
Also SkyHighv1.3 drauf geschmissen. Neustart und....Fehlanzeige. Hier ist "erst" beim Samsung Galaxy S Plus-Logo Schluss. SkyHigh startet immer weider neu. Der Stock Kernel verhält sich genau so.
Der Kernel von YardE kommt auch bis zum S Plus Logo, dann geht es allerdings nicht weiter. Steht jetzt schon ein paar Minuten.
So das sind meine ersten "Eindrücke" von der Alpha :D
Da bin ich ja mal gespannt ob das noch was wird. Ob die Portierung überhaupt funktioniert. Ich hoffe, da geht noch was vorwärts.
Die haben das Rom als download zurückgezogen. Macht wohl zu viele Probleme. Soll bei einigen nicht booten laut aussagen auf Facebook.
Jop kann ich bestätigen naja war ja auch sozusagen das Alpha vom Alpha
---SCHEISS-ACTA---
Naja. Villeicht kann ja jemand der kernelbastler :o was mit der rom anfangen. Oddr die customer eine lauffähige version "herstellen" *hoff*
Gesendet von meinem GT-I9001 mit Tapatalk
Ist jetzt OT, aber ich hab keinen Plan wo ich das sonst fragen kann! :flapper:
Also: Wo kann man im XDA Forum auf "Thanks" drücken? Ich find den Button nicht! :scared:
Sorry für die doofe Frage...
[Offtopic /on]
Wenn Du runterscrollst bis nach unten, dann kannst Du umstellen zwischen XDA Classic und XDA 2010. Wenn Du die 2010 Version nimmst, dann siehst Du auch den Button :cool2:
[Offtopic /off]
Neues Build auf dem Weg...
jaaa jetzt wirds wieder interessant.. !:D
Wo?
Lädt er es gerade selber hoch, aus einem anderen Forum..........
schlaumeier
@dijoha: auf der Startseite (Seite 1 dieses Themas)
"BUILD 2 [13/03/2012] (Upload in progress...)"
Heißt nach meiner Ansicht soviel wie "Wird zur zeit Geuploadet"
Ich hoffe das,das heute noch etwas wird
Schade, ich hatte gehofft das wir noch einen CM7 kriegen, welche ich persönlich viel besser finde.
Und ja, die Übersetzung ist richtig ;) Wird grade hochgeladen das ganze.
juni
  • Lohenstein
se1111
sgspluss
sgspluss
sgspluss
