flasher78
Dauer-User
- 309
Dies ist ein inoffizieller Port der Root-Box ROM für unser Gerät. Ich hatte keinen Anteil an der Entwicklung, ich habe es nur kompiliert
"The Vanilla Rootbox ROM combines the best custom features of Android Open Kang Project (AOKP) and CyanogenMod (CM) ROM in a single profile, which includes per app DPI, tablet UI and Language features.
NOTE: As the Vanilla RootBox ROM is based on the newly released Android 4.2.2 firmware which is still under development, it may harbour a few untested bugs or broken features. However, all such issues are expected to be fixed in the upcoming updates as development progress.
Here is the complete list of key features supported by Vanilla RootBox v3.8 ROM:
-AOKP Features
-CM Profiles
-Per App DPI
-Per App Tablet UI
-Per App Language
-OTA Updates - Goo Manager
-Navigation Bar Colour
-Camera: Save to external memory
-Phone: Advance Phone Settings (Vibrate on Answer, Every 45 Seconds, On Hangup and On Call Waiting)
-Phone: Noise Suppression
-MMS: Message rate alerts (Modify SMS message limit for alert)
-MMS: Fully Customizable MMS Theme
-MMS: Soft Keyboard Type (Emoji, Enter to Send, Enter for a New Line)
-Home button call answer (Accessibility Option)
-Variable size pattern lockscreen
-LCD Density Changer
-Low Battery Warning (Pop-up & Sound, Pop-up only, Sound only, Off)
-Option to control cursor in text fields using volume keys
-Disable Fullscreen Keyboard (Landscape mode)
-Expanded Desktop
-Hold Back to Kill
-CRT Animation (Screen On/Screen Off)
-Lockscreen Shortcuts (Paranoid)
-Pie (Paranoid Android)
-Lockscreen Targets (CM)
-Screen Security Features (Unlock options: Quick Unlock, Delay Screen Lock, Menu Unlock, Home Unlock)
-cLock (Chronus)
-Option to disable sound when adjusting volume
-Launch Music app on Headset connection
-Hardware Keys Remapping
-Lockscreen Hardware Keys Remapping"
Ich bin nicht verantwortlich für gebrickte Geräte, kaputte SD-Karten oder andere Probleme, die auftreten können, wenn sie diese dieser ROM Flashen!
XDA Link Unofficial ROOT-BOX
Was funktioniert
Audio
RIL
GPS
Kompass
Näherungssensor
Wifi
USB-Massenspeicher
HW beschleunigt gui
HW-beschleunigte Video
Kamera
BLN
USB / Wifi Tethering
Vsync - für die vollständige Projekt Butter Erfahrung
Bluetooth
Link Download Release 4.6 : Release 4.6
Mediafire Mirror Release 4.6
Link Gapps 2013/07/15 : Gapps 2013/07/15
Mediafire Mirror Gapps 2013/05/18
Ältere Versionen
Changelogs:
Credits
ROOT-BOX TEAM
CM TEAM
AOKP TEAM
PARANOID ANDROID TEAM
KRISLIBAEER
CAMCORY
BLACKMAMBAZZZ
ARCO
IVENDOR
XISTANCE
-AOKP Features
-CM Profiles
-Per App DPI
-Per App Tablet UI
-Per App Language
-Expanded Desktop
-Hold Back to Kill
-cLock (Chronus)
Was funktioniert
Audio
RIL
GPS
Kompass
Näherungssensor
Wifi
USB-Massenspeicher
HW beschleunigt gui
Kamera
BLN
Bluetooth
Ältere Versionen
Changelogs:
Code:
[B]Release 4.6[/B]
In line with my CM 10.1 Release 4.6
Sync ROOTBOX repo
[B]Release 4[/B]
Compiled With GCC 4.7 SaberMod
String routines optimized for ARMv7
LW Android 4.3 (Sun Beam)
Correct Fonts Android 4.3
Revert to GPS.conf from ROOTBOX
Put back dalvik.vm.dexopt-data-only=1
Remove custom oncrpc node permissions
Enable NEON Optimizations
Clean out unused code from liblights thanks arco
msm7x30: Fix audio in Hangouts
New AriesParts thanks ADCteam
Somethings when you use Spirit FM app and you turn on Apollo the audio is missing and you need reboot the phone I solve this issue
Update kernel 3.4.52
Sync ROOTBOX repo
[B]Release 3[/B]
Compiled with GCC Linaro 4.6 Optimized for cortex-A8 by Christopher83
Switch from ROOTBOX to CM Bionic Optimizations
Add NEON Optimizations
Add Live wallpaper SunBeam from Android 4.3
Minor Updates in Rom
Update kernel
Sync ROOTBOX repo
[B]BETA 11[/B]
-O3 OPTIMIZATIONS
Add Apollo
Add CMfilemanager
Delete Goomanager
Delete Torch
AriesParts: Update German language (Thanks blackmambazzz)
Minor Updates in ROM
Update Kernel (Added last changes by Arco Make today)
Sync ROOTBOX repo
[B]BETA 10[/B]
Same changes from CM10.1 Beta 10
Sync ROOTBOX repo
[B]BETA 8.5[/B]
Fix ROOTBOX Wallpapers FC
Fix Loockscreen FC appear in Beta 7
Added Home and Volume Rocker Wakeup
Update Kernel 3.4.49
Sync ROOTBOX repo
[B]BETA 7[/B]
Frameworks TRDS 2.0
Fix Inverted Picture make with front camera (Thanks CastagnaIT)
Update kernel 3.4.48 "Without CM BLN for now in test fase by Ariesve-devcon-team"
Sync ROOTBOX repo
[B]BETA 6.3[/B]
Compiled with Linaro Toolchain 4.6.4 By Christopher
Update CameraHAL
Update liblights with BLN support
Update vibrator setting with softer vibrations
Update BoardConfig
Softer keyboard vibration
Update Kernel to 3.4.46
Sync ROOTBOX repo
[B]BETA 6.2.1[/B]
Same changes from CM10.1 BETA 6.2.1
Sync ROOTBOX repo
[B]BETA 6[/B]
All features cm10.1 Beta 6
Fix front camera
Update Kernel with last changes
Sync ROOTBOX repo
[B]BETA 5.2[/B]
All features Beta 5.2 CM10.1
Fix camera Thanks Krislibaeer
Sync ROOTBOX repo
[B]ALPHA 2[/B]
Fix Lags Thanks Krislibaeer
Same changes like CM10.1 BETA 5.2
Camera App Missing I don't know Why
Sync RooBox repo
[B]ALPHA 1[/B]
First Release
ROOT-BOX TEAM
CM TEAM
AOKP TEAM
KRISLIBAEER
CAMCORY
BLACKMAMBAZZZ
ARCO
IVENDOR
XISTANCE
