NitroX Rom NITROX GALACTICS 2,5 - EUROPA
  • 39 Antworten
schlurfi
Stamm-User
75
Dies ist die vierte Version von Nitrox Galactics, ROM auf Ice Cream Sandwich für Galaxy S Plus, aktualisiert Version 2.5 gewidmet Europa, eine der vier Monde des Jupiters!
Freigegeben in Verbindung mit der neuesten Version von Nitrox (das erste ROM von Nitrox-Entwickler für MID 8024 gemacht)
Aktuelles :
- Updated at last AOKP Release (beta 10 - build 40);
- Bessere flüssigkeit;
- Android 4.1 Jelly BeanPlay Store;*
- Changed Memo Icon in Official S III;
- Added NitroX Services;*
- Updated Flipboard;
- Updated Titanium;
- Updated MILauncher;
- Updated Maps:
- Updated Street View;
- Updated YouTube;
- Removed NitroX News;
- Removed NitroX Play;
- Added Vitality Kernel negli extra;
- Addes ICS SD Binder negli extra..
_______________________________
Charaktereigenschaften:
- Android 4.0.4 (AOKP build 39);
- Root;
- Deodexed;
- CyanogenMod 9 kernel;
- Init.d and build.prop support ;
- Galaxy S III UI;
- Galaxy S III Sounds;
- Galaxy S III Widget;
- Galaxy S III wallpapers choser;
- Official NitroX Boot Animation;
- Gapps included;
- Camera Fix included;
- Swype Keyboard inclueded;
- Gps working at 100% in all nation;
Default App (all updated at last release):
- Android Assistant;
- Browser;
- Calculator;
- Calendar;
- Vocal Composer;
- Download;
- Email;
- Equalizer;
- ES File Explorer;
- Facebook;
- Flash Player Settings;
- Flipboard;
- Gallery;
- Go Launcher EX;
- Settings;
- SIM Tools Kit;
- Maps;
- Memo;
- Messagge;
- Movie Studio;
- Music;
- News and Weather;
- NitroX Services;
- Clock;
- Contacts;
- S Suggest;
- Speech Recorder;
- Superuser;
- Phone;
- Titanium Backup;
- YouTube.
Launcher:
- Go Launcher Ex (whit SP Theme);
- MILauncher V4;
- TouchWizUX.
Extra:
- 6 Boot Animation (5 Made in NitroX + Galaxy S III);
- 2 Icon Pack Made in NitroX (Icon One + Icon Carbon);
- 2 Kernel (Oisis Kernel + Vitality Kernel);
- 3 App (Pudding Camera + Media Scan + ICS SD Binder);
- Wallpapers (NitroX Style + Galaxy S III Style + Galaxy S III Live Wallpaper).
Credits:
- Google (for Android);
- Samsung and S3 UI Developers of XDA (for S III Theme);
- oisis e AOKP developers (for AOKP);
- arco69 and vitality (for kernels);
- crypted (for GPS patch).
(If I forgot someone let me know via PM)
Part 1 Zippyshare.com
Part 2 Zippyshare.com
Part 3 Zippyshare.com
Home von NitroX:
NitroX-developers
XDAdevelopers link:
[ROM][AOKP][S3UI] ¤ NitroX GalactICS 2.5 ~ Europa ¤ « Fast | Customizable | Stable » - xda-developers
Habs mir mal drauf gezogen und werde es etwas testen...
Bei mir läuft es jetzt seit dem we. Und das bisher ohne größere Probleme.
Gesendet von meinem GT-i9001 mit der Android-Hilfe.de App
funktioniert die cam?
schlurfi schrieb:
wenn sich hier mal keiner die mühe macht es zu posten
Vielleicht solltest du noch einen Link zum original Thread auf XDA und die Installationsanleitung in deinen ersten Post werfen.
Gruß....busprofi
ok sorry hier noch die instanleitung:
How to Install (needed CMW Recovery o TeamWin Recovery):
- Download the two parts of package:
NitroX GalactICS 2.0 - Halley's Comet.part1.rar
NitroX GalactICS 2.0 - Halley's Comet.part2.rar
- Extract part1 (system automatic extract part1 and part2 in the same file);
- Open the extracted folder and go in ROM folder;
- Insert ROM in your microSD;
- Go in Recovery (when phone is turned off, press power button + Volume UP);
- Select "Wipe data / factory reset";
- Select "Wipe Cache";
- Select "Wipe Dalvik Cache";
- Choose "Install zip from sdcard";
- Install the ROM and ... enjoy whit Nitrox.
*Warning!Bugs of ROM base (AOKP) are also present in this ROM:
USB tethering - not work
HDMI - not tested
Der ursprüngliche Beitrag von 17:54 Uhr wurde um 17:56 Uhr ergänzt:
icHbinDere schrieb:
das ist aber der link zur ""alten"" - Android 2.3.6 (KQE)
bei kommt ein fehler E:signature verification failed
wtf?
Der ursprüngliche Beitrag von 18:30 Uhr wurde um 18:50 Uhr ergänzt:
hät sich erledigt hatte ne zu alte version vom cwm drauf...
Also ich habe es nach einem Tag wieder runter geschmissen.
Weiß nicht woran es lag aber bei mir hat sich das handy 3 x festgefahren und musste den akku raus nehmen und heute morgen das gleiche wieder und ich konnte es nicht einmal wieder starten, habe dann mein backup wieder eingespielt. schade...
wtf?
Muss man das CWM aus dem CM9 Thread installieren?
jepp
Schlurfi würdest du nitroX oder cm9 empfehlen?
Sorry ist Geschmacks Sache. Sie neuen beide auf dem gleichen auf haben die gleichem Bugs und den gleichen Kernel ;)
Probier sie doch beide aus. Mir persönlich gefällt mir die hier besser
wenn ich die eine ausprobiert habe & will die andere benutzen, dann muss ich im recoverymodus wieder die 3 sachen vor der installation machen, oder?
Ja, bei einem Kernel/Rom Wechsel immer diese 3 Schritte machen, wenn du eine Rom Updatest, z.b von RC1 auf RC2 von irgendeiner Rom, dann nur:
XeLLaR
Reaktionen: VooDooJ3ernd
Rom getestet ist sehr super :)
Ne frage gibts denn lockscreen vom s3 auch wo man einfach nur sliden muss
gute frage hab ich nu net nach gesucht
Ist hier die Camera_experimental schon dabei?
an sich gefällt mir die Rom sehr gut, vorallem wegen dem S3 look ;P
allerdings läuft sie bei mir nicht so recht flüssig und bockt... das Problem hab ich aber wie schonmal erwähnt bei allen Roms ausser Crybernation :p muss an der Hardware liegen, schade..
einziges Manko der Rom: anderer Lockscreen Style wäre wünschenswert.
Noch Ausbaufähig, wie alle anderen 4.x Roms
  • Lohenstein
se1111
meleran
Fiedl
Fiedl
