[I9001][STABLE][AOSP][6.0.1] Slimroms for Galaxy S Plus
  • 9 Antworten
elmuerte
21
Auf XDA wurde eine neue ROM für unser Galaxy S Plus veröffentlicht:
AOSP Slimroms for Samsung Galaxy S Plus (AriesVE - msm7x30)
AOSP version
android-6.0.1_r79
Auszug aus dem XDA Thread:
What works:
  • Boot
  • Sensors
  • Touchscreen
  • WiFi
  • Bluetooth
  • RIL (Making calls & Mobile data)
  • Vibration
  • GPS
  • Camera
  • Sensors
  • ADB
  • Adoptable Storage
What's not working:
  • FM Radio
Danke an outofmemory13 sowie
Quote:
  • to Sir mordred - for ancora sources
  • to K_TECH - for lollipop aosp based device tree
  • to LegacyXperia for msm7x30 sources
25.04.2018:
- initial release
27.04.2018:
- Fixed bluetooth
- Changed DPI to 200
- Removed torch from quick settings
- Optimized for low-ram
- Increased zram/swap to 512MB
- Changed IO Scheduler to BFQ (from ROW)
- Changed that ugly deep-green accent color to pixel-blue
04.05.2018:
- Fixed SuperSU
- Fixed sensors
- Fixed camera (partially)
05.05.2018:
- Fixed settings crashing
- Fixed weird CPU usage (ondemand)
- Reduced zRAM to 384MB
- Optimized GPU
- Enforcing selinux is supported
10.05.2018 - First BETA Version:
- Fixed wrong permissions in ramdisk (CPU should work correctly)
- Replaced SlimLauncher with AOSP Launcher3 (+~10MB RAM)
- Expanding status bar is now working w/o weird UI bugs
- Reduced boot time
- Included AriesParts
- Optimized dalvik - Launching apps is faster (Eg. Settings - ~1.872ms - in older build: even above 3 seconds)
- LMK is now less agressive
- Disabled multiuser feature (+~9MB RAM)
- Disabled rendering high quality shadows
- Enabled Wake up on charge
- Fixed OTG (mouting USB storage is working fine)
- No UI lagging when changing brightness
- Disabled rendering transparent views when activity is not visible
- Swappiness is now set to 60 (default value)
- Removed LiveWallpapers
15.05.2018 - Second BETA Version:
- Faster UI rendering
- Applied newer security patches (April 2018) - ONLY CRITICAL PATCHES!!! Probably not all - I've noticed some rejects
- Changed material-green color to pixel blue in some locations
- Low RAM configuration is now set by default
- Improved HD Video playback (720p video recording should work better, but it also fails)
- Fixed wake function in sensors HAL. The issue with rotation still exist, but at least there's some progress
- Faster flashing in TWRP(block-based OTA is finally fixed)
- Enabled Ambient Display feature
24.05.2018:
- Updated kernel to 3.4.113-stable
- Added F2FS filesystem support to cache partition (change filesystem in TWRP)
06.06.2018:
- Optimized graphics (no more hwcomposer OOM)
- Compiled with O3, Os flag (GCC optimizations)
- Kernel compiled with archidroid toolchain 4.9 with my cortex-a8 neon configuration
- Added necessary permissions for Gapps (just in case you want kill your device
- Removed aptoide, Ariesparts, Terminal
- Changed default browser to LineageOS Jelly
- Faster app launching
- Changed default system font to Google Product Sans
- Support for gapps (DOWNLOAD HERE)
16.06.2018:
- Fixed sensor issue (finally! ALL sensors are working, w/o deep sleep bug )
- Changed screen color temperature (Checked on few SGS+ devices - looks better)
- Reduced boot time (~8 sec.)
- Fixed offline-charge overheating
- Replaced ugly AOSP charger with better one
- Changed O3 flag to Os... & built with -mfpu=neon-vfpv3
- Replaced old rild with AOSP rild
- Disabled compression on zRAM
- Reduced zRAM to 64MB
- Fixed WiFi Tethering
- Added missing GPS config (GPS should work)
- Re-enabled CPU+GPU rendering
Bearbeitet von: Taba - Grund: Doppelpost zusammengeführt. Gruß Taba
Reaktionen: pjozsef54
Installation funzt nicht.
Fehler meldung :
Digest Datei nicht gefunden.
dann versucht er zu installieren geht dann aus und nix geht mehr.
habe TWRP 3.2.1.0 wie empfohlen geflasht,
Wo steht diese Empfehlung?
Und wo hast Du das TWRP 3.2.1.0 her? Ich finde nirgend eine Downloadmöglichkeit für das I9001 .... :-(
Läuft echt gut! Eine TWRP 3.2.1.0 hab ich zwar auch nicht entdecken können aber die 2.8.1.0 hats auch getan.
@MachineHead Hallo, ich hab da mal eine Frage. Ich habe noch die Slimrom mit Android 4.4.2 auf meinem Gerät.
Die TWRP 2.8.1.0 habe ich zum Download gefunden.
Welche Gaps nehme ich denn am besten? Hast du evtl. einen Link zu den Gaps die funktionieren?
Benötige ich auch die Light-AOSP-Ariesve STABLE - Build 21.10.2018 oder reicht SlimRoms-Ariesve STABLE - Build 16.06.2018
Hab ich sonst noch etwas vergessen?
Vielen Dank schonmal vorab für die Hilfe
Nein, das sind zwei verschiedene Betriebssysteme. Kannst du also auswählen/testen was dir lieber ist. Gapps zu der SlimRom bietet der Entwickler auf einer der 22 Seiten irgendwo an. Sorry musste mal durchblättern. Bei der LightAOSP ist der Playstore schon integriert. Dort hakelt aber die Anrufannahme.
@MachineHead vielen Dank für Deine schnelle Antwort. Wie hast du denn deine Speicherkarte formatiert?
Im ext4 oder F2FS Format?
Wenn die Anrufannahme hakelt dann doch lieber die SlimRom.
Hatte glaube ich F2FS ausgewählt, aber laut CyanogenMod 12.1 Anleitung kann man wohl auch ext4 nehmen
@MachineHead Ok danke Dir nochmal hat alles funktioniert.
Sorry wenn ich noch eine Frage stelle. Ich kann ja die externe Speicherkarte bei android als internen Speicher verwenden allerdings wird diese dann formatiert. Das geht also bei der Rom nicht oder?
Sollte eigentlich funktionieren. Bei mir gings
