Flo08
Hallo alle zusammen, das ist der offizielle Thread über meine frisch gebraute Rom Dirty Unicorns für das Samsung Galaxy S Advance
Dirty Unicorns kommt mit der TWRP - RECOVERY!
Information: Falls du einen Status 7 ERROR beim Flashen bekommen solltest, kontrolliere nochmals, ob du bereits eine Android 4.4.2 Rom installiert hast!
Flo0008
GæxD
hastalafiesta
Team Website: TEAM P8
Den Download Link findest du etwas weiter unten im 1.Post
Team Canjica
J-Team
Dirt Team
@Tesla-MADAL93
@Alex Cruz
@Chirag_Galani
@iiD4x
@Rox
@hastalafiesta
@Bx16
@Force
@Sachinist
@herna
Danke an alle, die mich bis jetzt so unterstützt haben!
Zusätzliches:
Dirty Unicorns (DU) is a custom ROM originally based off AOKP, but now based from OmniROM. DU brings you a great mix of stability and customization. The idea to start a ROM like this was purely out of boredom, but later turned into a form of an addiction, a good one. We began to have fun while still doing things the right way. By doing so, we received high praise from not only our users but by fellow developers of other ROMs that enjoy seeing things done the right way. This ROM will always be free of charge without any strings attached or any of it's developers luring you into donating or any form of "pay to flash".
Credits und viele Danke gehen zu:
| OmniROM | AOKP | ChaOS | Paranoidandroid | SlimROMs | Preludedrew | Team Black Out | Official Testers / Translators |
Facebook Sync Hack
PDroid patches included
Immersive mode
Hot Reboot Option
Appbar (ribbons)
Customizable Quick Settings
Customizable power menu
Customizable lockscreen shortcuts
App Ops access in Settings
TRDS (built in theme in settings)
Statusbar Clock options
NavBar Options
Halo from Paranoidandroid
Halo size changer
Hardware key remap mod
Battery Bar / Circle batteries
Network speed indicators in statusbar
CF's SuperSU
Build.prop mods
Init.d Tweaks
Active Display (Moto X notifications)
ListView Animations
Custom System Animations
Custom BusyDialog
Advanced Low Battery Indicator options
ScreenShot QuickTrash
Color Changing PhaseBeam
Gesture Anywhere
Button Light Notification
Statusbar Color options
Hosts file manager (ad-free option)
OmniSwitch (multi-tasking tool)
Driving Mode
Lockscreen theme options
Lockscreen notifications / options
1. Downloade die Rom und die Gapps
3. Verschiebe deine Downloads zur SD Card
4. Reboot zur Recovery, mach einen Factory Reset, Wipe Chache und Wipe Dalvik (in Advanced)
5. Installiere die Rom und danach die GApps
6. Reboote das System
Fehler:
-WiFi startet manchmal nicht
-Art funktioniert nicht
Extras:
- Settings -> Performance and change the default governor to ABYSSPLUG. Check set on boot.
- Tap build number 7 times. Go to developer settings and switch runtime from Dalvik to ART -> boot lasts some minutes
Screenshots gefällig?
Hier findest du welche: Screenshots
Sources:
Device-Source of awesome TeamCanjica: here
DirtyUnicorns Rom Sources: here
2014 Feb 21 14:00 - Build1: Erste Version
Download DirtyUnicorns-Rom: here
Download 4.4.2 GApps: here
Nach dem ersten Reboot gehe bitte in die Einstellungen -> Entwickleroptionen und deaktiviere USB Debugging!
Warum?
Falls du es nicht tust, könnten Fehler bei der Wiedergabe von Musiktiteln oder Videos uvm. auftreten!
