[UPDATED!!] [ROM/THEMES][AOSP/AOKP][4.0.4][29-04-12] M3dD0g´s LiquidSmooth V1
  • 25 Antworten
meier2009
Dauer-User
567
LiquidSmooth for SGN
Original Thread:
★★★ [ROM/THEMES][AOSP/AOKP][4.0.4][29-04-12] M3dD0g´s LiquidSmooth V1 ★★★ - xda-developers
UPDATE:
Download LiquidSmooth V3
Goo.im Downloads - Downloading LiquidSmooth_V3.zip
Installation LiquidSmooth V3
This is the safest way to flash LiquidSmooth to avoid your device from super brick.
You can be on any rom simple follow the installation guide...
1. Go to CWM and flash Abyss Kernel 4.2 (safe Kernel)
2. Under advanced Reboot Recovery
3. In Abyss 4.2 Recovery wipe data then wipe cache and dalvik
4. Install LiquidSmooth V3
5. Reboot Phone
You have installed LiquidSmooth ?
Go to Settings - Liquid Control - Propmodder
Check "Optimize TCP Stack"
Check "3G Speed Hack"
Check " GPU Acceleration"
Reboot your Phone and enjoy the Smoothness
Not working/Bugs
1. S-Pen Button
2. FM Radio
3. Theme Chooser
Changelog LiquidSmooth V3
Added Francos r6 Kernel THX
New Themed MMS.apk
Specifiy load offset for ramdisk
Settings: Fix data toggle
Added Liquid Launcher with alot optimizations and tweaks
Added Lockscreen weather and reset manual sync timeout
Framework more Themed
Settings completely rewritten
Volume FC fixed
Brightness FC fixed
Settings <> LiquidControls Migration
True Bootanimation Disable
BootAnimation preload into memory when used
Cleanup Calendar code and make room for new patchset
PhoneStatusBar: fix calling the incorrect path for calendar
Clean up values: surface flinger / contact
GPS Linaro optimizations / tweaks / fix
New Keyboard
Fix Locksreen Wallpaper FC
Telephony: Fix SmsManager
OMAP_ENHANCEMENT code from omapzoom.org (MERGED)
Remove message notification while in conversation
Removal of redundant settings and duplicates
Update codebase to 4.0.4_r2.1 aka IMM76L
Changed default null iconset for liquidsmooth
Bluetooth pairing fixes
DynamicChangelog optimized
Libstagefright: LPAPlayer: Fix choppy playback on BT
(Weather) Sync on n/w connection, Fix authorship / liscensing info on util classes
Linaro toolchain implementation / optimizations / etc...
UPDATE END:
Rom Features
Extremely responsive, slim, resource friendly UI
Backup/Restore Liquid Control configurations so you can reflash and retain your personal UI/ROM customizations (note this does not apply to any of the settings under the goodies section)
Liquid Control, allows for manipulation, customization, and optimization of nearly every area of this ROM.
Full screen mode (upper left of power menu birdie!)
More Incremental Navbar Heights to tweak the size just to your liking!
Now Includes 5 Lockscreen options
Customizable Navbar background color, button glow speed, colorkeys.
Center clock mod/customizable Color
Customizable battery icons
PropModder, a new convient way to edit your build.prop with the flick of a finger!
Quad/Octo Lockscreen with native/(now customizable) ICS icons
Overclocking/Undervolting Perfromance Utility
Gamma/Color Control
And much much more!
Installation
Du bist auf 2.3.6?
1. Install Mobile Odin
2. Flash REPACK_LP1 CF
3. Lass die Rom Booten
4. Reboot ins CWM und flash LiquidSmooth
5. Wipe Data, Wipe Dalvik/Cache
Bist du schon auf ICS? (LiquidSmooth, imilka, neobuddy89...)
1. Reboot ins CWM und flash LiquidSmooth
2. Wipe Data, Wipe Dalvik/Cache
Hast du schon LiquidSmooth ?
Geh zu Einstellungen - Liquid Control - Propmodder
Reboote das Note und geniesse die Smoothness
Bugs
1. S-Pen Button
2. FM Radio
Changelog LiquidSmooth V1
WE REACHED A STABLE BUILD !!!
Lockscreen flickering issues fixed
Small Framework changes
New Wallpaper
CRT-OFF Effect fixed (enable/disable it in Liquid settings)
and other things i forgot...
Download LiquidSmooth V1
LiquidSmooth_V1.zip
Download LiquidSmooth Beta 2.1 only 99mb
LiquidSmooth_Beta2.1.zip
Download LiquidSmooth Beta 2 only 99mb
LiquidSmooth_Beta2.zip
Download LiquidSmooth Beta 1 only 100mb
LiquidSmooth_Beta1.zip
Download Extras
Faceunlock + small system changes (flash in CWM after Wipe Cache/Dalvik reboot)
LiquidSmooth_Faceunlock.zip
Multi Language Support for LiquidSmooth 2.1(flash in CWM after Wipe Cache/Dalvik reboot)
LiquidSmooth_Language_Pack.zip
For USB mass storage install this App (thx neobuddy89)
UMS1.0.apk
Install newest LP6 Modem with Mobile Odin
modem.bin
Themes und other Stuff:
Themes For LiquidSmooth
(Updated 29.04.12)
......:::: InvertuS RevolutioN for Liquid V1 ::::......
What is done:
This things are all heavy modified and blacked out :)
- Framework-res
- SystemUI
- Softkeys modded
- New Icons for Apps/System
- Newest Apex Launcher added and Themed
- Browser
- Calender
- Contacts
- Calculator
- GMail
- New Battery Icons added
- SMS/MMS
- Play Market
- Phone with T9 works on both modes tablet and phone
- YouTube
Buglist:
In Tablet mode some settings are not themed
Installation:
Press THANKS button or Donate when you like.
Simple flash the .zip file in CWM over stock Rom, after install, wipe cache/dalvik. If you want stock look simple flash stock rom over and wipe dalvik/cache.
Thanks goes to...
JayR_Themer
travp624
gsxrdon
Nitroz
Download Invertus Revolution for Liquid V1
InvertuS_RevolutioN_V1.zip
......:::: Bl00dy SandwitcH for Liquid V1::::......
Reaktionen: reSor, watcherlein und Sliderxxl
ovaj patriotizam je vrlo dosadan
Dies hier ist ein Forum über Android Handys nicht über patriotismus!
Ps: das ist ein deutsches forum! :)
Pozdrav
Croatia1
Reaktionen: reSor
Hat die Rom schon wer?
Okay danke! Werde ich verlinken!
Pozdrav
Sieht Interessant aus, aber ich werde dieses Rom erst Flashen wenn 2 Punkte die mich stören erledigt sind :)
1. Native USB, das muss gehen! Hab keine Lust/Zeit mich damit umzuschlagen, dieser Bug ist fast sowild wie ne Kamera / Sound / Display Bug :D
2. Die drei Softbuttons weg sind, da es nur unnötig Bildschirm Platz wegnimmt.
Aber natürlich handelt es sich hier nur um ein Beta Rom (Sind eigentlich alle ICS Roms für den SGN zurzeit), deswegen kann man auch nicht zuviel erwarten bzw. zu fest Kritisieren.
@T2X: ich glaube die bildschirmtasten kann man in den LiquidEinstellungen weg geben
Pozdrav
Croatia1
Hatte ich zwischenzeitlich laufen. Hatte für den Test von dieser und Stunner extra wieder ein FULL wipe durchgeführt. LiquidSmooth empfand ich quasi als Stunner "small", waren funktional nicht so große Unterschiede. Allerdings hatte bei Liquid Probleme mit Root - Titanium maulte über fehlendes Root - konnte ich auf die schnell auch nicht fixen. Reflash usw. hatte nichts geändert. Da ich eher den integrativen Ansatz der Einstellungen von cm9 mag, hatte ich wieder imilka cm9 v3 geflashed und Root war wieder komplett!
Seit dem "Stopp" von imilka's cm9 habe seit gestern CyanoFree am laufen - hoffe das wird noch länger gepflegt.
Zu 2.: Wenn ich mich recht erinnere, konnte man die Softbuttons abschalten. Einfach in Power Menu und dann das linke obere Icon deaktivieren.
Zu ICS Beta: imilka's cm9 war bis gestern seit dem ersten Release mein Standard ROM - für meinen täglichen Einsatz OHNE Einschränkung oder FCs. Seit gestern CyanoFree am Laufen - das muss ich noch beweisen. ;)
Aber wie immer: your mileage may vary ...
Auch ich hatte sie am laufen, da fehlt leider noch zu viel.
Ich kann im Moment nur davon abraten!
Bam ist mobil!
Reaktionen: Reddy
Dem gibts nicht viel hinzuzufügen,
Noch nix für den täglichen Gebrauch
Reaktionen: Bam
LiquidSmooth V1 verfügbar!
Stable Rom und ein paar Bugfixes!
Pozdrav
Croatia1
Sollte aber gesagt werden das es nur auf Englisch ist.
Wird nach Rücksprache wahrscheinlich keine deutsche Version kommen da der Dev die Rom möglichst schlank halten will.
Reaktionen: Condro und manupot
Schade das hier nicht mehr aktualisiert wurde!
2.1 ist nicht mehr Beta sondern Stable! Nun das Update auf die 2.2!!!
★★★ LiquidSmooth for SGN ★★★
Rom Features
Gamma/Color Control
And much much more!
Screenshots
Credits and thanks
TEAM LIQUID
Liquid0624
Jbird
n0coast
Francisco Franco
JRThemer
JakeBites
Roman
CyanogenMod
neobuddy89
and Me
Installation LiquidSmooth V2.2
4. Install LiquidSmooth V2.2
5. Reboot Phone
Not working/Bugs
1. S-Pen Button
2. FM Radio
3. Backup/Restore under LiquidControl
Download LiquidSmooth V2.2 and don´t forget to PRESS THANKS BUTTON
Goo.im Downloads - Downloading LiquidSmooth_V2.2.zip
Download LiquidSmooth V2.1
Goo.im Downloads - Downloading LiquidSmooth_V2.1.zip
Reaktionen: Reddy und Quasico
Jetzt mit neuen DEV
Bitte keine Mirrors erstellen da ich mit dem DEV gesprochen habe und er keine Fremdmirrors für den Moment erlaubt da er gerne eine Übersicht der Zugriffe haben will.
Habe die Rom selber noch nicht probiert werde es aber morgen nachholen.
@croatia1
Wäre toll wenn du die Startseite updaten könntest.
[ROM]-[THEME] <<< LiquidSmooth V 2.3 >>>[16-06-12]<<<Updated by Firasusman>>>
Hi every one...
First Of All ...THANKS to m3dD0g The original ROM developer ,
I fixed the previous known issues, and customized the ROM with other features....
Changelog v2.3:
1- added franco r6 kernel
2- fixed market incompatibility
3- fixed Call waiting issue ..now you can switch B/W two calls and hear the other caller
4- added latest modem.bin
5- added titanium backup
6- added NOVA launcher with unread count plugin - You have to purchase and install Prime version (you can merge two widgets together in home screen Now)
7- added SGSIII sound effect and touch screen effect
8- added SGSIII dandelion live wallpaper which give the LiquidSmooth real look of liquid
9- other useful Stuffs to access all market applications ….
10- FC's in Setting/Volume, brightness have been fixed.
11- Lock Screen Style Function Now implemented in Setting/Liquid Control
12- Tablet Mode settings modified and working now.
13- Added S.VOICE from SGSIII
14- Framework modified.
15- SystemUI modified.
16- Theme chooser feature is still being worked...
Installation instructions …
This is No Wipe ROM ...
If you are in V2.2 :
Just go to recovery mode and install...
FOR CLEAN INSTALLATION :
do exactly steps below :
SAFE METHOD...
1- download AbyssNote kernel 4.2, ROM, Theme to internal SdCard
2- reboot to recovery mode and install AbyssNote V4.2 original touch
3- don't leave recovery , Go back to advanced then reboot recovery
NOW THIS IS TOUCH SCREEN ONLY (buttons will not work)
4- wipe data/factory reset…yes--delete all user data
5- wipe cache partition…yes--wipe cache
6- go to advanced and wipe dalvik Cache…yes--wipe dalvik cache
7- Go back
( optional )
8- go mount and storage
9- format /cache…yes--format
10- format /system…yes--format
11- format /data…yes--format
12- Go back
now install LiquidSmooth_V2.3
Reboot System
Links /
LiquidSmooth_ V2.3
http://www.crocko.com/0505C995A8AA4A...mooth_V2.3.zip
Revolution_Theme_V_2.3
http://www.crocko.com/8CD1293F52CD4E...heme_V_2.3.zip
Weather IconsSet
extract and put folder in internal SdCard..
http://www.crocko.com/18E2161F4E0B4D...F/IconsSet.zip
AbyssNote Kernel V4.2
AbyssNotekernel42CWTouchOriginalLogo.zip
PRESS THANKS BUTTON
Donation will be appreciated to m3dD0g
https://www.paypal.com/cgi-bin/websc...=6CUSGYMQ4WTSS
Reaktionen: Reddy
croatia1
ist zu der S3 gewechselt. Ich weis nicht wie oft und ob er hier reinschaut. Frank sollte diesen Thread jemandem übertragen, damit es up 2 date bleibt!
Gruss
Reaktionen: Reddy
versuch, so wie´s meine Zeit erlaubt, in der Zusammenfassung dann zumindest denn Aktuellsten UnterThread zu verlinken, falls ich´s, wie hier grad, bemerkt :D und der 1.Thread nit aktuallisiert wird!
Reaktionen: Reddy
ist die ROM eigentlich Multilanguage?
grüße von
mr.juziu
bauner
bauner
bauner
bauner
Talinsei
j1gga84
sMiRgL
sMiRgL
