[UPDATED!!] [ROM/THEMES][AOSP/AOKP][4.0.4][29-04-12] M3dD0g´s LiquidSmooth V1
  • 25 Antworten
Moin moin ein update...
[ROM]-[THEME] <<< LiquidSmooth V 2.4 >>>[20-06-12]<<<Updated by Firasusman>>>
Hi every one...
First Of All ...THANKS to m3dD0g The original ROM developer ,
I fixed the previous known issues, and customized the ROM with other features....
Changelog v2.4
1- removed franco r6 kernel, added XXLQ3
2- Frame work modified Thanks to MrDSL
3- systemUI modified.
4- added script to save battery Life ..
5- Black googlePlay Store..
6- Black MMs
7- all other things in V2.3..
instruction for Installation of V2.4
for liquidSmooth V2.3 User..
Reboot to Recovery mode,
Flash [SCRIPT] jBroid Kernel Cleaning :
http://forum.xda-developers.com/atta...3&d=1328015539
install V2.4 ,Reboot...
Coming from Other ROM
Clean install of V2.3 Then Follow step above..
Quelle:
[ROM]-[THEME] <<< LiquidSmooth V 2.4 >>>[20-06-12]<<<Updated by Firasusman>>> - xda-developers
P.S.
Jemand sollte diesen Thread übernehmen, weil croatia1 weg ist!
Reaktionen: Reddy
Update....schade das die erste Seite nicht upgedated wird!
@Frank bitte Thread an einen freiwilligen übertragen!
Installation LiquidSmooth V3
This is the safest way to flash LiquidSmooth to avoid your device from super brick.
You can be on any rom simple follow the installation guide...
1. Go to CWM and flash Abyss Kernel 4.2 (safe Kernel)
2. Under advanced Reboot Recovery
3. In Abyss 4.2 Recovery wipe data then wipe cache and dalvik
4. Install LiquidSmooth V3
5. Reboot Phone
You have installed LiquidSmooth ?
Go to Settings - Liquid Control - Propmodder
Check "Optimize TCP Stack"
Check "3G Speed Hack"
Check " GPU Acceleration"
Reboot your Phone and enjoy the Smoothness
Not working/Bugs
1. S-Pen Button
2. FM Radio
3. Theme Chooser
Changelog LiquidSmooth V3
Added Francos r6 Kernel THX
New Themed MMS.apk
Specifiy load offset for ramdisk
Settings: Fix data toggle
Added Liquid Launcher with alot optimizations and tweaks
Added Lockscreen weather and reset manual sync timeout
Framework more Themed
Settings completely rewritten
Volume FC fixed
Brightness FC fixed
Settings <> LiquidControls Migration
True Bootanimation Disable
BootAnimation preload into memory when used
Cleanup Calendar code and make room for new patchset
PhoneStatusBar: fix calling the incorrect path for calendar
Clean up values: surface flinger / contact
GPS Linaro optimizations / tweaks / fix
New Keyboard
Fix Locksreen Wallpaper FC
Telephony: Fix SmsManager
OMAP_ENHANCEMENT code from omapzoom.org (MERGED)
Remove message notification while in conversation
Removal of redundant settings and duplicates
Update codebase to 4.0.4_r2.1 aka IMM76L
Changed default null iconset for liquidsmooth
Bluetooth pairing fixes
DynamicChangelog optimized
Libstagefright: LPAPlayer: Fix choppy playback on BT
(Weather) Sync on n/w connection, Fix authorship / liscensing info on util classes
Linaro toolchain implementation / optimizations / etc...
:smile: Schmeiss rüber
So, der erste Beitrag gehört dir.
bauner
bauner
bauner
bauner
Talinsei
j1gga84
sMiRgL
sMiRgL
