Ultimate N7000 XXLSA JellyBean 4.1.2 v5
  • 312 Antworten
goffdel
goffdel
Stamm-User
423
Hallo
warum berichtet niemand von dieser hervorragenden Rom ??
Ultimate Rom v 5 / von "Joosh 3" by XDA
OTA Updates v5: [UPDATED 28/11/2012]
  • Added flashable MOD Script Tweaks to increase performance and battery life
  • Added new PhilZ 3.71 kernel on Kernels Section
  • Added Fix for Mass Storage to MTP method USB connection
  • Added Screenshot S Pen Fix to avoid crash while taking screenshots with S Pen
  • Added Multiwindow Hack and CRT Fix All in One
  • Added Lockscreen tooltip Toggle OFF Fix
  • Added fixed SystemUI Cyan on Themes Section
  • Added Stock SystemUI to revert it to stock look
  • Added new 3.65 PhilZ kernel on Kernels Section
OTA Updates v5: [UPDATED 26/11/2012]
New Changelog v5: [UPDATED 23/11/2012]
  • ROM Based on NEW leaked XXLSA Firmware
  • NEW Philz Safe Kernel 3.6.1 for XXLSA and New CWM Touch 6.0.1.9
  • NEW Modem XXLSA
  • Updates Over The Air - OTA UpdateMe added on Settings
  • Jelly Bean 4.1.2
  • SuperSU Added
  • Fully Rooted
  • Fully Zipaligned
  • Fully Deodexed
  • Added some more Build.prop tweaks for better optimization, battery life, 3G signal and network, camera, media and more...
  • Fixed CRT OFF fully working on new services.jar for XXLSA
  • Fixed 4 Way Reboot Options for new XXLSA (just long press power button and decide what you want to do)
  • SystemUI Soft Themed
  • Added SmartRotation in Settings
  • Fully working Lockscreen Shortcuts
  • Notification Panel into Settings with possibility to change Toggles order
  • Call Recording Fix added
  • Multiwindow Hack is available for unlimited apps
  • Popup Browser
  • SNote is finally working also with productivity tools
  • Airview general and in gallery fixed
  • Added S-Voice
  • Added new Android 4.2 keyboard
  • Added GMail 4.2
  • Added new Android 4.2 Camera Photosphere with new 4.2 Gallery
  • Added GL to SD to move huge apps or games to external SD
  • Added Solid Browser as file manager
  • Added CPUSpy
  • Some init.d optimizations included
  • and more!
Original Thread auf XDA von Joosh3 :
[ROM][4.1.2 JB]Ultimate N7000 XXLSA JellyBean 4.1.2 v5 | OTA Available | 25/11/2012 - xda-devel
Screenshots Here!
Mirror 1 Ultimate N7000 XXLSA JellyBean 4.1.2 v5 - Sourceforge
Mirror 2 Ultimate N7000 XXLSA JellyBean 4.1.2 v5 - Thanks to Bangsti for Mirror
Mirror 3 Ultimate N7000 XXLSA JellyBean 4.1.2 v5 - Thanks to Bangsti for Mirror
Flashanleitung:
Zip auf Ihrer SD / EXT-Karte
Starten Sie in CWM im Recovery Menue
Seien Sie sicher, dass Sie einen SAFE KERNELhaben, dann können Sie flashen
Fullwipe/ data / factory reset / Cache und Dalvik
Flashen der ROM
Warten Sie einige Minuten, bis das Telefon bootet!
alles drin und läuft absolut sauber,sehr smooth,einfach great !!!
mir stellt sich die Frage was soll da noch vebessert werden, es ist einfach alles darin enthalten was das Herz begehrt ,Airview funktioniert bei Bildern als auch bei Videos incl. Timeline im VRecorder,Multiwindow mit Hack ,Kontakte 3sek.dauer behoben schnell da, usw.usw..........
Die Rom hat sich bei mir ohne Probleme installieren lassen,einzigst bei der Herstellung mit Titanium BackUp
Anwendungungen & System kommend von XXLSA Stock konnte ich Einstellungen/Anzeige/Benachrichtigungsfeld/ nicht verwenden da sich die Einstellungen aufgehangen haben !!
von da her empfehle ich Herstellung mit TB nur Anwendungen mit deren Daten :glare:
Akku macht sich mittlerweile, nach drei Tagen mit regem Gebrauch telefonieren/Internet/E-Mail/ 8 STD. Bluetooh zum Headset nach 16 Stunden 25% Verbrauch
Das flashen geschieht auf eigene Verantwortung !!! Ich übernehme keine Haftung für eventuelle Schäden !!!
Ihr solltet wissen was Ihr tut und Euch gut informieren bevor Ihr es tut ! Hier im Forum lassen sich Alle Informationen finden die Ihr dazu braucht , nur guckeee müsst da halt selber :scared: !!
falls die Info`s hier im Thread nicht reichen.
sollte ich überlesen haben das es schon nen Thread gibt ,sorry !! einfach meinen löschen
LG.G.
New Changelog v5.1: [UPDATED 03/12/2012]
  • Fully ReBuild from XXLSC DUMP
  • ROM Based on NEW leaked XXLSC Firmware
  • NEW Philz Safe Kernel 3.73 for XXLSC and New CWM Touch 6.0.1.9 with exFAT Support
  • NEW Modem XXLSC
  • Updates Over The Air – OTA UpdateMe added on Settings
  • Jelly Bean 4.1.2
  • SuperSU Added
  • Fully Rooted
  • Fully Zipaligned
  • Fully Deodexed
  • Deleted some useless apps
  • Added and fixed some more Build.prop tweaks for better optimization, battery life, 3G signal and network, camera, media and more…
  • Added some more init.d optimizations
  • Switched to MTP instead of Mass Storage, you can also use Mass Storage
  • Fixed CRT OFF and fully working on XXLSC, now the screen will not turn on after a couple seconds you turned off (was already present on LSA)
  • Ultimate 4 Way Reboot Options for XXLSC (just long press power button and decide what you want to do)
  • SystemUI Soft Themed with semi transparent notification drawer background
  • Added Ink Effect Mod on Lockscreen
  • Popup Browser
  • Airview Fix Available
  • Airview in Gallery Fixed
  • Added S-Voice
  • Added GMail 4.2
  • Added CPUSpy
  • …and more to come!
Screenshots Here!
http://www.youtube.com/watch?v=n45wQVrGfOc&feature=plcp
Download Link v5.1:
Mirror 1 Ultimate N7000 XXLSC JellyBean 4.1.2 v5.1 - Sourceforge
hier ein Link von "Clue84" gespendet :
Ultimate_N7000_LSC_JB_4.1.2…zip (693,08 MB) - uploaded.to
MD5SUM: 92939c3a53895e1672fa11299361e90d
Die Galerie & Photo Sphere Cam 4.2 lassen sich per OTA Update unter "Einstellungen/Update Me Ota/Application nachinstallieren.......
Anleitung zum Flashen:
Nandroid Backup bevor Ihr Flasht ist empfehlenswert!
Lade *. Zip auf Ihrer SD / EXT-Karte
Starten Sie in CWM
Seien Sie sicher, dass Sie auf SAFE KERNEL, dann können Sie wipen
Full wipe/ data / factory reset / Cache und Dalvik
Format / data / und / preload
Flashen des ROM
Warten Sie einige Minuten, bis das Telefon boot!
16.12.12
OTA Updates v5.1: [UPDATED 16/12/2012]
  • Scrollable Wallpaper Mod on Homescreen for Ultimate LSC v5.1
  • Default SecLauncher without scrollable wallpaper
  • New PhilZ 3.75 Kernel for XXLSC firmware with CWM 6.0.1.9 with PhilZ Touch 3.63 based recovery and exFat support
  • SecPhone with No Ascending Ringtone on Fix and Mods Section (previously had already Call Recording button)
  • Stock Green SystemUI on Themes Section
  • Awesome Beat v3 on Fix and Mods Section (read description on UpdateMe)
  • Multiwindow without trasparency on Fix and Mods Section (read description on UpdateMe)
Reaktionen: Scum, ixi, droidopa und 14 andere
Offensichtlich nicht.
Könntest du Thread-Titel und ersten Beitrag noch den üblichen Anforderungen für Custom ROM Threads anpassen? Also die entsprechenden Prefixes in den Titel, deutsche Flashanleitung in den ersten Beitrag, Downloadlinks, Changelog, ..., halt alles, was so benötigt wird.
Reaktionen: perog, goffdel, Reddy und eine weitere Person
ich hab das zwar in vollem Umfang noch nie gemacht , versuche es mal !!!
wenn was nicht so sein sollte wie gewünscht , bin für alle Hilfe dankbar !!
etwaiige Übersetzungen basieren zum Teil auf Google Übersetzung und meinem wissen also habt Nachsicht :):rolleyes2:
LG.G.
Reaktionen: MichelFell
@goffdel
Du darfst auch gerne meine Mirrors verlinken.
Danke das du den Thread machst. Joosh ist ein prima Kerl und das Rom ist wircklich super.:thumbup:
*** Send from my Team Union Rom ***
Reaktionen: goffdel, Reddy, Berlino und eine weitere Person
Hast Du evtl. ein paar Screenshots von der Rom?
Danke und Gruss michel
Danke lieber Fred :D
Hat es denn schon jemand drauf? Klingt auf jeden Fall sehr interessant. Werd mich mal dran machen an das Rom.
also "Ultimate" setzt meine Erwatung hoch.
Ich hatte alle Versionen davor drauf und die liefen sehr gut!
Also eine Empfehlung wert!
Habe aber die lsa noch nicht getestet!
Grüße
Reaktionen: Reddy, Berlino, Bobsbobbys und 2 andere
Mutige vor!! Klingt wirklich gut :)
Laufen tut sie gut durfte ja schon vorher testen. Wichtig ist das richtige flashen ansonsten kann es die selben Probleme geben wie bei den anderen lsa leaks.
*** Send from my Nexus 7 ***
Reaktionen: Berlino und Reddy
Hab sie drauf. Bin von der JellyBam mit Thor 0.28 rüber. Keine Probleme. Sofortiger Start des Systems ohne zu zucken. Style ist eben Stock aber auch nicht die Welt wenn man es ändern möchte. Multiwindow funktioniert, stellt man die DPI auf 240 ein muss man sich mit den paar Apps die den 240 Mod mit machen begnügen (warum das so ist keine Ahnung). System funktioniert, soll heißen Phone, WLAN, BT und so weiter. Ja viel weiter bin ich noch nicht, habs grad versucht mit Titanium einzurichten aber es kam die leidige Ignorieren, beibehalten den ID. Hab sie ignoriert da ich Angst hatte, dass das System danach nicht wieder hochfährt. Meine Apps sind nun drauf, einige vom System habe ich entfernt. Alles in Allem ein gutes ROM, ALLTAGSTAUGLICH.
Reaktionen: skysat, Malzbier, Jrp Defy und 4 andere
The same mit Thor vorher auch keine Troubles.
Reaktionen: fred2346
@Fred
Haste mal den Link zum Thor Kernel? Und wie genau? Thor ,alles Wipen und dann den Philz 3.65 und das Rom oder direkt das Rom nach dem Thor?
Lg und danke im Voraus :thumbup:
Gesendet von meinem GT-N7000 mit Tapatalk
Hab auch über Thor geflasht und läuft gut.
Sam-Sung schrieb:
@Fred
Thor flashen, Reboot recovery, fullwipe, Habs ohne Format irgendwas gemacht und gleich vom thor das Rom flashen. Kernel ist da mit drin also keine sorgen machen
Sent from GNote
Was hat das mit der IP auf sich?
Was meinst du genau?
Sent from GNote
bauner
bauner
bauner
bauner
Talinsei
bauner
bauner
bauner
