[ROM] ROCKET ROM - v23 - XXLC1 [Update 29/03] - JKay Mod 13.6.1 - MIUI Style Theme!
  • 3.229 Antworten
eybee1970
eybee1970
Philosoph
5.255
Here is a great video of Rocket ROM:
Changelog ROCKET ROM-V23-XXLC1
  • based on official XXLC1 Firmware + Modem XXLB2
  • reworked scripting and tweaks --> again smoother scrolling
  • deodexed, zipaligned and rooted by me
  • added Multi-CSC
  • Franco Kernel v9 beta
  • Standard MIUI Theme
  • added JKay v13.6.1 (took framework-res.apk + SystemUI.apk from LB1)
  • lots of other tweaks + scripts for faster performance, smoother scrolling, better RAM handling, better 3rd party launcher perfromance
  • transparent Sammy Weather Widget
  • DigiClock in FlipClock Style (thx to Chrack)
  • automatic zipalign of all system apps on every reboot
  • working Play Store - no prob with purchasing apps here
  • SIP VoIP Support for Wifi + Data
  • Sony Bravia Mod for better graphic quality (might be nonsense but doesn't harm anything
  • build in Smoothness-Fix in framework.jar
  • build in 'No SMS on Call Log'
  • bootanimation 'Speeddaemons' reworked by meier2009
  • build in smooth spinners (thx to doctorcete)
  • combined nobnuts genius theming with a new 'MIUI style' DarkTheme (pics attached)
  • added nobnuts DarkThemed apps (Dialer, Music Player, SMemo, etc)
  • RTL Patch as flashable zip: http://ma-kistim.ch/Downloads/RTL_Patch_LC1.zip
  • HOTFIX for installing newest SamsungApps, Flashplayer and Google Maps 6.5.0 as flashable zip: http://forum.xda-developers.com/show...postcount=9243
  • HOTFIX for Banding-issue solved: http://forum.xda-developers.com/show...postcount=9282
IMPORTANT1: coming from Rocket ROM v22 just flash v23 over without wiping anything. If coming from any other ROM, FullWipe, first flash v22!!!, reboot, boot back in Recovery, flash v23 WITHOUT wiping anything, reboot --> everything will work!!!
IMPORTANT2: Freeze Wifi-Sharing
IMPORTANT3: There is no need to flash any previous updates on top - it's all included!
Download-link: https://docs.google.com/open?id=0B2dwI5Ev5PcadjEwZ1hkME9SY1dPZklTbG1Sa0pSdw
MD5-Hash: C1C9043991DC35A84F6A486B2B1BFB1C
Mirror: http://rocket.ph0enyx.de/rom/ROCKET-v23-LC1-eybee1970.zip
Changelog ROCKET ROM-V22-XXLA6
  • based on official XXLA6 Firmware + Modem XXLA4
  • added Multi-CSC
  • Abyss-Kernel 3.6
  • new Standard MIUI Theme with some bugfixes and small changes
  • added JKay v13.5.1
  • build in SMS-Mod from padlad (no limitation of contacts, no convert to MMS, ...)
  • CallRec-Mod can be downloaded as CWM flashable here: http://forum.xda-developers.com/show...postcount=7682
  • build in ICS transition animations in framework
  • working new Market added! No more Workaround needed! (works flawlessly, but you pobably need FullWipe to be able to purchase apps!!!)
Hotfixes:
240 dpi patch + Swype patch for v22 as promised, here are 2 patches for v22 as CWM flashable zips
  1. Theme-Fix for 240 dpi (you NOT need this on standard 320 dpi!): RocketROM_v22_MIU_Stock_240dpi.zip
  2. Enable Swype (gets lost by FullWipe only): Swype_enable.zip
IMPORTANT1: ROM is NoWipe, but I STRONGLY recommend to do a FullWipe before!! No bug reports without making FullWipe before!!! Reboot your device twice after flashing ROM!!!
Download-link: http://rocket.ph0enyx.de/rom/ROCKET-...-eybee1970.zip
MD5-Hash: 7D96D08928B1E35784529D263CEAE4F5
Mirror v22 (Rapidshare): https://rapidshare.com/files/3345086813/ROCKET-v22-LA6-eybee1970.zip
Changelog ROCKET ROM-V21-XXLA4
  • ultimate speedupdate (you will see...
  • added nobnuts DarkThemed apps (SMS-App, Dialer, Music Player, SMemo, etc)
  • JKay Alpha3 on board (don't ask for lidroids 14 toggle! It's history on GB!)
  • Abyss Kernel 3.5c
  • new bootanimation
  • rest is identical with v20
  • HOTFIX for Music Icons on Lockscreen (Standard MIUI Style only) as CWM flashable here: http://forum.xda-developers.com/attachment.php?attachmentid=880962&d=1328017083
IMPORTANT1: There will be bootloop after FullWipe! So if you do a FullWipe, flash v20 (or other LA4-ROM) afterwards, REBOOT, then flash v21 without wiping anything!
MD5-Hash: 6B0F6B8FE8C63626B3F475C24472DD6C
Mirror v20 (Direct Link): tbd
MD5 generated on server : tbd
This is how new Standard MIUI Style Theme looks like:
scaled.php
scaled.php
scaled.php
scaled.php
Changelog ROCKET ROM-V20-XXLA4
  • based on official XXLA4 Firmware + Modem XXLA4
  • added Multi-CSC
  • Android Version 2.3.6
  • Abyss-Kernel 3.3
  • Standard Theme as usual
  • added 1% battery steps
  • Added CRT-OFF
  • optimized framework-res.apk for additional speed and performance!
  • Added '14 Toggle Status Bar' (individual modifications can be made in App 'Quickpanelsettings'
    ) --> again forgot to add the App to ROM
    , find here as CWM flashable zip: http://forum.xda-developers.com/atta...1&d=1326960762
  • Some tweaks from pikachu01 (libs + bins from Android 4.0 and some others)
  • Widget Clock themed by criskelo
  • build in 'Lower Autobrightness Levels' (saves battery)
  • build in CallRec-Mod
  • for getting new Market after FullWipe, download any app with old market, afterwards flash new Market: http://leomar75.celogeek.com/Note/XX...roidMarket.zip (Credits go to Team CheckROM!)
  • RTL Patch can be found here: Multiupload.com - upload your files to multiple file hosting sites!
  • 'JKay Mod Alpha3' as an optional CWM flashable download here in StockLook : http://rocket.ph0enyx.de/rom/Rocket_..._StockLook.zip
    ==> above Jkay Mod is special adaption for Rocket ROM with follwowing changes
    • optimized framework (size 8,5 mb!) for ultimate speed and performance
    • added ICS transitions
    • added smoothspinners
    • lowered AutoBrightness Settings
MD5-Hash:
Mirror v20 (Direct Link): http://rocket.linuxgeeks.info/ROCKET...-eybee1970.zip
MD5 generated on server : http://rocket.linuxgeeks.info/ROCKET...-eybee1970.md5
Changelog ROCKET ROM-V19_1-XXLA4
  • build in JKay Mod alpha 2 (look here for all features working: http://forum.xda-developers.com/show....php?t=1439635)
  • StockLook Theme identical with JKay's (watch pics here: http://forum.xda-developers.com/show....php?t=1439635)
  • build in ICS transitions in framework
  • small fixes for speed and smoothness (I think it is perfect now for GB and no more improvements possible
  • deleted unlock messages for all languages
  • added AppWidget Picker (automatically sorting widgets using alternative launchers)
  • deleted lidroids 14 toggle (as it is useless with JKay
  • rest is identical to v19
IMPORTANT1: ROM is NoWipe, but I STRONGLY recommend to do a FullWipe before!! You have to install v19 after FullWipe first, then reboot your device and then install v19_1 with NO WIPE afterwards - if you install v19_1 directly after FullWipe you will get bootloop! No bug reports without making FullWipe before!!! Reboot your device twice after flashing ROM!!!
Download-link: Multiupload.com - upload your files to multiple file hosting sites!
MD5-Hash: F83EBD651ABC8D2D9D2214B593F259CD
Mirror, direct link v19_1: http://rocket.linuxgeeks.info/ROCKET...-eybee1970.zip
Md5 generated on server http://rocket.linuxgeeks.info/ROCKET...-eybee1970.md5
Mirror 2, direct link v19_1: http://rocket.ph0enyx.de/rom/ROCKET-v19_1-LA4-eybee1970.zip
Changelog ROCKET ROM-V19-XXLA4
  • added Multi-CSC
  • Abyss-Kernel 3.2
  • Themed as usual
  • new Rocket bootanimation :)
  • Added CRT-OFF
    ) --> forgot to add the App to ROM, find here as CWM flashable zip: https://www.android-hilfe.de/attachment.php?attachmentid=66004&stc=1&d=1326961910
  • build in transition animations in framework
  • deleted text to unlock from lockscreen - except for English language (special there
  • RTL Patch can be found here: (all credits go to taiseer999)
  • 'JKay Mod ported by criskelo' integrated
    • you can do your modification with app 'Deluxe Settings' in your App Drawer
    • the following JKay Mods are working:
      • Disable overscroll effect toggle
      • Support for setting Auto brightness delay. Select between values: No delay, 0.5 seconds, 1 second and 2 seconds.
      • Support for Auto brightness profiles
      • backup and restore all settings
      • Volume Lock (on/off toggle: a deluxe setting that will make sure notification volume is the same as ringer volume)
      • Added Home button haptic feedback on/off toggle
      • Added 'No lock screen' option as lock screen selection.
      • A toggle for CRT TV on effect (bypassing Animation setting!)
      • A toggle for CRT TV off effect (bypassing Animation setting!)
      • Support for Skipping music track/fm radio station using vol-up/down-keys when screen is off (as a toggle)
      • 15 seconds timeout on lockscreen... (as a toggle)
      • Confirm shutdown on/off toggle (asks for confirmation when using Reboot, Recovery, Download and Power off)
      • Support for disabling Home button double click
      • Supports customizable Power Options Dialog (all the toggles from SGS2 and can also be reordered)
Download-link: http://rocket.ph0enyx.de/rom/ROCKET-v19-LA4-eybee1970.zip
MD5-Hash: 07D76BA980B8D911408662DBCC9DFF9B
Changelog ROCKET ROM-V18-XXLA3
  • based on o XXLA3 Firmware + Modem XXLA3
  • added Multi-CSC
  • Abyss-Kernel 3.1
  • Themed as usual
  • Added CRT-OFF
  • build in smooth spinners (zns to doctorcete)
  • 'JKay Mod ported by criskelo' as an optional CWM flashable download here (don't flash directly after ROM! Reboot between!): Multiupload.com - upload your files to multiple file hosting sites!
MD5-Hash: C543F4CF99CE9F9632640DB6AE683DDE
Changelog ROCKET ROM-V17-XXLA1
  • based on official XXLA1 Firmware + Modem XXLA1
  • added Multi-CSC
  • Abyss-Kernel 3.0 with custom Bootlogo
  • Themed as usual with minor modifications
  • Added CRT-OFF
  • RTL Patch can be found here: Multiupload.com - upload your files to multiple file hosting sites! (all credits go to taiseer999)
MD5-Hash: 77FFC9B3644E62EEEDD0ECC488E663BF
Theme:
If you find the build in theme some kind of to 'colored' you can flash this one on v10 +v11 ONLY in Stock-Look with CWM-App or in recovery: Multiupload.com - upload your files to multiple file hosting sites!
SC20111206-161012
  • CWMManager.apk
  • QuickPanelSettings_flashable.zip
Reaktionen: Vrangr, TheMissingLink, simonwest und 57 andere
Das klingt ja auch schon mal interessant :)
Frage: Wo hast du die Tweaks etc. entnommen?
Reaktionen: eybee1970
Super! Wenn das heute abend noch kommt, werde ich es direkt noch mal testen. Das ist die ideale Basis, den neuen FM Kernel 1.3 morgen einem finalen Belastungstest auszusetzen (mit vielen neuen Features). ;)
Joar ich kenn's noch vom Milestone. Hoffe du lieferst hier auch gute Arbeit ab, aber da gehe ich einfach mal von aus *G*
Habe mein NOTE noch nicht gerootet, trau mich noch nicht^^. Werde es bei Zeiten aber nachholen.
Danke schonmal.
Die Screenshots sehen ja toll aus - genau nach meinen Wünschen !!!
Bitte denk an die ICS Bootanimation , kann man aber wohl auch nachladen ...
Merci , schon mal als Vorschuß.
Grüße Hannes
Bootanimation hab ich ne andere...die von ICS finde ich graphisch für unser Gerät ne Zumutung...musste selber nachinstallieren :)
gesammelt aus 1001er ROM (hauptsächlich S2) und xda
Download-Link jetzt im 1. Post verfügbar ;)
Viel Spass und reichliches feedback.
Der erste Lotus notes Nutzer den ich treffe und der auch noch Roms kocht - prima - nutze auch Lotus Notes und den Traveler 8.5.3.1
>Add Performance:
> Habe vergessen was mit einzubauen...enfach nach Flashen der ROM noch die Add_Performance.zip im Anhang runterladen und >über CWM flashen - bringt noch mal zusätzliche Smoothnes (libs + bins von Android 3.1)
Sollte man dazwischen 1mal booten um das Rom zu starten oder kann man alles im CWM hintereinander flashen
Grüße
dingolino
Grüße
dingolino
LOTUS RULES! :D ....und jetzt komm mir bitte keiner mit der Windoof-Keule :flapper:
dingolino schrieb:
>Add Performance:
Grüße
dingolino
einmal dazwischen booten schadet nicht...sicher ist sicher
Ist das ein Nachfolgemodell vom Lotus Elise?
Das ROM ist drauf und macht einen sehr guten Eindruck. ;) Die Bootanimation gefällt mir.
:flapper: Nein, von dem:
eybee1970 Rom geflasht mit CMW - gebootet - läuft :thumbup::thumbup::thumbup:
  • ICS Bootanimation :thumbup:
  • Transp. Wetter W.:thumbup:
  • Faby Graphic:thumbup:
  • mehr ist heute nicht mehr drin, um diese Zeit .....
Huhh - wo ist denn der CMW , wollte noch das Performance flashen ??
VIELEN HERZLICHEN DANK an ALLE Beteiligten
Grüße Hannes
Guten Morgen :)
Hatte noch nicht vor mein Note mit einer anderen ROM zu bestücken,
bevor BLN nicht an Bord ist,
aber hier siegt die Neugierde und werde dieses Rom hier testen :)
Bissel Vertrauensvorschuss MUSS sein ... auch für noch nicht Kenner ;-)
Bericht kommt .. wenn ich es geschafft habe.
@ eybee1970
Kannst Du mir ne Seite nennen, auf der beschrieben ist wie ich das DataToggle in die Statusbar integrieren kann. Habe Stock KK9 mit Root und möchte das gern behalten, nur halt mit dem Toggle.
Thx!
Hab das ROM soeben installiert und es gefällt mir sehr gut. Im Moment läuft alles flüssig!
Freu mich schon auf Fank´s Kernel ;-)
dingolino schrieb:
Würde das
Toggle 2G/3G
[APP] Toggle 2G/3G (Tasker/Locale plugin) [v0.0.17 / 11-18] now with injection! - xda-developers
mit dem Rom funtkionieren?
Mit sheep 1.2 läßt es sich nicht installieren, ich das signed script mal durchlaufen lassen aber dann doch davor zurückgeschreckt das dann nochmals darüber zu flashen.
Auf dem Sensation mit einem custome rom ging es ohne Probleme, da waren die notwendingen Zertifikate mit im Rom dabei.
Grüße
dingolino
keine Ahnung, ob das laufen würde....ich werde es nicht ausprobieren - vielleicht erbarmt sich wer anders?! :)
Ich hab gerade Probleme beim Installieren der ROM.
Hab mit "Ein Klick" gerootet ... und gerade versucht mit dem ROM Manager die Rom zu installieren. Wurde abgebrochen.
Ein CWM App hab ich nicht.
Ne Idee Jemand??
OK .. hab mir jetzt den CF Kernel geflasht ... und somit CWM.
Nun ist das ROM drauf :) und es sieht gut aus.
Die CWM App ist wieder weg ... ist das Absicht??
Danke erst mal an den Koch + Mit-Koch ;-)
Ich dachte Du könnest vielleicht mal wegen den Zertifikaten schauen, ob man das einfach im Rom dazufügen kann?
Grüße
dingolino
PS Wie gesagt auf meinem Sensation funktioniert es gut an man leicht zwischen 2 und 3G wählen bzw den automatischen Mode nutzen - spart z.T. Batterei (in Städten wo die 3G Abdeckung gut ist, bracuht man es nicht, aber auf dem Lande ...)
bauner
bauner
bauner
bauner
Talinsei
bauner
bauner
bauner
