croatia1
Stamm-User
- 170
Wanna be up to date with ParanoidAndroid team news?, click here, and visit our webpage!
Donations to CM Donation Tracker - CyanogenMod Forum , to molesarecoming http://forum.xda-developers.com/dona....php?u=4491046, to D4rKn3sSyS http://forum.xda-developers.com/dona....php?u=3484876
CHANGELOG:
v04
Gps fix, i hope it works fine (i just catched 14 sats)Long-pressing menu button shows recent app lists as beforeSome adjustmentsImprovements on OTA app, scheduled checkupsImprovements on Backup app, now it automatically launches on startup after you install a newer (or older) versionHybrid speedup, less lag, considerably faster list scrolling when pad/pal is in actionKeyboard scaling, an androids firstPAD/PAL bugfixes for apps that still crop images in lower dpisSettings revamp, speed preferences to switch between modes without having to set up anything, less clutterTrebuchet extras: 3x4 widgets, speed dial menu button, ... and some weird rocket button which im sure will be very useful to most of youPad.prop revamp, new preferences that should pretty much nail it. Im sorry but this trashes your old settings again, do not attempt to restore them unless you do it in a text editor
Installation:
Flasht nicht von einem Samsung Stock ICS oder ICS Roms die auf den ICS Samsung Kernel aufgebaut sind(Imilkas CM9, AOSP,...)
Install Rom: https://www.wuala.com/abangerl/Gala...DROID/paranoid_note_v02.zip/?key=9nzFt89pIrkz Dies ist die v0.2
http://d-h.st/lU1 Dies ist die v0.3
http://d-h.st/DtV Dies ist die v0.4
Neueste Hybrid Apps: http://4ndr01d.com/drcmda/common/
EIN RIESEN DANKE FÜR DIE LINKS: lady27 und a.bangerl!!!!!!
Wipe caches, factory reset ist ein muss wenn man von einem anderen Rom als CM9 kommt
Wenn die Statusbar nach dem 1. Reboot weg ist: lang drücken am Power button > Toggle Statusbar
Reboot and edit your Apps Dpi under Settings/Paranoid Settings/P.A.D. Hold the powerbutton to see the new fullscreen-togglebutton
Tipps:
Go to Settings, System, Font size, set it to NORMAL
Check "Auto Hide" in Settings, System, Statusbar, to finally get Fullscreen (or Hold power button, and press "Toggle StatusBar")
Launcher Settings: margins: SMALL
- Camera options looks cutted when "hide navbar" is enabled
- Keyboard popup layout looks a bit weird, this will be fixed soon
- Swap camera not working on tab mode, workaround is to press menu key, and then switch camera.
Pozdrav
Croatia1
