[ROM][JB][XXLSZ][TW][AROMA] - Galactus Phone UND Tablet 2in1 Rom v5.1 [21.02.13]
  • 106 Antworten
Berlino
Berlino
Enthusiast
6.462
Aufgrund fehlender Zeit, hat der Dev die Weiterentwicklung fürs erste eingestellt! http://forum.xda-developers.com/showpost.php?p=38938685&postcount=984
Hier ein TW Custom Rom auf XXLSZ-Basis von maskerwsk aus dem XDA-Forum:
[ROM][JB][XXLSZ][TW]Galactus Phone and Tablet ROM All in One213 dpi..v5.1 [21.02.13] - xda-developers
Galactus ROM PHONE and TABLET EDITION
One ROM Both Modes.
I got sick of looking after 2 ROMS so i merged then into one!
You choose Tablet or Phone!
Simply Flash the TABLETUI.zip for tablet mode (Including all Tablet Apps)
Or flash PHONEUI.zip for phone mode (Including all Phone Apps)
XXLSZ
V5.1
AROMA Installer
Using AROMA you can installer you have a complete custom install
Features:
Fully Rebuild from Official Release
Philz Kernel
Deodexed and zipaligned by Me
AIRVIEW working - Videos/Snote/Messages + Gallery (Mod by Me)
Lockscreen shortcuts
INK Effect with pen only (i added option to settings/display) + Awesome app from Mythtrandyr (not yet added)
5x6 App Draw
Build.Prop Tweaks
Mulitiview for all apps (added options in settings/display)
Smart Stay
Working S-Voice
Modified Framework
Custom Bootanimation
Modified Multi windows bar
CWM v3.60
Paper Artist
S voice - intergated into settings
Ported S-Voice from NOTE-2 (see screenshot)
Added AROMA Installer for a Custom Install
Additional settings in Settings>Display
Moved more Apps to Preload
XPOSED Framework (Intergrated into Settings/Display)
Ink Effect (Pen Only and Intergrated into Settings/Display)
4 Way Reboot
SMS log removed from call log
AOSP Lockscreen
Lockscreen Shortcuts
Smart Rotation
Multiwindow Control App (Intergrated into Settings/Display)
Google Music
Photo Editor
and More.................
Download - V5.1 - http://d-h.st/Eza
MD5 Sum: 555ad576c3ce39104bfeac484ba73af3
Download - TabletUI (flash this over 5.1 to enable Tablet Mode) - Dev-Host - TabletUI.zip - The Ultimate Free File Hosting / File Sharing Service
Download - PhoneUI (flash this over 5.1 to enable Phone Mode) - Dev-Host - PhoneUI.zip - The Ultimate Free File Hosting / File Sharing Service
Um 2 Instanzen desselben Programms in Multiwindows haben zu können, flasht bitte den Multi-Instance_and_180_Rotation.zip Mod: https://docs.google.com/folder/d/0B...edit?pli=1&docId=0BxzymQOcZo3sTXlBOTBNdDhzU1U
Um floating windows im Tablet Modus zum Laufen zu bekommen, navigiert in einem Dateimanager nach /system/etc/permissions und löscht dort die Datei com.sec.feature.multiwindow.phone.xml -> Reboot und es funktioniert!
Workaround für den FC in den Xposed-Settings bei Auswahl einer App:
Erst mal diese beiden Dateien aufs Note laden:http://forum.xda-developers.com/atta...9&d=1360570257 und http://forum.xda-developers.com/atta...0&d=1360570257
Deinstalliere in TB xposed installer und xposed settings, nicht neu starten, dann den heruntergeladenen xposed installer auf dem Note installieren und öffnen, dann auf installieren klicken, danach auf reboot klicken. Nach dem Reboot dann die xposed settings.apk installieren - FC behoben.
Einige Apps wurden entfernt (Samsung Bloatware), können aber über den Aroma-Installer ausgewählt werden:
Gmail
Email
All Samsung Sync Features
AllShare
Chat-on
Exchange
(Most of the Removed stuff can be downloaded if needed from app store or using AROMA Installer)
Hier dazu noch der passende PhilZ Kernel LSZ: http://unionrom.com/galaxyrom/System/Kernel/PhilZ-cwm6%20Root%20Kernel/07.03.2013%20-%20PhilZ-cwm6%20v4.87.6%20with%20CWM%206.0.2.8%20based%20recovery/PhilZ-cwm6-XXLSZ-OXA-4.87.6-signed.zip
Bug List:
Water Ripple Live wallpaper will crash on startup (if selected) but will restart and work fine
Android Keyboard FC
Some Apps have been SymLinked to Preload so be aware if flashing any Mods not created by me.
Installation:
Download Rom and save to SD Card/Phone
Ensure your on a safe Kernel
Reboot into Recovery
Wipe data/preload/cache/dalvic
Flash Rom
Wer v5 bereits oben hat, kann v5.1 ohne wipe drüber flashen. Man hat nach dem v5.1-Flash automatisch den Phone Modus - wer den Tablet Modus wünscht, flasht dann einfach die TabletUI hinterher.
Happy flashing und viel Spaß mit dem Rom. :scared::love::thumbup:
Screenshots
Reaktionen: hara74, sirturbo, fred2346 und 4 andere
Danke Andy
Coole Nummer, bin dabei.:D
Gruß und Groove michel
Reaktionen: Gelegenheitsrentner
Jo Michel, dann bügel dir das gute Stück mal rauf...es lohnt sich! :thumbup::D
Gruß, Andreas
Reaktionen: Jrp Defy und MichelFell
Mach ick doch glatt mein Freund, warte aber noch die v5 ab. Dann springe ick auf Deinen Zug auf und fahre mit bis zur Union-Station.;)
Reaktionen: Jrp Defy und Gelegenheitsrentner
Der Ink effect geht nicht. Wie nutze ich denn die 2 Updates oben in der description?
Sent from my GT-N7000 using Android-Hilfe.de App
Der Ink-Effekt geht derzeit nur für den SPen...die Updates flasht du nacheinander über CWM.
sirturbo schrieb:
Hmm, bei update2 wirft google-Docs bei mir einen Fehler?
Hatte ich auch, einfach immer wieder versuchen, irgendwann gehts.
Reaktionen: sirturbo und Berlino
Ist diese version nur auf Englisch oder Multilanguage.
Hmmm hmmm...
Ich hab den Effekt daß ein buntes X kommt und geht...
Aber irgendwie immer und immer wieder. Mal ist der Schirm länger schwarz, mal kürzer. Aber ich bin nicht sicher wie lange das gehen soll bis gebootet wird?
Ist das noch normal oder kann ich schon mal anfangen neu zu flashen?
Edit:
Habs jetzt mal unterbrochen. Wenn ich versuche zu booten hängt das Note entweder in der Samsung-Schrift oder beim bunten X.
Ins CWM komme ich nicht, das war bei meinem Gerät aber immer schon etwas schwierig (warum auch immer). Die Galactus-ROM installiert doch aber eine CWM in die ich eigentlich mit VolUp/Home/Power kommen müsste oder?
In den download komme ich - aber ich bin nicht so ganz scharf darauf den grossen Weg zu gehen über sicheres GB-ROM...
Edit2:
Niedlich^^ Jetzt komme ich nicht mal mehr in den download-Modus, obwohl es zwischendurch mal ging und ich seitdem nix mehr geflasht habe... Grml... Flashen ist doch immer wieder eine Wundertüte... jetzt ist erstmal basteln angesagt.
Edit3:
Ok, hat sich erledigt. Im x-ten Anlauf bin ich dann doch noch ins CWM gekommen, das Ganze noch mal von vorne und diesmal hat es wohl geklappt. Warum auch immer^^
(am Meisten ärgert mich daß mein Note immer würfelt ob ich in CMW/Download komme - normal geht das beim reboot ja direkt, aber wenn das System gerade nicht will mache ich ziemlich dicke Backen^^)
Schaut mich gerade "multilanguage" an:)
Reaktionen: blubenow und Berlino
Edit3:
Sammy scheint das Reboot-und-Hängenbleiben-Problem noch nicht in den Griff bekomen zu haben. Der Rom-Dev rät bei einem Hänger mit der 3er-Kombi ins Recovery zu booten (wenn es denn geht), dann unter advanced reboot Recovery und danach reboot system. Hatte bei mir aber auch nur zu nem Hänger geführt - habe dann einfach im CWM eybee's flashable bootloader geflasht und dann fluppte alles. Seitdem auch keine Probs mehr mit Hängenbleiben.
Reaktionen: sirturbo und MichelFell
Tu mal einer kuck;)
Also ich bin im xten Anlauf (wobei ich da mehr mein Gerät als das ROM in Verdacht habe) in das CWM gekommen das mit der ROM/PhilZ installiert wird.
Einfach noch mal gewipet, neu installiert. Gleich mit dem ersten updaten Hinterher (den reboot-Haken nach dem ROM rausgenommen).
Und dann alles der Reihe nach ohne Probleme.
Macht ja einen guten Eindruck - mit Project Butter ist auch ein TW mal richtig zu geniessen;) Das macht natürlich den "Markt" für echte Rom-Entwicklungen ala AOSP ziemlich eng auf dem Note? Finde ich gut daß Samsung das Note noch vernünftig mit Updates versorgt die dann verwurstet werden können. Auch wenn die Codebasis von CM und Co immer schon weiter ist. Mal schauen ob mir ggü der CM10.1/PA2.99 was fehlen wird.
sirturbo schrieb:
Tu mal einer kuck;)
Was macht ein Tw-Rom aus/interessant? Es sind halt die Sammy-Schmankerl, allen voran Multiwindow. Im Vergleich zu ICS läuft es schon viel geschmeidiger. CM hatte schon zu CM9-Zeiten ein eigenes Multiwindow aka Cornerstone in der Schublade, aber Google hatte da was dagegen...Sammy hat halt die "Erlaubnis" bekommen.
Bin soweit erst mal sehr zufrieden mit diesem Rom, Akkuverbrauch hat sich im Vergleich zu den Leaks deutlich vetbessert. Jetzt noch ein passender OC-Performance-Kernel und alles würde noch besser.
Was ein TW interessant macht? Die bessere Hardware-Unterstützung:)
Ich bin zB absoluter Fan von MHL und co. Note an den TV als Mediaplayer und Spielekonsole, externe Speicher anschliessen, Tastatur und Maus usw.
Einiges geht ja "auch so" zB GNote statt SNote für den Stift. (Hab gerade gestern Notizen in der Besprechung mit dem Stift erledigt)
Aber gerade die Unterstützung von externer Hardware schwankt bei Non-TWs doch immer zwischen "geht nicht richtig" und "geht gar nicht". leider...
So, die v5.1 ist raus! Jetzt gibt es das Rom als Phone UND Tablet Version in einem Rom. Genaueres entnehmt bitte bis auf weiteres dem XDA-Thread, bis ich die Startseite aktualisiert habe. Bin gerade unterwegs. ;)
Reaktionen: sirturbo, Jrp Defy, lady27 und eine weitere Person
Ich muss sagen, dass sich das ROM mehr als interessant anhört.
Ich habe zur Zeit noch das Ultimate-Rom v5.1 drauf; Hier gab es aber schon über zwei Monate kein Update mehr. Hier scheint es ja weiter zugehen.
Nun meine Frage (ganz stumpf... :unsure:): Macht der Wechsel Sinn? Was würdet Ihr ganz subjektiv sagen?
Die V5.1 selber ist noch im Upload und wird noch etwas dauern da masker keine so gutes Internet hat.
Die Phone UI und Tablet UI für die kommende V5.1 gibt es bereits.
War mal so frei und habe zwei Mirrors gemacht. Sobald die V5.1 kommt mache ich da auch Mirrors bzw Fredi wenn er wieder zuhause ist.
Download - TabletUI (flash this over 5.1 to enable Tablet Mode) - Mirror1 / Mirror2
Download - PhoneUI (flash this over 5.1 to enable Phone Mode) - Mirror1 / Mirror2
Reaktionen: Gelegenheitsrentner, Berlino und Basti3
Und noch eine Zweite hinterher:
Für die 5.1 muss ich erst die Galactus v5 flashen und dann die phoneUI.zip drüberbügeln, richtig?
@basti3
Du musst noch etwas Geduld haben da die 5.1 noch im Upload ist.
bauner
bauner
bauner
bauner
Talinsei
bauner
bauner
bauner
