CVH
Enthusiast
- 4.264
RECOMMENDED INSTALLATION PROCEDURE
Coming from another Custom ROM:
Wipe Data/Factory Reset (This does not affect your Internal/External storage)
Format /System (This does not affect your Internal/External storage)
Flash ROM
Flash Gapps
Wipe Cache
Wipe Dalvik Cache
Reboot
Coming from Stock Samsung ROM:
Root Phone - Get CWM Recovery
Flash ROM
Flash Gapps
Wipe Cache
Wipe Dalvik Cache
Reboot
Updating from previous version:
Flash ROM
Flash Gapps
Wipe Cache
Wipe Dalvik Cache
Reboot
DOWNLOADS
ROM
Goo.im Downloads - Downloading pac_n7000_toxicthunder.zip
GAPPS
Goo.im Downloads - Browsing gapps
NOTE:
As per request from the Paranoid Android Team, ParanoidPreferences.apk has been left out from the ROM as it is not fully open-source.
However, the relevant framework files for it are present in the ROM. I am sure you can get the missing apk for yourself
CHANGELOG
Provide haptic feedback on long pressing keys in lockscreen.
Default device volumes not initialised
Merge "core and telephony: Additional HSPAP support" into jellybean
Prevent Sym key from showing the IME picker
UMS support with any volume, not only primary
Stylus gestures features
AudioService: Don't adjust volume when vol-downing to vibrate or silent
Merge "PT-BR: Added missing translations" into jellybean
Framework: Fix Profiles Insecure lock screen not working
Remove duplicated and unneeded code
shorter debug out
Notification: add option to show connected wifi network
Suppress String resources build warnings
WeatherPanel: Add toast
SystemUI: Cog Circle Mod Battery
Lockscreen: Add Circles Lockscreen to AOKP
SystemUI:Widgets fix & Class Move
Lefty Mode for NavBar
SystemUI : Fix NPE on Rotate
NavRing: Long press actions.
TransportControl: Remove unnecessary check
Fix volume track skip control with 3rd party applications
QUELLE: http://forum.xda-developers.com/showthread.php?t=1999908
