[ROM][ICS][TOUCHWIZ LQ2] Assassin's v1.0 and Assassin's lite v1.0[17th June]
  • 9 Antworten
Cpt. Future
Gast
Hi there everyone, this is my first rom for galaxy note n-7000 inspired by KingDroid ICS NoteMania Edition with more tweaks.
i am going to upload two roms, one with all applications [Assassin's v1.0] and the other one the lite version of the rom[ Assassin's v1.0 lite]
Assassin's v1.0
-New official base LQ2 FOR N7000
-Kernel 3.0.15 Franco R5
-modem LPT
-Full root
-superuser
-busybox
-Deodexed
-Zipplaning
-Optimized 100%
-Stock Boot Animation
-Galaxy s3 boot sound
-NEW init.d Tweaks
-Misc Kernel Tweaks
-Battery tweaks
-Micro sd Speed Tweaks
-Governor Tweaks
-NEW Tweaks build.prop
-Fast charge
-Better Touch response
-Save Battery
-Other Misc Tweaks
-Digital clock and transparent blue
-Wheather widget transparent
-Native call-REC
-Self Cal automatic battery-
-Added host to eliminate 90% of advertising in apps and browser
-Added custom System_server
-Android-App_progress 4.04 (sgs3)
-Added android libsqlite.so 4.04 (sgs3)
-Added android libsqlite_jni.so 4.04 (sgs3)
-Added android libsystem_server.so 4.04 (sgs3)
-15 Toogles statusbar (thanks @criskelo)
and more..
Assassin's Lite v1.0
-Kernel 3.0.15 Franco R4
-modem LPT
-Full root
-superuser
-busybox
-Deodexed
-Zipplaning
-Optimized 100%
-Lots of apps removed
-NEW init.d Tweaks
-Misc Kernel Tweaks
-Battery tweaks
-Governor Tweaks
-Fast charge
-Save Battery
-Other Misc Tweaks
-Native call-REC
and more..
Known Bugs:
wallpaper gives a FC when changed from the list of stock ics wallpapers for galaxy note(where the first one is of a beach.)
S3 MOD UPDATE
flash the S3 mod if you like the launcher and want the other apps like weather widget live wallpapers melodies and sounds
Installation instructions for both the versions
NOTE:
Don't flash it via unsafe ics kernels as they are not safe to wipe
1. Charge your phone above 60%
2. you can flash this rom from any rom with franco kernel or speedmod kernel preinstalled
3. We perform all three wipes, ie. wipe cache, wipe dalvik cache (advanced) and wipe data/factory reset.
4. Flash the rom Assassin's, reboot and enjoy
Optional S3-[CreditsKingdroid]
Just flash it after flashing the rom.
Screenshots
CREDITS:
-All of the Kingdroid team for awesome roms
-Franco for the amazing kernels
-Criskelo
-XDA
PM me if i missed someone and i'll add to the credits
DOWNLOAD LINK
Assassin's v1.0-
https://docs.google.com/open?id=0B9w...lNOTkJQWi1QclE
Mirror-[thanks to bangsti]
http://www.partystoned.de/Android-Hi...27s%20v1.0.zip
Assassins Lite v1.0-
https://docs.google.com/open?id=0B9w...0p1cm00ZGdNZXc
http://www.partystoned.de/Android-Hi...ite%20v1.0.zip
Assassin's S3-
https://docs.google.com/open?id=0B9w...kNrTEp5NHQwRDg
Quelle:
XDA
Reaktionen: hara74, Reddy, CVH und eine weitere Person
Bei der normalen v1.0 gibt es anscheinend noch Probleme beim flashen.
Die Lite Version habe ich selber schon getestet und läuft absolut smooth und mit dem Goku Kernel geht sie ab wie ne Rakete.
Reaktionen: 149217
ui ui ui Fred,
schon wieder eine Rakete Ihr schiesst ja eine nach dem anderen ab!:thumbup:
Ich werde die Screenshots auf ein Minimum reduzieren geht ja gar nicht so gross wie eine Tapete:ohmy:
Gruss
Reaktionen: Reddy
Ich komme nicht mehr mit dem downloaden hinterher. Aber die zieh ich mir und schau sie mir an.
Viper, seit dem 17.06.2012 ist hier in der Abteilung Sylvester. Ein Feuerwerk der Rom-Pyrotechniker.
Ja jetzt tut sich was.
Wie gesagt die Lite Rom ist wirklich wie eine Rakete die normale macht anscheinend Probleme beim flashen konnte es aber nicht testen.
Reaktionen: 149217
Ist die Lite vom Speed her vergleichbar mit RR6 und dem Turbokernel?
Meiner Meinung her schon aber sie ist stark entschlackt und es fehlen einige Sachen ( siehe Changlog) und man sollte vorher wissen ob man es braucht.
Mit dem Goku Kernel zumindest auf meinen Note eine Rakete.
Reaktionen: lassiter34
Moin moin ihr flasholics, (off topic) aber wichtig!
Ich vermute das einige von uns da draussen nicht an das sichern des "EFS" Ordners gedacht haben. Ich hoffe es sind ganz ganz wenige! Daher gilt dieser Post jenen die nicht daran gedacht haben!
Was ist der "EFS" Ordner? Auszug aus den FAQ's
FAQ
EFS Backup:
EFS steht für "Encrypted File System" und beinhaltet gerätespezifische Informationen, z.B. Informationen zum ProductCode und die IMEI. Ein schreibender Zugriff auf EFS ist extrem gefährlich, da dabei oft was schief geht, vor allem, wenn unvorhergesehene Schreibzugriffe erfolgen. Unvorhergesehene Schreibzugriffe erfolgen immer dann, wenn sich der ProductCode ändert, weil eine unpassende CSC geflasht wurde. Und deshalb geht dabei so oft die IMEI verloren.
Um Unfällen beim Flashen vorzubeugen, ist es sinnvoll, vorm Flashen ein EFS Backup anzulegen:
Diesen Ordner kann man auf unterschiedliche Art und Weise sichern! Mit einem Programm am PC oder mit Root Explorer oder ähnlichem direkt auf dem Note.
Am PC unter anderem mit dem Tool EFS Pro (kostenlos, im Anhang)
oder mit Root Explorer... Anleitung siehe unten.
Das brauchen wir um den EFS Ordner zu sichern :
Root (Um Root zu bekommen kann man sich z.B. den cf-root flashen)
Einen Handy File Explorer wie z.B. in diesem Fall "Root Explorer".
Startet die App "Root Explorer".Dann sehen wir auch gleich den "EFS" Ordner.
Drückt nun auf "Mount R/W" um Rechte zu bekommen.Dann wechselt es wie im Bild zu "Mount R/O".
Lasst den Finger jetzt lange gedrückt auf dem Ordner "EFS".Es öffnet sich ein Kontext Menü wo wir nun "Copy" drücken wie auf dem Bild zu sehen.
Nun navigieren wir zum Ordner "SDCARD" und öffnen diesen.
Ich habe im Vorfeld einen Ordner in "SDCARD" erstellt mit dem Namen "Apps Sicherung Orginal".Diesen Ordner öffne ich jetzt auch.
(Ihr braucht aber keinen Ordner.Es reicht auch "SDCARD" zu öffnen und dann den "EFS" Ordner dort rein zu kopieren).
Nun befinde ich mich in dem Ordner "Apps Sicherung Orginal".Dort drücke ich jetzt Links unten auf den Button "Paste".Damit wird der EFS Ordner in den Ordner "Apps Sicherung Orginal" kopiert.
Quelle:
Hier gefunden
EFS_Pro_1.7.13_Release.zip
Hallo hier bitte auch schliessen. Keine Entwicklung mehr!
Gruss
bauner
bauner
bauner
bauner
Talinsei
bauner
bauner
bauner
