[ROM][ICS][1/6][PRE.AOKP.B35] ICS StuNNeR - 1.6.26 [ResuRRecteD & Re-StaBiLizeD]
  • 630 Antworten
Hallo Du willst die Unterschiede wissen? Hier sind Sie und das alles hast Du verpasst.
Changelog:
1.4.26.1:
_Corrected mount points in kernel: Camera pics saved on internal
_Minor fixes in kernel
_NTFS module for testing (may not work)
1.4.26:
_Fixed Bootloop issue (Removed EXT4 Tweaks for now)
_Fixed ICS Long Press Home Key in Phone Mode
_Mount Points reverted back to original
_Re-stabilized
_Updated Google Maps
1.4.25:
_Fixed root issues. Everyone should get proper root coming from any ROM.
_LP6 Rooted & Modded Kernel (on test; soon to be replaced with open source kernel)
_EXT4 Tweaks applied on second boot (long press power key if you get stuck)
_External SD card mount point is now /mnt/sdcard (following CM9 standards)
_Internal SD card mount point is now /mnt/emmc (following CM9 standards) Your titanium Backup location may need to be changed.
_Superuser app is back with Root Browser.
_X-plore removed. Can be installed from market though.
_GPS should be better. Don't expect to be perfect yet.
_Recording format set to "MP4".
_Updated Google apps and other apps.
_Fixed mobile data toggle not updating for serious
_Fixed navigation buttons for tablets
_Long press home options added to General Interface for phones that have hardware buttons
_Fixed icon transparency being applied to right-side buttons (BT, etc)
_Add BT MAP Profile
_Fixed font sizing in statusbar
_Fixed volume sliders not updating when volumes are linked
_Many fixes for ColorPicker in ROM Control
__gradient showing properly
__color picker should fit in all screens now
__show color preview before opening dialog (in-line)
_Fixed sound playing when volume zoom is enabled in camera
_last.fm AVRCP crash fixed
_Contact pictures now displaying properly in notifications when receiving new sms
_Bluetooth: Fixed memory leak and file handles leak
_Nav bar & tablet status bar FCs fixed
_Fixed some init.d scripts not running due to lack of bash
_Changing brightness by sliding on the top of the statusbar (if enabled) shouldn’t FC anymore
_ROM Control: Fixed scrolling cache not setting properly
_Weather will refresh whenever SystemUI starts instead of when the phone boots (so if it gets restarted, it should fetch weather again, it didn’t before) _Lockscrens: Added lockscreen wallpapers to pin & pattern unlock screens
_Settings: fixed link mute states always being checked
_Added bluetooth headset config
_Other fixes of AOKP build 33 which where not included.
1.4.19:
_Beta Testing Completed!
_Complete AOKP compiled (no separate patches from CM9)
_Added missing fonts
_Services.jar patched for OOM Tweaking
_DSP Manager removed
_Updated Apps: Google Maps, Xplore and Videos
_Camera: Pinch and Volume Zoom
_General UI: Customizable rotation delay is back!
_Bluetooth: AVRCP 1.3+ support
_Lockscreen/NavBar: Allow shortcuts to specify their own icons
_NavBar: Allow tablets to use “hide NavBar” feature
_NavBar: Custom NavBar is now available for tablets as well!
_NavBar: Customizable glow color (New Feature)
_Quiet Hours: Configure the hours your device should be quiet and/or still
_Statusbar: Added ability to WeatherPanel to start a custom app
_Statusbar: Added ability to hide signal bars
_Statusbar: Customizable font size
_Statusbar: Customizable icon transparency
_Added German translation for weather
_Fix CRT Off Animation
_Fix embedded flash on websites
_Fix compass
_Fix disabling Camera Sounds
_Fix NavBar showing up in landscape lockscreen
_Fix long-press resetting custom NavBar icons
_Fix incorrect bluetooth address on some devices
_Fix lockscreen events showing up 1 day before
_Fix quickunlock not allowing passwords longer than 8 chars
_Fix centered clock not showing the correct time
_Fix camera internal issues
_Other small fixes
Reaktionen: freebotaste
Ost schon viel aber wieso höre ich immer negatives über die rom
Negatives wirst Du immer und über jede ROM hören.
Wichtig ist, ob Du damit zufrieden bist.
Wenn Du (Daten- und funktions-) Sicherheit brauchst, dann kommt nur eine GB(Android 2.3. Irgendwas) ROM in Frage.
Wenn's den Spielbetrieb befriedigen soll und Du bereit bist, ein gewisses Risiko einzugehen, dann probiere ICS (Android 4.0.3 oder .4) aus.
Also: eine philosophische Frage..
Gute Nacht.
Bam ist mobil!
Reaktionen: FuzzyHead
Für mich ist diese ROM ideal. Ich gebe zu, ich brauchen mein Handy kaum produktiv, benutze keine speziellen Office-Anwendungen o.ä., dennoch bin ich voll und ganz zufrieden!
Hatte noch keine Bootloops, FC's, Blackscreens oder eine andere Beeinträchtigung in irgend einer Weise.
An der Stelle mal ein großes Danke an die Entwickler!
Bin wirklich schwer beeindruckt, wie ausgereift dieses ROM ist.
Nur weil wir es grade von den Unmengen an negativen Anmerkungen haben. :D
Alles in allem bin ich auch zufrieden. Einzig ein paar mehr Einstellungen zur Kamera würden mir zusagen. Und natürlich die Allshare Funktion
ich habe zur Zeit die Mod-Version 1.4.26.1 mit der I9220ZCLP6 Baseband-Version installiert.
Problem: Verbindungsabbrüche beim Telefonieren
Provider: O2
Kennt Ihr womöglich das Problem? Gibt es eine bessere Baseband-Version?
Moin probiere bitte die LP5 ist eine flashbare also unter CWM.
Oder die LP1 die für Europa ausgelegt ist!!!
Edit: Berichte natürlich ob es besser wurde!
Gruss
  • Modem_ZCLP5_CWM.zip
  • XXLP1.zip
Reaktionen: Lich10berger
bin auch bei o2 und benutze die 1.4.26.1 mit der I9220ZCLP6 Baseband-Version ohne irgendwelche probleme.
Muss auch Office- Anwendungen nutzen- ich weiss nicht was ihr alle habt- die neueste Stunner Version läuft und läuft und...:rolleyes2:
Lag das vielleicht an der HILFE von Viper5?
Da ich immer ereichbar sein muss, nutze MailDroid Software. Wobei ich mich noch nicht entschieden habe ob nicht KaitenMail besser ist?
Ach ja, weil gute Arbeit was kosten darf, habe ich von der Software die mich überzeugt hatte, nur Pay Versionen. Ich denke, wer sich ein Smartphone für 500,- € kauft, kann sich auch die paar € für Software leisten, oder?
grüße von
mr.juziu
Oder man hat genau weil das Handy so teuer war, kein Geld mehr für die Apps. :D :thumbup:
Und wenn man dann noch altersbedingt keine Kreditkarte hat, wie meine Wenigkeit, dann macht es das auch nicht gerade besser.
Sicher gibt es Möglichkeiten .. aber auch um ohne Apps zu kaufen zufrieden zu sein. :cool:
Prepaid-Kreditkarte bekommst Du auch keine ??? Falls noch nicht informiert, schau z.B. mal hier: Kalixa
Werde ich mich mal schlau machen, danke für die Idee!
Zur Stunner; In wie weit ist denn unser schönes ROM hier von der Flash-Warnung betroffen?
Ich denke mal gleich betroffen wie jede andere die auf einem China reepack aufgebaut ist!
Gesendet von meinem GT-N7000 mit Tapatalk
Bin sicherheitshalber mal zurück auf GB. Kann mir kein neues Note leisten. :D
die warnung besagt nur,das dieses chinarom bricks verursacht hat und sämtliche leaks drauf basieren.
versuch einfach die CM9. ist echt der hammer :D
Kann mir kurz jemand schreiben, ob ich die originale ICS 4.... Version mit CWM einfach über die ICS Stunner drüberbügeln kann.
Oder gibt es da etwas zu beachten!?
Also ich würde es mit mobile odin drüberbügeln. Hat bei mir funktioniert.
Ich bin aber wieder zurück zur Stunner. Trotz Warnung. Das normale ICS mit TW ist für mich unbedienbar:thumbdn: Die Features der Stunner sind für mich unverzichtbar geworden.
Meine Frage:
Kommt die Stunner auf Basis der Original ICS mit den Samsung-Apps? S-Note etc.? Kann da wer was zu sagen?
Danke.
Jetzt habe ich die offizielle Stockrom geflasht, war ja doch sicherer..
Ich vermisse diese tolle Rom hier jetzt schon :-( echt schade.
hoffe, es kommt eine Stunner raus, mit SNote, SPlanner u.s.w. die auch auf der Deutschen Rom basiert!
Reaktionen: DroidJunky
Leute - so leid es mir tut, ich fürchte da könnt ihr lange warten.
Stunner ist ein AOSP Rom und hat somit keine twframework. Diese ist aber notwendig für S-Pen & Co.
Also wird man sich wohl entscheiden müssen: entweder die S-Apss oder Stunner...:blushing:
Reaktionen: MichiPA
eine Supernachricht wie ich finde :biggrin:
Originally Posted by neobuddy89
And I may not be replying here too much, but haven't abandoned this project.
Thanks to all once again.
Grüße von
mr.juziu
Ist dieses ROM jetzt tot oder gibt es weiterhin Updates?
Lasse mein Note momentan unter dieser ROM laufen und bin super zufrieden damit.
Wenn ja welche andere ROM würdet ihr mit empfehlen?
bauner
bauner
bauner
bauner
bauner
bauner
bauner
Talinsei
