zooot
AniDroid-N7000 ICS ROM
Short ROM Information:
AniDroid-N7000 ROM*was built from the latest*CyanogenMod (CM9)*source with the latest*Linaro Toolchain*(GCC 4.7.1)
AniDroid-Hardened-N7000 ROM*that will be also available soon will include*GRsecurity*Kernel and ROM support to provide different Security functionality for mobile devices..
Provided Features:
Linux Kernel*version*3.0.32*based on the latest*CM9 Kernel Source
CM9 RC1*ROM and Kernel source base built with the latest*Linaro Toolchain*(GCC 4.7.1)
In Development:
GRSecurity*version*2.2.2*with different security features enabled by default (Will be available in*AniDroid-Hardened ROM*soon.. seeGRSecurity Feature List*for details)
SLQB Memory Allocator
USB OTG*support (use with*this*app)
CPU Overclocking (OC)*support
Advanced CPU LiveOC!!! (ALOC)*support with*Selective LiveOC MOD*(Thanks to*byeonggonlee! In most cases*LiveOC and OC itself need overvolting (OV)*due to stability issues!Each device has it's own stability limit, some devices don't need OV with lite OC. So, in most cases you need to choose optimal OV value on each OC value for your own device!)
NTFS filesystem read/write support
HIGH BIGMEM that provides more available memory for Android on device
Backlight Notification (BLN, notify you about new events by blinking Menu and Back buttons)
Backlight Dimmer (BLD, let you turn off the backlight of the Menu and Back buttons when using with soft buttons only)
Battery Life Extender (BLX, let you limit the maximum battery charge level)
45 FPS and 65 FPS Screen Refresh Rate support (you can see the difference in Battery Drain)
-fstack-protector buffer overflow detection
USB Fast Charge (FC) feature that force adapters that are detected as USB to charge as AC enabled
GRSecurity Feature List (will be available in AniDroid-Hardened ROM soon..):
Active Exploits Protection (deter exploit bruteforcing, active kernel exploit response)
Role Based Access Control (RBAC)
Filesystem Advanced Protection (including advanced security for applications running in CHROOT environment)
Full Kernel Auditing (event logging for many process-related kernel events)
Executable Protection (deter ptrace-based process snooping)
Network Protection (TCP/UDP blackhole and LAST_ACK DoS prevention)
Larger Entropy Pools support (adds additional randomness to grsecurity features)
Managing support via Sysctl Interface
CPU Frequence Scaling Governors:
PegasusQ
Adaptive
Conservative
Userspace
Powersave
Ondemand
Performance
MinMax
SmartAssV2
InteractiveX
ConservativeX
LagFree
Lulzactive
Intellidemand
Scary
LionHeart
Wheatley
SavagedZen
BrazilianWax
IO Schedulers:
CFQ
Noop
Deadline
Simple IO (SIO)
VR (Default)
Installation
!!! Bitte NIE von einem ICS-ROM bzw. ICS-Kernel flashen oder einen Full-Wipe ausführen, nur über CM9-Kernel / GB-Kernel / Dafuq-Kernel !!!
- Nandroid-Backup erstellen
- Wipe DATA/CACHE/DALVIK
- Flash ROM
- Flash Gapps
- Reboot
Wenn man bereits auf CM9 ist
- ROM & GoogleApps auf die interne oder externe SD kopieren
- Wipe CACHE & DALVIK, DATA ist nicht zwingend notwendig
- Flash ROM
- Flash Gapps
- Reboot
Changelog:
AniDroid-N7000 v0.1 - v0.2:
SLQB Memory Allocator is now used instead default SLUB
NEW CPU Frequence Scaling Governors added: MinMax, SmartAssV2, InteractiveX, ConservativeX, LagFree, Lulzactive, Lazy, Intellidemand, Scary, LionHeart, Wheatley, SavagedZen, BrazilianWax
EXT4, CIFS support
2048 Kb ReadAhead support
Fixed CM error due to lazy copypasta
AniDroid-N7000 v0.2 - v0.3:
Linux Kernel updated to 3.0.36
Different Kernel source improvements devoted to GCC 4.7.x support
CM9 source updated (See the Changelog)
AniDroid-N7000 v0.3 - v0.4:
PegasusQ and Adaptive CPU Frequence Scaling Governors added
FIX for correct CPU Frequence Scaling Governors
CPU Overclocking up to 1.6 GHz support added
AniDroid-N7000 v0.4 - v0.5:
Linux Kernel updated to version 3.0.37
ReadAhead value changed to 1024 kb
CWM Recovery is now updated to v6.0.0.7
CM9 updated to RC2 (See the Changelog)
AniDroid-N7000 v0.5 - v0.6:
Linux Kernel updated to version 3.0.38
Kernel source is now porting for completely support new compilers like Linaro GCC 4.7.x (still in development)
Fixed BUG with Apps installation on Internal/External memory
ReadAhead value changed to 2048 kb
Lazy CPU sheduler was removed
CWM Recovery is now updated to v6.0.1.0 (Fixed BUG with empty folders in CWM)
CM9 updated to the latest nightly (See the Changelog)
AniDroid-N7000 v0.6 - v0.7:
Kernel: UMS Mass Storage FIX (UMS Mass Storage mode is now working correctly)
Kernel: GPU (Mali400) MAX Frequency is now changed to 400 MHz (insted of 300 MHz in default CM9 kernel) without rising the voltage and battery usage
ROM: default fonts from JellyBean are now used
CWM Recovery source updated to the latest from CM9 repo
AniDroid-N7000 v0.7 - v0.8:
GPU MAX Frequency changed to 250 MHz to save more battery (performance is still great)
GPU Voltages are decreased to save more battery
Additional Soft Keys are added to make the ROM more convenient for the left hand usage
AniDroid-N7000 v0.8 - v1.0:
Linux Kernel updated from 3.0.38 to 3.0.42
CWM Recovery updated to 6.0.1.2
Additional SoftKeys have been removed
Rom base updated to the latest CM 9.1
Download Links:
Current ROM Binaries:
AniDroid-n7000-v1.0_01092012.zip
AniDroid-n7000-v1.0_01092012.md5
Current Kernel Binaries:
AniDroid_Kernel_v1.0_01092012_CWM_Flashable.zip
AniDroid_Kernel_v1.0_01092012_CWM_Flashable.md5
Previous versions:
Previous versions binaries
Google Apps:
https://www.hidrive.strato.com/lnk/wHuRYa2v
http://goo.im/gapps
