[ROM] Criskelo's ICS V11.2 << LRK 4.0.4>> ICS 15 togg TW*S3*-AROM <<<SIM-Lock FIX>>>
  • 2.031 Antworten
Cpt. Future
Gast
Entwickler-Thread: XDA
Entwickler: criskelo
CriskeloRom ICS Note V11.2 LRK
LINK
CriskeloRomNOTE.vICS-V11.2-MD5-7FEDC9597F42C0E9CA2AE4673E84798B.zip
MIRROR 1
MIRROR 2
MIRROR 3
Changelog V11.2
• ADD option in Aroma FullWipe
• Fix Sony Bravia that was not installed
• Fix Sony PlayStation that was not installed
• Fix USB mode now works as it should to return to MTP from Aroma MOD options
• Note 11.1 Updated kernel G
• Add stock theme SIP
• Add stock CRT off in theme
• Now you can apply mods, themes, kernels and modems without complications, should only select what you want
• Several minor tweaks
CriskeloRom ICS Note V11.1 LRK Base No WIPE
LINK
CriskeloRomNOTE.vICS-V11.1-MD5-E69E443254694198E29F0B2FA8C98259.zip
Mirror 2
Mirror 3
Mirror 4
FTP Mirror Criskelo V11.1 danke an a.bangerl
Changelog V11.1
• Some adjustments build.prop TKS Petking
• Added options in aroma
• Select from HTC or Stock DigitalClock
• Select Sony PlayStation Games Library Certified On / Off
• Sony Bravia Engine Library Select On / Off
• Select Sony Walkman Music Pleasure On / Off
• Delete SIM Block protection
• Added language selection to Aroma Installer (English / Spanish)
• And more
Neues Theme
Download danke an galaxy1210 & a.bangerl
CriskeloRom ICS Note V11 LRK Base No WIPE
Erste Berichte über die neue ROM:
"Die Rom läuft sehr smooth und nach den heutigen Test kein einziges Problem und FC.
Mit dem NoteCore v9 Kernel ist diese Rom wieder ganz vorne dabei und vom Design war Criskelo schon immer spitze".
danke an a.bangerl
Changelog V11
• Base LRK
• LRK MODEM
• Kernel CF-Root LRG
• Multi CSC
• Deodex
• ADD Superuser.apk
• No incremental volume in ringtones
• 4 Way Extended Restart Menu
• Stock AccuweatherWidget (Transp.)
• Stock DigitalClock (style HTC)
• Fixing CRT-Off thanks Tungstwenty
• Camera ICS MOD (configurable Volume keys and Camera VideoRec - save internal memory / SD card and more)
• ADD Swype Keyboard
• ADD Chinese Keyboard (on request)
• Start up sound S3 by Syps
• Add TouchWiz launcher-UX S3 (5x6) completely fix all errors (Select wallpapers / widgets etc.) TKS @Smando
• LiveWallpapers Galaxy S3
• New Status Bar 15 toggles (Add Spanish Frech)
• QuickPanel settings now also in Fr y Spanish
• ICS Color Icons in statusbar
• Everything you need to run VPN (not tested) Thanks to ookba
• SMS are not logged in CallLog
• Several tweaks Framework-res.apk
• Mod Settimgs.apk Version Rom /Fast Dormancy/ QuickPanel shortcut / CPU Spy/Working CPU/Select CSC/Samsung Secret Code.
• Roletube (download videos from youtube SD-Card/downloads)
• Host updated to Avoid ads
• Add stock ICS BrowserPlus Browser
• ICS keyboard AOSP
• ICS keyboard Samsung
• ADD AppWidgetPicker (Groups the same application widgets)
• More HD Wallpapers AppStock, and CriskeloGallery
• Themed Dialpad, statusbar and other
• SMS 100 contacts and no convert to MMS
• Add SGSIII MusicPlayer tks grgsiocl
• New CallRec LRK
• SIP working completely
• Improved Cache SD-Card
• Auto BackUp EFS / sdcard / efs.autobackup.img
• Patched services.jar for using supercharger scripts
• And other improvements more
Aroma
Themes:
• Clock Center
• Clock Right
• Theme Stock
MODS:
• [MOD]Modified DSP Manager with BEATS audio.(only GoogleMusic) TKS ...Awesome...
• On/Off Auto Mass Storage
Kernels:
CF-Root LRG
SpeedMod k3-11
GL-Notecore v9
GL-Notecore EX
MODEMs:
LB1
LP6
LPB
LPK
CriskeloRom ICS Note V10.1 LRI Base No WIPE
"Die v10.1 sollte man mal testen, ich bin mal wieder überrascht. alles geht auf anhieb und läuft bei mir besser als die v10. bis jetzt kein hänger oder andere negative dinge. ich kann euch die v10.1 nur empfehlen und ihr werdet criskelo seine arbeit lieben ;-)" danke an hummelbummel
LINK
CriskeloRomNOTE.vICS-V10.1-MD5-.zip.html
Mirror 1
Mirror 2 tks bangsti
Galaxyrom FTP Mirror danke an a.bangerl
AROMA
Add Notecore V8
Add Notecore EX V8 OC 1.6
Fix Install app y mod No FullRom
Several modifications AROMA
Fix Camera Stock
Fix SuperSuNo more losing Root with any kernel
Updated SuperSu and binary
Fix Updater-Script
Add RoleTube
CriskeloRomNOTE ICS V10
"Ich habe die neue version jetzt einige stunden am laufen und alles ist bestens."
LINk
CriskeloRomNOTE.vICS-V10-MD5-1C544E6177C63981802556C384B4DAFF.zip
Mirror 1
CriskeloRomNOTE.vICS-V10-MD5-1C544E6177C63981802556C384B4DAFF.zip.html
Mirror 2
• Base LRI
• LRB MODEM
• Multi CSC
• Deodex
• ADD Superuser.apk
• New Status Bar 15
Spanish Frech)
• ICS keyboard AOSP
• New CallRec LRI
• Mod Settings
CriskeloRom ICS Note V9.1 LRG Base No WIPE
"Im Gegensatz zu der v9 läuft die v9.1 jetzt ohne Probleme bei mir. Root vorhanden und Wlan geht. Rom läuft mit neuen NoteCore 5.1 Kernel super flüssig."
danke an a.bangerl
• Add roletube
• Fix Wifi and SuperSu (I recommend only Use, CF-Root)
• New options in Aroma Installer
• Updated some Apk of system
• Updated Kernel (now speed Mod does not fail in WiFi)
• And some things I do not remember
LINK
CriskeloRomNOTE.vICS-V9.1-MD5-23150AAE6CD2C2809158EB8510963B3E.zip.html
Mirror 1
Mirror 2
RS-Mirror v9.1 danke an mystery007
Uploaded.to Mirror Criskelo v9.1 danke an a.bangerl
LINK
CriskeloRomNOTE.vICS-V9-MD5-601C0BA75D8406A067E2864682747D6D.zip
Mirror 1
Mirror 2
Mirror 3
ADDON
UPD_Hacked.SVoice.zip 80.75 MB
• Base LRG
• LRB MODEM
• Kernel CF-Root LQ3
• Multi CSC
• Deodex
• ADD Superuser.apk
• Start up sound S3
• QuickPanel settings now also in Spanish
• Mod Settimgs.apk Version Rom / QuickPanel shortcut / USB Switch shortcut
• ICS keyboard AOSP
• New CallRec LRG
• Mod Settings
CriskeloRom ICS Note V8 LQ3 Base No WIPE
LINK
CriskeloRomNOTE.vICS-V8-MD5-C36FBDA6EAA88708473158907B44B606.zip
Mirror1
Mirror2
Mirror3
Mirror 1 danke an Fred
Mirror 2 danke an Fred
https://www.hidrive.strato.com/lnk/poux4hnp danke an Cheezusweezel
FIX Camera ICS
Update.CriskeloRomNOTE-ICS-FIX-CameraICS-PanoramicMode.zip.html
ADDON
NOTE CriskeloRom ICS V7
• Updated to the latest firmware S3 Launcher
• New CallRec LQ3
• Mod Settings
CriskeloRom ICS Note V7 LQ3 Base No WIPE
FTP Mirror by GalaxyRom danke an Fred
LINKs
CriskeloRomNOTE.vICS-V7-MD5-D26598CD952E647E80A5910D6E776550.zip
Mirror 1
Mirror 2
• Base LQ3
• LPT MODEM
• Multi CSC
• Deodex
• ADD Superuser.apk
• 4 Way Extended Restart Menu TKS masiullah, chudy_85 and kahvitahra
• Add S3 AccuweatherWidget and S3 DigitalClock (sdcard/CRISKELO-ADDONS)
• Start up sound S3
• New Status Bar 15 toggles V4 View here
• Added new "S Note" premium pack of Samsung
• ICS keyboard AOSP
• Enabled the option CallRec Phone
• Many more things I can not remember
1* Full Golden Theme for criskeloRom v.07 ICS*full*
Download full Golden Theme: Here.
If you have the golden theme only flash
the framework-res next 2.*Full Golden Theme for criskeloRom v.07 ICS (FIX),
is an update of Framework-res, which I had any fault detected.
It installs as a rom above the golden theme, fix some minor bugs.
2* Full Golden Theme for criskeloRom v.07 ICS*(FIX) update framework-res, Ph0enyx contacts*
Download Golden Theme update: Here.
If you have the golden theme only flash it
3.*Golden Apps ICS*
-APEX Launcher
-NOVA Launcher
-Swiftkey X
-TapaTalk
-Whatsapp
Golden Apps ICS download link: Here.
Anleitung
From any GB or ICS roms with mobile Odin and FULL ROOT, do :
1. select "open file" and choose "N7000XXLPY_N7000OXALPY_N7000XXLPT_HOME.tar.md5" file Alternativ Mirror oder Mirror2 danke an Joko90
2. select "kernel" and choose CF kernel LQ2 zip file
3. select "wipe data and cache", then flash Chriskelo v5
Instruction when coming from GB/Stock ICS ROM cwm recovery
1)Check you have full root.(If you dont know how to check dont flash
2)Download both files and save them in your internal sd
3)Go in cwm recovery and flash abyss (yes i know speedmod and franco say it safe but i still not sure and i still recommend abyss)
4)advanced<< reboot recovery(This is where everyone messes up)You should be in Red Pill Recovery at all times..
3)Wipe cache and Dalvik cache
4)Wipe data
5)Mount and storage and Format/system
6)Install criskelo v5.zip..dont reboot
7)Immediately istall criskleo v5.1
8)Now reboot.
Instruction to While coming from previous criskelo versions
3)Go in cwm recovery and flash abyss(yes i know speedmod and franco say it safe but i still not sure and i still recommend abyss)
4)Install criskelo v5.zip..dont reboot
5)Immediately install criskleo v5.1
6)Now reboot.
Anleitung
4)Wipe data
8)Now reboot.
6)Now reboot.
Reaktionen: xvs1100, Sliderxxl, stffnk und 13 andere
Ok coole sache :) Danke schonmal ^^
Reaktionen: Reddy
Ich werds mal laden...danke
Das gefällt mir.
Ist etwas besonderes zu beachten beim flashen?
Rom oder was meinst du?
Gebt mir noch einige Minuten bin gerade bei bearbeiten des Threads.
Anleitung kommt noch.
Cirka 20 Minuten.
Reaktionen: Reddy und manupot
Cirka 20 Minuten.
zu spät!
läuft schon auf meinem note:drool:
Und wie läuft die Rom?
Speed etc.
Hammer hoch 100 :D
kann ich nur empfehlen!!!
Auch die Optik iss ansprechend ... passt!! ;)
Reaktionen: Andi1989
Screenshots kommen gleich habe aber anscheinend ein Problem mit meiner Homepage bzw hat gerade jemand etwas gepostet darüber und ich kann es nicht ganz nachvollziehen.
Reaktionen: Reddy
Hmm....... Naguuuuut überredet ^^ Werde sie mal ausspielen. Zur Zeit mit Galaxyrom2.1 unterwegs ^^
Aber wenn diese hier soviel schneller ist...
Sind irgendwelche Bugs bekannt???
Bis jetzt funktioniert alles ...
nur angerufen hab ich noch nicht ....
Reaktionen: hara74
Wenn jemand meine meinung hören möchte::flapper:
Diese ROM ist momentan das beste was es auf'm markt gibt, werde nacher ein paar mods rausgeben für diese ROM :D
Hab sie auch drauf und ich will sie nich mehr missen. ;)
Reaktionen: barani, Darktrooper, manupot und 3 andere
Also diese Aussage hat mich jetzt angespornt zu flashen.
Du flasht dir sicher nichts rauf was nicht läuft :rolleyes2:
Los gehts und Danke
lg
@DjSonix
Dann kann ich mit ruhigem gewissen die galaxyrom2.1 wechseln ;)
Sind hier die 1% Schritte für den Akku schon drin ?
Oder machst du das später noch ?
EDIT: Sogar Navigon läuft jetzt wieder in den Einstellungen :)
Reaktionen: DjSonix
@all
Wäre jemand so nett und könnte mir einige Screenshots von dieser Rom schicken.
Bin momentan etwas im Stress da es jemand ganz gross gepostet hat das meine Webseite Malware enthält usw ( danke den User pahnik für die Post und nicht schreibst was genau es sein soll)
Habe jetzt gerade einige Tests durchlaufen lassen und es ist bisher alles sauber was ich auch nicht anders erwartet habe.( siehe galaxyrom thread)
Ebenfalls hat frank_m den Post gelöscht da er es auch nicht nachvollziehen kann.
Sollte sich derjenige doch noch melden wäre ein Statment angebracht bevor man solche Sachen postet.
Reaktionen: Reddy
Jo, NAVIGON klappt!!! hab gerade Neu runter geladen ...
und nix mehr FC :D
Reaktionen: majemaco
bauner
bauner
bauner
bauner
Talinsei
bauner
bauner
bauner
