[ROM] Criskelo's ICS V11.2 << LRK 4.0.4>> ICS 15 togg TW*S3*-AROM <<<SIM-Lock FIX>>>
  • 2.031 Antworten
LR5-Basis ?
Changelog:
• Base LR5
• LRB MODEM
• Kernel CF-Root LRG
• Multi CSC
• Deodex
• ADD Superuser.apk
• No incremental volume in ringtones
• 4 Way Extended Restart Menu
• Stock AccuweatherWidget (Transp.)
• Stock DigitalClock (style HTC)
• Fixing CRT-Off thanks Tungstwenty
• Camera ICS MOD (configurable Volume keys and Camera VideoRec - save internal memory / SD card and more)
• ADD Swype Keyboard
• ADD Chinese Keyboard (on request)
• Start up sound S3
• Add TouchWiz launcher-UX S3 (5x6) completely fix all errors (Select wallpapers / widgets etc.) TKS @Smando
• LiveWallpapers Galaxy S3
• New Status Bar 15 toggles (Add Spanish Frech)
• QuickPanel settings now also in Spanish
• ICS Color Icons in statusbar
• Everything you need to run VPN (not tested) Thanks to ookba
• SMS are not logged in CallLog
• Several tweaks Framework-res.apk
• Mod Settimgs.apk Version Rom / QuickPanel shortcut / USB Switch shortcut
• Roletube (download videos from youtube SD-Card/downloads)
• Host updated to Avoid ads
• Add stock ICS BrowserPlus Browser
• ICS keyboard AOSP
• ICS keyboard Samsung
• ADD AppWidgetPicker (Groups the same application widgets)
• More HD Wallpapers AppStock, and CriskeloGallery
• Themed Dialpad, statusbar and other
• SMS 100 contacts and no convert to MMS
• Add SGSIII MusicPlayer tks grgsiocl
• New CallRec LRG
• SIP working completely
• Improved Cache SD-Card
• Auto BackUp EFS / sdcard / efs.autobackup.img
• [MOD]Modified DSP Manager with BEATS audio.(only GoogleMusic) TKS ...Awesome...
• Mod Settings
• And other improvements more
Reaktionen: Reddy, pakino, 149217 und 2 andere
Kann ich die jetzt einfach über die Stock 4.0.4 drüberbügeln? MIt wipe cache und dalvik?
Jop, das geht.
Reaktionen: pakino
Ich finde das transparente Wetter-Widget klasse. Ist das hier inklusive oder muss ich das separat installieren? Passt die alte apk des Widgets mit dieser Version?
Geht auch das goldene Thema aus der V8 oder ist das nicht möglich?
So ihr lieben flashjünger:D
Erste Seite up 2 date, habt viel spass mit der neuen Criskelo.
(ich beneide Euch:blink:)
Gruss (man glaubt es nicht in HH scheint die Sonne:thumbsup:)
Reaktionen: Reddy, blubenow und hara74
Also wenn hier mal die schwarzen Wolken weiterziehen, kommt sie bei uns auch raus.
Moin leutz,
endlich ist criskelo am start..... ;)
Aber warum zum Teu..el nimmt er den CF-LQ3 und nicht den LRB?:blink:
Download läuft:D
Falls gewünscht gäbe es in ca. 1Stunde einen Wuala Mirror von mir?
Bin gespannt da Chrack die Latte doch schon sehr hoch gelegt hat:D
Wie bekomm ich die ROM installiert? Über e3 und mobileOdin gehts nicht. Steh gerade voll auf dem Schlauch....
Wenn Du ROOT hast, geht es natürlich über MobileOdinPro, aber nur als tar.md5, nicht als ZIP ! Woran scheitert es denn ?
Und über CWM-R muss es auch gehen, aber vermutlich hast Du nur die temporäre Variante zum Rooten genommen !?
Root hab ich. Hab aber die ROM nur als zip. Wo bekomme ich die tar.md5 her?
Das ZIP entpacken und dann als flashable-TAR packen, das ist aber nicht ganz einfach bzw. Bedarf etwas "Einlesearbeit". Daher solltest Du besser einfach den CF-Rootkernel 5.6 LRG mit MobileOdin flashen, dann hast Du CWM-R und kannst das Criskelo-zip flashen.
Welche rom hast grad drauf, wenn laut signtaur du die criskelo v8 hast dann einfach per 3 tasten kompi ins cwm recovery booten und die v9 flashen und fertig
das warten hat ein ende, ich liebe android-hilfe und alle helfer hier im forum!!!
Ich denke er hat die 4.0.4 drauf, nur Root, kein CWM-R.
Link zum CF-Kernel, zu flashen über MobileOdin oder OdinPC: CF-Root 5.6 LRG
Der ursprüngliche Beitrag von 13:44 Uhr wurde um 13:49 Uhr ergänzt:
Hier mein CriskeloV9-Mirror: HiDrive
Reaktionen: Reddy
Ich sollte öfter mal unken .. dann passt das mit ein Update ;)
Hat Jemand die v9 schon drauf?
Ich kann Heute erst mal nicht ... Job ruft in einer Stunde ...
Mal ne Frage, was hat das mit dem ADON zip auf sich?
muss man den im Stück mit CWM-R flashen,
oder auspacken und einzeln installieren??
Bin wieder zurück auf Chrack´s Rom da ich mit der V9 nur Probleme habe.
Zuerst ohne Fullwipe geflasht und Root verloren.
Saubere Installation mit Full Wipe kein Root und Wlan und ständig FC.
Habe es insgesamt viermal probiert und bin sicher kein Flashanfänger aber mit der V9 habe ich anscheinend nur Troubles.
Reaktionen: xvs1100, pakino und Reddy
Ich werde mich auch mal daran versuchen, danke für die Info Fred, falls es nicht so funktioniert wie es sollte spare ich mir die Fehlersuche.
OT: wird ja eine richtige Catgang:tongue:
Reaktionen: pakino und Reddy
bauner
bauner
bauner
bauner
Talinsei
bauner
bauner
bauner
