[ROM] Cassie's XtraLiteRom JELLYBEAN V14.8 LSZ "Your Rom Your Way" 24/02/2013
  • 183 Antworten
Cpt. Future
Gast
Entwickler-Thread: XDA
Entwickler: thering1975
Cassie's XtraLiteRom jellybean EDITION v14.8 LSZ
Specs
VERSION 14 official LSZ JELLYBEAN-Aroma Edition
Based on officialn LSZ GERMANY ROM
Deodexed and Zipaligned by Eyebee
Philz LSZ kernel
LSO or LR1 Modem
Thunderbolt tweaks applied for smoother experience and battery use thanks Pikachu01
Services.Jar modded for enhanced speed and ready for v6 sc
Services.Jar modded for 24 Hour app expiry multitasking not 30min
Services.Jar modded for DIEhardened launcher in memory
Restored Build.Prop tweaks streamlined for Jellybean
Working Snote with productivity
Full stock look as standard or various mini themes in aroma
Used preload partirion with symlinks
Included adobe flash in system
Added 4 way reboot option
Added airview fix. Works in email gallery video calendar and bookmarks
V14.8 also includes
Mini Themes by Trinev
Mod Pack inc mods by the people listed below
Modem choice in Aroma
Some apps installed to data
Philz 4.63 LSZ Kernel
This Rom has a stock theme, allowing you to choose a theme based on your preferences rather than mine
As Always, make sure you make a nandroid before installing this rom, i will not be held responsible for any issues that may arise AND BACK UP YOUR EFS FOLDER before flashing ANY rom
Downloads
--------------------------:biggrin:---------------------------
Cassie's XtraLiteRom JB EDITION v11.1 LSA
VERSION 11 and 11.1 LSA JELLYBEAN-Aroma Edition
Based on leaked LSA rom by Eyebee
Deodexed and Zipaligned by Eyebee why reinvent the wheel
Philz v.3.65 kernel
LSA Modem
Working Snote with productivity tools
Added Swype as was missing from leak
V11.1 - Fixed Chaton install failure
V11.1 Update to kernel v3.71
V11.1 Moved approx 60mb of apps to data for those who came accross install error due to full system partition (affects those who install most of the apps only)
JELLYBEAN LSA V11.1
Cassies XtraLiteRom V11.1 LSA
Cassie's XtraLiteRom JB EDITION v11 LSA
Specs
VERSION 11 LSA JELLYBEAN-Aroma Edition
Philz v.3.65 kernel
LSA Modem
New Aroma Options
Working Multiview thanks maskerwsk
I have modded Maskerwsk services.jar to include the supercharging as above
4 way reboot menu by REVERSIN
Enabled call recording mod thanks to Reversin
Enabled Smart Rotation, Lockscreen, USB Switcher thanks to Reversin
Option to install Mini Dark theme looks great thanks to Trinev
Downloads
JELLYBEAN LSA V11
Cassies Xtraliterom V11 LSA
Size:
787.47 MB
Specs
VERSION 10 LS7 JELLYBEAN-Aroma Edition
Based on leaked LS7 rom by Eyebee
Deodexed and Zipaligned by Moi
Philz v.3.1 update 1 kernel
LS3 Modem
Working Multiview thanks not-i
4 way reboot menu by majdinj
Full stock look
New Aroma Options
Additional Tweaks and Mods
Added SGS louder ringtones as defult
Downloads
JELLYBEAN LS7 V10
Cassies Xtralierom V10 LS7
Cassie's XtraLiteRom ICS EDITION v8 LRQ
VERSION 8 LRQ- ICS Aroma Edition
Based on stock LRQ ICS Rom (United Kingdom)
Single XEU CSC Files included
Deodexed
Zipaligned
Gavins Note Core Kernel V14
Removed Pikachu01 Thunderbolt
Services.jar enhanced for optimum speed and management
LRKModem
New TW Launcher
New Samsung Keyboard
Build prop tweaks - revised 6th Sept for smoother UI experience and reinstated enhanced media encoding
Hardware Ui Rendering
Hardware acceleration
Net Tweaks - Reinstated
Media Tweaks
SGS2 Louder Ringtones and Notifications
Fully Stock Framework
Rewritten Aroma Installer individual app install now possible over 55 choices
Downloads
ICS VERSION 8 LRQ
Cassies XLR LRG V8
V8 LRQ High Speed Mirror courtesy of Bangsti
MD5 Sum: cc951084538e4a6b56dde9146c770762
Mirror 1 [ROM][AROMA] Cassie's XtraLiteRom ICS V8 "Your Rom Your Way" LRQ 09/09/12
Mirror 2 [ROM][AROMA] Cassie's XtraLiteRom ICS V8 "Your Rom Your Way" LRQ 09/09/12
Mirror 3 [ROM][AROMA] Cassie's XtraLiteRom ICS V8 "Your Rom Your Way" LRQ 09/09/12
danke an Phoenyx
Cassie's XtraLiteRom ICS EDITION v7.2 LRK
Based on stock LRK ICS Rom (United Kingdom)
Single CSC Files included
Deodexed
Zipaligned
Pikachu01 Thunderbolt script 2.7.7
Thunderbolt 60mb LMK Tweaks REMOVED
LRKModem
Touchwiz 4 Launcher
Build prop tweaks - revised 4th August for smoother UI experience
Media Tweaks
Fully Stock Framework with option for lower brightness settings for standard and powersave
Cassies XLR V7 4.0.4.zip - 681.52 MB
Mirror Cassie´s ICS V7.2 danke an a.bangerl
Wifi Fix for LRK based roms created by G.Lewarne all credits to him
Known issues bekannte Fehler
Snote equation causes fc
Screencapture will FC if you try to edit straight away - so instead take a screencapture then press home key. Goto gallery then edit it
Cassie's XtraLiteRom ICS EDITION v6.0 LRG (DBT)
Erste Berichte über die neue ROM:
"Habe die ROM heute morgen geflasht und muss sagen, obwohl von Chracks ROM verwöhnt, das Chassies durchaus zu gefallen weiss:cool2:
Mit dem Aromainstaller kann man(n) fast eine maßgeschneiderte ROM erstellen die (bis jetzt) sehr smooth und schnell läuft."
danke an unhold 31
VERSION 6 - ICS Aroma Edition
Based on stock LRG ICS Rom (Germany)
Deodexed
Zipaligned
Chainfires LRG Kernel
LRBModem
Touchwiz 4 Launcher
Stock samsung keyboard reinstated (replaced two fonts)
Build prop tweaks - revised 15th July
Net Tweaks - Removed
Media Tweaks
Fully Stock Framework with lower brightness settings for standard and powersave
Downloads
ICS VERSION 6 LRQ
Cassies XtraLiteRom V6 Build 4 LRG
Wuala Mirror danke an unhold 31
Reaktionen: skysat, maximus78, Felidea77 und 5 andere
Danke Viper5
Rom gibt es jetzt auch auf galaxyrom.com inkl. den gelöschten apps.
Wie gesagt ist es eine Lite Version läuft dafür aber super smooth und sehr akkuschonend.
Reaktionen: Robby57, Reddy und 149217
Fred besten Dank grosser! Habe deine beiden Links oben eingebaut!
Gruss
Reaktionen: Reddy
thering1975 hat sie im XDA Thread mal gepostet finde sie aber auf die schnelle nicht.
Hier wären meine Links
Download Rom
Download gelöschte Apps
Siehst du das Powermenü wollte ich schon auf galaxrom stellen und hab es wieder vergessen.
Ich werde alt.:sad:
Danke dir.
Hallo ihr.
Hab die ROM seit gestern Abend mit Franco r4 auf meinem Note.
Läuft bei mir problemlos und smooth, vielleicht einen Tick langsamer als meine abgespeckte King v2.
Ist aber nur mein Gefühl. Bilder kann ich leider erst morgen Abend anbieten, da ich jetzt das reale Leben geniesse und morgen Dienst hab.
Danke unhold31 werde mich jetzt auch noch über meine realen Lehrbücher hauen.
Reaktionen: 149217
Hallo Fred.
Wenn's vom Handy funktioniert müsste das erweiterte Powermenü als flashbare zip Datei auf Wuala sein.
Reaktionen: Reddy
Habs gerade gesehen das du am hochladen bist.
Danke für den super Service.
War schon in einigen Foren unterwegs aber so klasse Menschen wie hier findet man selten.
Powermenü ist in einigen Minuten auf galaxyrom.com verfügbar.
Reaktionen: Reddy und 149217
Das kann ich nur bejahen.
Und immer wieder Danke sagen an all die unermüdlichen die dies erst möglich machen.
Schönen Bugfreien Abend aus Wien
Danke an Fred und an unhold31
@unhold31...
auf die Bilder freue ich mich sehr! Wenn Du es wie Du Zeit hast zusendest, werde ich es gerne auf die erste Seite mit einbinden!!!
Gruss
Reaktionen: Reddy
Mach ich gern, nur wird's wahrscheinlich morgen Abend erst gehen.
Ext. Powermenü ist online. Kann nur leider übers Note den Link nicht einbinden.:blushing:
Moin :)
Wo bekommt Ihr immer nur die Neuigkeiten her!! Find ich Klasse!!!
Ich guck mir die ROM auch mal an ... muss aber erst mal auf Arbeit,
hilft nischt ;)
Danke an Euch!!!
Kann man auch Frankos Kernel nehmen ?
Guten morgen allseits:biggrin:
Kann man. Ich hab den r4 dazu. Bilder gibt's in kürze.
Moinsen, kann man den die ROM kommt ja bereits mit Franco r2. Und die ROM existiert ja bereits einige Tage. So schnell kann man nicht mal flashen wie die Kernels nachkommen:biggrin:
@unhold31
Freue mich auf die Bilder:thumbsup:
Gruss
Ich hatte die ROM gestern Abend auch kurz drauf und muss sagen Homescreen-Scrolling etc. ist EXTREM schnell & flüssig. Aber bei mir wollte die haptische Rückmeldung der Sensortasten nicht reagieren und auch das Wetter im Lockscreen mochte nicht. Daher erstmal wieder runter ...
Und jetzt mal die Bilder.
Ich war so frei und hab nochmal neu geflasht weil ich mir dachte das interessiert mehr als das fertige, angepasste ROM.
Einzige Veränderung, Kernel (Franco r4) und Modem (LR1):D
Und nachdem die Fotos des Nächtens gemacht wurden, auch noch eines wo man sieht das der Kernel auch brav schläft:D
Und jetzt viel Spass und Happy Flashing:thumbsup:
Reaktionen: cheezusweezel, lady27 und Reddy
Ich habe die Rom seit Heute Früh drauf, ohne Probleme, auch nicht beim Wetter. Hab kleine Wipe gemacht und Franco r4 geflasht. Läuft sehr flott :)
Reaktionen: 149217 und lady27
Moin Reddy Sir,
ich selbst habe die ROM nicht drauf, wird aber auf XDA wegen seiner sparsamen Akkuverbrauch gelobt!
wie z.B.
"This Rom has always been known for its excellent battery life.
Da der DEV erst mit einer GB Version anfing, startet die XDA Diskussion erst ab diesem Link!
ICS Discussion starts here ICS CHatter
Gruss
Reaktionen: 149217 und Reddy
Tja, so unterschiedlich kann es sein. Ich habe mich sogar ausnahmsweise 100% an die Flashanleitung des Devs gehalten, sauber war auch alles. Naja, wollte eh nur mal reinschauen und es freut mich, wenn ich nur ein Einzelfall war.
bauner
bauner
bauner
bauner
Talinsei
bauner
bauner
bauner
