Kkangpae
mir widerstrebt es die vollen GAPPs zu installieren. Ich bin da ein wenig eigen, so als Google-Hater
Versuch zuerst die beta5 kernel only zip zu installieren und dann die recovery neu zu starten.Ich habe versucht diese Rom zu flashen, allerdings bricht TWRP immer wieder ab, erst Error 7, dann corrupt File
Hat noch jemand das oder ein ähnliches Problem?
Oder hat jemand eine Problemlösung?
The CM12.1 20150612 is the first real stable running version and the most things are working well, but there still can be some minor bugs!
You should not use other kernel as the stock one for CM12.1 20150612! Other/older Kernel for CM12.1 would work too, but it would bring back the stability problems!
If you wan't to use another kernel you should ask the kernel dev if he will make a new version based on my smdk4210 version
Changes:
Merged cm changes (Android 5.1.1_r3 with the new App drawer in Trebuchet)
Codec changes to fix some movie types in Nuplayer
Changes in wifi config
smdk4210 kernel with mali r3p2 to fix the reboot, freezing, heating and battery drain problem (no zram, ksm, trim and selinux support atm)
