[ROM][AROMA][14DEZ][4.1.2][XXLSC]CRASH ROM [En Linea]
  • 131 Antworten
Cpt. Future
Gast
Entwickler-Thread: XDA, HTC Mania (spanisch)
Entwickler: Crash 1976
eybee1970
rupiahvn
Phil3759
Livebyte
DooMeDboY93
sbasil
Bangsti
BASE XXLSC
KERNEL PHILZ
MODEM DE LA BASE
-Deodex
-ZIpaling
-Busybox
-VPN Support
-EXT4 Tweak
-GPU 2D tweak
-Init.d Tweaks
-Tweak para 3g mejor señal y desempeño
-Herramientas al Settings (Fastdormancy, CPU SPy, Working CPU, CSC)
-Modo tinta (Gracias a Robbie)
-Grabación de llamada
-Mod MMS no conversion
-Menu de restauración (4 way restauration)
-Acid Mod (SUper mod para Audio)
-Smart rotation
-Smart stay
-mas otras cosas que ya no recuerdo...
DOWNLOAD LINKS
Download link click here or here
Quelle: Hier
make sure you are on a JB-ROM with CWM recovery and brickfree kernel installed
copy ROM on your USB-storage
boot in Recovery
FullWipe
flash ROM (it will reboot automatically)
after initial setup, open Super SU-app and you might have to update SU-bin (app will do that for you if necessary!)
CHANGELOG V10.1 PLUS WITHOUT AROMA
This is simple call PLUS, no need to install if you don´t want to hehe
-Add Keyboard without uper numbers
-Add King Soft (10 time better then Polaris)
-Add ICS Camera
-Add Play Station App (Thanks to lsbe)
-Add Mod Logs provider (No sms on logs)
-Remove RamTweak (Makes phone and contacts app open faster)
-Add New Launcher similar to Nova and Apex but with coolest weather widget (Thanks to
i forgot the user name if someone now please send me a PM)
INSTALLATION METHOD
CWM Recovery no need wipes or nothing
DOWNLOAD V10.1 PLUS HERE
ADITIONAL THEME FROM MY FRIEND GLAXY1210 HUGS MATE
NOTE: YOU HAVE TO HAVE STOCK THEME IF YOU INSTALL ON SCAMUS THEME YOU MAY HAVE PROBLEMS
INSTALLATION METHOD
DOWNLOAD GALAXY1210 HERE
ENJOY
Reaktionen: McMiller, Robby57, simonwest und 3 andere
Reaktionen: Reddy und cheezusweezel
@viper, sag mal, sind die Screenshots zufällig von Dir ? Falls ja, wie bekommt man die so schick hin ?
Die sind auch im XDA Thread so mit drin.
Reaktionen: cheezusweezel
Mist ...^^
Moin moin ihr flasholics, (off topic) aber wichtig!
Ich vermute das einige von uns da draussen nicht an das sichern des "EFS" Ordners gedacht haben. Ich hoffe es sind ganz ganz wenige! Daher gilt dieser Post jenen die nicht daran gedacht haben!
Was ist der "EFS" Ordner? Auszug aus den FAQ's
FAQ
EFS Backup:
EFS steht für "Encrypted File System" und beinhaltet gerätespezifische Informationen, z.B. Informationen zum ProductCode und die IMEI. Ein schreibender Zugriff auf EFS ist extrem gefährlich, da dabei oft was schief geht, vor allem, wenn unvorhergesehene Schreibzugriffe erfolgen. Unvorhergesehene Schreibzugriffe erfolgen immer dann, wenn sich der ProductCode ändert, weil eine unpassende CSC geflasht wurde. Und deshalb geht dabei so oft die IMEI verloren.
Um Unfällen beim Flashen vorzubeugen, ist es sinnvoll, vorm Flashen ein EFS Backup anzulegen:
Diesen Ordner kann man auf unterschiedliche Art und Weise sichern! Mit einem Programm am PC oder mit Root Explorer oder ähnlichem direkt auf dem Note.
Am PC unter anderem mit dem Tool EFS Pro (kostenlos, im Anhang)
oder mit Root Explorer... Anleitung siehe unten.
Das brauchen wir um den EFS Ordner zu sichern :
Root (Um Root zu bekommen kann man sich z.B. den cf-root flashen)
Einen Handy File Explorer wie z.B. in diesem Fall "Root Explorer".
Startet die App "Root Explorer".Dann sehen wir auch gleich den "EFS" Ordner.
Drückt nun auf "Mount R/W" um Rechte zu bekommen.Dann wechselt es wie im Bild zu "Mount R/O".
Lasst den Finger jetzt lange gedrückt auf dem Ordner "EFS".Es öffnet sich ein Kontext Menü wo wir nun "Copy" drücken wie auf dem Bild zu sehen.
Nun navigieren wir zum Ordner "SDCARD" und öffnen diesen.
Ich habe im Vorfeld einen Ordner in "SDCARD" erstellt mit dem Namen "Apps Sicherung Orginal".Diesen Ordner öffne ich jetzt auch.
(Ihr braucht aber keinen Ordner.Es reicht auch "SDCARD" zu öffnen und dann den "EFS" Ordner dort rein zu kopieren).
Nun befinde ich mich in dem Ordner "Apps Sicherung Orginal".Dort drücke ich jetzt Links unten auf den Button "Paste".Damit wird der EFS Ordner in den Ordner "Apps Sicherung Orginal" kopiert.
Quelle:
Hier gefunden
EFS_Pro_1.7.13_Release.zip
Reaktionen: LRP
Momentan das beste was man kriegt... Butterweich nur der browser spinnt manchmal
Aber dafür gibt es den ics browser+
Moin moin v2 ist online:flapper:
Siehe Post1
Reaktionen: Reddy
Die v3 ist da ...
Link: CRASH V3 - Wuala
Changelog:
Build: DDLPA
Kernel: XXLQ3 (change with the one you like)
Modem: XXLR1
-CRT-OFF Animation
-S3 Fugutweaks build in (Thanks to hikarugo)
-S3 Music Player (Thanks to grgsiocl)
-TW5 (Thanks to Goatrip)
-Add MultiLing (Keyboard support any language)
-Svoice 3 with Homemyhome (Thanks to padlad)
-Multi CSC
-S3 Ringtones
-Add SmartStay (Beta thanks to elnoxvie) original post HERE
-Call record
-USB Mass storage
-4 way restart menu (Thanks to masiullah)
- Autocalibration Battery Tweak
- Add VOIP-SIP
-Snote Premium
Reaktionen: Sliderxxl
Thx für die Info + den Upload.
Ist auf Galaxyrom eingefügt/aktualisiert.
Moin bin zur Zeit auf Seminar und sobald ich PC Zugang habe wird auch die erste Seite aktualisiert.:rolleyes:
Gesendet von meinem GT-P7500 mit Tapatalk 2
Moin moin sodele erste Seite aktualisiert!:smile:
Gruss
Hallo inzwischen ist die v4 raus und kann aktualisiert werden.
LG Faberon
Gesendet von meinem GNote aus Berlin TTTT
Reaktionen: majemaco
Ja wenn du einen Downloadlink hast der geht!
Der Wuala Link geht nicht und der DEV macht gerade einen neuen Upload und schickt mir den Link für weitere Mirrors.
Hi also ich habe es runtergeladen und versucht zu installieren die v4 aber es bleibt immer dabei das ich die v3 habe also kein update was mache ich falsch?????
Moin,
erste Seite wieder aktuell.
Gruss
Reaktionen: manupot
bauner
bauner
bauner
bauner
Talinsei
bauner
bauner
bauner
