[ROM][AOSPA 3+ | JB 4.3] paranoidandroid 3.99 RC2 HALO 2.0 | 21.09.2013
  • 1.396 Antworten
AA1973
AA1973
Enthusiast
6.003
[AOSPA 4.3] PARANOIDANDROID 3.99 RC2 HALO 2.0 | 21.09.2013
Developer für unser Galaxy Note: beerbong
[YOUTUBE]aN9an9rqwOY[/YOUTUBE]
http://www.youtube.com/watch?v=aN9an9rqwOY&sns=em
ParanoidAndroid ROM 3 Review, Tips and Complete Walkthrough
A great review from raakaysh.
[/CENTER][/QUOTE]
INSTRUCTIONS
0. FLASH A SAFE KERNEL (CM10 or CM10.1), STAY IN RECOVERY, REBOOT IN RECOVERY (UNDER ADVANCED)
1. FACTORY RESET (WIPE DATA)
2. INSTALL ROM, GAPPS:
ROM: ROM
GAPPS: GAPPS
+++++ MIRROR +++++
ROM Goo.im Downloads - Browsing n7000
GAPPS Goo.im Downloads - Browsing gapps
3. WIPE CACHE & DALVIK CACHE
4. REBOOT
PA 3.0+ UPDATES DO NOT NEED A FACTORY RESET,
BUT YOU NEED TO INSTALL GAPPS ASWELL.
FEATURES for 3.0+
Hybrid engine +++ Per app Layout, this will let you choose the UI of any app,--
that means you can switch apps into their tablet layouts +++ Per app Size, scal
e apps individually, this is especially important if you use tablet apps, go as
small or big as you like +++ Per app Color, this lets you select statusbar and-
navbar colors for apps individually, colors will shift when you jump from one a
pp to another +++ Hybrid engine makes it possible to use any tablet ready app--
available on your phone, start with your regular Google apps and see what treas
ures lie hidden in them and just how well they work on your device. +++ You can
use hybrid engine to use all available general interface UI's aswell: Phone, Ph
ablet, Tablet. This is safe as milk, we don't change DPI, we don't trash your m
arket, we don't shrink all your apps or force them into layouts, you don't need
to edit system files for that. +++ Transparent bars and color pickers, new Syst
emUI drawables thanks to giannisgx89 +++ Theming Engine +++ Statusbar Settings,
Lockscreen Settings +++ Multiuser support +++ Quicksettings -> Quicktoggles +++
4.2 Walls and sounds, Google stock apps As we merge back our old CMPA feature--
catalogue this list will grow considerably over the coming weeks +++ New holo-s
tyled theme chooser +++ T9 dialer +++ New papreferences app
GALLERY,
TUTORIAL,
DONATIONS,
to molesarecoming
to D4rKn3sSyS
to jaybob413
to aaronpoweruser
to beerbong
CREDITS,
AOSP/Google, Cyanogenmod, Goo, XDA, Krebsmilk, giannisgx89, Liquid,
AOKP, our users, supporters and donators, everyone who's helped us in the past,
heartfelt thanks to all of you!
LINKS,
Website: www.paranoid-rom.com
Github: www.github.com/paranoidandroid
Gerrit: review.paranoid-rom.com
BANNERS,
Reaktionen: starmagoo, hansalbert, agentdoggie und 17 andere
gestern erst einen bericht über pa 2.99 aufn n7 gesehen gestern und jetzt ist es schon auf dem note sehr schön :D danke für den thread :)
Reaktionen: MichelFell und AA1973
FAQ
- AOSP like keine Power Widgets (Toggles, da CM feature) > aus dem PlayStore "Power Toggles" installieren.
https://play.google.com/store/apps/details?id=com.painless.pc
Oder Notification Toggles oder oder oder ...
Known bugs/issues:
- PaPrefs: cannot save the preferences
- FM Radio: unsupported > SpiritFM aus dem PlayStore oder auf XDA ausprobieren
- TV Out: unsupported, will never work !!! (proprietary, undocumented)
- You say...
+++++ P. S. A. +++++ P. S. A. +++++
- S-Note, S-Planner etc benötigen Touchwiz Framework und funktionieren daher nur auf Samsung Touchwiz Roms, aber nicht auf AOSP basierten Roms. (AOSPA, CM, OMNI, SLIM ETC)
Reaktionen: Bastizpunkt, MichelFell, Jrp Defy und eine weitere Person
Danke AA1973 für den Thread und an beerbong für sein Arbeit.
Habe die Paranoidandroid auf den Nexus7 am laufen und wenn man sich an die Pie Funktion gewöhnt hat möchte man nichts anderes mehr.
VID_20130122_194147.mp4 - YouTube
Reaktionen: Jrp Defy, MichelFell und AA1973
Perfekt, hatte beim gestrigen Lesen auf Mobiflip schon die Hoffnung aufgegeben, dass wir diese Version auch noch bekommen ... ;)
Reaktionen: Jrp Defy und AA1973
Reaktionen: Jrp Defy, MichelFell, cheezusweezel und eine weitere Person
AA1973 schrieb:
Flink flink AA. Danke dir. Nach sechs Tagen ohne Flash wirds gleich mal angeschaut.
Noch ne Frage, Die GAPPS sind spezifisch oder kann ich die SlimGapps draufknallen?
Flink, flink, stimmt :D
Bitte erst einmal nicht SB gapps ;) Ich habe keine Probleme mit den Gapps von beerbong - und ja, auch für das Nexus gibt es gesonderte PA-Gapps. :thumbup:
Reaktionen: Jrp Defy, Berlino, MichelFell und eine weitere Person
Ich bin zu blöd glaub ich. Bekomme den Kuchen nicht angezeigt
Edit
Hab's hinbekommen. Wer lesen kann ist klar im Vorteil
Hab zwar kein Note aber schätze es wird hier das selbe wie am Nexi sein.
Aktivieren der PIE
Einstellung-Toolbars - Pie Controls
Funktion hast du aber nur im Expanded Desktop ( über Powerbutton zum auswählen)
Für die nun fehlende Statusbar habe ich Smart Statusbar installiert.
Hoffe etwas geholfen zu haben.
Reaktionen: beafraid, Malzbier, CVH und 5 andere
Stimmt, die Statusbar fehlt, es wird aber alles im Kuchen angezeigt.
Zusätzlich kannst du über die linke Hälfte swipen, dann bekommst du die Quick Tiles angezeigt. Wenn du über die rechte Hälfte wischst, zeigt es dir die Notifications an.
Zurück zum eigentlichen Bildschirm > einfach in den "freien/leeren Raum" klicken :thumbup:
Der "Kuchen" nimmt die Standardfarben der Softkeys an, es sei denn du hast "PA colours" als feature gewählt. Andere Farben sind auch möglich über hybrid prop > apps > system ui > colours tab
Viel Spaß! :D
Den Kill all button gibt es auch nur in der PIE :thumbup: es werden alle Apps gekillt, bis auf die letzte (unterste) aktive APP.
Reaktionen: CVH, Jrp Defy, Berlino und eine weitere Person
Hey aa
ich geh jetzt mal von aus das Utacka auch ne paranoid entwickelt...
Was ist denn jetzt da der unterschied?
Utacka: basis cm10.1
und beerbong basis aosp?
ist das richtig?
Gibt es sonst noch unterschiede?
Der Kuchen macht den Unterschied :)
Reaktionen: AA1973 und Jrp Defy
rinbe schrieb:
Hey aa
ist das richtig?
Nein, utacka macht eine Weiterbildung und hat keine Zeit zum developen. Hat er mehrfach im Thread geschrieben, mir auch persönlich.
Utackas Basis war CM10 (4.1.2) und nicht CM10.1 (4.2.1)
PA Team hat sich entschieden, zukünftige Entwicklungen nur noch auf AOSP-Basis zu machen, statt wie bisher auf CM-Basis.
Beerbong's Basis ist AOSP 4.2.1 und der große Unterschied ist, wie bereits von Sanj3k genannt, u.a. der "Kuchen"...;) und die hybrid engine ist weiterentwickelt worden.
Nandroid von der aktuellen ROM machen und ... Du weißt schon :thumbup:
Reaktionen: rinbe und Sanj3k
Hallo
Irgendwas lief bei der Installation schief, kann mein Wlan nicht finden. Jemand ne Idee?
Gruss michel
MichelFell schrieb:
Hallo
Gruss michel
Installier noch mal den neuesten CM10.1 kernel; hoffe, das hilft. Hattest du vorher Thor Kernel am Start?
Ja, und als ich dann ins cwm ging um mein Nand zurück zu holen, war immer noch der Thor drauf.
War bei mir ebenso. Nach dem zweiten Full-Full-Wipe und zweitem PA-Flash war noch immer der Thor drauf, aber es hat gebootet. Auch OK ... ;)
Ja, habe jetzt den cm10.1 Kernel geflasht, ist auch hochgefahren aber ich kann wlan nicht einschalten, das der Schalter sich überhaupt nach rechts schieben lässt, geht nur im Flugzeugmodus, aber er geht sofort wieder auf aus. Also kein Wlan. Was nun?
So nochmal Fullwipe und wieder das selbe, Wlan lässt sich nicht einschalten.
Ich habe den Thor zum flashen genommen und gleich im Installationsmodus mit integriert, also Rom+GAPPS+Thor. Keinerlei Probleme. WLan kam auf Anhieb.
Reaktionen: Berlino und MichelFell
