[ROM] [AOSP/CM10] [27-09-12] BlackCNA / Codename Android v2.1
  • 96 Antworten
cheezusweezel
cheezusweezel
Enthusiast
5.012
Dank Onkel Trahzebuck, ich selbst habe es übersehen, hier nun das (für mich) bisher erste CM10-ROM, welches CM9 das Wasser reichen kann, was Speed & Co angeht. Mit Nova-Launcher zumindest. Dazu noch einige AOKP-Features, passt.
Entwickler-Thread: [ROM][AOSP][4.1.1] ★★★ BlackCNA v2.1 ★★★ [AROMA][OTA][27-09-12] - xda-developers
Features:
- kaum noch Memory-Leak/Lag
- File-Manager
- Uhr inkl. Stopwatch & Timer
- Bluetooth: Avrcp v1.3
- Kernel: HydraCore Standard v4.3b
- Black Google-Apps
Mehr Infos & ROM-Features im Entwickler-Thread !!!
DOWNLOAD
BlackCNA-ROM v2.1: Dev-Host - BlackCNA_V2.1-signed.zip - The Ultimate Free File Hosting / File Sharing Service
GApps einfach über den AROMA-Installer auswählen !
Known Bugs
NavBar not working
CHANGELOG:
BlackCNA v2.1
updated with latest CM10 sources
added force tablet mode UI and dpi change (Settings -> Interface -> Gerneral UI)
added alternate signal layout (Settings -> Interface -> Status bar)
add alow mock sms to developer settings
increased themeability of the statusbar
added the advanced calulator features from cm
updated Gapps (hope google search is fixed)
BlackCNA v2.0 "AROMA birth"
Complete clean compiled build for n7000 !!!
no port anymore
added AROMA installer (to much you will see)
added OTA update in apps
updated AOSP base to 4.1.1_r6 (JRO03R)
seperated the ability to center the lock screen widgets and the lock screen targets widget
better performing wifi connection
wifi will no longer avoid poor connections if not connected to a mobile network
HTML 5 video user experience and stability fixes and network optimizations
better text rendering
enabled fdatasync for SQLite
added theme, smiley, emoji, strip unicode and date support for Mms Quick Message
added sms over bluetooth (i.e. ability to read sms via car stereo)
added feature to configure wifi idle timeout (Entropy512)
added the ability to have up to 5 customizable ring targets (Steve Spear)
lockscreen widgets can now be on the right, centered, or on the left (FaultException)
added timer snapshot support to the camera (Jonathan Steadman)
added burst mode to the camera (Jared Caliendo - up to 20 pictures at a time)
added jpeg quality settings to the camera (Jared Caliendo)
added settings for enabling and disabling WebGL in the browser
added AOKP lockscreen weather icons
added option for preloading media in the browser
better multilanguage support
moved ring targets feature into the navigation bar settings
re-organized all phone settings
power widget no longer shows data options if they arent supported
added landscape layout for the color picker
fixed weird black line about Mms text feild
fixed small down arrow when keyboard is up and phone is in landscape
fixed wi-max power widget toggle
fixed export-to-storage function in contacts
bluetooth audio streaming should be fixed across all music apps and hardware
fixed tethering issue that was occurring on some devices
reverted to previous CPU Settings while preserving the new voltage settings
automatic lock screen weather refresh will no longer cause freezes
and more i forget...
BlackCNA V1.2 "DarkNess"
Added new keyboard
Revised systemui
Added more Note 2 smoothness ;)
USB Mass Storage enabled thx neobuddy89
Bluetooth fixed (I hope so report back please)
Added new Dialer (S3 themed) thx tunsd
Added new BlackCNA Gapps (too much u will see) thx tunsd
Fixed Google Now
Added latest CM10 Camera
Revised framework
Added Apex Launcher
Some cosmetic changes
New wallpaper
and things i forget...
BlackCNA V1.1
Fixed Software Keyboard
Added SIM PIN feature in Settings
BlackCNA V1
Initial Release based on Codename Android 3.5.0
INSTALLATION:
Go to Recovery do a Wipe/Factory Reset (Necessary if you come from a different ROM, use a SAFE kernel)
Flash BlackCNA V1 ROM
Flash BlackCNA Gapps
Reboot your device
READY !
Credits:
M3dD0g
Firasusman
Imilka
MrDsl
Wesamothman
CrazyKiddo
Reaktionen: Bastizpunkt, gizmoau, murixxx und 6 andere
Muss ich direkt mal testen.
Was mich bis jetzt immer zurück zu Sammy roms gebracht hat War die Tatsache das der Akku Verbrauch unter jellybean bei mir unterste Schublade war.
Bin gespannt ob sich hier etwas geändert hat.
Reaktionen: trahzebuck
+1
Ich würde so gerne... aber komm im Moment einfach nicht dazu. Am WE werde ich es aber sicher mal ansehen... Derzeit ist Projekt ReVo angesagt...
Ja ja, Seb, lach nur... :D CM-Fan auf Sammy, Rom - ich weiß...
Naja bei mir ist es auch gleich.
Bin mit der small Rom vom project revo so zufrieden, aber wenn unser weezel mal sagt das es cm9 das Wasser reichen kann muss ich es einfach testen.
Das behaupte ich mal ganz frech ... ;) Der Onkel ist eben ein alter Touchwiz-Fan, hossaaaa !
Aber Akku saugt es bei mir in den ersten Stunden auch ordentlich, Sauerei !!!^^
und wie entferne ich die softkeys? So wie der Dev das beschreibt, funktioniert nicht!
Grüße von
mr.juziu
Es geht auf jeden Fall, habe sie weg, aber vergessen WIE ... ;)
hmmm, und wat nu? Hast Du eine Idee?
edit:
jetzt habe ich auch hinbekommen- die xda seite war doch sehr hilfreich. War aber anscheinend nicht der einzige, der die Instruktionen missverstanden hatte...
Grüße von
mr.juziu
Theoretisch, sollte es ja auch folgendermaßen gehen: in der build.prop am Ende die Zeile "qemu.hw.mainkeys=1" einfügen !?
Hossa? Ich geb' Dir gleich Hossa und mache eine Nichte aus Dir. :p
Im Ernst, Warum wird eigentlich Samsung immer mit TW gleichgesetzt? Klar ist bei Stock dabei. Aber seit LRQ, wenn Du den ganzen Samsung-Schrott massiv erleichterst und einen gescheiten Launcher (Nova) reinpackst, sind die Samsung-basierenden Roms echt gut geworden.
und auch m3dd0g hat nicht nicht gelernt, dass ein delete_recursive besser ist als ein format. Seufz....
Reaktionen: AA1973
Yupp. Kann ich bestätigen. LRQ rennt wie Schmidts Katze (wenn man die System Apps um knapp die Hälfte bereinigt). :D
Stock LRQ [slim line] > NoteCore 14.1
habe soeben die rom zum testen geflasht.
1. eindruck:
theme ist sehr sehr gut gemacht, etwas dunkler als standard jellybean. gefällt mir sehr gut.
ausserdem gibt es sehr sehr viele einstellungen, wie zb. dpi vom ganzen system usw.
werde es erstmal drauflassen und schauen, wie sich die rom im alltag macht
edit:
auch wenn ich die rom vorhin erst geflasht habe, fange ich die rom an zu lieben^^
nicht nur das es etwas dunkler ist...playstore und viele andere apps wurden auch schön gethemed...
buttons aufm screen sind auch sehr nützlich wenn man den stylus nutzt :)
edit2:
nachdem ich weiss, wie man die navigation buttons editiert und die höhe der leiste einstellen kann bin ich einfach nur begeistert von dieser rom :D
akku scheint schon relativ schnell leer zu gehen, wird aber bestimmt gefixt :)
Hello.
Ich bin noch immer am testen der Rom und bin echt schwehr begeistert.
Jedoch habe ich die softkeyes noch nicht weg bekommen.
Kann mir da einer helfen der es schon geschafft hat?
was meinst du genau? die navigationskeys auf dem touchscreen?
ich will die home taste bzw eher die zuruck und menu softkey buttons von note deaktiveren. geht das?
Seb ! du hast mich ja voll angelogen :sneaky: 4 Wochen hast du geschätzt bis eine nutzbare CM 10 Variante auf dem Markt kommt :flapper: !
Naja dann muss die Stock LRQ mal runter :D......
Edit: Rom läuft echt super ! Sehr schnell.....
Ich finde die DPI Einstellungen für das gesamte System nicht ! Wo sind die denn ?
Weis schon jemand wie ich die Softkeys wegbekomme ?
mfg
DPI Einstellung
Einstellung - Entwickleroption - 3 Option von oben - fertig
Habe jetzt die Asylum CM10 v3.0 drauf. Ist nicht schlechter, nur ohne "AOKP-Features".
Die CM10-Dailydriver sind endlich da ... ;)
@manupot
Systemeinstellungen-> Interface-> Ausschalten-> Navigation bar toogle Haken setzen. Lange den Powerknopf drücken, im Ausschaltmenü das linke untere Ausschalticon drücken dann sollte die bar weg sein.:D
Reaktionen: P4RTYH4RTY, Jrp Defy, manupot und eine weitere Person
unhold 31 schrieb:
@manupot
Mist,schneller gewesen :D
Hehe hab mich doch entschieden erst mal hier rein zu schauen!
Mich haut es gerade von den Socken was sich getan hat bzw. was soll noch schneller und direkter als meine Asylum v3 aokp werden!
Jetzt bin ich eines besseren belehrt worden, ist ja nicht normal wie genial die rom läuft !
Werde jetzt mal noch testen und auf mich anpassen, ich glaube ich komme hier so schnell nicht weg !
Grüße
Edit: Mit Nova Prime und Dpi auf 240, perfomence stock, seh ich schon gar nicht mehr was ich da gerade mache!! Sowas schnelles hatte ich noch nicht in der Hand!!
bauner
bauner
bauner
bauner
Talinsei
bauner
bauner
bauner
