[ROM][4.2.2][AOKP/CM/PA]Vanilla RootBox | Nightly 11/07/2013
  • 167 Antworten
AA1973
AA1973
Enthusiast
6.003
Ein Port der Rootbox Rom von bajee11, portiert für das Note von unserem chasmodo
picture.php
picture.php
picture.php
picture.php
This Rom is a brainchild of RD/RC bajee11, and all credits and donations should go to him only.​
Features
Built from RootBox Sources
AOKP Features
CM Profiles
Per App DPI
Per App Tablet UI
Per App Language
OTA Updates - Goo Manager
Navigation Bar Colour
Camera: Save to external memory
Phone: Advance Phone Settings (Vibrate on Answer, Every 45 Seconds, On Hangup and On Call Waiting)
Phone: Noise Suppression
MMS: Message rate alerts (Modify SMS message limit for alert)
MMS: Fully Customizable MMS Theme
MMS: Soft Keyboard Type (Emoji, Enter to Send, Enter for a New Line)
Home button call answer (Accessibility Option)
Variable size pattern lockscreen
RootBox Settings
Pie (Paranoid Android)
LCD Density Changer
Low Battery Warning (Pop-up & Sound, Pop-up only, Sound only, Off)
Option to control cursor in text fields using volume keys
Disable Fullscreen Keyboard (Landscape mode)
Expanded Desktop
Hold Back to Kill
CRT Animation (Screen On/Screen Off)
Lockscreen Shortcuts (Paranoid)
Lockscreen Targets (CM)
Screen Security Features (Unlock options: Quick Unlock, Delay Screen Lock, Menu Unlock, Home Unlock)
cLock (Chronus)
Option to disable sound when adjusting volume
Launch Music app on Headset connection
Hardware Keys Remapping
Lockscreen Hardware Keys Remapping
First Time Installation Steps
1. you must be running a safe kernel (emmc_cap_erase disabled)
2. drop into recovery
3. wipe everything, including your posterior (i.e. do a full-wife)
4. flash RootBox
5. flash 4.2.2 Gapps
6. reboob
How to upgrade RootBox versions:
1. Download RootBox update
2. Flash RootBox update
3. Flash 4.2.2 GAPPS (obligatory!)
4. Wipe Cache (Optional)
5. Wipe Dalvik Cache (Optional)
6. Reboot
Downloads:
Auf goo.im-Download links am Ende des Posts...
RootBox Sources
www.github.com/Root-Box
Kernel Sources
CyanogenMod Samsung SMDK4210
Bugs
PA option in Settings/Hybrid Settings: you have to tap ParanoidAndroid Settings at the top for the options to appear
Unfortunately, browsers FC for now, not only for n7000, but for other devices as well
CPU frequency sliders in Performance Settings don't work (known CM10.1 bug), but you can set them using Rom Toolbox, SetCPU or similar apps from PrayStore
Rootbox is currently being updated to being compiled using Google 4.7 toolchain, so there may be some other bugs, but please do keep
in mind that this is a work in progress, and things will only get better given time
Credits/Thanks To:
* AOKP
* Teamhacksung
* The CyanogenMod Project
* rovo89 - For his excellent work on Xposed Framework
* Paranoid Android
* DaXmax
* Rodries
* Pier
* BigDenn - Logo, bootanimation and wallpapers
ScreenShots
picture.php
picture.php
picture.php
picture.php
picture.php
Downloads:
Vanilla_RootBox_20130417_n7000.zip
Goo.im Downloads - Downloading Vanilla_RootBox_20130417_n7000.zip
MD5sum: 399f4dc7719f8d35f88607a12d3cde68
removed-apks.zip > Goo.im Downloads - Downloading removed-apks.zip
Removed apps:
Email
Exchange
Launcher2
Live Wallpapers
Live Wallpapers Picker
Sound Recorder
Video Editor
Voice Dialer
You have to extract those you need, paste or push them to /system/app,
fix permissions so they are the same as the other apps in the folder and reboot. It is NOT a flashable zip.
Bugs:
PA prefs (hybrid settings) nicht vollständig. Wird geändert.
Browser FC. Andere Browser funktionieren.
Reaktionen: starinator, MichelFell, Berlino und 8 andere
Gar nicht mal schlecht, mit Thor ... ;)
Reaktionen: Jrp Defy, AA1973 und CVH
Ich kann leider keine Screenshots sehen. Ist optisch gleich wie alle anderen cm Roms?
Würde sie gerne testen
Reaktionen: AA1973
Danke für den Hinweis. Mache ich heute abend mal besser.
Gestern abend hat es noch gut ausgesehen...
Bzgl Bugs und workarounds:
Browser FC > anderen Browser nehmen
Tablet UI führt zu permanenten FC der System UI > Phone UI anwählen
Wer bugs findet, kann sie behalten oder hier posten :p
Der Rom Cook (Bajee) ist zur Zeit in Examensphase und kann sich nur unregelmäßig um die Entwicklung kümmern. Das ist die Aussage auf g+ - in seiner github ist er aber doch sehr aktiv. Abwarten :)
Edith - noch einmal: jetzt gerade sehe ich die Screenshots in tapatalk. Keine Ahnung woran das liegt. Bin aber gerade unterwegs und nicht die Zeit den OP zu editieren und so.
In der Zwischenzeit hier noch die offizielle Homepage > http://rootbox.ca/
Der ursprüngliche Beitrag von 11:29 Uhr wurde um 13:00 Uhr ergänzt:
Um die Frage korrekt zu beantworten. Die Rom beinhaltet ROM Control von AOKP, die hauseigene Root box Settings und PA Preferences APP von AOSPA, sowie die PA Pie. Also ein paar mehr Optionen zum Rumspielen.
Reaktionen: CVH und manupot
Inwiefern unterscheidet sich diese Rom von der Jelly Beer oder Fredis Rom? Wenn man mal so fragen darf :D Weil an sich bin ich mit meiner Jelly Beer super zufrieden was Akku, App Einstellungen usw angeht und habe keinen Grund zu wechseln ^^ Jedoch juckt es mich so ein bisschen in den Fingern haha
Hat JellyBeer alle diese Features? Dann ist es das selbe.
Reaktionen: Sanj3k
#BROWSER FIX
Download des attachments
Extrahier' die libwebcore.so und kopiere sie in den Ordner system/lib
Die existierende lib-Datei wird dabei überschrieben
Permission auf 644 (rw- r-- r--) setzen
Reboot
Browser fixed! :)
Bitte um Rückmeldung ob erfolgreich oder nicht! Danke :D:thumbup:
  • libwebcore.so.zip
Reaktionen: Jrp Defy und CVH
Was ist den die removed apk. ZIP
Die restlichen Apps die nicht mit ins System integriert wurden.
Steht ja oben auch unter dem Link welche das sind
GNote
Reaktionen: AA1973 und Jrp Defy
Wen ich das update installiere sind dan die installierten apps weg
Welche Apps meinst du? Deine Apps aus dem Store -nein.
Du brauchst nur Rom + GApps flashen.
Wipe cache + wipe dalvik cache ist optional. Kann man machen, musst du aber nicht.
Update Vanilla Root Box :thumbup:
http://goo.im/devs/chasmodo/RootBox/Vanilla_RootBox_20130422_n7000.zip
MD5: 1572375e2ae44a8a31f8987aa0730365
Link: http://goo.im/devs/chasmodo/RootBox/Vanilla_RootBox_20130422_n7000.zip
Der ursprüngliche Beitrag von 13:31 Uhr wurde um 14:47 Uhr ergänzt:
New #AOKP #Ribbons in system settings > AOKP ROM control > Ribbon options
What are those ribbons
A lot of questions about the AOKP Ribbon feature I've been working on. It is a series of "Ribbons" full of you're favorite Apps, Shortcuts, and AOKP Actions. These Ribbons are all scrollable and can house as many targets as your heart desires. Ribbons have found their way into many of your frequently used areas I.E. Lockscreen, Notifications tray, and Quick settings. Your favorite AOKP options are all here, including long press and custom icon options. I've also created a feature rich Swipe Ribbon that gives you every option the AOKP team could think of, from background color and opacity to custom icons, app label options and more. The really nice part about using the SystemUI as the platform for this Swipe Ribbon opposed to a User app is reliability. No notification is needed to keep it alive. It is always available just like your NavBar or Status Bar. I don't want to say for sure when release will be but I think our first nightly will be very exciting and worth flashing...
By Steve Spear -
Ribbon: https://plus.google.com/u/0/107766449895730667621/posts/R6rGh4cGeSx
AOKP Swipe ribbon
Reaktionen: MichelFell, Berlino, Jrp Defy und 2 andere
PIE ist nun wie in AOSPA - über die rechte Hälfte swipen bringt die Notifications, die linke Hälfte die Quick panel settings
Browser FC ist behoben
Tablet UI scheint zu funktionieren
Reaktionen: Berlino, Jrp Defy und CVH
Geschmeidige rom :thumbup:
Tablet funktioniert jetzt.
Läuft mit dem neuesten nx erste Sahne!
Da kann man Stunden verbringen um rumzuspielen:)
Grüße, Julian
Reaktionen: Berlino und AA1973
Thor und NX? Keine Ahnung. Frag mal am Stammtisch. :D
Reaktionen: MichelFell und Jrp Defy
Quick Update:
1) Tablet UI FC fixed. Some minor overlapping left to fix.
2) Pie behaviour Fixed
3) Ribbon Bottom switch should be fixed as well.
4) Ribbon timeout and buttons reset will be fixed in next release - thanks to Steve
5) PA Colours - needs to be fixed*
6) App menu UI Flow - needs to be fixed (3 dots menu)
7) Notifications Shortcuts FC - needs to be fixed
8) Profiles toggles not getting refreshed - needs to be fixed
9)If no one noticed, I merged a new feature from CM - Power sounds. You'll find it in Settings>Sounds
10) Fix every other minor bugs
As you can see, I'm aware of most bugs but I just don't have the time for it. If you think you can fix a few things in my absence, don't hesitate to send me a pull request. I'll try my best to merge the pull request as fast as I can. For those submitting translations pull requests, I kind of got fed up since you guys were submitting patches that were breaking the builds. Before submitting a patch, make sure you built with it first. The current bugs in RB are very minor IMO but if you feel it's too much for you to handle, then I suggest you move on to something better. And the rest of you guys, enjoy the latest nightly.
SAUCE™ g+
Das ist das Update von Bajee auf g+. Sobald es eine neue Version gibt, wird sie hier gepostet. (Von wem auch immer :thumbup:;)
Update 23042013...:D
http://www.androidfilehost.com/?fid=22926241640219073
size 149.5MB
md5 cdc7757ad2b739313308d15a7d409993
Reaktionen: Jrp Defy, Berlino, CVH und eine weitere Person
Dieses Rom ist dem Gefühl nach, das schnellste, fluffigste das ich bisher auf menem Note hatte. Die Vielfalt der Einstellmöglichkeiten ist enorm und man braucht einige Zeit um alles zu durchschauen.Zwei "Bug´s" ??? sind aufgetreten : kopieren von einer Datei mit dem Rootexplorer - ich kann die Datei nicht markieren sondern Abfrage mit welchem Browser soll die Aktion durchgeführt werden - abgebrochen.
Neue Versuch: Rom Toolbox Dateimanager: beim ersten Versuch die Datei zu kopieren, macht das Note ein reboot. Beim zweiten Versuch klappt´s.
Goo.Manager sagt kein Update -Post 17 sagt neues Update !!
Reaktionen: AA1973, Berlino und Jrp Defy
Also mit dem solid Explorer und der rom, kein Problem.
Jo läuft echt sehr schön.
Reaktionen: Berlino, AA1973 und Tataf
Total Commander läuft auch rund. Mehrere Dateien kopiert, ohne Probleme.
Reaktionen: Jrp Defy, Tataf und Berlino
