AA1973
Enthusiast
- 6.003
Aktuell kannst du nur den Stock CM (bzw den integrierten slim bean kernel) oder Thor Kernel nutzen.
Fenerholiker schrieb:Hey,
Welchen Kernel nutzt ihr?
AA1973 schrieb:Was machst'n du für Sachen? Habe die unter 100 MB so nicht hinbekommen. Hast du noch extra die memleak APP oder alte r2d2 Treiber geflasht?![]()
So it's time for a new build. As some of you probably have noticed we included this time, some truly unique features.
Especially The Real Dark Slim is now directly integrated into the ROM. Read more on it here ->The Real Dark Slim<-.
Please download and reflash the GAPPS or AIO in order to make it work correctly!
Apps that TRDS includes
System framework/settings
Calculator
Contacts
DashClock
Gallery2
LatinIME
Mms
Phone
*However we also included many other new things such as*SlimSizer which allows you to further slim down your ROM. Please be careful with it because you're deleting system apps which might be important to run the phone. If you don't know what an app does better don't delete it.
Changes & Features
TheRealDarkSlim Toggle (Initial)
Shiny new SlimSizer
Renamed SlimOTA to SlimCenter
SlimFilemanager: Added root functionality
Extended QuickSettings style options (tiles per row, press/bg color, etc)
New Notification/Lockscreen Shortcut icons
