[ROM]*2.9.7*HYBRID_TMT_MIUI_3.0 INTERNATIONAL Codename "THE ONLY ONE" 09/16/12
  • 43 Antworten
bangsti
Gast
TMT MIUI 3.0 ist online
https://docs.google.com/file/d/0BzRB...U3T21XOWs/edit
Changelog gibts noch nicht, aber hier mal ein erfahrungsbericht von Mohan herle
TMT_MIUI_3.0_UPDATE_1.zip
This is almost a perfect ROM....maxicet..Thanks a TON
All the followers of this thread waited for quite some time till Maxicet returned yesterday with the announcement of arrival of TMT MIUI V3....But the wait is well worth...
On the outset I cannot thank enough for this wonderful ROM. An overview about this current ROM:
The size of the ROM is around 682 MB with good justification considering applications and tools included. Download is quite fast from google docs.
  1. Installation was very smooth (full wipe for better results).
  2. Incoming/outgoing call,SMS etc works fine.
  3. GPS fixing is fast and accurate.
  4. No partial/full Root issues.
  5. Camera (Front/Back/Video recording) works fine.
  6. Bluetooth performance is good (not checked A2DP)
  7. Access to Internal/External SD card within the phone and PC is hassle free.
  8. WiFi, EDGE works fine.
  9. FM Radio is good.
  10. Call recording feature of MIUI is functioning.
  11. Changing of themes (full and mix) is smooth.
The following applications are pre-installed and works fine.
Swype Key board
  • Polaris Office
  • S planner
  • S Memo
  • CPU spy
and many more......
For those devices with Yellow triangle at boot up related to custom ROM/flash counter, Triangle away V1.95 application from Chainfire is included which removes the triangle and resets the flash counter quickly (before using this application read the corresponding warnings by Chaifire).
To sum it up this is a very smooth and fast ROM which will allow you to have some of the features you liked in stock ROM (S pen related) and MIUI and with a safe kernel unlike earlier versions. Yes...Now default kernel of this ROM is HydraCore_v2b which is a known safe kernel.
Reaktionen: dmh, Cpt. Future, frank e. und eine weitere Person
Reaktionen: dmh und manupot
Also da könnte ich meiner flashpause mal ne Pause gönnen :D
Werd sie mir am abend mal anschauen.
Reaktionen: bergheil
Habe die Rom auf dem Note meiner Frau oben und sie ist super zufrieden damit.
Noch nicht ganz so schnell wie die 4.0.4 Custom Rom´s nach meinen empfinden aber von der Optik der Hammer zumindest ist meine beste Hälfte super zufrieden damit.
Reaktionen: datt-bo und manupot
Die Optik hat mich ja schon bei meinem sgs1 und sgs2 angesprochen.
Mit dem richtigen launcher wird die Rom bestimmt auch flutschen.
Ich hab mir mal den tsf Shell launcher gegönnt und der läuft bei jeder Rom aber sowas von smooth das es eine Freude ist.
Deswegen muss ich mir heute abend die Rom mal flashen.
Kannst du zum Akku Verbrauch auch etwas positives berichten?
Lg
Akkuverbrauch ist laut Gabi super und soweit ich von Maxicet mitbekommen habe arbeitet g.lewarne ( NoteCore) an einen Kernel für die Rom da momentan nur der mitgelieferte Kernel geht.
Sollte beim nächsten Update dabei sein aber wie immer alle Angaben ohne Gewähr.
Toller Server, nach 240 MB und 1 Stunde abgebrochen:thumbdown:
Na ja, später nochmal versuchen.
Habe es über google runtergeladen. Stimmt der Server ist etwas überlastet.
Das könnte heute durchaus eine lange flashnacht werden.
Der download tröpfelt mit 52kb grrr.
Komisch ich lade bei google mit 1 Mbit runter.
Google Startet bei mir erst garnicht!
koisch komisch
Ja spinnt bei mir auch öfters und der neue Server von Maxicet dürfte schon in die Knie gegangen sein.
Ich hab ja noch Chracks v8 oben!
einfach mit redpill Abyss kernel und Full wipe drüber?
Ja habe es so gemacht ohne Probleme.
Für alle die einen uploaded.to account haben hier mein Mirror
Reaktionen: typischAndy und manupot
Sodale! trotz voller Hütte hab ichnun die TMT MIUI geflasht!
gefällt mir sehr gut das was ich bis jetzt probiert habe!
(2) COMING FROM GB (WITH ANY KERNELS) AND ICS (WITH "5.6" CF KERNELS ONLY) :
1. Download THE ROM /Uploaded.to Mirror / Mirror1 (md5 is b2507b0eeaaa450fa543f989f6f62434)
2. Reboot in recovery, wipe data and cache and flash the rom
Hallo verstehe ich es richtig das ich "wipe data" mit dem 5.6 CF Kernel machen soll?
Das löst doch den Brick aus oder nicht?
Edit: habe die V8 von Chrack drauf mit dem 5.6 CF rooted Kernel
Ich kam von der selben rom wie du.
Ich hab mir zuerst den abyss 4.2 redpill geflasht.
Zurück ins recovery gebootet ( das findest du im recovery unter advancet)
Dann im redtouch recovery einen full wipe gemacht und dann die tmt geflasht.
Funktionierte wunderbar.
Nur habe ich zurzeit ein deepsleep problem.
Ich werde mal alles noch einmal von vorne starten.
Vuelleicht war ja irgendeine app schuld.
Obwohl mir betterbattery stats nichts dergleichen angezeigt hat.
Reaktionen: Mace89
Ja so hätte ich es auch gemacht aber es steht nicht dabei das man erst den Abyss flashen soll.
Meine Frage war ja ob es den Brick auslöst.
Ich bin der Meinung das man dadurch den Brick auslöst.
Danke trotzdem für deine Antwort:)
Ich gehe jedenfalls auf nummer sicher.
Das habe ich bei den cm9 roms auch schon so gemacht auch wenn diese kernel dort brick sicher sein sollen.
Kann mir kein totes note leisten.
Edit.
Ich bekomme es einfach nicht in den deepsleep.
Full wipe hat auch nichts gebracht.
Wenn es so weiter geht werd ich wohl wieder zurück zur chracks v8 gehen müssen,
Edit2.
Themen habe ich auch noch kein anderes zum laufen gebracht.
Weder mit dem theme app was dabei War noch die verlinkten Themen auf xda.
Ich fmglaub ich bin zu blöd für diese ROM
Reaktionen: Mace89
