[ROM][*19.03.12*] MIUI Livewings Edition B4-CFG10 - FASTEST MIUI ROM EVA!
  • 24 Antworten
DjSonix
DjSonix
Stamm-User
720
MIUI Livewings EditionB4-CFG10
Anyone who links my ROM to another forum, linkback to this thread.
IT IS COMPULSORY.
Features
- Based on imilka V5 fused with ICS Stunner B2.
- HD playback on Black-Themed YouTube via 3G/WiFi
- Removed that annoying mouse cursor when using S-Pen
- Added ASUS SuperNote app for your S-Pen!
- MIUI Launcher removed
- Apex Launcher & Nova Launcher included.
- New Google Boot Animation!
- Phone UI Default @ 320DPI
- Using MIUI.us 2.3.16 Galaxy Nexus + Galaxy S II + Nexus S
- Default Wallpaper = MIUI Colourful Wallpaper.
- Smoooooooooooooooooooooooooooooth!
- MX Video Player included as default video player.
- Hardware Acceleration Fixed!
- MIUI Music removed due to poor rendition on the Note.
- Play Music added as default Music Player.
- Play Store, Play Books added.
- Removed duplicating ICS apps.
- MIUI Gallery removed. Available as a package below.
- Native NFC function removed since WE NO NFC.
- New lockscreen!
- Camera can now be taken up to 8MP!
- Themes work without creating /data/system/theme.
- Support for Semi-Tablet Mode with Dual Pane Settings @240DPI
- External SD is now mounted through /sdcard/external_sd
It's the most stable MIUI build out there.
Things that don't work.
- USB File Transfer (AOSP bug)
- Flash Video (Kernel Bug)
- Video Recording (AOSP bug)
- MHL doesn't work (Kernel Bug)
Steps to install MIUI Livewings Edition.
Step 1: Install CF-REPACK on Odin Desktop or Odin Mobile.FULL FLASH NEEDED NOT JUST THE KERNEL!
DON'T BOOT INTO THAT LEAK ROM! You will immediately will reach to the recovery after flashing the leak.
THOSE COMING FROM GB OR ICS I9220/N7000 LEAK YOU WIPE BEFORE FLASH MY MIUI-BASE. if not you will have billions of force-closes.
Step 2: Install MIUI-BASE-CFG1 (available below!) Boot MIUI-BASE-CFG1 first!
Step 3: Reboot into Recovery again, then install my ROM!
Step 4: ENJOY!
I AM NOT RESPONSBILE IF YOUR PHONE GOES TO DEEP SHIT. IT IS AT YOUR OWN RISK.
ENGLISH. NO MULTILANGUAGE UNTIL MIUI RELEASES ONE.
Synonym understanding:
B4 -> Beta 3
CFG10 -> Configuration 8
After every new zip I compiled, a new CFG version will be born.
So it's easier for me to track down bugs.
I will slow down my Update Cycle from now on.
Unless there are very serious bugs that needed to be solved right away.
Expect B4-CFGX in the coming days.
Upgrade Chart Eligibility:
Any Gingerbread ROM -> MIUI Livewings Edition 2.3.16 B4 | Start from Step 1 * ** ***
ICS Leak I9220 Chinese -> MIUI Livewings Edition 2.3.16 B4 | Start from Step 2 *
ICS Leak N7000 -> MIUI Livewings Edition 2.3.16 B4 | Start from Step 1 * **
MIUI V6 to V9 -> MIUI Livewings Edition 2.3.16 B4 | Start from Step 3 *
MIUI Livewings Edition B1/B2/B3 -> MIUI Livewings Edition 2.3.16 B4 | Start from Step 3
Any AOSP/AOKP ICS Rom -> MIUI Livewings Edition 2.3.16 B4 | Start from Step 2 *
* You will definitely get force-closes. To solve that, please go to Settings - Apps, and clear data, clear cache and force close that specific app that is screwing you over.
** Use TriangleAway to get rid of Yellow Triangles!
*** WIPE DATA IS COMPULSORY, or you see many errors that ain't my fault. YOU WIPE BEFORE YOU FLASH MY MIUI-BASE! YES?
If you have any headphone issues, wipe cache from Recovery.
MyUI Designer Revolution R1
- Focus on first impression out-of-the-box experience
- Pure MIUI Experience
- MyUI Designer Evolution Theme
- MyUI Designer Evolution Boot Animation
- Based on ICS Stunner with Call Fix.
- MIUI Keyboard based on ICS
- 3-Way Reboot Option
- Multilanguage (If MIUI releases it)
- NATIVE MIUI LAUNCHER
- Bugfixes
I will test thoroughly than during B1/B2/B3 to ensure minimal problems.
Stay-tuned for closed beta. PM me to signup.
Reaktionen: manupot
MIUI Livewings B4-CFG10
Changelog from B3-CFG8
- Lockscreen Issue Fixed
- New Standard Lockscreen Wallpaper
- WiFi Direct fixed
Those coming from CFG8.2 need not flash this ROM.
Fresh users, use this ROM.
You can still get MIUI Home Launcher from various sources but it's not advisable to use yet until I give the green light.
Download Link:
Part 1
Part 2
Almost bug-freeeeeeeeeeeeeeee!
MIUI Livewings B3-CFG8
Changelog from B3-CFG5
- Calling Issues Fixed.
- New Lockscreen.
- Settings now have a width gap just like ICS.
Download Link:
http://www.mediafire.com/?z8ii8lh1h7l997s
http://www.mediafire.com/?61pcr2xt1s7rhd5
Mirrors:
https://www.wuala.com/abangerl/Galax...y=9nzFt89pIrkz
Both parts are split into two as Mediafire has a 200MB restriction.
Make sure you extract the .7z so you get a .zip file
.zip file is to be placed in your SD card.
Patches for B3 to B4
Semi-Tablet Mode:
Flash this after my ROM if you want Tablet Mode.
YES YOU CAN CALL IN SEMI-TABLET MODE.
@240DPI with Dual Pane.
Note: WiFi Direct will cease to function if you use this patch for B4.
http://www.mediafire.com/download.php?97tw5zdkdbaet51
MIUI Gallery: Testing in progress. Not to be done until further notice.
S-Pen Mouse Cursor Fix: http://www.mediafire.com/?7iuqrunrk7oo8cc
MIUI-BASE-CFG1 features:
- Barebone ROM that only has bare essentials
- File Explorer & AirDroid available in case you forget to put ROM.
- No GAPPS. Removed on purpose.
- Small size. 124MB.
- This ROM allows booting into MIUI Livewings Edition B3-CFG8/B4-CFG10
MIUI-BASE-CFG1: http://www.mediafire.com/?n3xx5phtoo63q5s
http://www.mediafire.com/?qk9kk44564jl61g
Und noch einer;)
Man bist du schnell.
Sobald es einen Download gibt werde ich es ebenfalls online stellen.
Reaktionen: DjSonix
Jetzt warst du schneller :p
Pozdrav
Croatia1
Ihr zwei habt es wirklich drauf.
Haha und was wird jetzt aus meinen Thread?
Den lassen wir noch ein bisschen offen, weil noch nicht alle gewechselt sind, und dann wird er geschlossen.
Reaktionen: DjSonix
Ihr seit ja der Wahnsinn.
Kaum hat man seine Traum Rom gefunden kommt wieder was neues!
Ich werde aber mit dieser etwas warten da mich der miui style nicht so richtig anspricht!
Lg manuel
Gesendet von meinem GT-N7000 mit Tapatalk
Da wart ich noch, bis es auch deutsch ist.
Neue Beta 3 ist Online
Leider noch immer nur auf Englisch aber super stabil wie ich finde.
Download wie immer unter: www.galaxyload.at
Oder Direktlink zu Wuala
Semi-Tablet Mode:
Download
Reaktionen: manupot
Jetzt geht es Schlag auf Schlag
Neue Version soeben Online gegangen.
B3-CFG8
- New Lockscreen.
Download über Wuala
Neuer Fix für die CFG8
MIUI Livewings Edition B3-CFG8.1 Minor Lockscreen Update
Wuala Download
Übrigens wird meine Seite www.galaxyload.at auch offiziell von Livewings untersützt.
Hat es schon wer drauf?
Pozdrav
Croatia1
Hatte es heute oben und hat einen sehr guten Eindruck gemacht.
Habe heute aber wieder mal die neue Chrack Small Rom geflasht.
Warte bis es eine deutsche Version kommt.
Habe heute etwas mit dem Dev gesprochen und ich kann jetzt schon sagen das es noch viele Neuerungen gibt.
Neues Update.zip zum flashen
MIUI Livewings Edition B3-CFG8.2
Changelog
- MIUI Home Launcher with support for 5X5 Grid
- Added A.I Keyboard Free for users with Keyboard Problems.
- New Lockscreen from 2.3.16 removed.
- Added 2.3.9 Lockscreen.
- New native 800x1280 default lockscreen wallpaper.
Download Wuala
Neue Version Online leider noch immer nur auf Englisch.
- WiFi Direct fixed
Download Wuala
Reaktionen: manupot
Jetzt fällt es schon sehr schwer sich zu entscheiden!
Jeden Tag kommt jetzt etwas neues.
Vorerst bleib ich mal bei der aokp! :D
Lg Manuel
Habe die Miui schon probiert und sie läuft erste Sahne ist aber leider nur auf englisch.
Bin vorerst zurück auf Chrack´s neue V16 da ich dieser Rom lange treu war.
Noch was in eigener Sache.
Dieser Post hat zwar nicht wirklich was mit der Rom zu tun aber ich hoffe es ist Recht das ich auch hier frage.
Wie ihr bereits mitbekommen habt bin ich gerade beim Aufbau einer zentralen Downloadseite.
Die Seite ist sehr gut besucht und hat zu 99% positve Zustimmung bekommen.
Ich möchte jetzt das Angebot erweitern und bin auf der Sucher nach einen Helfer da es doch viel Zeit in Anspruch nimmt.
Folgende Unsterstützung würde ich benötigen.
Upload der neusten Rom´s auf meinen Webspace.
Eventuell Mithilfe bei der Homepageaktualisierung.
Ich bin mir bewusst das es viel verlangt ist und man nicht reich wird damit aber wer mit Herzblut an Android bzw an diesen Thema hängt wird es gerne machen.
Wer Lust hat schickt mir eine PM.
Noch etwas habe zwei negative Bewertungen bekommen und es wäre nicht schlecht wenn mir die jenigen auch sagen könnten was ihnen nicht gefällt oder sie besser machen würden.
Ich mache die Arbeit freiwillig und opfere meine Zeit dafür und nicht damit ich reich werde.
Danke fürs lesen.
An Alle
Sorry Leute, ich werde aber erst am Wochenende dazu kommen diesen Thread wie gehabt auf deutsch zu übersetzten. Bis dahin bleibt der OP in English, für fragen stehe ich euch wie gehabt zur verfügung.
Danke fürs zuhören
Euer DjSonix:p
bauner
bauner
bauner
bauner
Talinsei
bauner
bauner
bauner
