cheezusweezel
Enthusiast
- 5.012
Entwickler-Thread: http://forum.xda-developers.com/showthread.php?t=2071669
CHANGELOG:
- Rootbox Source / AOKP Source synced upto 14th May
- Comes with Stunner-Kernel. It is AOKP-only kernel built from NX-Kernel source. No NXTweaks app support. It's like basic kernel but with lot of fixes and user options for governors, schedulers and more.
Features:
AOKP Features
CM Profiles
Paranoid Android's Hybrid Settings ** NEW **
New-Super-Awesome-Bootanimation by Color_Hunta
NX-Kernel - Latest Linux Build LINARO Kernel
GCC 4.6 ROM build.
Elegant Vanilla Black Theme (You can switch back to stock from Theme Chooser)
Per-app DPI/Language/Tablet UI
Dual Panel switch for any DPI
Customizable SPen Gestures
Switchable to Traditional Toggle Style
New Toggles
UI Mode to enable Tablet NavBar
Navigation Bar Color
Multi User capability (Feature from Nexus 7)
Lockscreen vibration option
Phone: Advance Phone Settings (Vibrate on Answer, Every 45 Seconds, On Hangup and On Call Waiting)
Phone: Noise Suppression
Camera: Enable selection to storage on internal or external SD.
MMS: Message rate alerts (Modify SMS message limit for alert)
MMS: Fully Customizable MMS Theme
MMS: Soft Keyboard Type (Emoji, Enter to Send, Enter for a New Line)
Option to control cursor in text fields using volume keys
Home button call answer (Accessibility Option)
Variable size pattern lockscreen
Build.prop and init.d tweaks
and many more....
Stunner Settings:
PIE Control: More awesome than ever!!
Expanded Desktop
Step by step LCD Density changer
CRT on/off animations
Lockscreen Shortcuts
Lockscreen Targets
Losckscreen See Through
Notification Shortcuts and Behavior
LockClock (Chronus)
Hardware Keys Remapping
Swap Volume Buttons in landscape
Volume Key Cursor Control
Low battery popu & sound settings
Lockscreen Hardware Keys Remapping
Screen Security Features (Unlock options)
Launch Music on HeadSet plug-in
Breathing Notifications
Power Widgets
and many more.....
DOWNLOAD: http://www.mediafire.com/?0ve4w2ncd943umy
Installation:
!!! Bitte IMMER dieser Anleitung folgen, außer man weiß es selbst besser !!!
1. ROM & GApps auf die interne oder externe SD kopieren
2. In CWM-R booten und ein Nandroid-Backup erstellen
3. Den Thor ICS Kernel installieren, Reboot to Recovery
4. Im Thor Touch-Recovery (Bedienung über die Onscreen-Tasten)
- Wipe DATA/CACHE/DALVIK (Dalvik findet sich unter dem Menüpunkt ADVANCED)
- Format SYSTEM/DATA/PRELOAD (die Optionen befinden sich unter dem Menüpunkt MOUNTS&STORAGE)
5.
- Flash ROM
- Flash Gapps
- Reboot
Donation Links:
NeoBuddy89
NGiordano
Team Kang
Credits:
Imilka for first AOSP and inspiration.
Team Passion
Team Kang and Romanbb
Cyanogenmod9
All involved in fixing issues for NOTE.
R3b0rn for ICS True Root Method.
