[ROM][11.10.2013]Helly_Bean [JB 4.3] [(almost) nightly builds] - N7000 |
  • 264 Antworten
AA1973
AA1973
Enthusiast
6.003
ROM: Helly_Bean [4.3] basierend auf CM10.2 - aktuellste Version: 11.10.2013
Developer: Der Teufel1980
Original-Thread auf xda:
xda-developers - View Single Post - [ROM] Helly_Bean [4.2.2] [(almost) nightly builds] - N7000
Many thanks, to all the other people who commit to gerrit. without these, this rom wouldn't be possible
you can find the official website for this projekt here
Helly Bean
IRC channel:
freenode Web IRC (qwebirc)
Additional changes, compared to cm10.1 (this list might not be complete):
- facebook sync integrated
- option to enable high end gfx effects
- possibility to activate and customize navigation bar
- aokp clock (right/center, custom color, big/small am/pm, display weekday)
- misc settings in settings menu
- added possibility to change the colors of the statusbar toggles
- added option to enable/disable coloring of toggles
- added option to display a small bar below the toggles as indicator for toggle state
- alternate default app picker (from aokp)
- notification panel transparency
- statusbar transparency
- removed cm stats
- removed cm updater
Install instructions:
- wipe data/factory reset
- flash Rom zip
Helly Bean 4.3 for Note1 n7000 » Helly Bean | Android Hellybean Rom
- flash gapps
NEU für 4.3 Goo.im Downloads - Downloading gapps-jb-20130813-signed.zip
ALT für 4.2.2 (Goo.im Downloads - Downloading gapps-jb-20121212-signed.zip)
many thanks to:
- cyanogenmod team for their rom sources
- stratosk (from who's initramfs i could start build my first jb booting kernel)
- team nyx who always have good tips for me, if i get problems with my kernel
- SysTem-X for hosting
- Rootax for hosting
- RolluS for hosting
- if i have forgotten you, please pn me (DerTeufel1980)
Viel Spaß!
Reaktionen: ixi, Malzbier, trahzebuck und 8 andere
Werd ich mal antesten. Hatte die Werke vom Teufel in Form von Helly Bean als auch als Kernel schon auf meinem i9000. Und das Ding lief damit wie "Der Teufel"
Reaktionen: Berlino, MichelFell und AA1973
Den Kernel kenne ich nicht aus persönlicher Erfahrung, aber gehört habe ich davon. Es wird aber aller Voraussicht nach keinen "devil kernel" geben, da er kein Note besitzt.
Reaktionen: MichelFell
Hat es schon jemand in der Mache?
Müsste ja mit dem Thor laufen, oder?
Gruss michel
Ja. Läuft seit 15 Stunden, runde Sache.:)
Ja, auch das geht. ;)
Reaktionen: Berlino und MichelFell
Kann sie vom Speed her mit Asylum mit halten, oder ist sie gar schneller?
Asylum vs Helly_Bean: Kann ich so genau nicht sagen, da ich seit mehr als 2 Wochen mit AOSPA unterwegs war. Ich finde sie sehr gelungen und schnell.
Und... man kann selbst entscheiden, ob man dual panel settings haben möchte, ohne pitch-patch :p nur ein click...;)
Ok, danke Dir.:thumbup:
Reaktionen: AA1973
@AA
Hast du den flashable CrossBreeder mit oben oder Seeder+Zepp? Mit der flashable soll es ja eigenartige Veränderungs-Abfragen für die Recovery geben...ist ja auch nervig. Und wenn es eh keinen grossen Unterschied zwischen Breeder und Zepp/Seeder gibt, ist letzteres doch die bessere Wahl!?
Bin noch auf Asylum mit Breeder konstante Entropy von 4096 - auf meinem alten Defy mit CM10 und Zepp+Seeder ebenfalls konstante Entropy von 4096.
Wie sieht das mit dem Lockscreen aus? Ist dort ein eigenes Sperrhintergrund-Bild möglich? Lockscreen im Portrait-Mode?
Reaktionen: AA1973
Kannst ein seperates Bild einsetzen Berlino. Kein Thema. Hab den CrossBreeder installiert jedoch kam bei mir bis jetzt keine komische Abfrage.
Reaktionen: AA1973, MichelFell und Berlino
Berlino schrieb:
@AA
Ja. Habe Cross-breeder erst mal deinstalliert. Die Kombi Zepp/Seeder wird jetzt auch gleich aktualisiert, Seeder läuft, Zepp gleich.
CVH schrieb:
@CVH: Zu der komischen Abfrage, kommt vielleicht daher.
Was meint ihr?
idcrisis schrieb:
The original tries two methods to auto start CrossBreeder, /etc/install-recovery.sh and /system/bin/debuggerd, and these separate zips contain one each. In case one method causes any issues, one can try the other.
Of course the original first with both methods is the preferred.
Sent from my Transformer TF101G using xda app-developers app
Mal schauen, was dabei raus kommt...
Edith sagt, die Katze lässt das Mausen nicht...:D
Das heutige update bringt 2 Moglichkeiten:
CrossBreeder_2.7.13_insrec.zip > da ist u.a das folgende enthalten > system/etc/install-recovery.sh > deswegen habe ich es nicht genommen!
CrossBreeder_2.7.13_debuggerd.zip > diese habe ich genommen und auch keine nervige Abfrage erhalten.
Reaktionen: Gelegenheitsrentner, Berlino und CVH
Habe den CrossBreeder manuell eingefügt-heute mal geflashed. Hab die zip zum deinstallieren auch noch drauf, könnte man mal ausprobieren und das Ding runterschmeissen und den Seeder wieder rauf. Momentan bin ich was das angeht skeptisch geworden wenn ich so lese was passiert ist. Der CrossBreeder scheint doch nicht unbedingt die allersicherste Variante zu sein. Keine Ahnung.
Reaktionen: AA1973 und Berlino
@CVH welche Version hast du denn?
AA, du bist auf Zack..hatte vorhin geschaut - da gab es noch keine Updates! :thumbup:
Scheinbar ist also die debuggered.zip vorzuziehen.
Reaktionen: MichelFell und AA1973
Instant notification ;) aka Zufallstreffer
Reaktionen: CVH und Berlino
Bei mir läuft die 2.7.13
Hab da grad noch was Passendes zum Thema gefunden
Notes:
0. If you're having issues with the installation, it doesn't stick or SOD, then two other versions of the installation: CrossBreeder_2.7.13_debuggerd.zip and CrossBreeder_2.7.13_insrec.zip are attached for your perusal. Do remember to run the attached CrossBreeder_Uninstall.zip before each installation.
Zu finden ist das Alles hier. Es sind heut zwei Dateien dazugekommen
http://forum.xda-developers.com/showpost.php?p=37062006&postcount=1
Reaktionen: MichelFell, Berlino und AA1973
Danke @CVH :thumbup:> genau die beiden meinte ich auch weiter oben. :)
Reaktionen: CVH
Hab die Zip heute Mittag mal gezogen gehabt und erst jetzt wieder dort nachgeschaut. Jetzt weiß ich auch was du erst gemeint hast mit "welche Version". Bin ziemlich durch den Wind und nicht auf der Höhe heut. Mich überrollt grad ne Grippe und die versaut mir irgendwie die Lust zu Allem. Wenn man schon keine Lust mehr zum flashen hat ist´s weit. Naja ich bleib jetzt erstmal auf der Helly bis es mir halbwegs besser geht. Nicht das ich in meinem Wahn noch nen CM10.1 Kernel auf ne TW ICS und GAPPS hinterherflashe.:D
Reaktionen: Gelegenheitsrentner und AA1973
Dann gönn Dir doch erst mal etwas Ruhe.;)
Gruss michel
Reaktionen: Gelegenheitsrentner, AA1973 und CVH
Ich glaube heute sind wir alle ein bisschen Bluna ;)
Gute Besserung bzw Erholung :thumbup:
Reaktionen: Gelegenheitsrentner, MichelFell, CVH und eine weitere Person
bauner
bauner
bauner
bauner
Talinsei
bauner
bauner
bauner
